POV-Ray : Newsgroups : povray.off-topic : A kind of revolution is happening in the United States Server Time
18 Jul 2026 13:02:21 EDT (-0400)
  A kind of revolution is happening in the United States (Message 251 to 260 of 452)
Subject: Re: A kind of revolution is happening in the United States
Date: 18 Apr 2011 18:43:42
Message: <4DACBEA4.4020204@gmail.com>
On 18-4-2011 10:10, Invisible wrote:
> On 15/04/2011 22:25, andrel wrote:
>> Oh no, that means that someone really believes that because the society
>> as a whole seems to have almost exactly the right amount of bakers,
>> plumbers and housewives that must imply that the society is designed by
>> a supreme being. And that the proof of that is that society is
>> irreducible complex because if you remove one group, the bakers or the
>> policeman, or the bus drivers, or... the whole thing stops working,
>> hence it cannot have been evolved.
> That's not gonna work. Society is composed of individuals with
> intelligence [allegedly].
The point is that to make it work someone has to understand it all and
design it to make it function. Even if you had been intelligent, you
would still not know how much wheat, oil and bakers you need and anyone
who does, does not know how an engine works. So even if there is local
knowledge you still need global knowledge to design a society.
(FYI I do not believe any of the above. I know society has evolved from
something simpler, but as it is now, so many earlier parts are missing
that it is hard to see how it came about. Starting with just the people
living in a country then no matter how intelligent they are, they will
not form a smoothly running society before most, if not all, died from
starvation.)
> Complex things can only come about due to
> intelligence, so if unintelligent chemical soup becomes living,
> breathing complexity, it must be my invisible friend's intelligence that
> made it so.
OMG, invisible has an invisible friend.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 18 Apr 2011 20:02:47
Message: <4dacd127@news.povray.org>
> In other words, there was no logical reason it couldn't have run from
> the power being still generated. Well, unless there was something in
> there so that, under disaster conditions, it "stopped" generating power,
> so shorts couldn't happen. Still... I don't get it.
It's just that the pumps were connected to the wrong power source.
You need that connection when you start the reactor to get everything in
motion. But once started, any power plant, using ANY technology, must be
self powered.
At Fukujima, it was'nt the case, and they payd dearly for that mistake.
Date: 18 Apr 2011 20:08:17
Message: <4dacd271$1@news.povray.org>
Le 2011/04/18 04:15, Invisible a écrit :
> On 17/04/2011 17:07, Darren New wrote:
>> On 4/17/2011 2:57, Orchid XP v8 wrote:
>>> Yes, I know what a crumple zone is. But at 100MPH, there are going to be
>>> fatalities, no matter which way you design a car.
>> I take it the UK doesn't have any Formula-1 races?
> Yeah, they do. But I'm pretty sure people driving road cars don't wear
> full-body flame-retardant suits, high-end crash helmets, custom-moulded
> seats, custom-calibrated seatbelts and heat restraints. I'm also fairly
> sure no known road car weighs as little as an F1 car, nor is quite as
> low to the ground. Also, walking around the Silverstone race circuit,
> there is a rather conspicuous absence of solid objects to collide with.
> If you crash a road car, you're not going to fly across a gravel trap
> for half a mile and then hit a deformable tire wall. You're either going
> to hit another car, or else a tree or a concrete wall. I doubt anybody
> is going to walk away from that alive.
> This is presumably why driving at 100MPH is an instant license
> revocation...
What about a head on colision against a concrete wall at over 200 Km/h?
There was such a crash here at Montréal a few years ago. The pilot was
able to walk shortly after the crash to get into the ambulance. He only
had some bruising.
Thankfuly, those F1 are realy tough, and the restrains excellent!
Date: 18 Apr 2011 20:12:30
Message: <4dacd36e@news.povray.org>
Le 2011/04/18 12:13, Jim Henderson a écrit :
> On Sun, 17 Apr 2011 10:57:32 +0100, Orchid XP v8 wrote:
>>>> Designing it so the car doesn't survive the crash but the people
>>>> inside do would be even more miraculous...
>>> You've never seen a car crash (or the results of one), have you?  Most
>>> of them are *designed* to crumple in order to protect the passengers.
> Um, can you guarantee fatalities?  Because I'm sure that it's happened.
> 100 MPH is two cars in a head-on collision doing only 50 MPH, remember.
