POV-Ray : Newsgroups : povray.off-topic : Rare for a reason Server Time
1 Nov 2026 11:08:24 EST (-0500)
  Rare for a reason (Message 1 to 44 of 44)
Subject: Rare for a reason
Date: 23 Apr 2011 11:59:45
Message: <4db2f771$1@news.povray.org>
Pipe organs measure pitch in "feet". Bigger number = lower pitch. The
number is not /directly/ related to the physical size of the pipes,
although generally bigger numbers mean bigger pipes.
A "normal" organ stop has 8' pitch. The pipes controlled by the peddles
are normally 16' pitch (i.e., one octave lower). Most organs will also
have 4' and 2' pitches, and unless it's a really small organ, there's
usually at least one 16' stop.
Now, a *cathedral* pipe organ will have at least one 32' stop, and a
really powerful one might have several of them.
There are exactly two pipe organs in the entire world which have a 64'
stop. And here's why:
http://www.sydneyorgan.com/STH64.mp3 [Sydney Town Hall]
http://www.die-orgelseite.de/audio/atlanticcity_64ft.mp3 [Broadwalk Hall
Auditorium Organ, New Jersey]
(Many organs have a 64' stop which actually generates /harmonics of/ a
64' pitch, but only these two actually have true 64' pitch pipes.)
Worth it... :-P
Then again, the organ at Liverpool Cathedral has a 32' Double Open Bass
which the organ's designer referred to as "the expensive draft". When
played, it makes a vague fluttering sound. The louder 32' stops make a
more definite sort of noise. (As best as I can tell, from video
recordings made with professional equipment...) If 32' isn't that
useful, why bother with 64'?
http://blog.orphi.me.uk/
Subject: Re: Rare for a reason
Date: 25 Apr 2011 09:04:27
Message: <4db5715b$1@news.povray.org>
Nigel Tufnel: The numbers all go to eleven. Look, right across the
board, eleven, eleven, eleven and...
Marty DiBergi: Oh, I see. And most amps go up to ten?
Nigel Tufnel: Exactly.
Marty DiBergi: Does that mean it's louder? Is it any louder?
Nigel Tufnel: Well, it's one louder, isn't it? It's not ten. You see,
most blokes, you know, will be playing at ten. You're on ten here, all
the way up, all the way up, all the way up, you're on ten on your
guitar. Where can you go from there? Where?
Marty DiBergi: I don't know.
Nigel Tufnel: Nowhere. Exactly. What we do is, if we need that extra
push over the cliff, you know what we do?
Marty DiBergi: Put it up to eleven.
Nigel Tufnel: Eleven. Exactly. One louder.
Marty DiBergi: Why don't you just make ten louder and make ten be the
top number and make that a little louder?
Nigel Tufnel: [pause] These go to eleven.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 25 Apr 2011 15:23:59
Message: <4db5ca4f$1@news.povray.org>
And then, the harmonics of 64 are:
32, 21 1/3, 16, 12 4/5, 10 2/3, 9 1/7, 8, 7 1/9, 6 4/10,....
Date: 3 May 2011 04:45:00
Message: <4dbfc08c$1@news.povray.org>
I love how the harmonics look like completely randomly chosen numbers,
with no obvious pattern at all.
Date: 3 May 2011 08:41:22
Message: <4dbff7f2$1@news.povray.org>
64/1 = 64
64/2 = 32
64/3 = 21 1/3
64/4 = 16
64/5 = 12 4/5
64/6 = 10 2/3
64/7 = 9 1/7
64/8 = 8
64/9 = 7 1/9
64/10 = 6 4/10
Nope, no discernable pattern at all
Date: 3 May 2011 08:47:41
Message: <4dbff96d$1@news.povray.org>
> 64/1 = 64
> 64/2 = 32
> 64/3 = 21 1/3
> 64/4 = 16
> 64/5 = 12 4/5
> 64/6 = 10 2/3
> 64/7 = 9 1/7
> 64/8 = 8
> 64/9 = 7 1/9
> 64/10 = 6 4/10
> Nope, no discernable pattern at all ;)
Exactly. I mean, unless you happen to be able to compute 64/7 mentally,
which normal humans can't.
If it was notated some other way, the pattern might be more obvious. But
as it is...
Date: 3 May 2011 19:21:53
Message: <4dc08e11@news.povray.org>
Harmonics are integer multiple of the base frequency, or integer
quotients of the base wave length having integer quotient of the power.
