POV-Ray : Newsgroups : povray.off-topic : The mysteries of Erlang Server Time
17 Oct 2026 14:59:08 EDT (-0400)
  The mysteries of Erlang (Message 1 to 29 of 29)
Subject: The mysteries of Erlang
Date: 9 Mar 2011 06:05:36
Message: <4d775f00$1@news.povray.org>
OK, so Erlang is something of an interesting case. There are several
reasons for this:
- There are many functional programming languages. (Haskell, OCaml,
Clean, and for some reason people keep calling Lisp "functional" too.)
However, Erlang is *the only* one that could be considered "commercially
successful", as far as I can tell.
- Other languages attempt to be *concurrent*, but only Erlang is
*distributed*.
- The system is supposedly insanely reliable. People toss around "nine
9s up-time" as if this is some sort of experimentally verified *fact*.
- The language claims to do all sorts of wacky, far-out stuff like
trivial concurrency and distribution, hot-swapping running code,
detecting and correcting run-time errors, and so forth. I want to see
how it's done.
I had a look at Erlang.org, but it's difficult to find anything that
really explains the interesting parts of the system. I can find plenty
of "Hello World" programs, and "this is how you run stuff remotely", but
nothing about "this is why we did it this way", or "this is how it
works" or "this is how to use it to build non-trivial applications".
Suffice it to say, from what little I could discover, I didn't like what
I was seeing. Like most commercially successful languages, Erlang is
obtuse, complex, ugly and kludgy. Much like C, Java or anything else
wildly popular. It's abundantly clear that Erlang is about as
"functional" as Lisp (i.e., not at all). Still, people claim that
Ericsson's entire business is based on it, and lots of people are using
it, so it must have got *something* right.
Eventually I discovered a file entitled Armstrong_theses_2003.pdf So I
spent the last two days reading this 300-page tome in the hope of
enlightenment.
Predictably, the author spends most of that page count either repeating
himself, or telling me in minute detail about things which are of
utterly no interest to me. However, I did learn some interesting things.
In a way, Erlang is a bit like Haskell: Fundamentally, it does something
extremely inefficient. And yet it seems to work just fine.
In Haskell's case, it's not allowing you to modify things in-place
(except under very controlled conditions). In Erlang's case, it's
refusing to allow processes to share state. This immediately implies
that if you want to send data from place to place, you must copy it all.
It's rather like Haskell's restriction, only much worse.
Then again, if one process is operating on a completely different node,
you are *forced* to copy data from place to place anyway. It is
unavoidable. So in a way, forcing you to do it all the time just makes
it that little bit simpler to move from local to distributed coding.
One thing that rapidly becomes clear (and doesn't seem to be mentioned
anywhere else) is that for Erlang, processes are about more than just
concurrency or distribution. They are about fault isolation. A
fundamental design assumption of the Erlang system is that stuff /will/
break, and /when/ it does, we want to maximally limit the damage. Part
of the philosophy is that if one process dies, it shouldn't hurt anybody
else.
Whereas in some other system you might structure things as separate
processes for increased performance or because it's more logical to
program it that way, in Erlang you might do this for no other reason
than the fact that one task can sensibly continue if the other fails.
You might use processes purely for error-handling reasons.
Another thing that becomes painfully obvious is that writing your
program in Erlang does not somehow magically make it reliable. The
language doesn't implement any kind of automatic error recovery system,
as you might be mislead to believe. Instead, Erlang provides more or
less the same kinds of error handling that any other language provides -
catch/throw, etc. You can nest exception handlers, re-throw or modify
exceptions, generate synthetic exceptions, and so on. And, as usual, any
uncaught exceptions at the "top level" just make the process die.
The difference is what happens when a process dies. Rather than just
dying, this situation is *detected*, and you can *react* to this. You
can make it so that related processes get auto-killed as well
(presumably because they can't sensibly complete without the dead
process), or you can make it send a notification to some monitor
process. The *language* itself allows notifications to be sent, but
nothing more. The *libraries* allow you to do sophisticated error
recovery, but *you* have to implement this. It doesn't happen by magic,
as many seem to suggest.
Very importantly, the system correctly handles things other than
software exceptions. Detecting division by zero is one thing. Detecting
that the machine in Australia that you were talking to just got hit by a
small pyroclastic flow is another. Obviously, no documentation actually
describes how this works.
So how does Erlang actually work then? I mean, you can create processes.
OK, then what? Well, as best as I can determine, each process has a
"mailbox", and you can send asynchronous messages to any process that
you have the address of. (And these messages can contain process
addresses.) This works the same way both locally and remotely.
Sending is a non-blocking operation. Receiving is a blocking operation,
and it makes use of Haskell-style pattern matching (which seems like a
rather neat fit here). You can also time out waiting for a message -
something which would be really hard to implement yourself, and which is
probably extremely important in networking code.
Message sending has the curious property that message delivery is /not/
guaranteed, but message ordering /is/ guaranteed. Like, WTF? I'm not
even sure how it's possible to tell that the messages are in order
without being able to tell if you got all of them, but whatever. Seems
very, very random to me. The thesis claims that implementing delivery
checks yourself is easy, but implementing ordering checks is very hard.
So they put the hard thing into the language, and left the easy thing up
to you if you need it. Um, OK?
One of the very trippy things about Erlang is that I can be sitting on
my PC in England, and I can just tell some Solaris server in Brazil to
spawn a new process. As expected, no word on how the hell this actually
works. I would have *thought* this means that the necessary code gets
beamed over the wire, but some documentation seems to suggest that you
have to install it yourself. And yet, you can apparently send arbitrary
functions as messages, so...?
There's also no word on authentication. I mean, how does the machine on
Brazil know that I'm authorised to be executing arbitrary code on it? My
best guess is that if you're a telecoms giant, you have a private data
network that nobody else can physically access, and you use that to
control your equipment. In other words, you're authorised if you can
actually access the system in the first place.
It's a similar story when we come to code hot-swapping. Surprise,
surprise, it turns out that you can't just magically hot-swap code, just
because it's written in Erlang. No, you have to do *actual work* to make
this possible.
The language itself allows two (and only two) copies of the same code to
be loaded at once, an "old" version and a "new" version. And it provides
a way to switch from one to the other for a specific process. And that's
*all* it gives you. Everything else has to be done, by hand, by you.
That means that you have to design your application so that there's some
sort of signal that you can send it which will make it switch to the new
version. So that takes care of your code, but what about your data?
Well, presumably your new code might have new data layouts or other
invariants, so you probably want to run some conversion function to port
the running environment to your new code.
In short, _you_ have to figure out how your new code is different from
your old code, _you_ have to write the code that converts any data
structures or establishes any new invariants, _you_ have to check that
this new code actually works properly, and _you_ have to design your
application in the first place so that you can tell it to switch to the
new code, running the conversion routine in the process.
And if you want to downgrade back to the old version? _You_ have to do
all the work for that too. Really, the only help that Erlang is giving
you is the ability to easily change from one chunk of code to another.
You could probably do the self-same thing in Java, if you built your
application so that every class has a version number, and there's some
way to tell the application to load a set of new class files and execute
a predetermined method on one of them. (I suspect Java's inflexibly type
system would probably whine though...)
Erlang really gives you no assistance at all beyond the minimal level of
"you can have two modules with the same name". And it's limited to just
two, by the way. If you try to load a third version, anything running
the first version is unceremoniously killed. And there's no mention of
any way to detect whether old code is still running. (Perhaps there is,
but I didn't see it mentioned.)
There was some talk of a packaging system, which sounds quite
interesting, but obviously no details are described. It talks about
being able to group modules into applications, and group applications
into releases which can have complex dependencies, build procedures and
installation processes. But... no details. So maybe it does
configuration management for you, or maybe it does very little to assist
you. I couldn't say.
The language itself has a few interesting features. Of course, being
designed as something easily parsable by Prolog, the syntax is utterly
horrid, it uses a kludgy preprocessor rather than actually supporting
named constants, and so forth. It's also dynamically typed, which some
people are presumably going to argue is somehow "necessary" because of
what it does. I can't help thinking that a powerful type system would
have made it /so much easier/ to make sure you got everything straight.
Just reading the document, I saw endless examples of data structures
who's meaning is ambiguous due to the lack of types. For example, it is
apparently impossible to tell the difference between a process that died
because of an exception, and a process which merely sent you a message
that happens to be a tuple containing the word "EXIT". The advice for
this presumably being "don't do that".
It's slightly bizarre. Erlang looks for all the world like a crude
scripting language with no safety at all and abysmal run-time
performance. And yet, the language is designed for running network
switches, possibly the most demanding high-performance hard-realtime
system imaginable, and people claim it has nine 9s up-time. The only
container types are linked lists and tuples, and yet the standard
libraries somehow include cryptography and complex network protocols.
Very odd...
