Unix has a concept of "current working directory". Windows has an
identical concept. But did you know that Windows keeps a working
directory FOR EVERY DRIVE?
C:\> CD Foo
C:\Foo> D:
D:\> CD Bar
D:\Bar> E:
E:\> C:
C:\Foo> D:
D:\Bar> E:
E:\> DIR C:
--lists everything in C:\Bar--
E:\> DIR C:\
--lists everything in C:\--
How random is that?
Am 01.06.2011 12:51, schrieb Invisible:
Yes.
> Yes.
And thus C:\ and C: are two different paths. Except that sometimes they
point to the same place...
Am 01.06.2011 13:18, schrieb Invisible:
>> Yes.
Yes.
It's one of those relics from the time when MS-DOS started out as a CP/M
clone with a few added features. CP/M did have the concept of drives but
didn't have directories, so one working directory per drive would give
you the opportunity to have programs ported from CP/M stick to drives
only, and yet prevent them from spamming the main directories of each
drive they'd work on.
So back then it was probably a good idea.
Oh... my God! o_O
> Oh... my God! o_O
OSes are like cities: built on top of the ruins of older ones...
(Don't remember who said it, I think it was a PC Week columnist who was
writing about solving a "NO ROM BASIC" error after installing Linux on
her machine)
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
>> Oh... my God! o_O
This seems to be the main think that's broken about both Windows and
Linux. Too many decades of backwards compatibility.
Am 01.06.2011 15:52, schrieb Invisible:
>>> Oh... my God! o_O
Coincidentally that's exactly what made them successful in the first
place (as opposed to e.g. BeOS). You know, avoiding the hen-and-egg
problem of OS vs. applications.
Hm... which makes me think: Has there ever been any attempts yet to
implement a stand-alone JVM as an OS?
> Oh... my God! o_O
That's gonna be my answer to everything: "Well, it seemed like a good
idea at the time."
~Mike
On Wed, 01 Jun 2011 11:51:21 +0100, Invisible wrote:
> How random is that?
Not very, it makes sense that they'd maintain the state of each drive
letter in memory. That's why on older DOS machines you had the LASTDRIVE
directive in CONFIG.SYS.
Jim
> C:\> CD Foo
> C:\Foo> D:
> D:\> CD Bar
> D:\Bar> E:
> E:\> C:
> C:\Foo> D:
> D:\Bar> E:
> E:\> DIR C:
> E:\> DIR C:\
> How random is that?
Let see from way back when I was using DOS 3... Well before knowing
anything about Windows.
Yes, I could do exactly that.
Well, I doubt they added it for Windows. The command prompt is pretty
much a deprecated way of doing things. It's only supported for backwards
compatibility. So yes, I had presumed this carried over from MS-DOS
(although I couldn't say what version).
http://blog.orphi.me.uk/
The same could be said of the ancient x86 platform, which still supports
running obsolete versions of MS-DOS if you want to.
Isn't that kind of the original *point* of Java?
Am 02.06.2011 09:56, schrieb Invisible:
Egg-sactly.
Not sure; the way it is /implemented/, the JVM seems to always be an
intermediate layer on top of some host OS. It might have gained enough
momentum by now though that a dedicated Java OS might be successful.
http://en.wikipedia.org/wiki/JavaOS
(Note the "see also" section as well.)
Am 02.06.2011 12:37, schrieb Invisible:
Hm... latest news from any of those projects date from January 2009...
so no, not enough momentum as it seems.
At some point, a couple of guys implemented an OS in Haskell.
And once they'd done it, they said "well, that was fun!", and the
project vanished into history.
I suspect that an OS is subject to some *serious* network effects. It's
an interesting toy project to write an OS in language XYZ, but once
you've done it, what are you going to use it for?
(I guess this leads us back to the dead-end OSes with decades of
backwards compatibility kludges...)
Am 02.06.2011 14:17, schrieb Invisible:
Ah - yes...
I think a much more important thing than "what [language] is it written
/in/" is the question "what is it written /for/". In case of a Haskell
OS I don't know what that would be, but in case of a Java OS it seems
plain as hell: Run JVM bytecode. Applications are plenty for that.
Yep.
For instance, the virtual memory management of an OS dedicated to
running JVM bytecode could easily provide built-in support for garbage
collection.
