POV-Ray : Newsgroups : povray.off-topic : Plug & play Server Time
1 Nov 2026 11:56:29 EST (-0500)
  Plug & play (Message 1 to 50 of 53)
Goto Latest 50 Messages Next 3 Messages >>>
Subject: Plug & play
Date: 4 Apr 2011 05:34:44
Message: <4d9990b4@news.povray.org>
What the user manual says:
"To expend the available recording capacity, simply purchase an external
USB harddrive or flash drive and connect it to the USB socket at the
back of the device."
What you actually have to do:
1. Purchase a USB HD.
2. Connect it to a computer running Linux.
3. Create a partition.
4. Format it with ext3.
5. Create at least one empty folder.
6. Connect it to the device.
Note, in particular, that if you do not possess a computer, then you
*cannot* expend the recording capacity of your device. Just back up and
think about that for a moment. We're talking about a set-top box for a
TV. You plug it into a power source, a TV and an aerial, and it lets you
watch digital TV. It also lets you record and play back TV. Now why IN
THE NAME OF GOD should you need to possess a computer just to upgrade
the storage capacity?
Seriously. You should be able to just plug in a HD and the device itself
should format it. Why the hell do you need a computer to do that?
Another thing. Technically you don't need to use Linux. The device
supports FAT16 and FAT32 as well. But apparently none of those go up to
the size necessary to make expansion worth the effort. Only ext3 seems
to support really big filesystems.
(Notice that's ext3. The device does not support ext2 or ext4. Only
ext3. Please get it right when formatting!)
Also, even if you format the drive, the set-top box still acts as if
it's read-only until you create at least one empty folder. At that
point, suddenly it works just fine. WTF?
Don't even get me started on the infelicities of *using* the external
storage.
1. Copying a file to the external HD allows you to keep watching TV, but
disables all controls. (E.g., you cannot change channel.) Mercifully
there's a cancel button. But cancel is the only operation you can
perform while the copy is in progress.
2. When you copy a file, it gives you a progress bar. When you copy
multiple files, it gives you a progress bar FOR THE CURRENT FILE. It
provides no indication whatsoever of overall progress. And when a large
copy operation takes several hours, that's a problem.
3. You cannot copy folders, only files. To copy a folder, you must
manually create the destination folder, open the source folder and
destination folder, select-all and copy. If a folder contains folders,
you must select-all and manually unselect any folders.
Still, what do you expect for several hundred pounds worth of hardware?
Oh, wait...
Subject: Re: Plug & play
Date: 4 Apr 2011 07:10:06
Message: <4d99a70e$1@news.povray.org>
> Oh, wait...
Benefits for the shareholders, what else ?
Date: 4 Apr 2011 07:18:25
Message: <4d99a901@news.povray.org>
>> Oh, wait...
Well, yeah. On the other hand, there are laws and things that require
that if you pay money for something, it actually *works*. Unfortunately
these laws do /not/ require that it works *well*...
The market theory is that if a device doesn't work very well, everybody
will buy a competing product instead. Except that, as far as I can tell,
almost all of these devices tend to be equally inept.
Date: 4 Apr 2011 08:43:17
Message: <4d99bce5$1@news.povray.org>
Maybe it wasn't possible to make a better one for that price and still
make a profit?
Date: 4 Apr 2011 10:25:43
Message: <4d99d4e7$1@news.povray.org>
> make a profit?
How hard would it be to add 3 lines of code to display the number of
files still to be copied? I mean, maybe it would actually be difficult
to add a second progress bar, I don't know, but I can't imagine adding a
little bit of text could be that hard.
There's already an option to reformat the internal HD. So why isn't
there one to format an external one? The necessary code obviously exists
already, so...?
Alternatively, if you actually need a PC, why not document this fact
correctly? If the drive has to have at least one empty folder on it,
document that too! (Weirdly, you can create and delete folders from the
device. You just can't until at least one empty folder exists, WTF?)
