POV-Ray : Newsgroups : povray.off-topic : Speedy thing goes in... Server Time
1 Nov 2026 10:13:29 EST (-0500)
  Speedy thing goes in... (Message 1 to 38 of 38)
Subject: Speedy thing goes in...
Date: 3 Jun 2011 16:30:40
Message: <4de94470$1@news.povray.org>
Okay, figure this out:
Since Update 10, Oracle's Java SE 6.0 comes with a tool called "Java
Quick Starter" (JQS). Its purpose? To speed up starting Java software,
by loading the most commonly used stuff ahead of time.
And loading ahead of time it does.
It does this not only once though, but - for whatever sake - every
bloody hour. Over and over again. The same bloody files. Which on my
system (maybe due to a sinister conspiration with the Anti-Virus
software I use) takes about 1 or 2 /minutes/ each time. Oh, and did I
mention that all this time it starves every other piece of software
running from hard disk I/O?
Heck, maybe it /does/ speed up startup of Java software, but seriously:
*I DON'T GIVE A BLOODY DAMN!*
Did I mention that the official procedure how to turn off this bullshit
mysteriously doesn't work on my machine? >_<
(Fortunately I stayed resolute and resourceful in an atmosphere of utter
pessimism...)
Subject: Re: Speedy thing goes in...
Date: 3 Jun 2011 17:40:50
Message: <4de954e2$1@news.povray.org>
and I bet it's documentation sux too ;-)
> pessimism...)
lol then ... I admire your half full glass (rather than empty) outlook
on things!
Date: 3 Jun 2011 18:40:55
Message: <4de962f7$1@news.povray.org>
Am 03.06.2011 23:40, schrieb Jim Holsenback:
Documentation?? *What* documentation??
>> pessimism...)
> on things!
Yeah; those 1-2 minutes an hour have been pestering me for months now,
until today I finally managed to identify the culprit... and nail it down.
*WIN!*
Date: 4 Jun 2011 02:31:36
Message: <4de9d148@news.povray.org>
> pessimism...)
  Someone has been playing too much... :P
Date: 5 Jun 2011 07:24:59
Message: <4deb678b$1@news.povray.org>
I'm pretty sure JQS has been there for years. Lots of software does this
(e.g., Acrobat Reader). The idea, presumably, is to load stuff into
memory ahead of time.
Except that isn't this the entire point of the Windows prefetch cache?
Also, won't the unused data simply get swapped back out to disk after a
while? (Thus utterly defeating the entire purpose of it.) Unless you
lock the pages in memory - in which case you're taking resources away
from applications that *definitely* need to run in order to benefit an
application which *might* need to run at some unspecified future point.
Personally, I dislike quick-starter services. They're a waste of resources.
OK, that's pretty screwed up. It shouldn't take anywhere near that long.
(Unless your AV product is decompressing all the JAR files to check
there's no viruses inside them...)
It's news to me that there's even an official procedure to turn it off...
> pessimism...)
Outstanding! You <subject name here> must be the pride of <subject
hometown here>.
http://blog.orphi.me.uk/
Date: 5 Jun 2011 07:25:25
Message: <4deb67a5$1@news.povray.org>
On 04/06/2011 07:31 AM, Warp wrote:
>> pessimism...)
What is this "too much" concept of which you speak? ;-)
Date: 5 Jun 2011 08:13:02
Message: <4deb72ce$1@news.povray.org>
http://www.thinkgeek.com/homeoffice/mugs/c7cc/action/215f43a/?cpg=160SS
Date: 5 Jun 2011 17:29:39
Message: <4debf543$1@news.povray.org>
I don't know how long, but I think that it was there with Java SE 5.x.
OR you reload the stuff periodicaly to reinitiate the countdown...
I share your opinion on those. I hunt them down, and kill them, as much
as I can.
1 - It reloads the files to prevent them been pushed on the page file.
2 - The AV is to agressive. Scanned files should be remembered, and,
unless they have been changed, skipped on the next scan.
3 - Yes, the AV need to uncompress and extract files from any archive if
it wants to scan it's content. JARs are compressed archives.
>> pessimism...)
> hometown here>.
If it's impossible to turn JQS off, then you kill the process, then you
delete JQS.exe.
Date: 5 Jun 2011 17:38:14
Message: <4debf746@news.povray.org>
>> resources.
> as I can.
If it works as intended, it's making one application faster by making
every other application in the system slower. How selfish is that?