Le 2011-06-01 16:32, Orchid XP v8 a écrit :
> The command prompt is pretty much a deprecated way of doing things.
Depends on what you do.
As far as Microsoft is concerned, the command prompt is deprecated. You
should at least be using PowerShell. Ideally, you should write your
scripts in VB (or better, VB.Net), or build a custom COM module, or
whatever. The command prompt is for backwards compatibility with MS-DOS
(which is beyond obsolete).
Not that anybody really listens to what MS wants, mind you...
Now you're talking.
Has anybody written anything more substantial than Tic-Tac-Toe applets
in Java yet?
(In the case of the Haskell OS, the design goal seems to have been
"let's demonstrate how using Haskell leads to far fewer bugs and hence
much greater reliability". Once they proved that this was so, they got
bored and did something else. Personally, the idea of a more reliable OS
is something that sounds pretty appealing to me!)
> collection.
Well now, let's examine that for a moment.
Every OS I know is based around a series of assumptions. In particular,
that a "program" is just a monolithic block of machine code, and that
the only "services" that it needs from the OS is resource allocation,
protection, and control over the hardware.
Given how many kinds of programming languages these days use garbage
collection strategies, an OS with that wired into the kernel sounds like
quite a promising idea...
...until you realise that changing the design of the GC is likely to
break all your applications. Unless they're written in a sufficiently
high-level language that they can't "see" this level of detail.
So yes, the Java VM, or something like it, seems like a rather promising
idea...
That makes you start to think what /other/ kinds of services you might
want the OS to provide. For example, this whole "a command is a file
name, and its arguments are strings passed uninterpretted to the
program" thing. Surely we can do better.
Am 02.06.2011 16:38, schrieb Invisible:
> Now you're talking.
> in Java yet?
Java Enterprise applications, anyone?
OpenOffice?
Eclipse?
Minecraft?
Just four examples of non-trivial software from four different domains
(business software, office software, software development, and gaming)
that pop to my mind instantaneously.
Like, say, passing messages to the program after it has been started?
I don't see much of a point in an elaborate interface to feed parameters
at the very moment of startup; after all, the program can't evaluate
them anyway until it has at least "started up a bit", so pushing the
same information into a message queue seems to be pretty equivalent to me.
Unless, of course, we'd go all the way of allowing programms to pass
around full-fledged Java objects to children, parents, or any other
program they happen to have a handle object for.
Of course, to go for cloud computing, passing around objects should be
transparent, via marshalling and stuff - and in the end we'd probably
end up re-inventing the Java Enterprise architecture...
>> in Java yet?
> OpenOffice?
> Eclipse?
> Minecraft?
As best as I can tell, OpenOffice is not "written in Java", it's written
in C++ and it merely /uses/ Java for a few auxiliary functions.
Eclipse, on the other hand, appears to actually be Java. (I can't say
I've ever tried to use it.)
And I don't give a stuff what the hell Minecraft is written in. :-P
If the command shell knows stuff about the syntax that commands expect,
it can do helpful stuff for you before the command even runs. (E.g., if
the third parameter is a number, don't do filename auto-complete on it.)
There are lots of commands that have "sub-commands"; the shell could
list them for you. And so on.
Well, yes. When your OS is written in the same language as your
development language, you can do random stuff like that.
Exhibit A: Smalltalk.
Those two statements contradict each other. PowerShell is a command
prompt, is it not?
Thank goodness for that. :)
Jim
> prompt, is it not?
PowerShell is a replacement for the old MS-DOS command prompt emulator.
Well... ;-)
>>> You should at least be using PowerShell.
>> prompt, is it not?
So that would be "yes" then. :)
> Well... ;-)
MS is in it for the money and for their self-interest. That's what
drives the organization. (That's certainly true of most for-profit
businesses)
Jim
Am 02.06.2011 22:37, schrieb Jim Henderson:
> prompt, is it not?
Note the tiny difference between "/a/ command prompt" and "/the/ command
prompt" :-P
And no, neither is a "command prompt" in the literal sense; I guess a
proper term might be "command shell" ;-)
>> prompt, is it not?
> prompt" :-P
Details, details. ;)
Jim
>>> prompt, is it not?
The old MS-DOS emulator is deprecated. CLI interfaces in general are
not, no.
> businesses)
Corporations vary by their level of indifference towards their
customers' interests.