Armonic 1 is the base signal.
Armonic 2 have twice the frequency, or half the wave length, and half
the amplitude. For 64, it gives 32.
Nothing random here, not even a bad pseudo-random. It's totaly
deterministic.
Date: 4 May 2011 04:02:05
Message: <4dc107fd$1@news.povray.org>
> deterministic.
So is a psuedo-random number generator, and yet it still *looks* random.
Date: 4 May 2011 08:22:34
Message: <4dc1450a$1@news.povray.org>
>> 64/1 = 64
>> 64/2 = 32
>> 64/3 = 21 1/3
>> 64/4 = 16
>> 64/5 = 12 4/5
>> 64/6 = 10 2/3
>> 64/7 = 9 1/7
>> 64/8 = 8
>> 64/9 = 7 1/9
>> 64/10 = 6 4/10
You're not that much younger than me, so maybe there's something
fundamentally different between the school system in the UK vs. Canada,
but in the 2nd or 3rd grade, we had to learn our multiplication tables
by heart.
Normal humans should remember that 7 * 9 = 63.
Or if they don't, they should be able to guestimate that since 64 is
rather close to 70, there's a good chance that 64/7 would be just a bit
less than 70/7, which is easy to compute.
If not, I weep for humanity.
Date: 4 May 2011 08:34:46
Message: <4dc147e6$1@news.povray.org>
> by heart.
This is almost universally regarded as one of the most useless things
you learn in school. I haven't studied this statistically, but I suspect
the majority of adults long since forgot all this stuff.
Start weeping. This kind of reasoning is apparently far beyond the
ability of most average people.
Even if it wasn't, standing there for five minutes computing tables
isn't very immediate. If, instead of notating note pitches as
wavelengths, they were noticed as, say "K * 7" or something, it would be
far more instantly obvious what the relationship is, without having to
perform complex mental arithmetic.
Date: 4 May 2011 13:05:20
Message: <4dc18750$1@news.povray.org>
Rubbish! Maybe young adults can't remember them as they are over reliant
on calculators.
Regards
Date: 4 May 2011 16:47:33
Message: <4dc1bb65$1@news.povray.org>
> on calculators.
Most "young adults" apparently cannot compute that 4 x £2.99 is
approximately £12, but there we are...
Date: 24 May 2011 16:40:48
Message: <4DDC17D1.9050006@gmail.com>
>> by heart.
The whole point of learning multiplication tables by heart is that you
need them to do all other computations in base 10.
If you don't know them by heart a large part of our culture is
inaccessible to you.
I'll join you.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 25 May 2011 03:48:18
Message: <4ddcb442$1@news.povray.org>
Most people would consider that you need a calculator to do any
computations in base 10, beyond really trivial ones.
Such as?
> I'll join you.
I fear for the future of society, but for many reasons in addition to
this...
Date: 25 May 2011 16:25:07
Message: <4ddd65a3@news.povray.org>
Trivial, like multiplying 2 random phone numbers in your head? :P
I've done that several times, just for the /fun/...
Take some random 10 digits number, then another random 7 digit number.
OK. Now, without paper, what is the product? Hint, it's 17 digit long,
possibly 18. Your pocket calculator can't give you the exact result.
> Such as?
>> I'll join you.
> this...
:P Alain
Date: 25 May 2011 16:31:24
Message: <4ddd671c@news.povray.org>
Now, personally, I can't even *remember* a 17 digit number without
pencil and paper, never mind *compute* it. :-P
Date: 25 May 2011 17:10:05
Message: <4ddd702d$1@news.povray.org>
Remember the 10 digit number and the 7 digit number.
Multiply the first one by the first digit of the 7 digit one.
Remember that.
Repeat for all other 6 digits.
Shift and add the 7 intermediate results.
DONE!
It's a king of mental jogging :)
Date: 25 May 2011 17:11:42
Message: <4ddd708e$1@news.povray.org>
I forgot to tel that you should do it while walking in the city. Please
use secondary streets.
Date: 26 May 2011 10:25:38
Message: <4dde62e2$1@news.povray.org>
> Remember that.
> DONE!
Crap! no way I could do that, my working memory does not have enough
capacity!
~Mike
Date: 27 May 2011 13:23:26
Message: <4DDFDE12.5000506@gmail.com>
> Such as?
basically most of the mathematical knowledge.
citizen per day.
Date: 28 May 2011 08:36:51
Message: <4de0ec63$1@news.povray.org>
>> Such as?