Don't you just love the way most AV product insist on down periodic
manual scans?
1. If a file is never opened, it doesn't *matter* how's inside it. It
can't possibly run.
2. If a file is opened, the on-demand scanner will scan it anyway.
There's no need to do a manual scan as well.
3. I've yet to see any AV product which "remembers" which files it's
scanned and stops rescanning them unless they changed. (Presumably
because that would make it too easy for a virus to slip past; just tweak
the file timestamp...)
For that matter, I've yet to see an AV product that's any good at
*removing* malware. Most of them will *detect* an infection, but they do
an utterly crap job of *removing* it.
A Jar file is just a Zip file. (Actually, a surprising number of files
are just orginary Zip files...) But yes, if it's loading a lot of Jar
files, that would explain it. I don't know what JQS is loading. Maybe
just [uncompressed] executable files, IDK.
> delete JQS.exe.
That's probably not an especially good idea; the product repair routine
will probably restore it for you.
Actually, I just checked my system. JQS is a normal Windows service.
Just configure it to not run at startup. Done.
Date: 5 Jun 2011 17:54:33
Message: <4debfb19$1@news.povray.org>
>>> resources.
>> as I can.
> manual scans?
> can't possibly run.
Avast does it. It have a local database of files scanned and found sane.
They are excluded from autoscans for a set, and configurable, duration.
They are NOT excluded from scheduled and manual scans.
>> delete JQS.exe.
Date: 5 Jun 2011 18:06:43
Message: <4debfdf3$1@news.povray.org>
Am 05.06.2011 23:38, schrieb Orchid XP v8:
X-actly.
Official procedure though is to go to the control panel, "Java" settings
dialog, "Advanced" tab, "Miscellaneous", deselect "Java Quick Starter",
and restart the system.
While this seems to be intended simply as an alternative way to both end
the process and set the service's start mode to disabled, on my system
it plainly doesn't. Checkbox toggles, but that's all it does. Next time
firing up the "Java" control panel, checkbox is back again.
Date: 6 Jun 2011 04:28:50
Message: <4dec8fc2@news.povray.org>
I had something similar with MSN Messenger yesterday. I opened up the
settings pane and unchecked "run at startup". Reboot, and it still runs
at startup. Unselected the checkbox again, and this time it appears to
have taken effect. GO FIGURE.
I prefer the old days of the Amiga, where software almost always did
what it was supposed to. (Or else failed to work completely.) None of
this "sometimes it works, sometimes it doesn't" nonsense. (Or "if works
if you press the buttons in this order, but no other order".)
This kind of thing seems to be endemic to Windows (and now Linux). For
example, when I was setting up our old file server, I discovered that
the only way to make the tape drive work was some long, complex routine
(which I eventually wrote down) where you uninstall and reinstall the
hardware drivers multiple times, rebooting in between, in just the exact
right sequence, and then it works perfectly. If you don't do this, the
device just refuses to function. WTF?
Date: 6 Jun 2011 05:46:17
Message: <4deca1e9$1@news.povray.org>
http://en.wikipedia.org/wiki/Quick_start
http://en.wikipedia.org/wiki/Prefetcher
In the process, I also came across this:
http://msdn.microsoft.com/en-us/windows/hardware/gg463004.aspx
Date: 6 Jun 2011 11:10:01
Message: <web.4deced642b550a083771cd8e0@news.povray.org>
I had something similarly strange happen:
My PC would wake up at night for no apparent reason. Each and every night.
I'm running it as a PVR and it usually goes to hibernate after recordings and
wakes itself for a new one. So it should have been off in the morning.
I finally foud out that it was a leftover from Windows Mediacenter, which I had
installed for the purpose of checking something with my new satelite tuner card.
It seems that uninstalling Mediacenter does not remove the daily EPGupdater task
which is set to wake the computer at 3:30am.
And since my PC doesn't have a timeout to go back into hibernation and the
EPGupdater was no longer available, it would just stay on. I suppose the EPG
updater would normally put the PC to sleep after it finishes.
Regards
Aydan
Date: 6 Jun 2011 12:44:37
Message: <4ded03f5$1@news.povray.org>
On 6/5/2011 14:38, Orchid XP v8 wrote:
> Don't you just love the way most AV product insist on down periodic manual
> scans?
Security in depth. Try Microsoft Security Essentials. It's really good.
> 1. If a file is never opened, it doesn't *matter* how's inside it. It can't
> possibly run.
But you still might propagate it to someone else, even if you don't run it.
