POV-Ray : Newsgroups : povray.off-topic : C++ question for the experts Server Time
27 May 2026 21:11:47 EDT (-0400)
  C++ question for the experts (Message 1 to 10 of 10)
Subject: C++ question for the experts
Date: 14 May 2011 12:43:43
Message: <4dceb13f$1@news.povray.org>
Is it possible to put a class into a variable in C++?
In particular, assume I have a superclass "Thing", with subclasses Alpha,
Beta, Gamma. I want to instantiate one of each of the subclasses and put
each instance into a vector.
Thing* thing;
thing = new Alpha(1,true);
stuff.push_back(thing);
thing = new Beta(1,true);
thing = new Gamma(1,true);
Is there any way to do that with only one call to new?
In something like Tcl or Python, I'd do something like
   for x in [Alpha, Beta, Gamma] {
      thing = new x(1,true);
Is there any way to do anything similar in C++?
In C# it would be sorta possible, as there's a type (called "Type") that you
can give a class to and it'll give you a data structure you can use to
indirectly construct or invoke routines, but I wouldn't call that "first
class".
Just curious.
   "Coding without comments is like
    driving without turn signals."
Subject: Re: C++ question for the experts
Date: 14 May 2011 13:18:32
Message: <4dceb968$1@news.povray.org>
I'm *far* from a C++ expert, but it sounds like what you're looking for
might be addressed by template metaprogramming.  In particular you might
take a look at Boost's MLP package, in particular entries such as
http://www.boost.org/doc/libs/1_39_0/libs/mpl/doc/refmanual/for-each.html and
http://www.boost.org/doc/libs/1_41_0/libs/mpl/doc/refmanual/list.html
The drawback of course is that you have to do template metaprogramming
in the first place, so it's probably best if you hide the functionality
inside of some convenient-to-call utility function.  Depending on what
you want there's probably easier vanilla-OO ways to achieve the same end
result, but I'm sure you're well aware of those options.
> Alpha, Beta, Gamma. I want to instantiate one of each of the subclasses
> and put each instance into a vector.
> Thing* thing;
> you can give a class to and it'll give you a data structure you can use
> to indirectly construct or invoke routines, but I wouldn't call that
> "first class".
> Just curious.
Date: 14 May 2011 15:41:04
Message: <4dcedad0$1@news.povray.org>
Am 14.05.2011 18:43, schrieb Darren New:
> Thing* thing;
Not out of the box; you could use a factory-based approach though, e.g.:
class Thing_Factory_Base {
public:
     virtual Thing* New(int i, bool b) = 0;
template<class T>
class Thing_Factory : public Thing_Factory_Base {
public:
         { return new T(i,b); }
Thing_Factory<Alpha> Alpha_Factory = new Thing_Factory<Alpha>();
Thing_Factory<Beta>  Beta_Factory  = new Thing_Factory<Beta>();
Thing_Factory<Gamma> Gamma_Factory = new Thing_Factory<Gamma>();
list = Factory_List[3] {
   Alpha_Factory,
   Beta_Factory,
   Gamma_Factory
for (int i = 0; i < 3; i ++)
     stuff.push_back(Factory_List[i].New(1,true));
Date: 14 May 2011 18:30:21
Message: <4dcf027d$1@news.povray.org>
OK, thanks. It wasn't really something I needed to do. I just wondered if
there was something funky I didn't know about in C++ that would let you
treat a class as a first-class value.
Date: 15 May 2011 04:22:09
Message: <4dcf8d31@news.povray.org>
  C++ isn't dynamic like that, so the short answer is "no".
  There are techniques to somewhat simulate that, although it's probably a
bit limited. Googling for "factory pattern c++" might give some ideas.
  As a side note, Objective C *does* support this out-of-the-box (which
shouldn't be surprising to you at this point, I suppose). There's a type
named "Class" which does exactly what you describe: It represents the class
type, and can be used to instantiate objects of that type. This "class
object" can be requested from any object using its 'class' static method.
So you can do things like:
void foo(id someObjectOfAnyType)
    // Let's take the class type of that object:
    Class theClassTypeOfTheObject = [someObjectOfAnyType class];
    // Instantiate another object of the same type as the parameter:
    id anotherObject = [[theClassTypeOfTheObject alloc] init];
  (And no, I still don't like Objective C regardless of that. ;) )
Date: 15 May 2011 12:38:07
Message: <4dd0016f$1@news.povray.org>
Yeah. Objective-C seems almost exactly like "let's put smalltalk in C", even
down to the syntax.
The reason I asked is I was having a conversation with someone, and I said
Smalltalk and Python and Ruby have classes as first-class objects, Java and
C# have them as "sort of" first class objects, and many others like C++
don't.  I had to explain the "sort of" of course, and I wanted to make sure
there wasn't anything in C++ that would fill the "sort of" roll that the
"Type" data type does in C# or whatever the equivalent in Java is that I
don't remember right now.
Date: 16 May 2011 00:17:17
Message: <4dd0a54d$1@news.povray.org>
Am 15.05.2011 18:38, schrieb Darren New:
> said Smalltalk and Python and Ruby have classes as first-class objects,
> Java and C# have them as "sort of" first class objects, and many others
> like C++ don't. I had to explain the "sort of" of course, and I wanted
> to make sure there wasn't anything in C++ that would fill the "sort of"
> roll that the "Type" data type does in C# or whatever the equivalent in
> Java is that I don't remember right now.
In Java the whole smash is called the Reflection API.
Date: 16 May 2011 01:01:29
Message: <4dd0afa9@news.povray.org>
In C# too.
Wow, Java really vamped that up since last I looked.
http://download.oracle.com/javase/7/docs/api/java/lang/Class.html
C# has the "Type" object with similar capabilities. You can even construct
new code and classes and such using it.
I'm not 100% sure I'm comfortable calling classes first-class objects, given
the documentation says things like :
"Instances of the class Class represent classes and interfaces in a running
Java application."
There's similar wording in C#.  It's more like "this type is an interface to
manipulate classes, which aren't really first-class objects, which is why we
give you this separate data structure to manipulate them."  It just *feels*
like they're not first-class objects, compared to Smalltalk or JavaScript or
something like that.
Of course, if the language provides a type that lets you do all that stuff
to a class, whether it's "really" a class or not is a pretty meaningless
question.
Date: 16 May 2011 02:53:49
Message: <4dd0c9fd@news.povray.org>
Am 16.05.2011 07:01, schrieb Darren New:
> to manipulate classes, which aren't really first-class objects, which is
> why we give you this separate data structure to manipulate them." It
> just *feels* like they're not first-class objects, compared to Smalltalk
> or JavaScript or something like that.
I do agree.
For classes to be 1st-class objects, I'd expect to be able to do the
same things with class expressions that you'd be able to do with class
names, such as:
     MyClass foo (Class<MyClass> c)
         return new c();
instead of the more cumbersome Java code:
         Constructor<MyClass> co = c.getConstructor();
         return co.newInstance();
Those are the things that make you /feel/ that the reflection API is
something designed on top of an earlier language design.
Date: 16 May 2011 15:01:51
Message: <4dd1749f@news.povray.org>
Exactly my complaint, yes. Except I'd say it's more that the classes are
obviously not in the same address space as the data is, which means they're
not really first class.