> Richard Hammond is still alive, for that matter - he was going 288 MPH
> when the "car" (it was a dragster with a jet assist, as I recall) he was
> in crashed.  He didn't walk away from it, but he didn't die, either (as
> evidenced by the fact that he's still presenting on Top Gear).
> Jim
1 car hiting a wall at 50 is similar to 1 car hiting a stationary car of
about it's mass at 100.
2 cars, each going 100, will fare about the same as ether at that speed
against a wall.
Date: 19 Apr 2011 05:04:03
Message: <4dad5003@news.povray.org>
>>> If you take ID to be the idea that some protein(complexe)s can not have
>>> been evolved from earlier proteins, then that is a testable hypothesis.
>>> Stating and researching that idea was real science.
>> So there's a theory, the theory has been repeatedly proven wrong,
> no it hasn't. All *cases* that have been put forward that should have
> shown support have in fact turned out to be in support of evolution.
> That does not prove there are none. For that to prove you need to
> examine all proteins that exist anywhere in nature.
That's like saying that to prove Newton's laws of motion, you need to
examine every object with mass in the entire universe. This isn't how
science works.
>> there's no particular reason to believe that it might be right in some
>> unknown case,
> You only say that because you 'believe' the theory and not the hypothesis.
No. I say that because there's nothing special about the disproven cases
than suggests that they're unusual. If there was, you might have a case
for suggesting that other examples exist which would, if discovered,
support ID.
It's like proving that Fermat's last theorem holds for all prime numbers
less than one million. You might well argue that the fact that these are
*prime* numbers makes them special, and the theorem might not hold for
composite numbers. But if you prove it for a bunch of numbers chosen at
random, there's less room for doubt.
Of course, any scientific theory always has the possibility of being
wrong, or at least incomplete. But based on available evidence,
evolution looks pretty safe. (Then again, people said that about
Newton's laws of motion. But on the first hand again, people still
*teach* Newton's laws of motion...)
>> and yet people continue to assert the truth of this theory
>> as *fact*? Doesn't sound very rational to me...
> That is entirely a different matter. These people need not be the same
> as the ones that do the real research.
Fair enough.
>>> BTW would dissecting the cases brought forward by Behe at al. count as
>>> spending time on ID? Because that would be an ideal way to teach
>>> students how real science works.
>> I commend the idea.
>> Right along side showing how String Theory, despite looking far more
>> professional than ID, is also not [yet] science.
> I also disagree on that. String theory is pure maths. I tend to think
> that maths is a science.
> I would agree that string theory is not physics yet.
String theory is mathematics developed explicitly for the purpose of
describing the real world. And yet, it does not yet make any testable
predictions. Someday it might, but it doesn't yet.
"Science" is usually defined as "the study of provable facts about the
real world". Mathematics would fall outside that scope.
>> (And examining why it
>> has the potential to /become/ science in a way that ID does not.)
> Remember that in the unlikely case they do find an example of something
> that cannot have been evolved in an autonomous way, ID becomes science.
> We might think that it is just as unlikely as someone handing over the
> telephone number of God, but it might just happen.
Point being, until that day, ID is not science.
In fact, hell, even on that day, ID won't be science. The statement that
there exist natural systems which evolution cannot explain will be
science. But that's not ID. ID claims that God did it. This will *never*
be science, since it is not possible to confirm or refute it by the
scientific method.
(Note that not being science is different from not being true.)
Date: 19 Apr 2011 17:38:31
Message: <4dae00d7@news.povray.org>
On 4/18/2011 2:46 PM, andrel wrote:
> On 18-4-2011 10:21, Invisible wrote:
>>>> You've got to admit, when you read about stuff like people believing
>>>> that ID is real science, it does make you wonder what kind of people
>>>> live there.
Actually, this represents two huge problems with their hypothesis
(please stop using theory, since that implies they already have some
sort of evidence to imply it is/could be true).
First - Irreducible complexity is a non-starter, since it assumes,
again, without *any* evidence, literally, that if you find a bridge,
where one stone being removed makes it fall, there couldn't have been
any sort of scaffolding to hold it up, later removed, which allowed it
to be constructed. It had to have been intelligently designed. This is
idiotic, since even such a bridge, having been so designed, required
missing steps, which are not obvious from simply saying, "If you remove
that one stone, it will fall down."