We're talking about tiny little changes that would have made a big
difference to how easy to use the product would have been. OK, making it
so that you can still change channel while a file copy is in progress
*might* actually be difficult. Most of the other stuff would have been
trivial.
Date: 4 Apr 2011 12:06:10
Message: <4d99ec72$1@news.povray.org>
It's all about priorities and deadlines.
   "Coding without comments is like
    driving without turn signals."
Date: 4 Apr 2011 20:14:04
Message: <4d9a5ecc@news.povray.org>
Sounds like Yahoo Small Business' "file manager". Stupid thing lets you
move/copy files up/down a level in the tree, but not "across", to
entirely other locations. And, you can't do shit with folders.
I seriously wonder, at times, what people are thinking when they do
stupid shit like this, then claim it "helps" you do anything. Luckily,
in my case, I was able to activate FTP, then make changes on my own
system. Maybe, in your case, you just boot a completely different OS,
make the changes/copies, then... lol
Date: 5 Apr 2011 04:01:23
Message: <4d9acc53@news.povray.org>
Indeed. And as usual, customer satisfaction is not a priority.
Date: 5 Apr 2011 06:03:58
Message: <4d9ae90e@news.povray.org>
> already, so...?
> trivial.
You'll probably find a lot of the code is just copied from an earlier
generation product (where HDs were much smaller), and the external drive
thing was a last minute add-on.  To go through a thorough a test, code
and test cycle would probably end up way more expensive than any
additional profits they could make over just shipping it "as-is" with
minimum modifications ("how can we make huge external drives work as
quickly as possible").
Don't forget these type of products sell for 12 months or so until the
next better one comes along, in a lot of cases it's much more profitable
to sell your product NOW with a few bugs rather than wait some time to
iron them out.  And in the end a company that makes amazing products but
no profit will not last very long.
Date: 5 Apr 2011 06:14:39
Message: <4d9aeb8f$1@news.povray.org>
It still bemuses me that they could go to all the trouble of writing a
huge, complex USB driver, and yet not bother to add 3 lines of code to
display a file count.
As the manufacturer, this is probably true. As the consumer, we've
bought this thing and we're probably going to use it for at least 10
years, if not longer. So the minor glitches that the manufacturer didn't
bother to iron out in their rush to market are extremely annoying, and
they're going to annoy us for the next 10 years.
> iron them out.
Reminds me of my PC motherboard. Splashed across the [very shiny] box is
something about RAID support and dual-BIOS support. You know what? The
product in the box doesn't actually possess either of these features.
(!!) But about a year later, Gigabyte released a BIOS update that makes
these features work as advertised.
(I especially love that you have to bypass the dual-BIOS in order to
make the dual-BIOS work...)
I would pay serious money to obtain hardware and software which isn't
infuriatingly awkward to use. But unfortunately, that doesn't appear to
be an option. Nobody makes it.
What, fundamentally, can we do about this? How can we make it
unprofitable to produce poor quality products?
Date: 5 Apr 2011 06:28:49
Message: <4d9aeee1$1@news.povray.org>
I doubt they wrote their own USB driver from scratch.
They've already got your $$$s though :-)
You need to stop the demand for cheap consumer goods - good luck with
that ;-)
Alternatively you could make it illegal to sell anything that hasn't
scored a certain amount in some unbiased consumer testing, but you're
likely to be pretty unpopular when the price of everything goes up.
Date: 5 Apr 2011 08:02:14
Message: <4d9b04c6$1@news.povray.org>
I doubt integrating whatever 3rd party code they bought into their own
codebase was a five minute job.
Indeed. And that seems to be all they care about.
(E.g., the user guide has a "go to this URL for support" printed in it.
The URL is 404, and when you check out their support section, the model
we bought isn't even listed. Not bad for a 4 month old product...)
> that ;-)
If we paid £20 for this thing, I wouldn't mind it being a bit naff. But
we didn't. It cost hundreds and hundreds of pounds. For that price, you
damned well *expect* it to be good quality!