So anyway, in spite of all the obvious bad things, there /are/ a few
interesting bits. You get Haskell-style pattern matching, but with a
twist. In Haskell, patterns are required to be "linear". (Don't you just
love how that single word is used to mean a million different unrelated
things?)
In Haskell, a variable is not allowed to appear twice in the same
pattern. If you want to things to be equal, you must bind them to two
different variables and then use a guard to check their equality. But
Erlang has no such limitation. It /automatically/ desugars a non-linear
pattern into a linear one with a guard. So there!
Erlang uses the rather baffling convention that mere variables start
with an upper-case letter, while proper nouns such as function names or
data points start with a lower-case letter. This makes it surprisingly
hard to read Erlang code. (Haskell, not to mention English, obviously
uses the opposite convention.)
I already mentioned that message receipt is by pattern matching. This
seems like a rather powerful way to work, especially considering that a
message that fails all patterns stays queued in the mailbox. So you can
actually use patterns to decide what order you want to process incoming
messages in. That seems quite sophisticated. And I already mentioned how
you can add a time-out as well, which is obviously a very frequent
requirement for hard-realtime systems.
In Haskell, general practise is to make all functions "total". In
particular, all pattern matching should cover every case if possible. By
contrast, apparently the general practise with Erlang is to /not/ cover
cases which aren't expected to occur, and just let the thing throw an
exception on a pattern-match failure. The rationale apparently being
that the automatically-generated exception string is just as descriptive
as anything that you could write by hand yourself, and it makes the code
less cluttered.
Certainly some people have a tendency to make their functions try to
return a valid result no matter how silly the inputs are. This is almost
certainly not the way to write reliable software. Myself I've always
thought that "***exception: Data.Map.lookup: key not found" is far more
informative than "***exception: Data/Map.hs, lines 12312-12315:
non-exhaustive patterns in case expression". In the first case, it's
instantly obvious what the problem is, and that the bug is likely to be
in the caller. In the second case... uh...?
Still, either way, if a key being missing is something that you're
anticipating, you can and should handle the exception in the caller (and
it won't matter what the text of the exception actually is). And if it's
a high-availability system, if the exception /is/ uncaught, you have a
program bug, and you probably want to log huge volumes of data about it,
/and then/ restart the thing ASAP before somebody notices it went wrong!
I read the part about "behaviours" and face-palmed. The idea is that the
standard library contains skeletons for things like "a server", and you
supply the body code that makes it "a name server" or "a unique ID
server" or whatever. Get this:
- The body code has to go in its own special module.
- The module has to export a specific set of functions with specific
names and specific numbers and types of arguments returning a specific
data structure as the result. (If only Erlang had type signatures, eh?)
- The skeleton passes an opaque "state" object between these functions,
which the functions can update.
What does that sound like to you? Yes, congratulations, you've just
invented object-oriented programming. But without dynamic binding or
inheritance. (Or static typing, for that matter.) A "module which
exports a special set of functions" is basically a *class*, and this
"threading opaque state from function to function" is basically a
stateful object.
Of course, modules don't have inheritance. That means that you can't use
an abstract class to define what methods a class is supposed to have. It
means you can't write a half-implemented class that other concrete
classes can inherit from. But it also means that you don't have to worry
about the nightmare of multiple inheritance either.
And there's another little twist: /Objects/ have state. But /functions/
passing around a mostly /immutable/ state gives the system a somewhat
functional flavour. Indeed, in one of the example programs, a function
receives some data, starts processing it, but if a certain condition
happens, it /reverts to the old state/ rather than keeping the new one.
This is jaw-droppingly hard to do if you use real objects with real
mutable state. But in a semi-functional approach, it's quite trivial.
This whole "module with special functions" monstrosity is all the more
weird because Erlang also has
1. first-class function names
2. lambda functions
Um, like, WTF? Why does the code have to go in its own module? Why can't
I just pass you a tuple of function names, or even lambda functions,
that define the callbacks? Hello??
One really neat feature of the language, which I didn't look into *too*
deeply, is the binary operators. Given that IP datagrams and so forth
are complicated assemblages of binary data fields with different
alignments and so forth, packing and unpacking binary data is kind of
crucial in networking code. Accordingly, Erlang not only allows you to
write binary literals, but to /pattern match/ on them. Eat that!
I didn't look at it too closely, but it looks quite neat. You write an
integer (or variable) followed by the number of bits. If you're packing,
the requested data gets put into the appropriate places. If you're
pattern matching, an integer obviously matches against that integer,
while a variable causes that many bits to be copied into the variable.
(I'm fuzzy on whether it becomes an integer or stays a binary...)
Not sure what happens if you need to write bytes backwards, as some
broken protocols and file formats require. Is there a directive for
that? Or do you have to do it by hand?
Many things about Erlang still remain unexplained. I still have
absolutely no clue WTF an "atom" is. Nor have I discovered what this
"OTP" thing that gets mentioned every 3 sentences is. I have utterly no
idea how the "registered process names" thing works. Erlang is supposed
to be for very high-performance systems, and yet to send any data from
one process to another you have to /copy/ it. It seems like that can't
possibly scale, but somehow it does. Apparently there's a distributed
database system written in Erlang, but I didn't find any mention of
that. And so on...
Still, I only have 1 PC, so what do I need distributed programming for? ;-)
Subject: Re: The mysteries of Erlang
Date: 9 Mar 2011 07:54:57
Message: <4d7778a1$1@news.povray.org>
Am 09.03.2011 12:05, schrieb Invisible:
> reasons for this:
That uptime claim is probably not based on reliability, but on the
ability to hot-swap code at runtime. Without such a feature, even the
most reliable computer system (hardware + software) will have
considerable downtime now and again just for the sake of updating the
software.
As for reliability, with Wings 3D being written in Erlang I'd say
apparently you can write unstable code in Erlang, too.
Date: 9 Mar 2011 08:10:43
Message: <4d777c53@news.povray.org>
It's probably based on what the system was *designed* to do, rather than
any *actual* measurement of its reliability.
> software.
Well, that's true enough. But Erlang is hardly the only system to allow
you to dynamically load code. Even C lets you do that, if you're
masochistic enough...
I didn't find Wings unstable. Incomprehensible, sure. But unstable? No,
not really.
Besides, writing unstable code is easy. It's writing *stable* code
that's hard. ;-)
Date: 9 Mar 2011 08:23:45
Message: <4d777f61$1@news.povray.org>
What you call "broken" is just a different convention: There is no such
thing as a "natural" byte order, unless you're really digging as deep as
the baseband level -  where it again breaks down to a convention issue,
because it depends on whether multi-bit values are sent MSBit first or
LSBit first.
Fun fact: The famous MSByte-first "network byte order" used in the
TCP/IP protocol family does /not/ match the bit ordering of the famous
Ethernet, which is LSBit-first. So if there is such a thing as a broken
protocol with regard to bit/byte ordering, TCP/IP-over-Ethernet is one
of them.
(That said, I guess a language that is deeply rooted in the world of
network protocols will have plenty of ways to deal with byte & bit
ordering.)
Date: 9 Mar 2011 13:22:03
Message: <4d77c54b$1@news.povray.org>
Having worked with Erlang, here's some comments.
Erlang isn't functional. It's single-assignment. The "functional" bit in
Erlang doesn't give you benefits like it does in Haskell because there's
still a whole bunch of non-functional operations. However, since you can
only assign to each variable once, it means you can't have loops and you
can't do a sequence of operations without making up new meaningless names
for the data at each step.
If it was *actually* functional, you could put your own functions in guards,
for example.
> *distributed*.
Yep.
It is. They've been running a commercial switching network with it for
something like 10 years, and one of the six data centers lost power or
something and all the machines in it for 20 minutes once, so they had a 15%
downtime for 20 minutes out of ten years.
> how it's done.
It's pretty straightforward. The rest is in libraries. The collection of
libraries that make it easy is called OTP. The documentation on OTP is
either non-existent or blows mooses, depending on what you can find.
Yes. It got the reliability right.
No, not true. Since the data is immutable, you don't actually need to copy
it if sender and receiver are on the same processor. It *acts* like it got
copied, but then "X = [5, Z]" acts like it copies Z into X also.
Except you're not really forced to copy stuff. And big things (like code or
large binaries) get allocated in their own heap anyway.
Indeed, that was the fundamental goal. Not distributed computing, but
reliable computing, however that may be achieved.
There are a handful of primitives that are reliable. You have to build
everything else on top of that. For example, the spawn-link function gives
you the basis for reliability, because there's no race condition between
spawning the new process and linking to its error messages.
> catch/throw, etc.
Huh. I didn't even know it provided catch/throw. I've never seen that used,
actually.
> process),
Yes.
OTP is the libraries that make it seem like magic. However, being typical
undocumented libraries that you learn by spending 5 years as an employee of
Erricson, written in a language so modular you can't even figure out what
pieces of code are part of the program and what aren't let alone read the
code to see what it does, I've never quite figured it out beyond the very
surface level.
