POV-Ray : Newsgroups : povray.off-topic : There's something wrong about... Server Time
17 Oct 2026 13:55:08 EDT (-0400)
  There's something wrong about... (Message 1 to 20 of 20)
Subject: There's something wrong about...
Date: 4 May 2011 12:50:16
Message: <4dc183c8$1@news.povray.org>
... a company that requires you to twice enter a password with upper case,
lower case, digits, *and* punctuation, and then mails it to you as a
confirmation in the clear.  Sheesh.
   "Coding without comments is like
    driving without turn signals."
Subject: Re: There's something wrong about...
Date: 4 May 2011 16:48:25
Message: <4dc1bb99$1@news.povray.org>
> case, lower case, digits, *and* punctuation, and then mails it to you as
> a confirmation in the clear. Sheesh.
How about mailing it to you every 6 weeks in case you forgot it? (Yes,
I've seen systems that do this.)
http://blog.orphi.me.uk/
Date: 5 May 2011 04:12:01
Message: <4dc25bd1$1@news.povray.org>
You know what's worse?
A company that requires you to send files to them electronically using
SFTP, requires that it uses public key authentication, and emails you
the private key that you're supposed to use, unencrypted.
People, the entire *point* of public key cryptography is that you should
never do this! >_<
Date: 5 May 2011 12:37:57
Message: <4dc2d264@news.povray.org>
  I thought the private key can only be used to decrypt, not to encrypt.
(Unless the public key can be created from the private key, which might be
the case.)
Date: 5 May 2011 13:59:12
Message: <4dc2e570@news.povray.org>
> the case.)
Normaly, you should first create your private decryption key.
Then, from that key, you generate the public encryption key. That key
can be transmited unencrypted.
Date: 5 May 2011 14:34:12
Message: <4dc2eda4@news.povray.org>
> > the case.)
  That's not what I was asking.
Date: 5 May 2011 16:53:45
Message: <4dc30e59$1@news.povray.org>
An asymmetric encryption algorithm has an encryption key and a seperate
(but related) decryption key. Which one is the "public" key depends on
which one you make public.
If you make the encryption part public, then people can use it to
encrypt stuff and send it to you securely. If you make the decryption
part public, you can use it to sign stuff which other people can verify.
[In some algorithms, either key can be used for encryption, obviously
with the other key becoming the decryption key. For other algorithms,
the two keys are not equal and only one can be used for encryption or
decryption. But that doesn't really alter the point above.]
Date: 5 May 2011 19:38:43
Message: <4dc33503$1@news.povray.org>
It depends on the algorithm. RSA can go either way. Otherwise, you wouldn't
be able to sign and encrypt with the same key.
In either case, sending the "private" key over cleartext and then using it
for authentication is just as broken as sending your password in cleartext.
Moreso, because you'd think someone smart enough to use encryption for
authentication would be smart enough to know that's not how you do it.
Date: 6 May 2011 03:38:11
Message: <4dc3a563$1@news.povray.org>
>>> the case.)
Private key and public key are the mirror of each other.
If you crypt with the public key, only the private key can get it back
in clear.
If you crypt with the private key, only the public key ... and so on.
Using the public key to encrypt allows to restrict the number of people
able to read the clear: only the private key can decrypt. It's a kind of
"For these people only".
Using the private key to encrypt is stranger, it would be "From this
people only".
Usually, the private key is used to crypt a checksum of the message
(signing), so that the users of the public key can verify that the
holder of the private key did in fact that operation.
The RWTF is that the private key should not be generated by the company
but by the identified people (you). And they should get your public key,
verify your identity-matching-that-key using a separate *secure*
channel, and then sign your public key with a trust level and their own
dedicated key-pair for that purpose.
The usual private-public key's algorithms allow only to compute the
public key from the private key, at best.
If the private key was computable from the public key alone, it wouldn't
be private any more.
Now, there is also weakness in algorithms, and rainbow book for the some
low length of keys.
For instance DES is weak enough, yet 3DES in some modes (such as Crypt
with key 1, uncrypt with key 2, crypt again with key 3) is assumed
strong enough as long as key2 is not key1 or key3 (moreover, DES use an
internal vector, and some mode propagate/share that vector with the 3
stages, whereas other modes have their own vector for each stage).
And last but not least, usually the asymetric keys (public-private) are
only used to crypt a "random" symetric key (like XOR) generated for the
session (or less), because asymetric cyphering is expensive in CPU
whereas symetric is usually far less.
Which also means that if part of the data exchange can be guessed (such
as a standardised header), the eaves-dropper could try to find the
symetric key in use by comparing the crypted data with the clear one.
(hence the random appeareance of "no-data" packets in the ssh streams:
just to make their lifes more difficult)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 6 May 2011 04:02:02
Message: <4dc3aafa$1@news.povray.org>
> it for authentication is just as broken as sending your password in
> cleartext. Moreso, because you'd think someone smart enough to use
> encryption for authentication would be smart enough to know that's not
> how you do it.
If you're using passwords for authentication, it's almost infeasible to
not make the system extremely fragile. Public key authentication is a
sophisticated system which solves almost all of these problems... except
that these people managed to do it so completely wrong as to trivially
circumvent any extra security provided.
Actually, the key they sent us was password protected. And they sent us
the password in a separate email. But really, how long is it going to
take a password cracker to figure out the 8-digit random alphanumeric
code they used for a password? That's even assuming the two emails
didn't trickle across the Internet right next to each other in the first
place.
Still, it's not a major company or anything. *cough* Pfizer *cough*
Date: 6 May 2011 04:12:21
Message: <4dc3ad65$1@news.povray.org>
> in clear.