Yeah, I'm guessing that's not going to work too well...
Date: 5 Apr 2011 09:11:56
Message: <4d9b151c$1@news.povray.org>
I wonder what OS is it using?  Also they probably have some 3rd party to
write the software anyway, so have no direct control over exactly how
things are implemented internally, so long as it works.
Just change your expectations, then your problems are solved :-)
Date: 5 Apr 2011 09:21:35
Message: <4d9b175f$1@news.povray.org>
It supports FAT16, FAT32 and EXT3. It does not support NTFS. Take a wild
guess...
[Assuming that they're using a full off-the-shelf OS, and not a smaller
piece of custom software.]
If it's actually running a standard desktop OS, adding a USB driver is
probably trivial. If it's a custom product, arranging for interrupt
handlers to fire and so forth is probably not trivial at all, even if
the handlers were written for you by somebody else.
And people wonder why Britain is no longer great. :-P
Date: 5 Apr 2011 09:29:48
Message: <4d9b194c$1@news.povray.org>
>> make a profit?
> already, so...?
> trivial.
It always seems to me that usability is the lowest possible priority of
set top box hardware. I won't even go into how much I despise the
software on our cable box. I'm rather busy when I get home. I expect
that my favorite shows will be dutifully recorded by the box, stored,
and the box will warn me if I'm running out of storage. It seems rather
simple. Every week record show with title X. When new data comes in, add
anything that matches my list to the schedule. If a show conflicts, the
highest priority always wins. If a show is set to record both new and
repeats, then record both new and repeats. How hard can it be? And yet
... the functionality is so broken that if I don't babysit the device,
it fails to record anything. I noticed my selection of shows was growing
rather thin, so I looked at the future recordings. Nothing. I had to
re-enter all of the series I had set to record. Now it records fine. My
wife reminds me to check that our favorite show is being recorded, about
30 minutes in (we were busy ... this is what a DVR is for...) No, it was
not recording. The show is set to record new and repeat (because new
doesn't always work) and is Priority 1 on the DVR's list. and it was not
set to record. WTF... Oh, but it was recording something further down
the list, and still had an open receiver for recording another show.
Oops... it looks like I just did.
~Mike
Date: 5 Apr 2011 09:31:31
Message: <4d9b19b3$1@news.povray.org>
This is so 20th century...
Welcome to the 21th century!
Were the price is not fixed by how much it costs to produce, but how
much the target is ready and expecting to pay.
In this wonderful time, selling a set of identical items with different
price is just an opening.
A 2TB hard drive at 25$ : it must be crap.
At 100$ : it's cheap and ok.
At 130$ : it is a bit of margin for the seller.
At 200$ : it must be real good.
At 500$ : it's only for the pro.
It's also a sad time: the expected time life of any product is about the
one provided by the law. (and that might be short!)
If Britain  was great, what about the United Kingdom ?
and the Common Wealth ?
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 5 Apr 2011 10:05:49
Message: <4d9b21bd$1@news.povray.org>
I think perhaps the problem is that
1. You cannot tell how good the software is until *after* you bought the
device.
2. Once you bought the device, there is no come-back.
Before you buy, you have several competing products that you could
select. The manufacturers do all they can to make you buy their product
rather than somebody else's. This usually involves stuffing as many
features as possible into the device for the lowest possible price, and
then loudly shouting about all the features on the product packaging.
After you buy... the manufacturers have your money. They don't *care*
what happens next. It is of no consequence to them. Needless to say, if
you buy a set-top box and discover 4 months later that the functionality
for using an external storage device sucks arse, there is nothing you
can do about it. You cannot possibly take the device back and demand a
refund [unless you can show that it is actually failing to operate as
advertised, which you can't].
I think perhaps the way to remedy this is to make it possible to do
something about poor quality products. Make it so that if the customer
is not happy, it directly affects the manufacturer in some way. Damned
if I know how though...