There is documentation.
Each hardware box is running one interpreter, each of which is running one
thread per CPU. Each interpreter keeps a TCP socket open to all the other
interpreters it knows about, as well as sending periodic "are you there"
messages. That TCP socket is also used to send application-level messages to
remote processes. If the socket breaks, anything on the local system linked
to that socket gets a notification that it broke.
There's also a separate process running on each local machine that's
monitoring the local Erlang interpreter that will reboot the machine if the
local Erlang interpreter stops working. (For some definition of "working"
which isn't clear from the docs, but clearly includes answering keep-alive
probes.)
Yep.
Correct.
Message delivery isn't guaranteed because it's asynchronous, and the remote
machine may crash between the time you send the message and the time the
remote machine receives it. Ordering *is* guaranteed because if the remote
machine crashes before it gets message #5, it won't get message #6 either.
 > I'm not
You can't, but the *sender* doesn't know if you got them all. The receiver does.
Yep. Knowing if something is out of order is hard in a single-assignment
language. By the time you do the pattern match, it's too late to not get the
message out out of the queue. But the runtime can just look at the sequence
number of messages from that other machine and pretend the message didn't
arrive until the missing ones show up.
Given it all runs over TCP, tho, I don't think that's actually a whole lot
of trouble.
Knowing the receiver got the message is as simple as adding code to send an
ack each time you handle a message.
The functions are merely references to installed code. The code itself has
to already be in Brazil, and the function you send is "this module, this
name, this version".
There's a document out there somewhere that lists the binary formatting of
the contents of all the messages.
Starting the process remotely works because the local interpreter has (or
establishes) a TCP link to the remote machine. All the messages for all the
processes on your PC go over the same link to the machine in Brazil. There
isn't one connection per communicating process.
Nope, you're fucked.
Yes, exactly. Or you proxy the connection between machines through a VPN
with authentication. Basically, you secure it at the machine-to-machine
level, which is done outside of Erlang's source code and instead done at the
Erlang interpreter level.
> this possible.
Well, sure.
The two-versions limit is because the code itself isn't GCed. They document
that they could have GCed the code, but that would have added lots of
overhead for something relatively rare.
If you *really* need more than two versions, first move to a "new" version
that talks to one of N versions, then start up the N versions as appropriate.
Yep.
You'd have to be able to pass the network connections around too, remember.
There is, but it's deep in the bowels of "system" stuff.
The OTP system provides all the packaging and maintenance for the higher
levels of management. Complaining that Erlang itself doesn't automate such
stuff is like complaining that you need a Linux package manager because the
file system only knows about files, not applications. :-)
It does a bunch of stuff, including giving you ways to roll things forward
and back and such.
Realize that most of these "systems" you're talking about are actually
implemented as Erlang code. So, for example, to compile code, you actually
sit down at the REPL and invoke the compiler function. To package code, you
sit down at the REPL and invoke the packager function. To debug code, you
sit down at the REPL and invoke the debugging functions. Etc.
I agree about the syntax etc. It's quite possible a better type system would
make it easier.
You should also check out Hermes, which is essentially the same thing with
an astoundingly strict and high-level type system.  Indeed, Hermes is kind
of a high-level Erlang, in that you (for example) let the compiler/runtime
decide where to run the process and how many to create. You write a loop
that says "read a message, process it, send an answer, loop" and it gets
automatically parallelized. You write a process that says "read a message,
process, send an answer to where this message came from, exit" and it gets
turned into an in-line subroutine. Etc.
Well, it's possible unless you asked "turn all crashes from processes I'm
watching into EXIT messages."
> The advice for
No, this is actually more like "We did that on purpose in case you want the
supervisor to react as if you exited while you keep running." So, for
example, you can get the supervisor to spawn a new handler process while the
previous handler process rolls back the transaction that failed in *its*
child process or something.
> Very odd...
It's possible to link C (or anything else) into Erlang. The GUI for Erlang
launches a separate Tcl/TK process and talks over a socket to it to do the
drawing, for example.
In general, network switching isn't that hard real-time, because you usually
have custom hardware to do the switching. A 5ESS (which can handle up to
800,000 phone lines) runs on two 6800s, one of which is a hot spare. But of
course there's a large lump of hardware that's routing the individual bytes
here and there, so the 6800 only actually gets involved when you connect or
disconnect, basically.
Erlang is the only language I've found whose syntax sucks worse than C++,
yet it has way, way less built in than C++.
The primary problem, I think, is it started out as "let's investigate how we
can write a million lines of code that doesn't crash."  Of course, once you
have that million lines of code and it's running reliably, you're not going
to go back and fix anything as trivial as the syntax.
It's very handy, yes.
> less cluttered.
Well, that's not quite true for message pattern matching. For matching a
pattern against a value, yes. But if you don't read messages, you leave them
in the input buffer, which then grows and grows until you take out the
entire interpreter. Normally you'd find the place in your code where you
*think* you handled all the messages, and you'd put in a "if I match
anything else, crash out" branch to the pattern match.
A module is the granular unit of code update, so this makes sense.
There is that.
Yep.
> stateful object.
Yep.  Except since it's actually a separate process, it's called an "actor",
not an "object". :-)
No. You'd instead write something that invokes functions in a module whose
name you provided when you instantiated this module. There's actually even
syntax for this. You don't "inherit" but you can have essentially "abstract
modules."
> 2. lambda functions
Because then you can't update the module. One of the things OTP is providing
for you is the whole infrastructure for updating your module. That's why you
send the "state" back to OTP and why the code has to be in a separate
module. When OTP gets the "update" message, it invokes the new module with
the state.
They are pretty cool, yes. Handy, but I've seen it done better elsewhere. :-)
I think there is. Lots of stuff can come after a second colon to control
that sort of thing.
An atom is an interned string. Same as a "symbol" in LISP or Smalltalk. The
trick is that in a message, an atom is an index into the atom table, so it's
short regardless of how long the atom is.
It's the libraries that take the basic operations Erlang supplies (like
"load new code" or "spawn link") and turn it into things like installable
packages.
> I have utterly no
A process can say "My mailbox is the registered process on server ABC for
XYZ".  Another process can say "Give me XYZ@ABC" and get that mailbox. It
works by shchlepping non-Erlang messages between the erlang processes, just
like the keep-alives do.
 > Erlang is supposed
Not really.
Mnesia. They were originally going to call it Amnesia, but someone pointed
out that naming a database system after an illness characterized by
forgetting things is probably a bad idea.
It's a cute little system, but it has its flaws due to being implemented on
top of a single-assignment language and keeping everything in memory. For
example, if the node crashes and you have a gigabyte of data in the table of
that process, it has to go through reading all the logged updates and
applying them to the tree in memory before it'll actually start answering
queries. I guess if you can afford several machines running the same
database entirely out of RAM, it's not much of a problem.
It's basically a distributed transactional system on top of the built-in
database tables whose TLA name escapes me at the moment.
http://www.erlang.org/doc/man/mnesia.html
Note that all these things, OTP and Mnesia, along with stuff like the
compiler, the debugger, the profiler, the package manager, etc etc etc, are
all documented as "here's the functions you use to do it in Erlang." Almost
none of these things are actually command-line tools.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 9 Mar 2011 13:22:52
Message: <4d77c57c$1@news.povray.org>
It's both.
Yes. But Erlang gives you the tools to recover from the instability without
taking down the whole system.
     "That was fatal?"
Date: 9 Mar 2011 13:25:07
Message: <4d77c603@news.povray.org>
No, technically, it isn't C doing the dyanmic loading. :-)
In any case, the benefit that Erlang gives you in terms of dynamically
loading the code is (A) it's automatic, and (B) it lets the old code finish
up while the new code is running. It's like letting currently-running web
pages finish on the server while you're serving the new web pages to someone
else. Yeah, we pretty much can solve that now, but it was a necessary
component to the whole reliability enchalada.
     "That was fatal?"
Date: 10 Mar 2011 05:37:20
Message: <4d78a9e0@news.povray.org>
In what capacity are you "working with Erlang"? As I understand it, the
main selling points of the language are reliability and distribution.
While I doubt anyone actually *wants* unreliable software, there can't
be too many problems that require distributed programming.
> names for the data at each step.
Erlang is partially functional, in that functions are apparently
first-class, and it's got single-assignment and immutable data
structures. On the other hand, it doesn't enforce referential
transparency; you can put side-effects anywhere you like. The document I
read claims that it's considered beneficial to limit side-effects to
just a few places in the codebase, and write most of the code in a
"pure" style - which is exactly the same as for Haskell. It's just that
the language itself doesn't /enforce/ any kind of strong separation
between pure and impure code.
> guards, for example.
Wait - you *can't* do this already?? o_O
Why on earth would you design it this way?