> 2. If a file is opened, the on-demand scanner will scan it anyway. There's
"I have an idea! Let's make the system seem more responsive by doing a scan
of a file the very instant the person starts waiting for it to run! That'll
have the double-good effect of loading every single page of the executable
into RAM, bypassing that pesky demand-paging stuff."
> 3. I've yet to see any AV product which "remembers" which files it's scanned
Microsoft security essentials.
> (Presumably because that
> would make it too easy for a virus to slip past; just tweak the file
> timestamp...)
Don't use the timestamp. Use the USN journal. That's what it's for. Indeed,
you can just do a lazy background scan of anything that might be an
executable after whoever is writing to it finishes writing to it.
> For that matter, I've yet to see an AV product that's any good at *removing*
> malware. Most of them will *detect* an infection, but they do an utterly
It depends on the malware. It's hard to "remove" an infection that has
replaced valid code with virus code.
   "Coding without comments is like
    driving without turn signals."
Date: 6 Jun 2011 12:45:58
Message: <4ded0446$1@news.povray.org>
On 6/6/2011 1:28, Invisible wrote:
> I prefer the old days of the Amiga, where software almost always did what it
> was supposed to.
That particular one sounds like a permissions problem to me. :-)
Date: 6 Jun 2011 13:29:10
Message: <4ded0e66@news.povray.org>
>> manual scans?
> Security in depth.
Seems to me more like "useless busy-work to reassure the customer that
we really are doing something".
I notice that Symantec AntiVirus Corporate Edition doesn't do scheduled
scans at all by default. (Unless you explicitly ask it to.) Neither did
Trend Micro, until our IT department turned it on. (Why?)
It has "Microsoft" in the name. Why would it be good?
>> can't possibly run.
That's a valid argument for a file server. But even in that case, you
(or somebody else) still has to *access* the file.
While we're on the subject, almost all AV product claim to be able to
detect "virus-like behaviour" even if they don't have signatures for it.
But I've yet to see this actually work in practise...
> scan of a file the very instant the person starts waiting for it to run!
> That'll have the double-good effect of loading every single page of the
> executable into RAM, bypassing that pesky demand-paging stuff."
It's an optimisation in that it only scans files which could actually
harm the system, without wasting time scanning files which are never
used. On the other hand, it also scans them at the worst possible time...
>> timestamp...)
And how many 3rd parties know this exists? (Also, it only works for
NTFS. Which should be a non-issue, because *nobody* should be using FAT
by now...)
> Indeed, you can just do a lazy background scan of anything that might be
> an executable after whoever is writing to it finishes writing to it.
You might argue that you could also do lazy on-access scans by logging
who's accessing stuff, and then checking after. Still, difficult to
block access to a file after it's been accessed...
>> *removing*
For example, when my laptop was infected by MS Blaster, McAfee correctly
detected the virus file on disk, but was utterly unable to delete it. It
kept complaining about "access denied", because the virus was still
running. When *I* manually killed it in Task Manager and then deleted
the file myself, it worked just fine. Now why the **** couldn't McAfee
have done that for itself? Isn't that what we paid exorbitant sums of
money for? So that people who aren't the IT System Administrator can
clean malware off their systems?
Date: 6 Jun 2011 13:55:22
Message: <4ded148a$1@news.povray.org>
On 6/6/2011 10:29, Orchid XP v8 wrote:
> Seems to me more like "useless busy-work to reassure the customer that we
Or maybe "check that you haven't installed something while the scanner was
turned off"?
See above.
Because it's written by the same people whose OS you're trying to protect is?
> That's a valid argument for a file server. But even in that case, you (or
But the other person might not have a virus scanner.
> While we're on the subject, almost all AV product claim to be able to detect
> "virus-like behaviour" even if they don't have signatures for it. But I've
I have.
> It's an optimisation in that it only scans files which could actually harm
> the system, without wasting time scanning files which are never used. On the
Right. That's why using the USN journal is such a good idea.
> And how many 3rd parties know this exists? (Also, it only works for NTFS.
> Which should be a non-issue, because *nobody* should be using FAT by now...)
If you don't have the USN turned on, fall back to on-demand scanning. Lots
of third parties know it exists. It's well documented and has been around
for years. Heck, *I* know it exists and I don't even try to write
non-portable Windows code.
Too many people try to do cool stuff and just skip all the tools that
Windows gives you to make it work well. Not knowing the USN journal exists
when you're writing file scanning software for Windows is like not knowing
the Apple UI guidelines exist when trying to write interactive code.