Date: 5 Apr 2011 10:09:08
Message: <4d9b2284$1@news.povray.org>
Well, the price of cotton has been determined that way for millennia.
Then again, you can more or less tell what you're getting as soon as you
see it...
I know people like HP and IBM like to charge 10x for the same harddrive.
But they *claim* that it's because the device is engineered for greater
fault-tolerance. (E.g., take a 2TB drive, reconfigure the firmware so it
shows up as 1TB, but up to 50% of the sectors can go bad before it stops
working.)
I have absolutely no idea whether these "server-grade" drives really
*are* more reliable, or whether it's just a sucker tax.
Date: 5 Apr 2011 10:41:20
Message: <4d9b2a10$1@news.povray.org>
Am 05.04.2011 16:09, schrieb Invisible:
Server drives are designed to endure continuous use.
Desktop drives are designed to endure lots of power cycles.
The latter may or may not be easier, but there happens to be a high
correlation between usage profile and budget.
Date: 5 Apr 2011 11:19:57
Message: <4d9b331d$1@news.povray.org>
Write a review on amazon.
Date: 5 Apr 2011 11:21:46
Message: <4d9b338a@news.povray.org>
How does that help?
Date: 5 Apr 2011 11:50:15
Message: <4d9b3a37$1@news.povray.org>
> How does that help?
You don't read reviews before buying something?
Date: 5 Apr 2011 13:07:23
Message: <4d9b4c4b@news.povray.org>
The drives in a NAS are exactly the same as what you'd buy off the shelf in
an electronics store.
Google has a whitepaper telling about the drive reliability based on
statistics from half a million disk drives. There's little correlation
between "category" and reliability.
Date: 5 Apr 2011 13:08:29
Message: <4d9b4c8d$1@news.povray.org>
> infuriatingly awkward to use. But unfortunately, that doesn't appear to be
I have found that is just plain how it works in video. I'm not sure why. I
haven't been able to find a capture card that will process HD coming off a
TV cable, in spite of every TV having this capability. The few capture cards
that *seem* to have this capability require you to use their custom playback
software that only runs on the same machine where you have the card plugged
in, which kind of defeats the purpose of capturing the stuff in the first place.
Find a set-top box that'll play files *and* record TV.
Don't even get me started on the PS3 usability failures. :-)
Every day I notice 101 minor things where I say "with a little thought (or,
if they didn't make the compromise this way) it would have been much less
annoying."
You'd be surprised.
Shop someplace like Amazon where people give reviews that the company
doesn't get to vet.
Date: 5 Apr 2011 14:54:21
Message: <4d9b655d$1@news.povray.org>
On 05/04/2011 04:50 PM, scott wrote:
>> How does that help?
No. But generally I don't buy hardware from Amazon anyway...
(Usually I only buy music from Amazon. And then only when I already know
what I'm trying to buy, so the reviews are irrelevant.)
 From what I've seen, the reviews for just about *everything* are
unwaiveringly positive.
http://blog.orphi.me.uk/
Date: 5 Apr 2011 15:16:38
Message: <4d9b6a96$1@news.povray.org>
>>> How does that help?
That's not been my experience.  But more to the point, if you had a
problem and you don't write a review, you're not helping the next buyer
make an informed decision.
Jim
Date: 5 Apr 2011 15:22:31
Message: <4d9b6bf7$1@news.povray.org>
Maybe for music...
Date: 5 Apr 2011 15:33:30
Message: <4d9b6e8a@news.povray.org>
I agree.
Regards
Date: 6 Apr 2011 03:57:12
Message: <4d9c1cd8$1@news.povray.org>
> in an electronics store.
So it *is* a sucker tax then.
Date: 6 Apr 2011 03:59:29
Message: <4d9c1d61$1@news.povray.org>
> I agree.