> 15% downtime for 20 minutes out of ten years.
One data point is scientific fact?
Yeah, as I quickly found out.
> The collection of
Just like Haskell, then. :-}
> copy it if sender and receiver are on the same processor.
OK, fair enough.
(Presumably both processes have to be running within the same logical
"node", but then again also presumably you wouldn't have more than one
node on the same box except for test purposes anyway...)
As I say, this doesn't really seem to be spelled out anywhere else that
I could find, and it seems a rather crucial detail.
>> - catch/throw, etc.
> used, actually.
Yeah they do. It's in there. Apparently the catch functions turn an
exception into a tuple begining with 'EXIT' and followed by some stuff.
Using throw you can make catch return an arbitrary data structure.
(Quite how you tell the difference between an exception and a normal
result is left to the imagination... It looks like you can use throw to
make it look like the catch block exited normally.)
> typical undocumented libraries that you learn by spending 5 years as an
> employee of Erricson, written in a language so modular you can't even
> figure out what pieces of code are part of the program and what aren't
> let alone read the code to see what it does, I've never quite figured it
> out beyond the very surface level.
I'm glad it's not just me...
> one thread per CPU. Each interpreter keeps a TCP socket open to all the
> other interpreters it knows about, as well as sending periodic "are you
> there" messages. That TCP socket is also used to send application-level
> messages to remote processes. If the socket breaks, anything on the
> local system linked to that socket gets a notification that it broke.
> the local Erlang interpreter stops working. (For some definition of
> "working" which isn't clear from the docs, but clearly includes
> answering keep-alive probes.)
Right. So it just sends heartbeat messages? (I presume the bit about
rebooting the machine is optional; you wouldn't want your PC to reboot
just because Wings 3D crashed, for example.)
>> /not/ guaranteed, but message ordering /is/ guaranteed. Like, WTF?
> remote machine may crash between the time you send the message and the
> time the remote machine receives it. Ordering *is* guaranteed because if
> the remote machine crashes before it gets message #5, it won't get
> message #6 either.
You mean that if message #5 doesn't arrive, message #6 is actually
guaranteed not to arrive?
>> hard. So they put the hard thing into the language, and left the easy
>> thing up to you if you need it. Um, OK?
> language.
OK...
> lot of trouble.
TCP guarantees both delivery and ordering. Unless the connection
actually breaks. So is that all Erlang is saying? That it if one of the
machines catches fire, Erlang can't guarantee that messages will be
delivered to it?
These people are /serious/ about reliability. o_O
> an ack each time you handle a message.
Network protocols 101: It's not that simple. It is possible for the
message to arrive, but the acknowledgement itself to fail to be delivered.
Now, if you're running on TCP, so that ordering and delivery are
guaranteed (unless there's no transport or no endpoint), the only way
this can happen is if the transport or the endpoint dies after the
message is received, which is probably just as bad as the message not
being delivered...
>> actually works. I would have *thought* this means that the necessary
>> code gets beamed over the wire, but some documentation seems to
>> suggest that you have to install it yourself. And yet, you can
>> apparently send arbitrary functions as messages, so...?
> has to already be in Brazil, and the function you send is "this module,
> this name, this version".
I did think for a moment that you could send a function this way. Once
you've compiled your module, every lambda function it contains must
already exist in the compiled code somewhere. High-order functions make
the program more complicated, of course. You can't necessarily point to
just *one* function. It might be that you call several functions to
construct the final function object. But even that is likely to be more
compact than the actual executable code.
Thing is, I can open the REPL and type in a function, and then ask to
spawn that on a remote node. How does *that* work?!
> of the contents of all the messages.
I'll bet. No doubt somebody has written libraries for other languages to
speak the same wire protocol.
> (or establishes) a TCP link to the remote machine. All the messages for
> all the processes on your PC go over the same link to the machine in
> Brazil. There isn't one connection per communicating process.
Given that Erlang supports creating billions of processes and there's
only a few thousand possible TCP ports... yeah, I figured that's how it
would work.
I notice that connecting one Erlang node to another causes the two nodes
to connect to *all* the nodes that each endpoint knows about. I'm not
actually sure why though. You would think that a fully interconnected
mesh would quickly exhaust the supply of TCP ports too.
>> on Brazil know that I'm authorised to be executing arbitrary code on it?
> Yes, exactly.
Ouch.
>> just because it's written in Erlang. No, you have to do *actual work*
>> to make this possible.
> Well, sure.
You say "sure", but the documentation sings about how reliable Erlang is
and makes it sound like all this stuff just happens by magic, because
Erlang is so wonderful. The truth is actually that Erlang just
implements the minimal features required to let _you_ build complex,
robust, distributed applications.
> document that they could have GCed the code, but that would have added
> lots of overhead for something relatively rare.
Fair enough.
>> application so that [...]
You'd have to be able to do a lot of things. It would require careful
application design, but it doesn't look especially difficult. (To get
the framework done, anyway. Making the application itself sounds really
hard, in Java or Erlang.)
>> of "you can have two modules with the same name". And it's limited to
>> just two, by the way. If you try to load a third version, anything
>> running the first version is unceremoniously killed. And there's no
>> mention of any way to detect whether old code is still running.
>> (Perhaps there is, but I didn't see it mentioned.)
> such stuff is like complaining that you need a Linux package manager
> because the file system only knows about files, not applications. :-)
I don't mind which level the assistance is implemented at, just so long
as there *is* some. ;-)
> forward and back and such.
Yeah, that's what I figured. Handling this stuff manually for more than
a few dozen nodes sounds like the exact opposite of "reliable".
Hey, it worked for Smalltalk. ;-)
> actually sit down at the REPL and invoke the compiler function.
I wish the Haskell compiler could do this...
> would make it easier.
Escaped experiment, eh? ;-)
> with an astoundingly strict and high-level type system.
Heh, there is never enough free time. ;-)
>> is apparently impossible to tell the difference between a process that
>> died because of an exception, and a process which merely sent you a
>> message that happens to be a tuple containing the word "EXIT".
> I'm watching into EXIT messages."
The advice presumably being that workers should only receive "real"
messages, and supervisors should only receive exceptions. Then there can
be no ambiguity. (Until the supervisor's supervisor asks it to do
something...)
Actually, that's a point. Each process has *one* mailbox. Not one
mailbox for each process it's communicating with. Just *one*. So you
have to manually figure out who each message came from - usually by
having the sender put a reply address in manually.
>> The advice for this presumably being "don't do that".
> the supervisor to react as if you exited while you keep running."
To quote the document, "it's a feature, not a bug!"
>> Very odd...
> Erlang launches a separate Tcl/TK process and talks over a socket to it
> to do the drawing, for example.
So you're saying that all the "interesting" stuff like the SSL
implementation is actually just an off-the-shelf C library?
I never did understand what's so great about Tk. It looks horrid, it's
really hard to use, and it's almost impossible to get the layout you want...
> usually have custom hardware to do the switching. A 5ESS (which can
> handle up to 800,000 phone lines) runs on two 6800s, one of which is a
> hot spare. But of course there's a large lump of hardware that's routing
> the individual bytes here and there, so the 6800 only actually gets
> involved when you connect or disconnect, basically.
Wait, a 6800? As in, the chip *before* the obsolete 68000?
Damn. If the actual switching is in hardware, that the heck do you need
the CPU for at all?
> C++, yet it has way, way less built in than C++.
Erlang: 0wned.
> how we can write a million lines of code that doesn't crash." Of course,
> once you have that million lines of code and it's running reliably,
> you're not going to go back and fix anything as trivial as the syntax.
Yeah. It's an escaped experiment. And now it's too late. TOO LATE!!! >_<
Actually, one of the reasons I wanted to learn about Erlang was to see
if I can design something that does the same thing, but isn't insane.
>> By contrast, apparently the general practise with Erlang is to /not/
>> cover cases which aren't expected to occur, and just let the thing
>> throw an exception on a pattern-match failure.
> them in the input buffer, which then grows and grows until you take out
> the entire interpreter. Normally you'd find the place in your code where
> you *think* you handled all the messages, and you'd put in a "if I match
Well, yeah, I meant for pattern matching against a value. Receiving
messages as a bit special.
> "actor", not an "object". :-)
That's possibly the most irritating thing about the gen_server example.
It explains what each line of code is doing, but neglects to mention the
fact that one half of the code is potentially running on another
continent to the other - which, let's face is, is the entire point of
making *remote* procedure calls. :-P
> whose name you provided when you instantiated this module. There's
> actually even syntax for this.
Yeah. It's just a tiny bit more work, that's all.
>> 2. lambda functions
>> can't I just pass you a tuple of function names, or even lambda
>> functions, that define the callbacks? Hello??
> providing for you is the whole infrastructure for updating your module.
> That's why you send the "state" back to OTP and why the code has to be
> in a separate module. When OTP gets the "update" message, it invokes the
> new module with the state.