> You might argue that you could also do lazy on-access scans by logging who's
> accessing stuff, and then checking after. Still, difficult to block access
Right. But this way, you're scanning the executable as soon as it gets
potentially-infected, not when the person is waiting for it to run. You get
notified as soon as you visit the web page that gives you the virus, not a
week later after you have no idea why the program you only use once a week
is suddenly different.
> Now why the **** couldn't McAfee have done that for itself?
Dunno. Privilege problems?
Date: 6 Jun 2011 14:22:56
Message: <4ded1b00@news.povray.org>
> was turned off"?
...which the on-demand scanner is *still* going to detect...
> protect is?
Heheh. These are the people who thought "hey, let's make it so that
every home user has full admin rights by default". Yes, I'm sure they
know a thing or two about security. ;-)
If the file is on a file server, then each time you try to access it,
the AV product on the server will perform an on-demand scan.
Now /that/ I can agree with.
What, this scenario didn't show up in testing? "We want to clean a virus
that's currently running" seems like more or less test #2 or #3 in any
sane test suite...
Date: 6 Jun 2011 14:52:43
Message: <4ded21fb$1@news.povray.org>
Am 06.06.2011 20:22, schrieb Orchid XP v8:
>> protect is?
Um...
Wrong perspective. Development was actually from CP/M's "access control?
just lock the f*** room door" concept to there.
Oh, and didn't they go for "hey, let's make it so that every home user
does /not/ have full admin rights by default" when they introduced
Vista? Might be wrong here, but didn't both software and users kinda go
amok back then?
Date: 6 Jun 2011 15:03:00
Message: <4ded2464@news.povray.org>
> Um...
Yes. And it has taken them a spectacularly long time to figure out that
this model is ineffective today.
(Apparently this is the company that thought that networks were just a
"fad" that would go away after a while...)
> Vista?
Yes.
They didn't do it in Windows 2000, they didn't do it in Windows XP, only
in Windows Vista did they *finally* get it right.
Granted, backwards compatibility didn't help them at all. But I'm pretty
sure there are better solutions than what they actually came up with.
The company's goals seem to be to promote a /sense/ of security rather
than actually /being/ secure.
Date: 6 Jun 2011 15:41:17
Message: <4ded2d5d$1@news.povray.org>
Am 06.06.2011 21:02, schrieb Orchid XP v8:
>> Um...
Not really. It has been around in NT since when? Ever since the first
version, I guess.
If that's what they had thought, they surely wouldn't have attempted to
roll their own network.
But they possibly didn't expect a single network to win over all the others.
I think none of the network operators did back then. And definitely they
didn't expect a (then) /non-commercial/ network to make the race.
>> Vista?
> Yes.
Yes. I guess customers would go rampant if they gave them a somewhat
secure system - because people would (a) complain that they have to
invest time in security housekeeping (you can't just "buy" security), or
(b) complain that the system still isn't /totally/ secure (ignoring the
fact that such a thing as a totally secure system exists only beyond the
event horizon of a black hole).
Typical end users want to just "buy" their security (or, better yet, get
it for free), and not invest any of their own time into it. So Microsoft
serves this market segment with the best security you can buy for money
alone: The mere illusion of it.
Date: 6 Jun 2011 15:43:19
Message: <4ded2dd7$1@news.povray.org>
Am 06.06.2011 10:28, schrieb Invisible:
Increase in system complexity, anyone?
Date: 6 Jun 2011 16:02:36
Message: <4ded325c$1@news.povray.org>
Again, the on-demand scanner is the worst possible way, efficiency-wise, to
detect such things.  Where "efficient" means "minimal impact to actual
users." It should be a last resort, not a primary mechanism.
>> protect is?
> Heheh. These are the people who thought "hey, let's make it so that every
> home user has full admin rights by default". Yes, I'm sure they know a thing
I'm sure they do. And I'm sure every programmer in Microsoft *wanted* to not
make that the default. That business cases mean you lessen security doesn't
mean the security team doesn't know how to do security.
> If the file is on a file server, then each time you try to access it, the AV
Sorry? What file server?  I'm pretty sure Linux doesn't have a virus scanner
that will detect Windows viruses, for example.
> that's currently running" seems like more or less test #2 or #3 in any sane
> test suite...
As I said, "dunno."