Well, perhaps. Perhaps if I actually bought hardware from Amazon instead
of the 10^17 other suppliers, and for every single one I wrote a long
description of why it sucks, the manufacturers might lose 0.02% of their
sales, and a tiny few people would be spared buying one sucky product
only to buy another equally sucky product. I doubt this is going to
bring quality back to the marketplace.
Date: 6 Apr 2011 04:06:24
Message: <4d9c1f00$1@news.povray.org>
You don't need to buy it from amazon, but generally enough people have
that there will be a good range of reviews from people using it in
different ways.  After reading a couple of pages of comments it usually
becomes quite obvious if there are problems with the features you are
interested in.
Also check the "What people buy after looking at this page" section, it
seems to me like bad reviews certainly affect what people buy.
Is the recorder you have listed on amazon?  If it is then I'd definitely
leave a review highlighting the points you mentioned here - you'll get a
much bigger audience and actually influence future purchasers.  You
didn't even mention the make/model number here, so how are we meant to
avoid it :-)
Date: 6 Apr 2011 04:18:56
Message: <4d9c21f0$1@news.povray.org>
> sales,
Amazon has about a 10% market share for online sales...
Date: 6 Apr 2011 04:24:48
Message: <4d9c2350$1@news.povray.org>
>> sales,
How did you calculate that?
Also, what percentage of the total market is online sales?
Date: 6 Apr 2011 04:27:12
Message: <4d9c23e0$1@news.povray.org>
> interested in.
> avoid it :-)
First of all, AFAIK, most people don't bother with reviews. If you want
to buy some item of electronics, you go to one or maybe a few shops,
look at what they sell, analyse the features vs price landscape, and
select the product with the features that are most important to you for
the best price.
Even if I put something on Amazon, 99.99% of purchasers will never see
this review, and it will have no influence on their decision at all. And
even the tiny minority of people who read reviews... there are millions
of different places where you can post a review. There are reviews
written in printed and electronic magazines. There are user-submitted
reviews on Amazon and a bazillion other online stores. I can't post to
all of them.
Is the recorder listed on Amazon? Yes it is. And according to Amazon,
the device earned the What Hi-Fi 2009 Best PVR Award. (!) If I were to
read reviews, What Hi-Fi is probably *the* number one review I would
look at. And the fact that this device is top-rated would probably lead
me to buy it.
The actual user reviews all mention an endless succession of bugs,
glitches and annoyances. But with a top recommendation from the printed
press, I doubt this will make any impact on sales at all.
Secondly, I think the top-rated status reflects another big problem:
There isn't anything better on the market. ALL of these devices are
buggy and fiddly to use. If you read all the reviews, you'd just end up
buying nothing at all, because none of them work very well.
Date: 6 Apr 2011 05:19:05
Message: <4d9c3009@news.povray.org>
Amazon sales from 2009 (from their annual report) divided by total
online sales (found the same number from various sources via google).
This was for the US only, amazon didn't break the non-US sales down by
region.
I guess it depends on what products you look at, you probably would have
to limit offline spending only to those items that are available online
(eg not include things like gas/petrol).
Date: 6 Apr 2011 05:21:33
Message: <4d9c309d@news.povray.org>
  The user manual of what?
  FAT32 has a file size limit of 2GB. (Well, technically speaking the hard
limit is 4GB, but if you exceed 2GB the system might start behaving in odd
ways with it. At least Windows does.)
  If what you are recoding is MPEG-2 or something like that, 2GB could hold
something like 30-60 minutes of video. I suppose that's not enough for some
applications (such as recording an entire feature length movie).
  The system not supporting formatting the external USB drive is just lazy,
though. Almost seems like they added the support just as an afterthought,
without investing much time on it.
  Not as bad as that one application where the developer thought the
progress bar is kind of like the hour glass icon, making it fill then
unfill, repeat.