OK. So that's why the state is explicitly threaded (quite apart from
Erlang apparently having no other way to handle running state). That
still doesn't explain why I can't put several related behaviours into a
single module. Perhaps I *want* to replace them all at the same time.
> The trick is that in a message, an atom is an index into the atom table,
> so it's short regardless of how long the atom is.
I never really understood what an interned string is. (And hence what
the difference between a Smalltalk string and a symbol is.)
So you're saying that the compiler replaces all occurrences of an atom
with a pointer to a single instance of the string? (And hence, you can
compare atoms for equity by simple pointer equity rather than string
comparison.)
>> Nor have I discovered what this "OTP" thing that gets mentioned every
>> 3 sentences is.
> installable packages.
Right, OK. So what does it mean when they say "the compiler is an OTP
application"?
>> I have utterly no idea how the "registered process names" thing works.
> for XYZ". Another process can say "Give me XYZ@ABC" and get that
> mailbox. It works by shchlepping non-Erlang messages between the erlang
> processes, just like the keep-alives do.
OK, so, I can register a PID with a particular name. Is that name local
to just that node? Does every node in the system know about it? How do
you avoid registering a name that some unrelated application has already
registered? If I ask for a particular name, how does it figure out which
node that's on? If a node goes down, does the name get taken out of
service? How do you handle the same service being available from several
nodes? (For load-balancing or fault tolerance, perhaps.)
>> Erlang is supposed to be for very high-performance systems,
> Not really.
Hmm. It certainly seems to be.
>> Apparently there's a distributed database system written in Erlang,
> pointed out that naming a database system after an illness characterized
> by forgetting things is probably a bad idea.
The name still looks wonky to me. ;-)
> on top of a single-assignment language and keeping everything in memory.
Hmm. Sounds... fun.
Right.
> are all documented as "here's the functions you use to do it in Erlang."
> Almost none of these things are actually command-line tools.
Nothing wrong with that. The question is how much detail the
documentation explains. ;-)
Subject: Anmesia
Date: 10 Mar 2011 05:59:48
Message: <4d78af24$1@news.povray.org>
> It's a cute little system, but it has its flaws.
An object/relational hybrid "suitable for telecommunications applications"?
It says it has "extremely fast real-time searches", but it also says
that the query language is "an add-on library"?
Reading the rest of the documentation just made my head hurt. I
particularly love how a "table" can be "set", "ordered set" or "bag",
but only the first and last option are explained.
A reference manual is no way to learn how to use a complex system.
Date: 10 Mar 2011 12:54:52
Message: <4d79106c$1@news.povray.org>
I'm not, currently.
Unless you want to listen to radio stations in several different cities and
integrate the results. Altho I wound up writing my own stuff for that and
not using Erlang, that was the experiment.
> structures.
Functions in C are first class. That doesn't mean it's functional. The
immutable data structures come from the single-assignment, except where the
data structures aren't immutable, of which there are several.
Well, that's the killer. To me, if every statement can have side-effects,
then it's not a functional language. It's just single-assignment. You have
none of the benefits and all of the draw-backs of a functional language in
Erlang.
 > The document I
Except that message sending and message receiving are both side-effects as
is spawning or linking another process, so that works pretty poorly. Plus,
as I said, having the side-effects means you cannot (for example) use your
own functions in guards. Essentially, nothing is actually functional in the
language *except* assignment and a handful of built-ins. (Not even all the
built-ins, for that matter.)
For some reason, the Erlang enthusiasts think the crappy syntax and the
single-assignment procedures are intentional and beneficial properties of
the language. Like any niche language, the fanboi's refuse to accept that
any compromise was made during its design.
Because your own functions aren't referentially transparent, because the
language isn't actually functional, even at that level. The functions in a
guard are the ones that *are* functional. Not even all the built-in
functions can go in guards.
Actually, in the documentation, I think there's a note on each built in
function that says whether you can use it in a guard or not.
It's a scientific fact that you can achieve nine 9's of uptime over the
course of a decade with programs written in Erlang, yes.  Pretty sure that's
really, really hard to do with any other programming language.
You start up the run-time with a command-line argument that says "Hey, I'm a
node in a distributed program". Wings3D doesn't do this, so it's not a node.
It's kind of in all the books and stuff. I think the PhD thesis is presumed
required reading, if nothing else.
>>> - catch/throw, etc.
>> used, actually.
Ah, I see. Yes, I had forgotten about that.
Well, an exception will start with EXIT, while a regular result is unlikely
to, unless you specifically confuse things that way.
Yes. Basically, it lets you return early.
Yes, it's a separate monitor process. It sends heartbeats as well as watches
for a couple other simple things.
>> message #6 either.
If message #5 didn't arrive because the receiving machine crashed, yes,
message #6 isn't going to be received either. If message #5 didn't arrive
because the network switch died, then #6 isn't going to be delivered either.
> delivered to it?
Yes, exactly.  More precisely, you can't tell if the message was received
and processed or not.
Well, yes, that's how you get 5 minutes of downtime over the course of 10 years.
If the ack fails to be delivered, it's because the receiving machine (nee
sender) has crashed and hence doesn't need to see the ack.
Well, not quite. If the network between the machines dies, each machine is
going to think the other crashed. This makes a mess. Mnesia has all kinds of
crap in place to recover from this, especially given that you might make
independent updates to the same table in two places.
> being delivered...
Right. The point of their warning is, you have to deal with messages not
making it one direction or the other. You don't have to deal with the
messages being out of order. You have to deal with the fact that if you tell
a remote machine to do something, it might not happen. You don't have to
deal with the fact that if you tell a remote machine to do two things, it
might do them in a different order.
Hmmm. Actually, I think perhaps it *is* willing to ship functions around.
The details escape me at the moment. Maybe you can send functions but not
modules? I don't honestly remember.
I don't know. Probably, but I'm not sure why you would.
Yes, unless you tell it not to.
> I'm not actually sure why though.
Reliability. ;-)
Unless you have more than 50,000 machines, unlikely.
>> Yes, exactly.
> Ouch.
One of the OTP functions shows how to authenticate and encrypt the
connection en Erlang code, IIRC. That's also one of the tutorials.
Imagine a room full of a few thousand processors. One outgoing internet
connection running thru a firewall that's happy to VPN anything going out to
a known location, and which drops anything going in or out from an unknown
IP.  Why encrypt everything?
Actually, I had forgotten. There is a "cookie" you can set, and anyone
connecting needs the same "cookie". So there is a minimal security level,
not unlike the similar feature in X servers.
What, you're believing fanboi's?
If you want the version that actually *does* magically distribute and make
reliable your code, you want to read about Hermes, a language designed by Strom.
> Fair enough.
Plus, you should be dealing with the occasional "process suddenly ends for
no reason" exception robustly anyway. :-)
Heck. Honestly, you can do it in Ada.  Ada has facilities for declaring some
library code as capable of being hot loaded and unloaded.
I found it annoying that there's no global roadmap. So you read about
something and it says "If X happens, a message is sent to the error logger."
  WTF is the error logger? Where's the documentation. Then you track that
down, and it's all talking about bits and pieces that are also not
documented, etc, with the assumption that you have a bunch of people who
wrote the error logger hanging around to tell you how to find where the
errors got logged and such.
Yeah, basically the same idea, except instead of an "image" you actually
have a bunch of running processes.
That's exactly what it was. Except that by the time it escaped, there were
millions of lines of production code written in it, so you couldn't even
reasonably fix it.
I don't think the book is available any more, either. I should scan mine.
> something...)
Well, more like, normal worker processes shouldn't communicate with messages
that start with the atom "EXIT". It's not that hard. It's like saying "don't
make closing the TCP connection the confirmation."  There's only one or two
patterns that the error messages use. You shouldn't use "Close" as the name
of the routine to invoke when you want your object to keep running, either.
Yep.
Hermes gives you as many mailboxes as you want, with as many connections to
each mailbox as you want, and you can send both connections and mailboxes in
messages to other processes. So if you want hot-swap code, write your
processes as being capable of packaging up its mailboxes and sending them to
a new process.
It's possible.
> want...
Well, no, it's really easy to use, it's easy to get a good-looking layout,
and it only looks horrid because it looked cutting-edge 10 years ago and
nobody ever improved the look of it since then. (Altho they've worked on
that more lately.)
That's exactly why half a dozen non-Tcl languages actually went so far as to
embed a Tcl interpreter into their code in order to be able to use Tk. I'm
pretty sure it's not Tk that's at fault here. ;-)
Yes.
> the CPU for at all?
For deciding what to connect. You pick up the phone? The 6800 connects your
phone to the dial-tone generator. It's not sitting there generating the
waveform in software. You push a button? The 6800 routes your line to the
DTMF decoder, which signals the 6800 each time you let go of the tone. When
you've dialed enough numbers, the 6800 figures out what line you're supposed
to connect to and plugs you through.