Second - If you want to call something a theory, you need to do research
to test it. The only people that have *ever* tested it have been
biologists, and their tests mainly consist of pointing out, usually well
after the fact has already been established in their own research, that
pulling some random thing out and saying, "See, irreducible!", doesn't
work too well when 6 months prior someone had already described why it
wasn't, but the ID people didn't bother to read all of the papers on the
subject. The only "research" these clowns have done, to date, involves
a) writing articles, which often repeat assertions already disproven,
and sometimes using examples already shown to be invalid, b) scouring
other people's work, hoping to find something that is irreducible, and
c) writing more long winded papers, describing their hypothesis, while
usually glossing over, or rarely, making excuses, as to why they can't
yet describe what they are really looking for (in the case of ones like
ontological depth, which they *said* they would have "soon", like 7
years ago), how to find it, how to test it, how you would show it to be
incorrect, through testing, or anything else resembling science.
In short, they have a hypothesis, which they want to fit preconceived
data, but are using philosophy, instead of science, to "prove" it,
wandering about picking up bits of stuff they think fit their useless
guess.Its like if someone thought the debate over the existence of
cyclops in ancient times was real, and they went about declaring that
they *think* they found a skull (really from an elephant), and some big
bones (from some dinosaur), which suggest they are right, and cyclops
actually once existed. Meanwhile, we go on studying elephants, and
digging up dino skeletons, and wondering what these kooks are babbling
about, never mind why anyone is taking them seriously.
There is no science done by ID people, there is no research conducted by
them, unless doing the equivalent of google searches constitutes
"research", and no "theory", just a desperate guess, they want to be
true, so that either God had to do it, or, for some of the crazier ones,
they can take Genesis, and some made up "timeline" for the age of the
earth seriously.
Date: 19 Apr 2011 17:46:41
Message: <4dae02c1$1@news.povray.org>
> scientific method.
Mind, if you stated the hypothesis as, "Science can either identify, or
at least test for, whether something is true or not.", then this would,
given all collective evidence, suggest several facts - 1) In all cases
where you can actually collect data, this maxim is true, 2), in all
cases where data cannot be collected, this maxim is false, and 3) in
those cases where the maxim fails, the reason is not that the data never
existed, but has become, via time, etc., unavailable, 4) there is
usually some grounds to assume that the data had existed, and could have
been collected, had such collection been timely.
Apply the same to the god question as you get - 1) No data can be
collected, 2) There is no evidence to suggest that such data ever
existed, 3) Therefor, lacking evidence that data was *ever* available at
all, the implication is that you are attempting to find non-existent
data, for an non-existent object. QED - Its highly improbable that the
stated thing being examined is "true".
Date: 19 Apr 2011 17:51:45
Message: <4dae03f1@news.povray.org>
> science works.
What you need to examine depends on what you want to test.
For gravity, you only need a representative sampling. If all samples
falls within experimental bounds, it's comfirmed.
If you want to prove something but you did not find a single case that
match, you need to continue searching as long as you can, or find a way
to prove that it can't be.
In the case of ID, you effectively need to find and test every single
protein, enzimes, peptides and aminoacids in existance and their
predecessors to find at least one that can't possibly happen naturaly.
You also need to do the same with every sugars and glucides, as well as
lipids.
And then, finding one may not be enough, as it may be the result of the
degradation or a particuliar splitting of another molecule. So, you also
need to demonstrate that that degradation or splitting can't appen naturaly.
>>> unknown case,
>> hypothesis.
> support ID.
> Fair enough.
>>> I commend the idea.
Most scientists, starting with quantic physicists, are uneasy about the
string theory exectly for the fact that, by it's very nature, there is
no way to observe or realy test it.
It will probably stay forever at the stage of a mathematical abstraction.
> scientific method.
Date: 19 Apr 2011 18:14:55
Message: <4dae095f$1@news.povray.org>
That has nothing to do with proving ID.
The problem is that there are an infinite number of untestable theories out
there. In order to show *any* support at all for ID, you not only have to
find something that didn't/couldn't evolve naturally, but you have to show
how it *did* come from God.
Depending, of course, on what you mean by "naturally". It's entirely
possible one might find something that could not have arisen without the
interference of intelligent planning and forethought but which is
nevertheless completely naturally evolved.
But disproving that every single molecule of life on Earth is evolved does
nothing zero nada towards proving what *did* happen with that molecule. Even
*if* every single protein could not possibly have evolved naturally, that
doesn't tell you anything about how it *did* come to be.
   "Coding without comments is like
    driving without turn signals."
Date: 19 Apr 2011 18:24:00
Message: <4dae0b80@news.povray.org>
Just a fair point, "theory" can also mean "hypothesis", just as it can
mean "body of knowledge about a scientific subject".
Jim