Date: 6 Apr 2011 05:28:56
Message: <4d9c3258$1@news.povray.org>
Personally I would pay more attention to the actual user reviews from
people who have paid for the equipment and use it everyday, as opposed
to one or two guys who got it for free and used it for a couple of
evenings and probably only tried out 10% of the functionality.  Did they
even test out the external HD capability in their review?  If so did
they mention the problems you had?
Some appear to work better than others though (according to the reviews
I read), at least you know you bought the one with the fewest bugs :-)
Date: 6 Apr 2011 06:04:05
Message: <4d9c3a95$1@news.povray.org>
> region.
Right. So we don't know by what methods this data was collected then, or
how reliable it is.
Quite likely. I doubt many people buy food online. I'm having trouble
thinking of anything that more people buy online than offline. Computer
games maybe?
Hey, you can probably order that stuff online! :-D
Date: 6 Apr 2011 06:15:57
Message: <4d9c3d5d$1@news.povray.org>
Digital TV recorder.
I ran the "create partition" wizard a couple of times. If the partition
you tell it to create is larger than a certain size, FAT16 and/or FAT32
don't show up as options. But that size wasn't 4GB. I'm fairly sure it
was willing to let me format 100GB as FAT32. (Or was it 10GB? I don't
remember.) But it wouldn't format the whole 2TB. And if you've paid for
a 2TB drive, you wanna use it all.
(Maybe you could do multiple partitions, but I'm not sure how the device
would react. Besides, AFAIK ext3 is journalled, which FAT isn't, so
that's a worth while advantage right there. Especially for a device
which is likely to be shut down improperly!)
More like recording an entire series of a dozen different programs.
They already filled a 320GB drive, which I thought would take forever,
but apparently only took a few months...
Indeed. Especially when there *is* an option to format the internal drive.
Ditto for being able to copy multiple files, but not copy folders.
That's just lame.
> unfill, repeat.
Oh yeah, WTF is up with that? A progress bar is supposed to SHOW
PROGRESS. Far too many items of software these days don't bother to
compute actual progress, and just show you an indicator to make it clear
that progress is still happening (i.e., it hasn't locked up). That's a
useful thing to know, but it's much less useful than knowing how far
it's got.
On the other hand, there are applications that give time estimates, and
get them horrifyingly wrong: http://xkcd.com/612/
If instead of estimating how much *time* is remaining, you just tell me
how much *work* there is to do and how much is done, I could do the
estimating myself - and probably far more accurately than you.
Which brings us to those applications where progress rapidly fills from
0% to 99%, and then it sits there for 2 hours doing the last 1%...
Date: 6 Apr 2011 12:06:22
Message: <4d9c8f7e$1@news.povray.org>
More precisely, the file size limit on the file system is 4G, and some
implementations have bugs that limit it to 2G. :-)
Considering a FAT formatting routine is like 20 lines of C code, and if it
supports ext3 they already *have* the formatting routine.
Date: 6 Apr 2011 12:08:59
Message: <4d9c901b@news.povray.org>
*File* size.  The file size is recorded in a 32-bit integer in the
directory. It doesn't matter how big the drive is, but one file is limited
to 4G.
The best are the Windows file copying progress bars, which keep progressing
even when copying has stalled.
Date: 6 Apr 2011 16:52:13
Message: <4d9cd27d$1@news.povray.org>
> *File* size.
Oh, right, I see.
Yes, that could be a problem...
> progressing even when copying has stalled.
Ah yes! An activity indicator that doesn't even indicate activity. Pure
liquid evil! >_<
Date: 6 Apr 2011 22:17:31
Message: <4d9d1ebb@news.povray.org>
>>> buyer make an informed decision.
>> I agree.
Not doing it is guaranteed to have no affect on quality.  It isn't about
changing the manufacturer's process, it's about helping others make
informed decisions.  They can't use your opinion as part of their
decision making process if you don't share it.
Jim
Date: 6 Apr 2011 22:20:30
Message: <4d9d1f6e$1@news.povray.org>
>> shelf in an electronics store.