Check out Hermes first. :-)
Right.
I don't know. Go work for Erricson. ;-)
I explained this for Warp a couple weeks ago. An interned value is a
reference value where reference equality equals value equality.
Or, in normal speak, an interned string is one where there's only one copy
of any given string, so you can compare the addresses where two strings are
stored and tell if they're equal.
In Erlang, you can think of an atom as one element of a giant global enum of
all the atoms you've ever used in your program. It's nothing more than an
index into a table that happens to be readable.
> comparison.)
Basically, that's what an interned string is. An "atom" is implemented as an
interned string, but it's syntactically different. It's ... an atom. It's a
string treated as a single atomic value. You can't ask for the third
character of an atom, for example.
>>> 3 sentences is.
> application"?
It means the compiler is a function in the OTP libraries that you invoke in
order to compile the code.
I don't remember all this stuff. Registering as a known name passes your
mailbox and the name to a process that proceeds to distribute it and answer
queries about it. You can look at the documentation for it to see what it does.
> Right.
ETS is the name of the sub-system functions.
The other problem is that all the documentation assumes you've read the
previous documentation and knows what they're talking about, but it doesn't
actually give you pointers to any of the previous documentation.
So if you want to use mnesia, you read mnesia, but it assumes you know what
ets and gen_server are and etc. So mnesia will have a function and say "this
only works on ram_raw tables" or "that function starts a new server" and
assume that you know "ram_raw" is something that ets implements (not Mnesia)
and that a 'server' in this context specifically means a gen_server module.
You'd like mnesia, tho. It's a lot like STM in some ways.
     "That was fatal?"
Subject: Re: Anmesia
Date: 10 Mar 2011 12:59:59
Message: <4d79119f$1@news.povray.org>
By which they mean reliable, distributed, fairly fast, keeps everything in
RAM, and expects to run continuously, but which there aren't going to be any
ad hoc queries.
I guess it's extremely fast real-time searches *if* you know exactly what
you're going to search for. Otherwise, it does a full table lock-and-scan
without any optimization. And you have to maintain your own indexes, so
after you insert the record into the table, you have to insert the key into
each index as well.
The query language isn't the functions used to access the tables. It's sort
of like saying "We have really fast loops and comparisons. List
comprehensions are an add-on library."
That's exactly what I'm saying. You're expected to know that "set" and
"ordered set" and "bag" are the three different types of ets tables, and go
read the ets documentation to figure out what that is.
In this case, the other choice is to go work for Ericson, it seems.
     "That was fatal?"
Date: 10 Mar 2011 14:32:55
Message: <4d792767$1@news.povray.org>
the real mistery of Erlang is the name:  at first I thought it was for
"Ericsson Language".  But then I heard they were actually paying homage
to one of the pioneers of traffic engineering and related telophony techs:
http://en.wikipedia.org/wiki/Agner_Krarup_Erlang
a game sig: http://tinyurl.com/d3rxz9
Date: 11 Mar 2011 03:58:43
Message: <4d79e443$1@news.povray.org>
The real mystery of Erlang is that it was *banned* from Ericsson at one
point...
Date: 11 Mar 2011 05:10:11
Message: <4d79f503@news.povray.org>
>> structures.
In C it's not especially easy to write a half-line anonymous function
and pass that as the argument to something. In fact, function pointers
are probably the number #1 thing about C that I can't figure out how to
work, but presumably this only affects me...
> The
> the data structures aren't immutable, of which there are several.
I wasn't aware that there are any mutable data structures. Then again, I
read an introductory design document, so...
> side-effects, then it's not a functional language.
Depends on your definition of "functional". Some people say that
first-class functions is the definitive thing. Others claim it's
referential transparency. A few people even claim it's the type system
or the syntax...
> You have none of the benefits and all of the
> draw-backs of a functional language in Erlang.
Awesome.
>> The document I
> as is spawning or linking another process, so that works pretty poorly.
The guy goes on to point out that by using gen_server, your code has no
explicit message passing or process linking at all, and this is an
extremely awesome thing because it means that your own code is free of
side-effects.
> Plus, as I said, having the side-effects means you cannot (for example)
> use your own functions in guards.
Oh... my god.
> of the language. Like any niche language, the fanboi's refuse to accept
> that any compromise was made during its design.
I'm not sure a language with multi-billion lines of code in
mission-critical production applications can be considered "niche".
Fail.
> that's really, really hard to do with any other programming language.
Do we know that it isn't really, really hard to do in Erlang too? I
mean, one system did it, but how much time, money and effort did they
throw at the problem?
Now show that using something other than Erlang would have required
/more/ time, money and effort, and we have something resembling a proven
fact. ;-) Now repeat this for more than one system...
>> that I could find, and it seems a rather crucial detail.
> presumed required reading, if nothing else.
"The" PhD thesis?
> unlikely to, unless you specifically confuse things that way.
It just looks like the sort of thing I might do by mistake, spend 20
minutes wondering why my application is acting screwy, and then have a
little facepalm moment.
(E.g., one time I was building a Smalltalk application, and I wanted
certain building blocks of the application to have names that would
display on the screen. Obviously the name of a FirstOrderFilter doesn't
change for each instance, so I added a class method called #name... All
kinds of fun erupted after that. Eventually I discovered that the Class
metaclass already /has/ a #name method, or something like that. Ouch!)
> arrive because the network switch died, then #6 isn't going to be
> delivered either.
Presumably if the link dies and then comes back, or any other
combination of circumstances, either the TCP link is still alive (in
which case it resents #6 *and* #5), or the link has been broken (in
which case neither message arrives).
OK.
> 10 years.
Some people might refer to that as "luck". ;-) Apparently there are
Windows 95 systems with this kind of uptime.
> is going to think the other crashed. This makes a mess.
"Ow, I don't care *what* universe you're from, that had to hurt!"
> around. The details escape me at the moment. Maybe you can send
> functions but not modules? I don't honestly remember.
Or maybe if you do this, it just tells you to sod off. I don't know...
>> to speak the same wire protocol.
There are libraries that implement BEEP, even though nobody ever uses
it. I'm *sure* there are libraries for a massively successful thing like
Erlang. ;-)
> Reliability. ;-)
In what way is this more reliable?
>> You would think that a fully interconnected mesh would quickly exhaust
Hmm, yes. The number of links rises exponentially, not the number of
links per node.
> level, not unlike the similar feature in X servers.
And the "cookie" is presumably sent unencrypted from node to node when
they try to connect too.
BTW, how do you identify a remote node? Is it just by DNS name or IP
address or something?
Doesn't everything? ;-)
>> Fair enough.
> for no reason" exception robustly anyway. :-)
Layers within layers of crash recovery... :-}
> logger." WTF is the error logger? Where's the documentation. Then you
> track that down, and it's all talking about bits and pieces that are
> also not documented, etc, with the assumption that you have a bunch of
> people who wrote the error logger hanging around to tell you how to find
> where the errors got logged and such.
An error logger where you can't find the log? Oh, that's epic! :-D
Honestly, I thought only Haskell does this kind of stupidity...
(Yesterday, the new version of the Haskell Platform was released. Which
is just as well, because the home page has been saying that the next
release is due in "January 2011" for several months now.)
> were millions of lines of production code written in it, so you couldn't
> even reasonably fix it.
Well, you can do syntax changes with a conversion program. But
large-scale language changes? No, not really, no.
>> can be no ambiguity. (Until the supervisor's supervisor asks it to do
>> something...)
> messages that start with the atom "EXIT". It's not that hard.
It looks like the sort of mistake I would eventually make, and then
spend a seriously long time trying to debug. Maybe being all upper-case
is enough to prevent this, I don't know...
> to each mailbox as you want, and you can send both connections and
> mailboxes in messages to other processes. So if you want hot-swap code,
> write your processes as being capable of packaging up its mailboxes and
> sending them to a new process.
OK.
> It's possible.
What, you mean you don't *know*? Isn't this *documented* somewhere? ;-)
>> want...
> layout, and it only looks horrid because it looked cutting-edge 10 years
> ago and nobody ever improved the look of it since then. (Altho they've
> worked on that more lately.)
> as to embed a Tcl interpreter into their code in order to be able to use
> Tk. I'm pretty sure it's not Tk that's at fault here. ;-)
That's like saying "C is a fantastic language, it's really easy to use,
and that's why 90% of all software ever written uses it. I don't think C
is at fault here."
>> need the CPU for at all?
> your phone to the dial-tone generator. It's not sitting there generating
> the waveform in software. You push a button? The 6800 routes your line
> to the DTMF decoder, which signals the 6800 each time you let go of the
> tone. When you've dialed enough numbers, the 6800 figures out what line
> you're supposed to connect to and plugs you through.
That's seriously the only reason why it has a Turing-complete processing
unit inside it?
