POV-Ray : Newsgroups : povray.off-topic : Friday WTF Server Time
1 Nov 2026 08:43:09 EST (-0500)
  Friday WTF (Message 1 to 24 of 24)
Subject: Friday WTF
Date: 18 Feb 2011 09:18:35
Message: <4d5e7fbb@news.povray.org>
"The file Data.csv is already open. You cannot open two documents with
the same name, even if the documents are in different folders. To open
the second document, either close the one that's already open, or rename
one of the documents."
Who knew Excel couldn't do this?
For that matter, who has any idea *why* it can't do this?! o_O
Subject: Re: Friday WTF
Date: 18 Feb 2011 09:24:52
Message: <4d5e8134@news.povray.org>
Because internally it uses some reference based on the filename of open
documents?  Or it would get confused if you tried to reference another
open document and there were two with the same filename?
Date: 18 Feb 2011 12:12:39
Message: <4d5ea887@news.povray.org>
Or the UI didn't have a place to put the path name of the file in your face,
and the Excel team decided it was easier to disallow that than to fix the UI
to find a place to put the path?
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 21 Feb 2011 03:19:53
Message: <4d622029@news.povray.org>
I did. And it's not limited to csv file: all files in excel must have a
unique name, and the path is irrelevant.
It might be due to its long history... and the display of filename in
the window submenu. (it might be for the "benefit" of the end-users, so
as to not confuse them.)
Excel is a sandbox: it make nice graphics (yet not all of them keep
being available across its versions) but is usually overused for database.
It's fine to use excel as a sketch, but any real production should stay
away from it. Alas, it's so eye-candy that it usually stays with the
uneducated people in charge (like CEO and other administrative/marketing
people).
Date: 21 Feb 2011 04:13:23
Message: <4d622cb3$1@news.povray.org>
> people).
It's true enough that my company's IT department keeps *all* of their
records in Excel spreadsheets. License keys, user account records,
everything like that... all spreadsheets. Never mind that only one
person can work on it at a time and that people can screw up each
other's updates and all the rest of it. How hard would it be to put this
stuff into a trivial Access database? Not very. But apparently our IT
department is too stupid to understand why this would be a good idea.
For my part, the entire reason that I'm using Excel is that I *want*
graphs. If it were somehow possible to make gnuplot draw graphs from CSV
data, I'd use that. (It's scriptable, after all.) But since it isn't,
I'm stuck with Excel.
Date: 21 Feb 2011 09:06:43
Message: <4d627173$1@news.povray.org>
Your friend on unix would be ploticus.
The script can read a separated data file in csv...
scripting in ploticus has a strange learning curve, best to copy & paste
from their gallery then play a bit.
For the lazy and/or always overbooked people:
http://ploticus.sourceforge.net/doc/welcome.html
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 22 Feb 2011 06:15:06
Message: <4d639aba$1@news.povray.org>
>> people).
Excel is good for simple databases with infrequent updates for many
reasons, the most important is that almost everyone has it installed on
their machine and most people are familiar with it.  If you store the
Excel file on a network drive it will get backed up regularly and ensure
that only one person can edit it at a time.
There are also more advanced features to lock ranges of cell based on
who is logged in if you want to limit certain parts of the database.  We
use this on a couple of files where managers have to authorise certain
items (it prevents non-managers from changing those cells).
If you have no experience with Access it's not trivial to set it up
properly, and if the only perceived benefit is that more than person can
edit it at a time it's unlikely to be seen as worthwhile.
Probably they just have other stuff to do they think is more urgent.
Date: 22 Feb 2011 06:28:37
Message: <4d639de5$1@news.povray.org>
> reasons.
It's like the fact that all screenshots are always emailed as Word
documents, even though it takes up far more space. It's just that nobody
knows any better.
We don't use that feature at all.
(Unrelated, but... I was astonished when I discovered how hard Access
security sucks. Excel is much better at this.)
> properly,
True. But we're talking about the IT department here. If we don't know
how to work it, what hope is there?