This is true of algorithms like RSA. However, there are algorithms where
the encryption and decryption keys are actually in different formats,
and it is only possible to encrypt with the designated encryption key.
In this instance, we're only trying to establish a secure channel. If
they got an imposter's key, we won't be able to log in, and the problem
will quickly be rectified. (And the area the attacker temporarily gets
access to is empty until we put data into it, so there's no disclosure
to worry about.)
You understand that in principle, it is *always* possible to compute the
private key from the public one, right? It is impossible to prevent
this. All you can do is make it ludicrously expensive to do it.
AES exists for a reason. Triple DES is subject to meet-in-the-middle
attacks, and its keyspace is only 168 bits anyway. The keyspace of AES
is potentially much bigger, and in general it is considered far more
secure than any modification of DES.
Any symmetric block cipher worth toffee *must* be able to resist an
attacker with access to both the plaintext and the matching ciphertext
being able to deduce the key, or anything about the key. This is a very
basic property of symmetric block ciphers. Any cipher lacking this
property is trivially insecure. This has nothing to do with public key
cryptography.
Date: 6 May 2011 09:07:35
Message: <4dc3f297@news.povray.org>
>> in clear.
Agreed. Notice the "if" at the start of the lines, please.
It is always possible to *find by exhaustive exploration* of the key
space a private key that would match a public key. But that is not
computation.
Computation implies a better algorithm than "try key, generate next key,
repeat".
DES was used as an illustration. Moreover, the 3*56 bits of 3DES have a
lower entropy (so, 3*56 bits is *not* 168, at least in cryptography) due
to issue in the model.
I agree that there is better than 3DES, but it is one of the few
algorithms required (and then accepted) everywhere which also can have
dedicated hardware.
around.
it's free.
Date: 6 May 2011 09:16:20
Message: <4dc3f4a4$1@news.povray.org>
> computation.
No, that's computation. Given an input, it produces a correct output by
a deterministic procedure. That's more or less the definition of a
computable function.
For most algorithms, you can do something faster than that. For example,
for RSA, you just need to factorise a very large composite number. There
are algorithms for doing this much faster than an exhaustive search of
all possible bit patterns. (Although still in the same complexity class.)
It is always /possible/, and often it's less expensive than it
theoretically could be. The important point is for it to be too
expensive to be practical.
(The definition of "practical" varies depending on how valuable whatever
the key protects actually is, of course...)
How do you work that one out?
> dedicated hardware.
AES is widely supported (though perhaps not quite as widely as DES), and
I'm sure there are plenty of hardware implementations.
Date: 6 May 2011 10:52:52
Message: <4dc40b44$1@news.povray.org>
IIRC, it's part of the discussion in the SSH RFCs about the number of
secure bits.
Or it was in a SSH book. 3DES should actually be considered insecure, if
it was not for the administrations of USA to have it deployed a lot.
The wiki about 3DES in french states that 3*56 is 112 due to m-i-t-m
attack. The english version states the same, with added comment about
NIST reducing the actual value to something around 80.
around.
it's free.
Date: 6 May 2011 11:03:46
Message: <4dc40dd2$1@news.povray.org>
> secure bits.
Right. So what you're saying is that due to the possibility of a meet in
the middle attack, 3DES is less secure than a well-designed 168-bit
block cipher.
This is different from saying "a 3DES key has less than 168 bits of
entropy". Entropy is a specific property of a piece of data, and a
properly chosen 3DES key would indeed have 168 bits of entropy. What
you're saying is that not all of that entropy actually counts towards
the difficulty of breaking the cipher, which is a different thing.
Also: Yes, DES is obsolete, and even 3DES shouldn't really be used any more.
Three guesses which cipher our VPN tunnel uses...
Date: 6 May 2011 12:53:12
Message: <4dc42778$1@news.povray.org>
On 5/6/2011 1:12, Invisible wrote:
> This is true of algorithms like RSA. However, there are algorithms where the
> encryption and decryption keys are actually in different formats, and it is
There are also algorithms where any of many signatures can be generated (not
under control of the person doing the signing), and they can be checked.
This lets you build a signature algorithm that can't be used for encryption.
Then you don't need a certificate at all, so there's no need for both sides
to have a private key.
No. It may be possible to describe how to perform that calculation, but it's
trivial to make the possibility of stumbling across the right private key
arbitrarily small.
Triple-DES is useful only to those who have DES hardware ubiquitous in their
infrastructure.
Date: 6 May 2011 13:11:58
Message: <4dc42bde@news.povray.org>
The funny thing was, this was a password used to protect my submission of my
resume to a company. So, they wanted this sophisticated and hard-to-crack
password protecting something I *want* people reading anyway. There are
entire websites devoted to distributing your resume as far and wide as possible.
Date: 9 May 2011 04:12:02
Message: <4dc7a1d2$1@news.povray.org>
> sides to have a private key.
Oh, quite.
What's all the more baffling is that last time we set this up, they did
it the correct way. Why this time around they're doing it backwards, I
have no idea.
> their infrastructure.
...or when your provider wants to charge you extra for the tiny piece of
software required to enable AES. ;-)
Date: 9 May 2011 04:12:18
Message: <4dc7a1e2$1@news.povray.org>
> of my resume to a company. So, they wanted this sophisticated and
> hard-to-crack password protecting something I *want* people reading
> anyway. There are entire websites devoted to distributing your resume as
The fail.
Date: 24 May 2011 16:54:11
Message: <4DDC1AF3.301@gmail.com>
I have seen that a few times. I also complained and they said it was an
automatic feature of the system they use that they can not turn off.
I said that in that case they should warn in a big fluorescent font that
they are going to do that. So I can use a random password and change it
to a level 3 password later.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