I don't see why you need to memorise multiplication tables to understand
mathematics.
Indeed, one of the most important things I learned at college is that
mathematics is *not* just about memorising multiplication tables.
There's actually far more to it than that. The fact that my school
education completely failed to mention this is... rather worrying.
Date: 28 May 2011 20:00:31
Message: <4DE18CA1.2010208@gmail.com>
>>> Such as?
> mathematics.
You can not understand long division or long multiplication without
those tables. That means that e.g. the whole concept of prime number
becomes void. As will be most things in number theories. Not that you
actually need them, but not having a feeling for numbers will reduce it
to a collection of unrelated facts.
How to understand how to do long division with polynomials or binary
numbers without knowing how to do it with base 10 infinite precision
numbers?
What I am trying to say is not that the multiplication tables are
important, but that they are needed for the next steps. Long
multiplication and long division are among the first algorithms kids
learn. Skip them and everything in maths and physics (and ...) that uses
algorithms will suffer greatly.
And that relates to the other thing I want to get across: maths is part
of our Culture. As a teacher your task is to get across how beautiful it
can be.
ATM the problem is that some decades ago a process was started by which
the teachers teachers were selected on other grounds than knowledge of
the subject. Being taught by people who equated maths with boring sums
and stupid tables, the next generation was even worse. With time the old
teachers resigned and the young generation took over. In short: we are
in a downward spiral.
At the same time also politicians were recruited more and more from the
humanities departments (IIRC none of the politicians of our ruling
parties have a degree in any science of technology subject. In the
largest opposition party we have one real scientist (was professor in
biology, became minister of education and lost the election). In total
we have 150 members of parliament.) Culture is redefined as anything but
science by these incompetents. Not understanding maths is now considered
something to be proud of by those who think of themselves as the elite
of this society. That spiral will make have to make a few more turns
before it goes up again.
I hope Asia will be the guardian of this piece of human culture this
time, like the Arabs in mediaeval times. In the western world science is
on it's way to become extinct with very few changes of stopping the process.
citizen per day.
Date: 29 May 2011 07:12:31
Message: <xn0heovwu1pn4f2009@news.povray.org>
> > > > Such as?
> > understand mathematics.
> those tables.
One note: I think people should know them by heart and also be able to
do simple calculations in their head, simply because it is not very
pragmatic not to know them. You can't and shouldn't, IMO, always revert
to a calculator for that. It keeps you fit, up there.
But knowing these tables by heart does not help in *understanding*
anything. The knowledge only helps in applying that understanding a
little more pragmatically.
I can understand long division and multiplication, prime numbers and
number theory principles very well without knowing the multiplication
tables by heart.
Rudy Velthuis
"Go away...I'm alright." -- H.G.Wells, dying words
Date: 29 May 2011 09:51:51
Message: <4de24f77@news.povray.org>
>> mathematics.
> those tables.
You need to know what a multiplication table *is* in order to understand
long multiplication and long division. However, you absolutely do *not*
need to memorise the contents of said table to comprehend mathematics.
I have no idea what the corresponding tables are for octal. But I still
understand how long division works in octal - i.e., THE EXACT SAME WAY
AS IN DECIMAL!
The rest of your argument seems to follow from this flawed premis.
> can be.
Agreed.
FWIW, my teachers also utterly failed to demonstrate that literature can
be enjoyable. The only literature we did was Shakespear and some dope
addict named Coleridge...
I've often wondered how the hell we ended up in a society where being
stupid is considered a virtue. Apparently a few centuries back,
everybody who was anybody had to know and be able to debate the finer
points of (say) Lord Kelvin's new theories about thermodynamics...
Date: 29 May 2011 15:05:21
Message: <4DE298F3.3090409@gmail.com>
>>>>> Such as?
>> those tables.
> tables by heart.
You can in theory, but I am pretty sure you won't in practice. Or at
least the vast majority of people won't. At the age you are normally
learning it you need practical examples. Only much later on when you
have mastered abstract thinking you can understand the process without
being able to perform the process yourself.
That leaves open the question how much mastering abstract thinking is
hampered by not learning long division at the appropriate age. Then
again, I don't know what kind of games kids play nowadays, so abstract
reasoning and the concept of algorithms may come in a totally different
way than in my time. (Though my time as a teacher does not suggest that
other way was very effective).
citizen per day.
Date: 29 May 2011 15:17:18
Message: <4DE29BC1.7000006@gmail.com>
>>> mathematics.