The other benefit of course is that you can trivially sort the data
without screwing it up. (Excel makes it very easy to accidentally sort
one column only, muddling up all the data.) It also makes inserting or
deleting records vastly easier. (The same goes for adding or removing
columns.) Don't even get me started on how difficult it is to
cross-reference data in a spreadsheet. (Although admittedly it's
unlikely you need to do that very often.)
This is from the department that has set most of our admin passwords to
"our1Tr0x!"...
Date: 22 Feb 2011 06:45:56
Message: <4d63a1f4$1@news.povray.org>
Err, you did turn on filtering first on your table (select the header
cells and click Data->Filter)?  This makes sorting and filtering a
no-brainer and AFAIK prevents people from sorting the data incorrectly.
If you need to cross-reference beyond simple drop-down selection lists
then you're probably beyond what Excel can easily offer as a simple
database.
Date: 22 Feb 2011 07:03:58
Message: <4d63a62e$1@news.povray.org>
Really? I had literally no idea that was possible. In 15 years of using
Excel, I didn't know about this. (I wonder how many other people didn't.)
Rather than clicking on an unintuitive command name buried in a menu, if
you click on the big "sort ascending" button right there on the toolbar,
it can *totally* mess up your data. Fortunately there's an undo button.
(I wonder how many people know that?)
> database.
I meant stuff like if you have one spreadsheet with all the license
keys, and another spreadsheet that tells you when each product was
purchased, you're going to have fun trying to link one to the other.
With a real database this would be a trivial table join.
(On the other hand, databases generally *need* to do joins more often
because the data is usually normalised - something people don't bother
with for Excel.)
Date: 22 Feb 2011 09:51:07
Message: <4d63cd5b@news.povray.org>
Odd, I've seen this used on pretty much every "database" style Excel
workbook from several different companies.  Particularly for "action
list" type databases where it's essential to be able to easily filter
out certain rows.
Yes, it's quite tricky to get two tables linked in the same way a proper
DB would do it whilst keeping the GUI friendly, but usually there is an
easy enough hack using the lookup and data validation stuff that works.
Date: 22 Feb 2011 11:47:15
Message: <4d63e893$1@news.povray.org>
I guess fundamentally it just irks me that supposed IT "experts" are
using the wrong tool for the job. I don't suppose an Access database
would actually be any faster to access over an encrypted WAN link,
that's for sure...
Date: 22 Feb 2011 11:49:09
Message: <4d63e905$1@news.povray.org>
I read a while ago that while LOTOS 1-2-3 and visicalc were putting in
ever-more sophisticated math stuff, MS went and looked at how people were
actually using the product and realized some surprisingly large number of
spreadsheets had no formulas at all. So MS made it easier to keep lists of
stuff in Excel, and that's part of why it won out over those others.
Actually, I think nowadays you can set it up for multiple edits and it'll
coordinate. It seemed simple, but I never had two people actually try at
once, so take it with a grain.
Last I looked, Access was only one user at a time making changes too. The
one guy would lean back in his chair and bellow "IS THERE ANYONE IN THE
DATABASE?"  That was their locking protocol.
     "That was fatal?"
Date: 22 Feb 2011 11:56:08
Message: <4d63eaa8$1@news.povray.org>
> were actually using the product and realized some surprisingly large
> number of spreadsheets had no formulas at all. So MS made it easier to
> keep lists of stuff in Excel
That wouldn't surprise me.
Perhaps. I can well imagine people being too stupid to work out how to
use a proper database product...
> it'll coordinate.
I've never seen that.
> The one guy would lean back in his chair and bellow "IS THERE ANYONE IN
> THE DATABASE?" That was their locking protocol.
I spent six months watching a group of three people in an office. They
had an Access database, which everybody had constantly open all day. So
clearly that's not the case.
On the other hand, I have seen "error - database in use", so I'm not
sure what's up with that...
Date: 22 Feb 2011 12:11:04
Message: <4d63ee28@news.povray.org>
Remember at the time that a "proper" database product cost roughly $100K per
seat.