Am 03.06.2011 09:45, schrieb Invisible:
>> businesses)
No. Corporations vary by how much they expect to benefit/lose from
satisfied/unhappy customers.
There have been corporations who have a mentality that making their
customers happy is literally the most important thing in the world. More
important than making a profit, even. Now, whether anybody who thinks
like this stays in business for more than five minutes is somewhat open
to debate. But clearly some businesses do operate like this.
At the other end of the spectrum, we find companies who would quite
happily provoke global thermonuclear warfare if they thought it would be
profitable.
> profitable.
"Our earning forecast for the next quarter is for a double-digit growth,
however, the outlook for the longer term is a little less optimistic. We
will need to study the market and adapt our strategy to focus on growth
sectors."
>> profitable.
> sectors."
lolrus
Yeah, well, big business is somewhat noted for short-sighted decisions...
Am 03.06.2011 11:08, schrieb Invisible:
But why do they do it? Because they think it benefits /them/ to have a
corporate image of acting morally.
Small companies led by their owners in person (or even large companies
led by their owners in person, though those are quite rare) are a
different story. But corporations led by a board & traded on stock
exchange markets? Show me a single one that acts morally for the pure
sake of it.
>> profitable.
> sectors."
It's the new nomadic way of life: hunt, rape, burn and move further.
The opposite way (as in Cain vs Abel) could sound:
"Our installed based is stable and we foresee no interesting events for
the next quarter. We are studying a long term evolution to provide more
facilities and ease the life of everyone."
>>>> prompt, is it not?
>>> emulator.
> not, no.
But that's what you seemed to be saying.
>> businesses)
Some corporations are happy to *tell* the customer what the customer's
interest is.
Jim
On 6/1/2011 3:51, Invisible wrote:
> How random is that?
It's not at all random. It's also the reason you can unmount a drive where
your cwd is set in Windows and not in UNIX.
Remember that DOS 1 was based on CP/M, and thus didn't have directories at
all. When directories were added, the idea was that for each drive letter,
you set the directory you wanted, then started up the program which would
not refer to directories at all, but only to DOS 1 a la CP/M drive letters.
How come every time you come across legacy support, you say it's a kludge or
a wtf or a random? :-)
"Coding without comments is like
driving without turn signals."
Sort of. The idea was to insulate you from whatever was underneath, so you
could write UI applications and such (the sorts of things you'd see on a
smart TV or DVR or whatever) without worrying about porting them to other
machines.
On 6/2/2011 7:38, Invisible wrote:
> Every OS I know is based around a series of assumptions. In particular, that
> a "program" is just a monolithic block of machine code, and that the only
> "services" that it needs from the OS is resource allocation, protection, and
You should read about Singularity, wherein this is exactly the problem being
addressed. "Why do all the OSes do this? Because that's what an OS was
needed for in the 1970's, the early days of timeshare. Let's see what an OS
needs to do today...."
> ...until you realise that changing the design of the GC is likely to break
> all your applications. Unless they're written in a sufficiently high-level
Yep. That's exactly what Singularity does. Except the "high-level language"
is basically MSIL, and the GC engine is compiled into each program, so
different programs can use different GC engines.
> That makes you start to think what /other/ kinds of services you might want
> the OS to provide. For example, this whole "a command is a file name, and
> its arguments are strings passed uninterpretted to the program" thing.
If you really want to see, look at some of the new OS research. Read the
Singularity design documents, for example. There's some really cool stuff in
there when you get an OS that can rely on your programs actually declaring
in their manifest what resources they need and the OS can rely on the
programs actually obeying the semantics of the OS. (E.g., you get stuff like
bits of the kernel being compiled into the executable code for efficiency,
stuff like page faults being handled in user space, etc.)
> the OS to provide.
Or, alternately, look at Eros or Ameoba. Both are pretty easy to understand,
both are very very unlike the usual timeshare OSes.
Version 2.0 introduced directories, as well as the path-like calls (i.e.,
where you pass the file name as a UNIXy string rather than a FCB).
Version 3.22 was the first that actually looked at the control information
in the boot sector to decide how many sectors were on the floppy and such.
> prompt, is it not?
It's a command line interpreter. You'll confuse the crap out of everyone if
you call it a "command prompt", since the old command interpreter is called
"command".
It would be like calling a .pov file a "batch file" of SDL commands.
