POV-Ray : Newsgroups : povray.off-topic : Wolfram Alpha [again] Server Time
11 Apr 2026 10:45:19 EDT (-0400)
  Wolfram Alpha [again] (Message 1 to 5 of 5)
Subject: Wolfram Alpha [again]
Date: 25 May 2011 07:58:58
Message: <4ddcef02@news.povray.org>
Ask WA to factorise 40! [i.e., forty factorial] and it can do it in a
split second. Ask it what Euler's gamma function applied to 9 3/4 is and
it can instantly produce a result. Want to know what the DNA sequence
for the human homeobox gene HOX2 is? No problem. (And it'll also compare
it to the homologues in half a dozen standard model species too.) Ask
how many litres there are in one gallon and instantly get an answer.
Now ask, if petrol costs 132.7 pence per litre, and my car does 30 miles
per gallon, how much does it cost to drive 1 mile?
I just spent approximately 1 hour trying to make WA answer this trivial
question. In the end, the only way I could get it to work is to do all
the computation steps myself, one at a time. (I.e., ask WA to convert
this unit to that unit, ask WA to multiply this value by the conversion
figure it just gave me, etc. You can't even stuff all the queries into
one block of text. You have to run them as separate queries, or it fails.)
WA is hailed [BY ITS CREATORS] as the ultimate computational knowledge
tool. They show all sorts of [dubious] examples of real-world
calculations that you might want to do with it. But in solemn truth, if
you want something utterly nerdy, WA can probably do it in a heartbeat.
If math isn't your strong point and you just want WA to do a tricky
conversion for you... forget it.
[Don't even get me started on the fact that WA deliberately rejects
certain queries, because its creators still want to charge you money for
Mathematica, and nobody would ever buy that if they could do the same
stuff for free with WA...]
Subject: Re: Wolfram Alpha [again]
Date: 25 May 2011 14:44:32
Message: <4ddd4e10$1@news.povray.org>
Le 25/05/2011 13:58, Invisible nous fit lire :
An European or an African swallow ?
Huh ? I... I don't know that.
Date: 25 May 2011 16:31:50
Message: <4ddd6736$1@news.povray.org>
Laughably, WA *does* know the answer to this...
http://blog.orphi.me.uk/
Date: 28 May 2011 08:19:25
Message: <4de0e84d@news.povray.org>
> split second.
  40! is very easy to factorize (using common fast factorization methods
such as the elliptic curve method) because it has, by its very definition,
very small factors.
  Now try to make it factorize a number that is the product of two primes
in the order of magnitude of 40!, and you could wait for the Sun to die
before it happens.
Date: 31 May 2011 03:56:43
Message: <4de49f3b$1@news.povray.org>
On 28/05/2011 13:19, Warp wrote:
>> split second.
> very small factors.
> before it happens.
Nah. Wolfram Alpha gives up after only a few seconds. (Yet another
reason to spend money on a copy of Mathematica.) But sure, I take your
point.
*My* point was that geeky, nerdy stuff that nobody actually needs in the
real world works great in WA, but mundane real-world stuff (like the
sorts of things they constantly advertise that WA is fantastic for) tend
to fail miserably.