Man, you would have thought QBASIC would be enough for _that_ level of
functionality...
Worst FAQ answer *ever*! :-D
> in order to compile the code.
FWIW, I wish more languages were implemented like this...
(I'm just bitter because I spent yesterday trying to figure out how to
get GHC to compile and optimise some source code, and then give me the
AST. Which I managed, BTW, but trying to figure out WTF the AST actually
means? Ugh!)
At this point, I don't hold out a lot of hope... o_O
> doesn't actually give you pointers to any of the previous documentation.
I hate that. The Oracle documentation is like this too. Even the
chapters in a single document refer to things out of sequence. Like, in
chapter 1, it uses technical terms that aren't explained until chapter
2, and chapter 2 uses things that were explained in chapter 1, but the
explanation in chapter 1 doesn't make sense until you read chapter 3
anyway. WHO WROTE THIS CRAP?!
Still, it could be worse. Consider the following quotation from one of
the Haskell standard libraries:
http://www.haskell.org/ghc/docs/6.6/html/libraries/mtl/Control-Monad-Writer.html
"Inspired by the paper Functional Programming with Overloading and
Higher-Order Polymorphism, Mark P Jones (http://www.cse.ogi.edu/~mpj/)
Advanced School of Functional Programming, 1995."
(Notice that the URL no longer exists.)
I emphasise: /standard libraries/. Not even some exotic add-on library.
One of the base libraries that comes with the compiler. And there's not
one single line of human-written text on that page, beyond the reference
to the paper where this stuff is actually explained.
Except the part where there's at least 3 extensive yet readable
technical introductions to what it does, why you'd want that, and how
you use it, with full example source code and explanations. ;-)
Date: 11 Mar 2011 12:26:30
Message: <4d7a5b46@news.povray.org>
I didn't say it was convenient. I said it was first class.
ETS and the process dictionary both spring to mind.
> or the syntax...
I can't think of any language nowadays that doesn't have first class
functions. COBOL and FORTRAN, maybe, but that's about it.
I've never heard "functional" actually mean anything except "what you write
is functions", as in, mapping inputs to outputs. Anything mutable makes it
non-functional.
> side-effects.
Yes. gen_server separates out the functional part from the non-functional
part. But that doesn't give Erlang itself any benefits. No doubt functional
programming is easier to debug. You just have to manually separate it out
from the rest of the non-functional stuff.
> Oh... my god.
Yes, exactly. Still think it's functional?
It's niche, as much as formula-1 race cars are niche cars in spite of being
famous and wildly expensive. ERlang's niche is telecom programs that run for
decades without crashing.
Well, let's rephrase that. It's certainly easier in Erlang than it would be
in straight C. :-)
Look up the history of NIL. Then look up the history of Hermes. Now you have
three similarly-organized systems that all show you can run long-term
mixed-developer systems reliably by using these techniques.
Do you think Ericson had *not* been trying to come up with this system
before they wrote millions of lines of code in it? Do you think they
wouldn't have started using a different system if Erlang didn't give them
the benefits they expected?
> "The" PhD thesis?
Armstrong's PhD thesis.
I didn't use Erlang very much, and it never occurred to me to use an atom in
all upper case, let alone one that says 'EXIT'.
Name clash of methods? Sure. Name clash of values you're returning against
the three or four already-defined values? No. Treat it as a reserved word.
This is exactly why so many messages returned start with "ok".
Yes.
No there aren't. All the 16-bit Windows machines had a seconds counter that
wrapped after 42 days and crashed the computer.
> it.
Actually, I'm rather surprised at the number of people who use
syslog-reliable (which runs over BEEP) let alone BEEP itself. What makes you
think nobody uses BEEP?
>> Reliability. ;-)
If you lose a connection to a node, you can ask the other nodes if they lost
a connection too, for one thing.  And if A connects to B, then B passes a
connection to C to A, A needs a connection to C anyway. You don't want to
wait till that point for A to find out it is firewalled from C.
No, the cookie doesn't get sent at all.
http://www.erlang.org/doc/reference_manual/distributed.html#id80719
The documentation *is* online.
Incidentally, NIL worked it where you declared which processes were a group,
and you could kill them off or roll them over as a group. So you didn't have
the problem of one module being upgraded while another module isn't.
I'm sure you can find it if you can figure out which module it talks to. But
it's like .NET, where debugging output goes to the configured output
methods, and if you haven't configured them, it disappears. If you're used
to (say) C's assert() macro, finding out you have to configure where assert
messages go on a run-by-run basis is rather disconcerting if you didn't even
think to look.
Why do you make mistakes like that?  How often do you write code and use
reserved works as variable names?
It's in the source code. Welcome to open source!
> is at fault here."
No, because there really wasn't much of an alternative to C for many years.
People tried many alternatives, and they all sucked so bad they never really
got out of the lab. So clearly C is doing something right.
> unit inside it?
I don't know what else it does. Billing records, managing the configuration
changes, etc. The point is it's not switching individual voice packets, any
more than your CPU is getting involved in deciding which ethernet packets
going past are addressed to the machine the ethernet card is plugged into.
Well, that's the next version of .NET.  I think it's cool. I wish people who
weren't using Microsoft could use it as easily.
> means? Ugh!)
Erlang can hand you the AST for you to run macro preprocessign on at compile
time. (That's how records work, for example.) You think figuring out the AST
when you have a *statically* typed language is hard?
http://www.erlang.org/doc/apps/mnesia/users_guide.html
Were you maybe reading the reference manual instead of the user's guide?
     "That was fatal?"
Date: 11 Mar 2011 12:53:03
Message: <4d7a617f@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> - There are many functional programming languages. (Haskell, OCaml,
> Clean, and for some reason people keep calling Lisp "functional" too.)
  Why did you not mention Lisp? It's the first, and still considered by
many to be *The* functional language.
> However, Erlang is *the only* one that could be considered "commercially
> successful", as far as I can tell.
  How about Lisp?
> Suffice it to say, from what little I could discover, I didn't like what
> I was seeing. Like most commercially successful languages, Erlang is
> obtuse, complex, ugly and kludgy. Much like C, Java or anything else
> wildly popular.
  Can you name a programming language that isn't? (Besides Lisp.)
  And don't say "Haskell". I can understand a Java program much more
easily than a Haskell one. So much for obtuse, complex and ugly.
Date: 12 Mar 2011 08:14:03
Message: <4d7b719b$1@news.povray.org>
Ummm... I *did*? It's right there in the quote.
I can't figure out why. Functions are first-class in Lisp, but beyond
that there's nothing functional about it. (Unless you think "it uses
lists" has something to do with being functional...)
>    How about Lisp?
I wasn't aware that there are any multi-million line mission-critical
production-grade systems written in Lisp. I suppose there might be
somewhere. I'm certainly not aware of any well-known commercial entities
telling everybody that they should use Lisp.
>> wildly popular.
No, I'd say Lisp is kludgy too.
There are people who describe mathematical equations as being obtuse,
complex and ugly. And there are others who describe them as being
sublimely beautiful, even transcendental. Wanna guess which side I'm on?
Beauty is of course in the eye of the beholder, so I won't argue about
this further.
http://blog.orphi.me.uk/
Date: 12 Mar 2011 08:40:14
Message: <4d7b77be$1@news.povray.org>
>> or the syntax...
Java? Eiffel?
> non-functional part. But that doesn't give Erlang itself any benefits.
> No doubt functional programming is easier to debug. You just have to
> manually separate it out from the rest of the non-functional stuff.
Indeed. It lets you write in a functional style, but doesn't force you
to. I suppose some people will claim that's "pragmatic".
>> Oh... my god.
Personally, no...
> being famous and wildly expensive. ERlang's niche is telecom programs
> that run for decades without crashing.
Sure. But people often reverse the word "niche" as a kind of polite way
of saying "hopelessly unsuccessful". ;-)
> be in straight C. :-)
People claim that Unix (or maybe specificaly Linux) is insanely
reliable, and that's almost all pure C.
> them the benefits they expected?
I'm sure Ericsson things that Erlang is great. That's not "scientific"
necessarily though. ;-) I'm not seriously disagreeing with you, just the
fanboys.
>> "The" PhD thesis?
I wonder if that's the document I just read, or a different one...
> atom in all upper case, let alone one that says 'EXIT'.
So many, BUT NOT ALL. It seems to vary inconsistently. Sometimes there's
an atom to tell you whether it was OK or not, and sometimes there's only
an atom to tell you when it failed.
> that wrapped after 42 days and crashed the computer.
Got a reference for that?
>>> Reliability. ;-)
> lost a connection too, for one thing.
Oh, I see.
> passes a connection to C to A, A needs a connection to C anyway.
What makes you think that?
So how do you compare it then?
Right. So it's DNS name, plus a user-defined atom (presumably so you can
run several nodes on a single machine).
