POV-Ray : Newsgroups : povray.off-topic : Either my computer's PSU has taken a dive, or SpeedFan is reading the sensors incorrectly Server Time
20 Mar 2026 08:05:27 EDT (-0400)
  Either my computer's PSU has taken a dive, or SpeedFan is reading the sensors incorrectly (Message 1 to 10 of 23)
Subject: Either my computer's PSU has taken a dive, or SpeedFan is reading the sensors incorrectly
Date: 26 Feb 2011 11:14:19
Message: <4d6926db$1@news.povray.org>
So, with intensive POV-Ray work, I always like to open up speedfan and
(FREAKING HOT o_O! Normally they run about 50-60) I see no evidence of
CPU throttling down, though. But the even weirder thing I noticed was
the voltages. 1.2, 5, etc all seem to be fine and stable -12 comes in
around -15 and -16, and +12 seems to be all over the place, but never
anywhere near 12! When under high CPU load, it hovers around 5-6 volts,
and when the CPU is idle around 1-2v. (!)
The system is stable, seems to do the torture test fine, GPU operates
normally, and everything appears to be humming along normally.
I may need to pop the heat sink off the cpu, clean it off, and re-apply
some heatsink goop to get the temps down... All fans are nominal, there
was some dust collected on the filters on the case, but that has been
cleared off, airflow is great, it doesn't blow hot. Ambient temperature
does have a lot to do with it. After the AC kicked on (we've been warm
lately) CPU temps were arouns 85 under full load.)
The voltage is weird and disconcerting, though. I may wind up buying a
new PSU as an insurance policy. I don't want a temperamental power
supply trashing my CPU and motherboard.
Maybe the readings are just totally wrong?
Subject: Re: Either my computer's PSU has taken a dive, or SpeedFan is readingthe sensors incorrectly
Date: 26 Feb 2011 11:38:30
Message: <4d692c86$1@news.povray.org>
Are you using SSLT?
I noticed that my laptop gets into the low 90's when using SSLT. About
the high 70's or low 80's normally.
Regards
Subject: Re: Either my computer's PSU has taken a dive, or SpeedFan is readingthesensors incorrectly
Date: 26 Feb 2011 11:50:25
Message: <4d692f51$1@news.povray.org>
> Are you using SSLT?
Yep... using SSLT. wow. Wonder why that is. Yeah, running PassMark would
only warm the CPU up to about 68-70. So, maybe its just the case the POV
just really hammers the CPU.
Subject: Re: Either my computer's PSU has taken a dive, or SpeedFan is readingthesensorsincorrectly
Date: 26 Feb 2011 12:26:15
Message: <4d6937b7$1@news.povray.org>
On 26/02/2011 4:50 PM, Mike Raiford wrote:
>> Are you using SSLT?
Aye, must be. I blame Clipa ;-)
I just downloaded HW Monitor to check and it reports the same
temperatures. I suppose you could always reduce the duty cycle if it
bothers you.
http://www.cpuid.com/softwares/hwmonitor.html
Regards
Subject: Re: Either my computer's PSU has taken a dive, or SpeedFan is reading the sensors incorrectly
Date: 26 Feb 2011 13:12:46
Message: <4d69429e@news.povray.org>
> peek at the temps. (Under POV load, each core seems to be around 93?C
  I think that's too much. Many systems I have seen have been configured
for an immediate emergency shutdown if the CPU temperature exceed something
like 85 degrees. (If it reaches those temperatures something must be really
wrong. Maybe the CPU fan died.)
  I don't know if 93 degrees is a normal operating temperature for your CPU,
but it certainly doesn't sound like such. My guess is that your monitoring
software is reading or showing something completely bogus.
  In a well-ventilated, well-designed system the CPU runs at something
like 40 degrees when idle and 60-65 degrees under full load. (Of course
this probably depends on the CPU in question, but with many CPUs normal
operating temperatures may be even lower than that.)
  I'm not sure that would be the problem. I have been using my system for
something like 5 years without ever doing that, and it still runs at a
comfortable 44 degrees when idle. Just need to remove the dust from time
to time.
  I had a problem with the CPU fan (rather than the CPU itself), as it would
spin really fast when temperatures got even slightly high, but tinkering with
the BIOS settings fixed that. (Now something like 2200 RPM is enough to keep
the CPU down to about 44 degrees at normal room temperature.)
Date: 26 Feb 2011 14:03:58
Message: <4d694e9e$1@news.povray.org>
I tried the demo of The Ball on Steam, set it at full screen 1080, and the
machine powered down in about 3 minutes, apparently from overheating but I
didn't get any message to that affect on booting up again. Tried it again a
few hours later, windowed down to 800x600 and got about 10 minutes in before
it shut off again.
I think the graphics card may be underventilated (as all my slots are full),
but I've never had that problem with anything else (altho I can definitely
hear the fan spinning up when I'm gaming (at least other people's games)).
The GPU itself seemed rather scortching hot when I opened it up to check on
the dustiness.
I'm wondering if it's worth pulling the card out and visually inspecting the
surface and/or blowing it cleaner than I can with the card in place or
something.
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 26 Feb 2011 14:38:50
Message: <4d6956ca@news.povray.org>
Am 26.02.2011 18:25, schrieb Stephen:
>>> Are you using SSLT?
You're making me bigger than I am :-) ("Lipa" is polish for lime
(linden) tree; "Lipka" is the deminuitive form; the "C" is from
"Christoph".)
As implemented in RC3, SSLT shoots about half of its rays only against
the SSLT object itself, which might result in fewer cache misses than
other ray-tracing computations. In addition, SSLT does a lot of math,
with many exp() and sin() and cos() and such, so the floating-point
units are probably running near full-throttle.
> bothers you.
When I got my i7, I was worried about the high temperatures, too - but I
was assured by the local PC dealer that this was nothing to worry about,
since the i7 would self-throttle when in danger of overheating.
It doesn't - to the contrary, the cooling in my PC is apparently so good
that the CPU keeps overclocking itself even with POV-Ray blazing away.
Apparently the i7's temperature sensors measure the temperature at
totally different places than its predecessors. I heard that earlier
Intel CPU's measure the temperature of (or near) the heatsink, while the
i7 measures the core temperature.
Date: 26 Feb 2011 15:28:08
Message: <4d696258$1@news.povray.org>
You're a big man here. :-D
Good to know.
I've not seen my i7 laptop go into turbo
Any idea what the max working temperature is?
Regards
Date: 26 Feb 2011 18:53:58
Message: <4d699296$1@news.povray.org>
Am 26.02.2011 21:27, schrieb Stephen:
It may be disabled by the BIOS or chipset or whatever; after all,
typically Laptops go for low energy consumption, whereas turbo is going
for maxed performance.
Not really. I think back then I found some information indicating that
around 90 degrees Celsius is a "healthy" upper value, but I can't give a
guarantee for that information.
Date: 26 Feb 2011 18:55:46
Message: <4d699302$1@news.povray.org>
clipka wrote:
> ...("Lipa" is polish for lime
> "Christoph".)
BTW, pardon me for going off the off-topic topic, but is it just me, or
are there really, really lots of guys named
Cristoph/Cristopher/Christian/Chris around here?  Has anyone ever
calculated the Chris Quotient for this place?
Just curious.
--Sherry Shaw
P.S.:  In my high school graduating class of ca. 50 students, there were
four (4) girls named "Sherry" or something similar.  You had to holler
at me quite a while before I would even bother to look up.
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
