Hello,
I'm working with Processing and GLGraphics to produce various cellular
automata simulations. I've just found something worth sharing, and was
wondering if somebody might help me test it out. It requires Java and a
newish graphics card (GLSL, Pixel Shader 2.0+).
http://www.caltel.com/~abenge/index.html
You can draw bubble-producing explosions with the mouse. Tap inside a
medium-sized cell to "pop" it. The space bar clears the screen.
It will probably run blindingly fast on newer cards, slower if your card
is old, not at all if it's ancient. I get 30FPS on my GeForce 7600GS .
It would be faster, but I'm using 16-bit surfaces.
The simulation itself is based on an edge-finding technique combined
with diffusion and a method (developed with POV-Ray) for
pinching/expanding densities. As the field stabilizes, the result
resembles a minimal surface.
I was hoping to use something similar to make a suds effect for MilkDrop :)
Sam
I get a note at the bottom saying "class not found: RDMinim"
(When you describe it, you might want to mention it's an applet and not a
stand-alone java program.)
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
I just get a very small black square and nothing much happening (oh and
Java crashes when I try to close the webpage).
Sounds exciting though, can you post some screen shots?
Me too :-(
Regards
Works flawlessly for me (with Firefox, on a not so new computer).
It's mesmerizing !
Thibaut
Le 31/01/2011 02:19, stbenge a écrit :
> Hello,
> Sam
stbenge escreveu:
> Hello,
> Sam
404: not found
a game sig: http://tinyurl.com/d3rxz9
On 1/31/2011 9:46 AM, nemesis wrote:
> 404: not found
I just uploaded it to a new directory:
http://www.caltel.com/~abenge/applet/index.html
Sam
This is my first time uploading such a thing... I'll have to look into
it. It has its own directory now, so maybe it will work:
> a stand-alone java program.)
Ah yes, I should have mentioned that :S
Sam
As it turns out, there were two places to change the window size, so it
should be fixed now.
>(oh and
That's not very encouraging :(
I will, if the app still refuses to run. A series of PNG files would be
best, but they take a long time to upload...
Sam
The updated link:
> It's mesmerizing !
Thanks, Thibaut! I wish I could distill the core principles into a tidy
equation, but I'm not so good at reading/writing mathematical notation :(
Sam
Still getting "class not found: RDMinim" :-(
I've updated Java, Firefox and IE8
Regards
Ack... so far I've found that if the class in in ASCII format, there
will be problems. I don't know how to make it binary. My system wants to
open it with Notepad, and I doubt that changing the preference will
alter the nature of the file... I don't know why it would work for
Thibaut and myself and not you...
Sam
I must be a bad person. ;-)
Probably not related but I'm having problems today with port forwarding
and connectivity.
Regards
Still happening, altho it loaded a couple of things first.
"That was fatal?"
> and connectivity.
No, probably not related, but it can't be ruled out entirely.
Here's a very minimal test applet that does not use OpengGL:
http://www.caltel.com/~abenge/test/index.html
If it works, then it's most likely either a conflict with a version of
JOGL you've installed, or more likely, the newer version of JRE that has
been giving everyone grief lately.
If it doesn't work, then it is a binary/ASCII problem, possibly in
addition to other things...
Sam
It's vexing! Does this small test work?
It doesn't use OpenGL. I'm trying to rule out the possibilities :/
Sam
That works for me, Sam.
Regards
OK, then I'll download the latest JRE release and see if it breaks the
applet or not. Thanks for you input!
Sam
Thank you all for your input! I'd still like to hear any comments you
might have, if you can take the time.
One of my goals is to prepare a full-on cellular automata gallery that
anyone (with a graphics card) can view.
Sam
Got it, and it's broken! I can now proceed accordingly. Thanks again.
Sam
> will be problems.
Your web server has to deliver .class files as application/octet-stream. Sun
did this to kludge around the fact that many sysadmins didn't want to fix
their web server to use an official content type for .class files, so Sun
decreed that it had to be served with the default "I don't know what this
is" content type.
If your web server serves it as the default "this is HTML" then you need to
change that.