>> those tables.
> AS IN DECIMAL!
My point exactly. Having learned it in one situation carries over to
another. Proves how vital it was for you to learn at that point ;) See
also my response to Rudy.
That you didn't think it through does not make it flawed ;)
>> can be.
> Agreed.
> be enjoyable. The only literature we did was Shakespeare and some dope
Any relation with http://www.youtube.com/watch?v=JTD1QW3SM60 ?
It is not stupidity, they appreciate other things, like... like... whatever.
Yes. Interesting isn't it.
citizen per day.
Date: 29 May 2011 16:39:35
Message: <xn0hepasw28xijs00i@news.povray.org>
> > > > > > > culture is inaccessible to you.
> > > > > > Such as?
> > > without those tables.
> > to do simple calculations in their head, simply because it is not
> > very pragmatic not to know them. You can't and shouldn't, IMO,
> > always revert to a calculator for that. It keeps you fit, up there.
> > But knowing these tables by heart does not help in understanding
> > multiplication tables by heart.
I'm not so sure. OK, I know lots of people who don't understand
fractions (I'm a dentist and most of my - especially younger -
assistants don't), and these usually don't know the tables very well
either, but I think that is because of a common cause: they hate maths.
I don't think knowing the tables is a prerequisite. It is just
correlated with an interest in maths, and that is probably a
prerequisite for the understanding (or vice versa).
Rudy Velthuis
"Computers make it easier to do a lot of things, but most of the
 things they make it easier to do don't need to be done."
 -- Andy Rooney.
Date: 29 May 2011 16:59:01
Message: <4de2b395@news.povray.org>
>> AS IN DECIMAL!
You don't need to know the numerical value of pi to 40 decimal places in
order to know how to use it. Similarly, you do not need to memorise 50
figures of a multiplication table to understand how long division works.
> whatever.
 From what I can tell, "being rich enough to be able to afford stylists
and makeup artists and photo editing staff to give you immaculate looks".
Either that or "being on TV".
Date: 29 May 2011 17:03:54
Message: <4DE2B4BD.8090104@gmail.com>
>>> AS IN DECIMAL!
You do at the age you (or actually we, the old men in this group)
learned long division.
citizen per day.
Date: 29 May 2011 17:18:19
Message: <4de2b81b@news.povray.org>
I never memorised the tables, as in being able to say 3 X 4 = 12. I had
to recite them and stop at the right place.
Three nothings are nothing.
Three ones are three.
Three twos are six.
Three threes are nine.
Three fours are twelve.
Three fives are, oops!
But then as I’ve said before, I had problems at school.
Regards
Date: 30 May 2011 18:49:47
Message: <4DE41F12.2070408@gmail.com>
> Three twos are six.
Interesting, someone between old school and the calculator generation.
I think the most relevant question in this context is: Do you understand
long division and if so at what age did you learn it?
citizen per day.
Date: 31 May 2011 07:42:24
Message: <4de4d420$1@news.povray.org>
It depends what you mean by "Old" school. When I was at school,
calculators were mechanical and you turned a handle to power them.
Yes I understand long division and I can generally divide by two digits
in my head if the dividend is not too big. I really can't remember when
I was taught it, at a guess I would say, about 9 years of age.
Regards
Date: 6 Jun 2011 11:20:41
Message: <4decf049@news.povray.org>
I used to be able to do 4 and 5 digit long division in my head, back in
grade school.
   "Coding without comments is like
    driving without turn signals."
Date: 6 Jun 2011 11:27:33
Message: <4decf1e5@news.povray.org>
On 5/29/2011 4:12, Rudy Velthuis wrote:
> simply because it is not very pragmatic not to know them.
Indeed. Actually, there was one event that eventually convinced my very
smart wife that there are *actually* people in the world who are not very
smart. She'd never actually encountered it as a gut feeling before.
We're in a store. We're buying something that's $20, but 60% off. The clerk
is taking *minutes* to try to figure out the price. She finally digs out a
calculator, figures out the answer is 12, and then hopelessly says "But is
that the discount, or the price?" My wife finally snaps and goes "It's 60%!
It's more than half!"
So, yeah, I think you must have at some point memorized the multiplication
tables and used them a bit to get a feeling for such things.
Nowadays, I like to torture people when I buy $10.20 worth of stuff by
giving the person a $20, waiting until they've rung it up, then handing them
another $0.25 coin, and watch them struggle helplessly trying to figure out
what the change should be on their own. (Actually, there's a dilbert about
that that's pretty funny.)