>> upper-case is enough to prevent this, I don't know...
More often than you'd think. For example, I might try to use "if" for
"input file" and "of" for "output file". Shame both of those are
reserved words in Haskell. But - fortunately - this causes a
compile-time error in Haskell. You say "treat special atoms as reserved
words", but if they really were reserved words, you'd get a compile-time
error informing you of your mistake, rather than mysterious run-time
behaviour which possibly only shows up under unusual conditions.
EPIC FAILURE. >_<
>> use, and that's why 90% of all software ever written uses it. I don't
>> think C is at fault here."
> years. People tried many alternatives, and they all sucked so bad they
> never really got out of the lab. So clearly C is doing something right.
That's the actual reason? I've often wondered about this, but it was a
long time ago when all this stuff presumably happened...
>> processing unit inside it?
> configuration changes, etc. The point is it's not switching individual
> voice packets, any more than your CPU is getting involved in deciding
> which ethernet packets going past are addressed to the machine the
Wait - the CPU on my PC *doesn't* process the incomming packets??
> compile time. (That's how records work, for example.) You think figuring
> out the AST when you have a *statically* typed language is hard?
Strictly, what I'm looking at isn't the parse tree of the Haskell source
code. I'm looking at the internal data structures used by the Haskell
optimiser. And it's not so much that the data is complex, it's that most
of it is complex, and it's difficult to guess where the hell the
function for examining it is defined. And the API just plain isn't very
documented. I get the impression that the inside of the compiler is just
very complex, and not especially tidy, which is surprising.
Yeah, possibly.
Date: 12 Mar 2011 11:55:34
Message: <4d7ba586$1@news.povray.org>
>>> or the syntax...
> Java? Eiffel?
Well, alright. You have to wrap them up in an anonymous class.
I can't help people don't know english. :-)
I've never heard anyone claim that.  I've heard Linux people bash Windows,
and I've heard people brag about how reliable Linux is, but it's certainly
not reliable enough that it'll run ten years worth of upgrades without a
reboot or loss of service, unless you go to something like a Tandem.
In practice, in those routines (like catch) that return the value or an atom
if it failed, people return an atom tagging the success as well. Or they
return a different type like a list.
I'm sorry your computer can't get through to Google. I hope your
connectivity gets restored soon.
http://news.cnet.com/2100-1040-222391.html
Because B may pass to A a connection to a mailbox on C.
Oh, I see what you're asking. I assume they're smart enough not to send
passwords in the clear to machines that haven't proven they already know the
password.
Wow.
C was designed to be a portable that was *not* abstracted from the machine.
Therefore, it got ported a lot, often as the first HLL ported to a new
architecture.  The other languages only got ported to architectures being
used for that particular type of computing.
When people tried to make better languages than C, they tended to pile so
much extra stuff into it that would make it appropriate for both
machine-level stuff and high-level applications that it turned into a monster.
Not packets not destined for your machine, no. WTF do you think a MAC
address is for?
     "That was fatal?"
Subject: Re: The mysteries of Erlang
Date: 12 Mar 2011 11:58:55
Message: <4d7ba64f@news.povray.org>
Early versions of LISP were functional. It was for a long time the *only*
popular language you could write anything that looked like functional code in.
Which is the functional language: FORTRAN, C, COBOL, or LISP?
Yahoo was originally all in LISP before it got sold, including the store.
Several large video games are written in LISP. I think the right answer is
that more people use LISP than you think, but they don't advertise it
because it's a competitive advantage.
     "That was fatal?"
Date: 12 Mar 2011 12:13:58
Message: <4d7ba9d6$1@news.povray.org>
>> way of saying "hopelessly unsuccessful". ;-)
I love the way people use "legacy" to mean "that ancient hunk of junk
that we somehow ended up still having to support".
> Windows, and I've heard people brag about how reliable Linux is,
When Linux first became popular, this was *the reason* to switch to
Linux. Everything is so reliable and works perfectly without crashing
every 12 seconds. (Never mind that they don't have drivers for your disk
controller yet, never mind your graphics card... who cares about that?)
> but
> it's certainly not reliable enough that it'll run ten years worth of
> upgrades without a reboot or loss of service, unless you go to something
> like a Tandem.
I can't say I've tried.
...which links to http://support.microsoft.com/kb/q216641/ which says
that they fixed this problem 10 years ago.
Sorry, I misread your sentence.
> the password.
I'd like to believe that... *shuffle*
> Wow.
Hey, we all make mistakes...
(Like the time I discovered that "default" is a reserved word in
Haskell. I had to look at the language spec to find out what it's
actually for, since nobody ever actually uses it.)
> machine. Therefore, it got ported a lot, often as the first HLL ported
> to a new architecture. The other languages only got ported to
> architectures being used for that particular type of computing.
> so much extra stuff into it that would make it appropriate for both
> monster.
I guess the answer is only obvious in retrospect...
> address is for?
For telling you which machine a packet is addressed to? You still have
to *read* the MAC address to find out if that's you, surely.
Date: 12 Mar 2011 12:58:00
Message: <4d7bb428@news.povray.org>
I must admit, that's the one reserved word I don't infrequently use for a
variable by mistake. I got over it after the first five or ten times, tho.
Who is "you" in that sentence? Your CPU? No.
     "That was fatal?"
Date: 14 Mar 2011 05:02:13
Message: <4d7dd995@news.povray.org>
That's like saying "which is the high-level language: machine code,
assembly language, or C?"
Oh, wait...
> I think the right
> answer is that more people use LISP than you think, but they don't
> advertise it because it's a competitive advantage.
That's a pretty glowing recommendation for Lisp. Assuming it's actually
true of course. ;-)
Date: 14 Mar 2011 12:56:18
Message: <4d7e48b2$1@news.povray.org>
More like "which is the portable one?"
At the time it was written, LISP was the only language that *could* be
programmed in a functional way. You can't write functional COBOL or
functional FORTRAN.
Later, constructs were added to let to LISP you assign values and such.
> true of course. ;-)
I think you'd be surprised at some of the languages used in closed-source
projects.
     "That was fatal?"
Date: 14 Mar 2011 13:50:00
Message: <web.4d7e5507b01f867c773c9a3e0@news.povray.org>
> functional FORTRAN.
> > true of course. ;-)
> projects.
yep, a Lisp-like language was used by Naughty Dog to script AI in the Crash
Bandicoot games and even as far as the more recent Uncharted games by same
company for PS3.  OTOH, it was built as a culture within the company previous to
developments of python and Lua as more usable alternatives for the task...
this was in the 90's and early 2000's, when Lisp kind of made a resurgence
thanks to Paul Graham and his successful account of how Lisp allowed him beat
the averages.
Lisp is pretty much dead nowadays, even the flagship company for it, ITA
Software, today employs much java, python and C++... Lisp is mostly legacy.
even still, I'd say it's still used more than haskell... ;)
Date: 15 Mar 2011 10:42:07
Message: <4d7f7abe@news.povray.org>
  I have never actually been in a large game company, but it is my
understanding that using all kinds of interpreted (or sometimes bytecompiled)
scripting languages is rather usual in games.
  The core game engine as well as many of the middleware libraries (such
as the physics engine) are, AFAIK, usually written in C++ (with many C
libraries thrown in), but many of the higher-level functionalities are
often written in whatever scripting language the team likes (such as
Lua, Python, or a custom language of the particular game engine). It makes
it easier to change things (such as AI behavior) without having to recompile
the project. Also "scripted events" can literally have a double meaning:
Besides following a pre-written "script", they are often implemented using
a scripting language.
Date: 15 Mar 2011 13:10:41
Message: <4d7f9d91$1@news.povray.org>
Unreal engine is exactly like that, yes. All the collision stuff and
animation sequencing and things are done in system languages, while the code
for what to do (like, "Spawn here, then use the RUN animation until you get
within X distance of the player") are in Unreal Script.
It's pretty cool. All the documentation is online.
     "That was fatal?"
Date: 16 Mar 2011 06:11:45
Message: <4d808ce1$1@news.povray.org>
> code for what to do (like, "Spawn here, then use the RUN animation until
> you get within X distance of the player") are in Unreal Script.
Valve say they did something similar with [at least] the particle
effects in Team Fortress 2. They made it text-scriptable, so that
animators can design new particle effects for their weapons and models
and stuff without having to call a C++ programmer to write the animation
code.
Uh... Valve makes their Source SDK *available* online, but it can only
be considered *documented* for sufficiently small values of "documentation".
Date: 16 Mar 2011 11:10:28
Message: <4d80d2e4$1@news.povray.org>
On 3/16/2011 3:11, Orchid XP v8 wrote:
> Uh... Valve makes their Source SDK *available* online, but it can only be
That's the difference between buying a commercial engine designed for
writing your own games, and buying someone's finished game and them throwing
in the SDK for free.
Speaking of Erlang...
     "That was fatal?"