Likely for the same reason that everyone bitches at IE letting hidden worms
in: IE will look into the content of the file it gets that's served with the
wrong content type and fix that, for the same reason that Sun decreed you
must serve applets with the wrong content type. It gets around misconfigured
servers.
"That was fatal?"
Works for me!
"That was fatal?"
Don't you love web development? :-)
"That was fatal?"
> Works for me!
Alright, it's narrowed down to one or two possibilities. Thanks!
Sam
When it's not giving me trouble, it's boring the heck out of me (HTML).
Sometimes it seems like the problems expand outward in a branching
structure...
I think I can see the end of this limb though :/
Sam
:-D
Regards
> structure...
I have coined the term Zeno's Debugger for that.
Every time you try to figure out what's causing the error, you have to first
debug the tool you're using to figure out what's causing that error,
recursively.
"That was fatal?"
On 1/31/2011 1:38 PM, Darren New wrote:
>> structure...
> first debug the tool you're using to figure out what's causing that
> error, recursively.
But what do you call it when the only thing stopping your software's
deployment is one tiny exe that happens to be bundled into one humongous
development kit?
I may to jump (or glide slowly) through some hoops to resolve it, but
I'm 95% sure I know what the problem is: an applet, running under the
new version of JRE, needs to be /signed/ when using 3rd party libs! D:`
Sam
> development kit?
A b*st*rd? o_O
Regards
I spent more time with it, and it is really fascinating ! It looks a lot
like some sort of physical/biological process. If you can give some
qualitative information on the way the algorithm works, I'll be very
interested. A few things I like particularly:
- the different 'timescales' : after a click with the mouse, there is
the rapid process destroying the cell, but the system takes a long time
to reach a steady state as a whole
- I enjoy a lot when 'thin white lines' enter a big cell, and propagate
slowly with successive branching, changing in the end a big part of the
entire geometry.
Thibaut
> Sam
>>> structure...
>> error, recursively.
> development kit?
So you go to download the kit and you need to make up an account to download
it. But the make-up-the-account doesn't work through the corporate firewall,
so you go home. But your home computer has firefox and the download doesn't
work with that. So you install Chrome and manage to sign up, but they don't
take gmail addresses for logins. So you go to log in over the VPN, but the
VPN software has been upgraded, so you need to take your VPN box back to
work anyway to get reflashed. So you go back to work to download the file
but it doesn't come through the proxy. So you bypass the proxy but there
isn't enough temp space to download the package. So you go to back up some
useful files but the USB drive has gone missing. So you ask around to see
who has the USB drive .....
When, really, all you wanted was to write a f'ing piece of code.
"That was fatal?"
>> development kit?
> A b*st*rd? o_O
My inclination _is_ to to start using profane expletives, but the Zen
method of realizing the path I must take fills me with peace. At least I
know I /can/ resume a long, drawn-out broken download with this
particular development kit. Fortunately, Sun hasn't taken Microsoft's
route of providing a "user friendly" download installer that resumes the
downloads only at 20MB intervals X_x
Sam
>> humongous development kit?
> download it. But the make-up-the-account doesn't work through the
> corporate firewall, so you go home. But your home computer has firefox
> and the download doesn't work with that. So you install Chrome and
> manage to sign up, but they don't take gmail addresses for logins. So
> you go to log in over the VPN, but the VPN software has been upgraded,
> so you need to take your VPN box back to work anyway to get reflashed.
> So you go back to work to download the file but it doesn't come through
> the proxy. So you bypass the proxy but there isn't enough temp space to
> download the package. So you go to back up some useful files but the USB
> drive has gone missing. So you ask around to see who has the USB drive
Is that talking from personal experience, or extrapolating from a
possibility? I can see that happening. If only half of what you said has
actually happened to you, I no longer feel so bad.
I know the thing must be less than 200K, but after reading the
license/user agreement, I know that that one tiny file can't be
distributed singularly (without legal repercussions). At least after I
download the monolith-of-an-development-kit, I can start learning actual
Java and go beyond the scope of Processing.