Date: 6 Jun 2011 11:29:30
Message: <4decf25a$1@news.povray.org>
On 5/29/2011 6:51, Orchid XP v8 wrote:
> FWIW, my teachers also utterly failed to demonstrate that literature can be
> enjoyable.
My problem with many of those subjects is that nobody ever said why we'd
need to know that stuff. Why in the world do I need to read The Great
Gatsby? Or Macbeth?  Now I know, and I regret not having actually read them
properly when I had the time to do so.
Date: 6 Jun 2011 11:50:47
Message: <4decf757$1@news.povray.org>
> clerk is taking *minutes* to try to figure out the price. She finally
> digs out a calculator, figures out the answer is 12, and then hopelessly
> says "But is that the discount, or the price?" My wife finally snaps and
> goes "It's 60%! It's more than half!"
Three words: Verizon math fail.
> multiplication tables and used them a bit to get a feeling for such things.
You don't need to memorise anything to be able to solve basic estimation
problems. You just need to *have* a frigging clue.
Date: 6 Jun 2011 11:51:26
Message: <4decf77e$1@news.povray.org>
>> can be
>> enjoyable.
> them properly when I had the time to do so.
OK, I'll bite: Why the hell should anybody, anywhere, *ever* read Macbeth?
Date: 6 Jun 2011 12:50:00
Message: <4ded0538$1@news.povray.org>
So that they can memorise their lines to put on the play.
Regards
Date: 6 Jun 2011 12:54:21
Message: <4ded063d$1@news.povray.org>
Because it's full of words and expressions that are shortcut references to
entire sets of memes in educated society. Just like if someone truly ugly
walks past and I whistle the Wicked Witch of the West theme music, it brings
in a whole packet of memes and concepts which are incomprehensible if you
haven't watched the movie. If you hear something referred to as a "red shirt
assignment" in a military context, you'll have no idea what that means if
you're not familiar with Star Trek. If someone is complaining, and I tell
you "that's just sour grapes", you'll have no idea I'm telling you the same
thing as an "Ar Du" unless you were familiar with the literature of both
Grimm and China.
It's the same thing with shakespear and all those sorts of things. If I told
you he's got a scarlet letter on his chest, you wouldn't know what that
means different from having a scarlet letter on his mantelpiece unless
you're familiar with both those novels. It's just the educated man's way of
saying "African or European Swallow?"
Date: 6 Jun 2011 14:14:37
Message: <4ded190d@news.povray.org>
>> Macbeth?
Well, that's why *I* read Macbeth. But that's a pretty stupid
justification...
Date: 6 Jun 2011 14:33:55
Message: <4ded1d93@news.povray.org>
>> Macbeth?
> to entire sets of memes in educated society.
So you need to read the entire play just to comprehend the one or two
vague references that anybody could explain to you in five seconds flat?
> ugly walks past and I whistle the Wicked Witch of the West theme music,
> it brings in a whole packet of memes and concepts which are
> incomprehensible if you haven't watched the movie.
I've watched that movie, and I wasn't even aware the Wicked Witch of the
West *had* a theme tune!
> It's just the educated man's way of saying "African or European Swallow?"
Required XKCD quote: http://xkcd.com/16/
Date: 6 Jun 2011 15:54:33
Message: <4ded3079@news.povray.org>
On 6/6/2011 11:33, Orchid XP v8 wrote:
> So you need to read the entire play just to comprehend the one or two vague
Yes. Because that's not really understanding.
http://www.youtube.com/watch?v=r4kiXh8YOzk
Hint: So does Darth Vadar.
Date: 7 Jun 2011 04:00:54
Message: <4deddab6@news.povray.org>
>> vague
Riiight. Because reading several hundred pages of dense prose written in
a language so archaic that you need an interpreter just to explain
what's actually happening is *so* much more enlightening than having
somebody actually explain to you what a specific phrase means?
I'm not denying that one exists, I'm saying it's not very memorable.
Well yes, /obviously/. The Imperial March, by John Williams. One of his
masterpieces. Everybody knows that...
Date: 7 Jun 2011 09:17:10
Message: <4dee24d6$1@news.povray.org>
On 6/7/2011 1:00, Invisible wrote:
> Riiight. Because reading several hundred pages of dense prose written in a
> language so archaic that you need an interpreter just to explain what's
> actually happening is *so* much more enlightening than having somebody
Yes.
i think opinions will differ on that.
