POV-Ray : Newsgroups : povray.off-topic : Linked lists Server Time
17 Oct 2026 14:59:07 EDT (-0400)
  Linked lists (Message 1 to 11 of 11)
Subject: Linked lists
Date: 8 Apr 2011 04:03:40
Message: <4d9ec15c$1@news.povray.org>
Yesterday I was working on a small Haskell library for working with
mutable double-linked lists. Man, it's been such a long time since I
worked with this data structure, I'd forgotten how great it is!
OK, the down-side: Sequential access. You can only access lists
sequentially. Obtaining the Nth element is a linear-time operation, and
any attempt at parallel processing is fairly doomed from the start.
On the other hand, if you need to process *all* the data in your
container anyway, being limited to only sequential access might not be
all that bad. And you still have O(1) access to any node which you
already happen to have a pointer to.
So there's a big down-side. Now what's the up-side? Well, lists are
trivially resizeable. (That's an expensive operation for anything
array-based.) And they support a large number of O(1) operations.
Joining two lists is O(1). Splitting a list into two lists is O(1).
Inserting or deleting elements is O(1). Adding or removing entire
sublists is O(1). Moving a bunch of elements from one spot to another is
O(1). All these rearrangements that would usually be quite expensive
become O(1) on lists.
I'm enjoying myself here. Especially the bit where I implemented
transactional lists, so all these sophisticated list manipulations are
thread-safe without me having to worry about deadlock. I can even do
stuff like "move to the next node in the list, or block until one is added".
Subject: Re: Linked lists
Date: 8 Apr 2011 08:57:42
Message: <4d9f0646$1@news.povray.org>
Have you considered a skip list structure?
(http://en.wikipedia.org/wiki/Skip_list)
Date: 8 Apr 2011 09:09:03
Message: <4d9f08ef$1@news.povray.org>
No - mainly because I've never heard of it. ;-)
However, according to Wikipedia, it does everything in logarithmic time.
Well, so does a tree [assuming you can keep it balanced]. Haskell
already has a bazillion different tree implementations [although I don't
recall seeing a mutable one recently].
Date: 8 Apr 2011 10:46:53
Message: <4d9f1fdd$1@news.povray.org>
Skip lists structure is claimed to be so simple,
that it could be easily implemented within an hour
without a textbook  (http://goo.gl/yDqKJ).
Date: 8 Apr 2011 13:01:05
Message: <4d9f3f51$1@news.povray.org>
It moves forward and back in linear time. It moves far forward in
logarithmic time if you make it tall enough. It's like an unholy union of
tree and list that automatically keeps itself balanced. It's worth reading
about, because it's interesting and easy to understand.
The nice thing is a skip graph, which is as efficient as a skip list except
you can make it distributed like a DHT.
   "Coding without comments is like
    driving without turn signals."
Date: 8 Apr 2011 22:45:00
Message: <web.4d9fc71a39d65a313f0adf870@news.povray.org>
then why not using a LISt Processing language? ;)
Date: 9 Apr 2011 04:30:16
Message: <4da01918$1@news.povray.org>
Because I prefer working with a system that offers static type
guarantees? And thread safety? And sane syntax? And...
http://blog.orphi.me.uk/
Date: 12 Apr 2011 06:46:42
Message: <4da42d92$1@news.povray.org>
Also, as a mere technicality... Aren't lists in Lisp *single* linked
rather than *double* linked?
Date: 12 Apr 2011 06:50:17
Message: <4da42e69$1@news.povray.org>
> It's worth
> reading about, because it's interesting and easy to understand.
By contrast, I didn't bother reading much further because it appears to
be very complex and difficult to understand.
> except you can make it distributed like a DHT.
What's a DHT when it's at home?
Date: 12 Apr 2011 11:42:32
Message: <4da472e8@news.povray.org>
On 4/12/2011 3:50, Invisible wrote:
>> It's worth
> By contrast, I didn't bother reading much further because it appears to be
Well, come on. Look at the pictures and you can understand what's going on. :-)
a Hash Table that's not Distributed?
Date: 12 Apr 2011 16:21:19
Message: <4da4b43f@news.povray.org>
Invisible escreveu:
yep.
a game sig: http://tinyurl.com/d3rxz9