It depends.  If you purchase through, say, EMC, what you're paying the
'big bucks' for is the service contract, which in my experience is worth
its weight in gold - they consider a single reported *recoverable* bit
error on a drive in their cabinets as reason enough to replace the
drive.  The system calls them and a technician calls the named contact to
schedule the hot replacement of the drive that reported the error.
But such service certainly ain't cheap.  But their NAS devices are
*solid* and their service (again in my experience) is second to none.
Jim
Date: 6 Apr 2011 22:53:57
Message: <4d9d2745$1@news.povray.org>
> drive.
Google's whitepapaer basically said "Nothing says when a drive is going to
die, but you have a +30% chance of it dying in the next six months if you
get any read errors at all, recoverable or not."
In particular, all that S.M.A.R.T. stuff was stupid.
Date: 7 Apr 2011 01:43:29
Message: <4d9d4f01@news.povray.org>
>> they consider a single reported *recoverable* bit error on a drive in
>> their cabinets as reason enough to replace the drive.
> to die, but you have a +30% chance of it dying in the next six months if
> you get any read errors at all, recoverable or not."
I'd believe that - which is why for critical data, I'd prefer an
arrangement like the one my previous employer had with EMC to deal with
it.
Jim
Date: 7 Apr 2011 04:04:16
Message: <4d9d7000$1@news.povray.org>
> its weight in gold.
This is presumably why all Dell products are 7x the price of any other
supplier. Which would be great, if their service contract was worth its
weight in paper clips. But it isn't.
Hypothetically, in the event of a hardware fault, they're supposed to
come over here and fix it within 4 hours. In reality, in the event of a
hardware fault, THEY DO NOT GIVE A DAMN. They're just not interested.
You file a trouble ticket and NOTHING HAPPENS. You call them, they take
down all the details, and NOTHING HAPPENS. They don't lift a finger to
help you in any way at all.
Date: 7 Apr 2011 12:14:58
Message: <4d9de302$1@news.povray.org>
On 4/7/2011 1:04, Invisible wrote:
> Hypothetically, in the event of a hardware fault, they're supposed to come
It's not just Dell, either.  Sun did the same thing to us, back when a Sun
16-core machine cost $100K or so.  We had 24x7 4-hour replacement contracts,
as long as it didn't happen on a weekend and you were really close to where
the tech guy was already.
We had contracts on our stack of Dell machines, and they'd come out and fix
the stuff, but they'd come out pretty promptly, decide yes indeed it's
broken, and we'll expect the parts to arrive by mid next-week. And about
half the dell machines crapped out in the first 3 or 4 months, one way or
the other, with two or three being DOA.
Date: 7 Apr 2011 15:12:59
Message: <4d9e0cbb$1@news.povray.org>
Worrying, but not surprising.
> fix the stuff, but they'd come out pretty promptly, decide yes indeed
> it's broken, and we'll expect the parts to arrive by mid next-week. And
> about half the dell machines crapped out in the first 3 or 4 months, one
> way or the other, with two or three being DOA.
At least all our Dell stuff has had flawless reliability. Oh, except
that ancient tape robot that was out of warranty anyway...
Date: 7 Apr 2011 15:37:39
Message: <4d9e1283$1@news.povray.org>
>> worth its weight in gold.
My experience has differed.  I had a laptop (for example) in a class that
had a hard drive failure - I called Dell support and they overnighted me
a replacement hard drive so I could get the student working the next
day.  Not as good as "a tech is on the way", but we paid for overnight
service and got it.
Do you have an account manager with them?  I know some companies do have
service account managers/technical account managers (not sure what the
Dell analogue is), but if you are a named account for them, then you
should be able to escalate the issue, since that's what your company is
paying for.
And if you don't get what you're paying for, then it's time to look to
another supplier or to raise holy hell with the supplier you're dealing
with.
That said, I have heard that there are *huge* disparities in how Dell
deals with US customers vs. customers outside the US - so your issues
aren't unique to the best of my knowledge.
Jim