Date: 6 Jun 2011 16:04:59
Message: <4ded32eb$1@news.povray.org>
I still remember being amused at the Burroughs mainframe we were looking at
buying back then. We asked about multi-user features, and they said "code a
password request into your programs."  We asked something else along those
lines, and they said "that's why each terminal has a keyhole."
> Oh, and didn't they go for "hey, let's make it so that every home user does
> /not/ have full admin rights by default" when they introduced Vista? Might
> be wrong here, but didn't both software and users kinda go amok back then?
Exactly. It wasn't that they didn't understand what needed to be done, but
that different demands were made. The president would be safer if he never
appeared in public, also.
Date: 6 Jun 2011 16:11:46
Message: <4ded3482$1@news.povray.org>
On 6/6/2011 12:02, Orchid XP v8 wrote:
> Yes. And it has taken them a spectacularly long time to figure out that this
Not really. They figured if you had a system where it was single-user,
adding access control wouldn't help unless you were smart enough to not get
infected to start with. If you had a system that was multi-user, you
probably already know how to create accounts that aren't super-user.
> (Apparently this is the company that thought that networks were just a "fad"
Microsoft had networking before TCP/IP was popular enough to need DNS.
> They didn't do it in Windows 2000, they didn't do it in Windows XP, only in
If you had multiple users, you could create privileged users or
non-privileged users. If you had a multi-user networked machine, chances are
you were running AD or some such and didn't have an admin account.
Remember that when you're talking about security, the result is to break
things. Security in this sense means "preventing things from working as
programmed." Hence, you can't increase security effectively without breaking
backward compatibility. It's a careful balancing act you have to do.
Date: 6 Jun 2011 18:20:09
Message: <4ded5299$1@news.povray.org>
Am 06.06.2011 22:02, schrieb Darren New:
> scanner that will detect Windows viruses, for example.
It very bloody likely does.
Date: 6 Jun 2011 18:30:19
Message: <4ded54fb$1@news.povray.org>
> to detect such things. Where "efficient" means "minimal impact to actual
You need an on-demand scanner though, lest a program opens a file that
wasn't there when you last had a chance to check it.
Plug in a USB stick full of data, and open something from it right away:
In that scenario, on-demand is the /only/ efficient mechanism. You don't
want to tell the user, "sorry pal, that file you're trying to open
happens not to have been scanned yet - and there's still 4236 other
files scheduled to be scanned before it."
Likewise, you don't want to clog up the system for minutes just because
someone inserted a USB stick he only reads one file from.
So in the sense of "total computing & I/O time spent for virus
scanning", on-demand may be the worst - but "felt" system speed is not
measured in such ways.
Also note that even if a file has been scanned and hasn't changed, the
virus database may have; so if you don't want to dig through all files
on the system every time the virus database changes, on-demand scanning
provides an advantage there as well. (Ideally of course in that case the
file would only be checked against virus signatures that were installed
after the file was last checked.)
Date: 6 Jun 2011 19:34:04
Message: <4ded63ec@news.povray.org>
Or you have a USN journal. :-)
But yes, if you want to be sure, an on-demand scanner is necessary. It's
just not a good idea to have it as the first and/or only option.
> So in the sense of "total computing & I/O time spent for virus scanning",
> on-demand may be the worst - but "felt" system speed is not measured in such
> ways.
Yep. In those specific scenarios, where you suddenly add a bunch of files to
the file system *without* them passing through RAM as you do so, on-demand
works well.
> Also note that even if a file has been scanned and hasn't changed, the virus
> database may have;
Also a good point. As I said, on-demand should be the last resort, not the
first. Background-scanning while the screen saver is on of all executables
when the database changes or when they're written is far more efficient than
actually blocking a person's access while you scan an entire file. Managing
to do the scan as part of the VM paging would be even better, but that I
imagine would be hard to do.
Date: 7 Jun 2011 04:04:45
Message: <4deddb9d$1@news.povray.org>
I content that it was more a philosophical thing. Like, if you tried to
use something and it didn't quite work right, you threw it away and used
something else that /did/ work perfectly 100% of the time. If your
computer randomly malfunctioned from time to time, you would damned well
go find out /why/. Because, you know, this kind of thing /isn't normal/.
Today the populous has somehow been convinced that it /is/ perfectly
normal and /acceptable/ for computers to not work right. Given such an
attitude, what incentive is there for software writers to bother fixing
their stuff?
Date: 7 Jun 2011 04:12:57
Message: <4deddd89$1@news.povray.org>
> version, I guess.