You don't need a "proper" database product to keep your to-do list or your
org chart.
>> it'll coordinate.
It was really trivial in the menus. I think it's something around
tools->Shared Workbook.  One of the things under Tools should do it.
Well, this *was* years ago.  More than a decade, probably.
     "That was fatal?"
Date: 23 Feb 2011 03:44:34
Message: <4d64c8f2$1@news.povray.org>
>> it'll coordinate.
It's under the Review ribbon, then "Share Workbook".  But it only lets
you change basic stuff when shared (ie just cell contents, not the
layout, charts, etc), and the changes are only updated when you save the
file (or I think you can set it to automatically update at regular
intervals).  If two people change the same cell, the first one to save
will succeed, the second one will get to choose which value to keep.
I only worked on Access about 8 years ago so it's probably out of date
info now, but IIRC you could set up on a per-table basis how much of it
was locked when opened (entire table, single row, nothing).  It also
took a fair bit of work to get it to play nicely with multiple people
opening it (ie catching all the errors that might come up, and
preventing people doing stuff that would screw it up).
Date: 23 Feb 2011 04:13:39
Message: <4d64cfc3@news.povray.org>
>>> it'll coordinate.
Ribbon?
As in, Office 2007 or later?
Well, that'll be why I haven't seen it then. ;-)
> But it only lets
I bet that's fun if you try to add a new row to the bottom. (This would
of course be a complete non-issue if you used... a database.)
> was locked when opened (entire table, single row, nothing). It also took
> a fair bit of work to get it to play nicely with multiple people opening
> it (ie catching all the errors that might come up, and preventing people
It's not something I have a lot of expertise with, but I saw all this
set up 10 years ago, running under Windows 98. It can't be that hard.
Date: 23 Feb 2011 04:15:02
Message: <4d64d016@news.povray.org>
> your org chart.
Not really, no. Access may be hopeless as a "real" database, but it's
pretty much ideal for quickly setting up small databases for
non-critical stuff.
Now, if only it wasn't so absurdly difficult to secure it...
Date: 23 Feb 2011 05:24:03
Message: <4d64e043$1@news.povray.org>
Actually it works fine.  If two users both add a row to the bottom in
the same place it does what you would expect (ie add the 2nd row below
the 1st new row, and not ask if you want to overwrite it or not).
The problem with Access is that it's not included in the cheap Office
packs.  Everyone here needs to ask IT to get a new license if they need
Access (which of course costs more).  That is a big reason why people
use Excel for this kind of stuff.
Date: 23 Feb 2011 05:27:37
Message: <4d64e119$1@news.povray.org>
MS really have worked hard on this, eh? ;-)
> Access (which of course costs more). That is a big reason why people use
Oh. Really?
I can't say about other sites, but here in the UK, every employee has
Word, Excel, Access, Power Point and Outlook installed by default. We
have volume licenses for all of them.
Which is just as well, since several vital items of operational data
*are* Access databases. (All things developed in the UK, not by the
central IT department. I'm sure they would have used Excel instead...)
Date: 23 Feb 2011 05:36:40
Message: <4d64e338$1@news.povray.org>
IME not many organisations buy Access for every employee.
Date: 23 Feb 2011 05:46:43
Message: <4d64e593@news.povray.org>
OK, fair enough.
Still doesn't explain why *our* IT department uses spreadsheets. ;-)
Date: 23 Feb 2011 11:45:47
Message: <4d6539bb$1@news.povray.org>
> non-critical stuff.
It's the microsoft equivalent of sqlite except back from when DBase was
considered heavy duty for a personal computer. You shouldn't really expect
it to be "real".
     "That was fatal?"
Date: 23 Feb 2011 11:47:22
Message: <4d653a1a$1@news.povray.org>
Under 2003, it's under Tools, and there's a variety of "share" things to
play with.  Or you could, you know, look in the help file, now that you know
Microsoft calls it "share".
     "That was fatal?"