Am 06.06.2011 18:17, schrieb Darren New:
> stuff in there when you get an OS that can rely on your programs
> actually declaring in their manifest what resources they need and the OS
> can rely on the programs actually obeying the semantics of the OS.
> (E.g., you get stuff like bits of the kernel being compiled into the
> executable code for efficiency, stuff like page faults being handled in
> user space, etc.)
/Relying/ on the programs /obeying/ anything particular?
From what you write, it sounds like the inventors of that OS have never
heard the term "malware" in their whole life.
Yes, because the executable MSIL code is checked for correctness by code
that has, in turn, been proven to be correct. Just as one example. Or
because the kernel code is mathematically proven to be correct.
Of course, if you corrupt the hardware like in the Sony example, that's
something rather beyond what I'd call "malware".
It's Microsoft. I'm pretty sure they've heard of malware. Indeed, the whole
point of designing it like they did is, for one thing, to keep malware from
running. I'm pretty sure, for example, that there's no formal mathematical
proof that keeps Linux, for example, from letting a process access memory
belonging to another process. Nor is there a mechanism in place in most
operating systems to restrict file access to only those files a program
declares at compile time that it will access, or to keep a device driver
from accessing arbitrary other device addresses, or to limit authorization
based on which program did the authentication. Indeed, in the current
incarnation, it's impossible to modify the collection of executable code
without rebooting the machine; installing a program is the only way to
modify what can be executed, and that in turn requires a reboot. (Altho I'm
pretty sure that's merely a limitation, not a design intention.)
>> How random is that?
> where your cwd is set in Windows and not in UNIX.
Actually, last time I tried it, you can't do this in Windows either.
> kludge or a wtf or a random? :-)
What was a good idea 40 years ago is not necessarily a good idea today.
For that matter, there's very few systems out there that require all your
code to be digitally signed and which checks it every time you fire it up,
other than game consoles and phones for copy-protection purposes.
Am 06.06.2011 20:14, schrieb Darren New:
> your code to be digitally signed and which checks it every time you fire
> it up, other than game consoles and phones for copy-protection purposes.
... and still, even /those/ seem to keep dropping their pants if
addressed in the right manner. And you'd think, if anyone is willing to
invest real money into such systems, it would be the makers of such
systems (apart from military or secret agencies of course).
Seems like the problem is not /that/ easily solved...
Not only can you dismount it, when you remount it, you have the same cwd.
Since every drive has a cwd, it would be impossible to dismount any drive if
you couldn't dismount one where you had a cwd set.
That doesn't make it a kludge or a wtf or a random. It makes it an idea
whose time has passed.
On 6/6/2011 12:51, clipka wrote:
> ... and still, even /those/ seem to keep dropping their pants if addressed
Usually through the use of a hardware hack, tho.
The Sony hack required him to actually wire up the motherboard with switch
shorting out traces. The XBox hack was, IIRC, not so much a flaw in the
security of the system, but a broken game that let you run code from a saved
game (via buffer overflow or some such).
That's exactly why you need to do something like formal logical checks that
your code does the right thing at the lowest levels, then make everyone
conform to that.
When you're talking security against malware rather than copy protection,
it's a lot easier to get right, in some ways, because you don't *ever* want
the malware to run. Nobody is going to be sticking debuggers on the chip or
shorting out motherboard traces in order to get malware running on their own
machine.
Am 06.06.2011 22:15, schrieb Darren New:
>> addressed
> switch shorting out traces. The XBox hack was, IIRC, not so much a flaw
> in the security of the system, but a broken game that let you run code
> from a saved game (via buffer overflow or some such).
> that your code does the right thing at the lowest levels, then make
> everyone conform to that.
Ah yes - a formal proof... pretty useful if your intention is to make
sure a security-critical system never fails due to unforeseen errors.
As for making sure that a system is secure against /malicious intent/, I
believe it's pretty useless.
Just have a look at smart cards: For a given smart card design, you may
formally prove that there is no input sequence that makes the card
disclose even a single bit of its secret key...
... on its /official/ interface, i.e. the I2C bus data lines. But such a
formal analysis typically forgets a few other channels on which the
device is leaking information. For instance, an analysis may forget
about the timing of the data output, which might give hints about what's
going on inside. Or the power the chip consumes at any given time.
Say you will - I think a formal analysis can never foresee /all/
possible attack vectors a system might exhibit.