It still puzzles me that NT was designed as "business only". It's a
pity, really. It was quite a good OS...
That being the case, Windows Vista is still the first OS aimed at the
casual user base which actually has half-decent security.
Yes, perhaps that's the real problem here...
(I would say "so why don't they make a business version with *real*
security?" And then I realise that most PHBs /also/ think that
"security" is a product that you can just buy.)
Date: 7 Jun 2011 04:15:51
Message: <4dedde37$1@news.povray.org>
> breaking backward compatibility. It's a careful balancing act you have
> to do.
...which completely explains how Vista and 7 managed to be more secure
while not breaking everything in sight.
Oh, wait. No it doesn't.
It also doesn't explain why Windows couldn't have done this 10 years ago.
Date: 7 Jun 2011 04:23:40
Message: <4dede00c$1@news.povray.org>
You have a point. Scanning a file after each time it's modified would
seem the best approach, but I'm not aware of any product that does this yet.
>> thing
> not make that the default. That business cases mean you lessen security
> doesn't mean the security team doesn't know how to do security.
OK, how about this:
This is the company that produced a web server where you can completely
defeat all access controls and fetch files you don't have permission to
fetch just by using backslashes in the URL rather than forward slashes.
This works because:
1. The server neglects to check for invalid characters in the URL (such
as backslashes).
2. The server uses a list to determine file access rather than
properties of the files themselves (e.g., FS-level file security).
3. The server blacklists files that you can't access rather than
whitelists files that you can access, causing it to fail-open rather
than fail-closed.
4. Because the restricted URLs have forward slashes and the user typed
an equivalent path with backslashes, a textual match routine returns no
matches, and the URL is allowed. (This also means that any /other/ way
to generate a semantically equivalent but textually distinct URL would
/also/ bypass all security.)
Yes, /clearly/ MS knows how to design systems that are fundamentally secure.
>>>> you (or
>> the AV
If the file exists on another PC and that PC has an on-demand virus
scanner, than whatever way you access that file, it's going to trigger
that PC to perform an on-demand scan. So I'm not seeing how a file on a
PC with an AV product can pose a threat to other systems.
Date: 7 Jun 2011 09:29:12
Message: <4dee27a8$1@news.povray.org>
On 6/7/2011 1:12, Invisible wrote:
> That being the case, Windows Vista is still the first OS aimed at the casual
XP had half-decent security. Pretty much the same security as Vista, except
that Vista runs admin programs in a different screen space to avoid shatter
attacks. You're still logged in as an administrator by default. If you mean
the UAC, most people don't pay any attention to whether that makes sense to
be popping up or not.
> security?"
They do. You just have to actually use the one you have.  XP had real
security. About as good as UNIX (and better in some ways) as long as you
didn't log in as administrator by default. No amount of technical security
is going to force people to use it.
Date: 7 Jun 2011 09:30:56
Message: <4dee2810$1@news.povray.org>
On 6/7/2011 1:15, Invisible wrote:
> ...which completely explains how Vista and 7 managed to be more secure while
In what way are they more secure?  Remember everyone bitching that they had
to buy all new hardware like new scanners and printers and stuff for Vista?
Why do you think that happened?
How many Win3 programs broke when you tried to run them under Win2000?
(Answer: Lots and lots.)
See above. By now, nobody really complains when a Win3 or Win98 program breaks.
Date: 7 Jun 2011 09:32:43
Message: <4dee287b$1@news.povray.org>
> except that Vista runs admin programs in a different screen space to
> avoid shatter attacks. You're still logged in as an administrator by
> default.
Really? I thought they finally changed that in Vista.
Date: 7 Jun 2011 09:35:01
Message: <4dee2905@news.povray.org>
On 6/7/2011 1:23, Invisible wrote:
> You have a point. Scanning a file after each time it's modified would seem
Yes you are. You just ad hominem'ed them out of your memory.
> So I'm not seeing how a file on a PC with an AV
I write a program that writes out an executable file that has a virus in it.
(Like, say, the copy command.) I write that file to a USB stick, and I give
it to you.
Or, as has actually happened in the past, you install a program off a
commercial CD that has been created on a machine that is infected, and which
therefore includes a virus.
Date: 7 Jun 2011 10:37:58
Message: <4dee37c6$1@news.povray.org>
Really. The first account you create is an administrator account. (I may be
misremembering, but I'm pretty sure that's the case, since you have to frob
with privileged things in order to log in as administrator without being in
safe mode.)