Sam
Well... cellular automaton simulations are an entirely natural process,
so these things happen as a matter of consequence. As to just
/what/exactly/ is being modeled is determined by the purity of the
calculations. I know that some of my calculations have resulted in an
approximation of a minimal surface, but others were added to increase
growth. So maybe we have a biological organism with a lot of mucus...
> entire geometry.
That's one of the things that puts this sim into its own category. What
you are seeing is related to reaction/diffusion and minimal surface
systems, but I really don't think that its behavior is indicative of a
"pure" minimal surface.
> interested.
I can't really explain what I did. I know *what* I did, and *why* it
does it, but ask me to put it into scientific or mathematical terms, and
you won't get a satisfactory answer.
But here's the GLSL code. I'll attempt to provide useful descriptions:
// these uniform variables are piped in from the governing program:
uniform sampler2D bufA; // a 768x768 16-bit surface
uniform vec2 offset; // offset.s = 1/768, offset.t = 1/768
uniform int DoPaint; // is the mouse clicked? (a boolean would be better)
uniform float MX, MY, RX, RY; // mouse X/Y, random values X/Y
// variables for the red, green & blue components
float R, G, B;
// CA = blur sample
// C0 - C8 = point samples
vec4 CA, C0, C1, C2, C3, C4, C5, C6, C7, C8;
// a noise function (not mine, used for adding noise to Area_Add[below])
float rand(vec2 UV){
return
fract(
sin(
dot(
vec2(
UV.x+RX,
UV.y+RY
vec2(12.9898,78.233)
)*43758.5453
void main(void){
float dx = offset.s; // 1/768
float dy = offset.t; // 1/768
// UV.x = 0.0 to 1.0, UV.y = 0.0 to 1.0
vec2 UV = gl_TexCoord[0].st;
// expansion vector (realized with POV)
// uses the green channel
vec2 Expansion =
.0625*vec2(
texture2D( bufA, UV + .5*vec2(-dx, 0.0) ).g
-texture2D( bufA, UV + .5*vec2(dx, 0.0) ).g,
texture2D( bufA, UV + .5*vec2(0.0, -dy) ).g
-texture2D( bufA, UV + .5*vec2(0.0, dy) ).g
// applying the expansion to "UV"
UV += 1.0*Expansion*(texture2D( bufA, UV).g);
// center sample
C0 = texture2D( bufA, UV);
// samples clockwise from upper-left
// total (with C0): 1 + 2 + .92 = 3.92 (values are also thanks to POV)
C1 = texture2D( bufA, UV + vec2(-dx, -dy) )*0.23;
C2 = texture2D( bufA, UV + vec2(0.0, -dy) )*0.5;
C3 = texture2D( bufA, UV + vec2(+dx, -dy) )*0.23;
C4 = texture2D( bufA, UV + vec2(+dx, 0.0) )*0.5;
C5 = texture2D( bufA, UV + vec2(+dx, +dy) )*0.23;
C6 = texture2D( bufA, UV + vec2(0.0, +dy) )*0.5;
C7 = texture2D( bufA, UV + vec2(-dx, +dy) )*0.23;
C8 = texture2D( bufA, UV + vec2(-dx, 0.0) )*0.5;
// blur sample
CA = (C0+C1+C2+C3+C4+C5+C6+C7+C8)/3.92;
if(DoPaint==1){ // paint circular area
// adds a noisy, circular density when the mouse is clicked
float Area_Add =
rand(UV)*clamp(
1.0-16.0*sqrt( pow(UV.x-MX, 2.0) + pow(UV.y-MY, 2.0) ),
0.0,
1.0
R = clamp(CA.r + .05*Area_Add, 0.0, 1.0);
// green is given a blurred version of the red channel
G = CA.r;
// blue is given a blurred version of its own channel
B = CA.b;
}else{ // return the usual values
R = CA.r;
G = CA.r;
B = CA.b;
// edge-finding
B = C0.r+(C0.r-CA.r)*760.0;
// mix old values with squared edge values
// ("mix" is the same as a linear interpolation["lerp"])
B = mix(CA.b, B*B, .025);
// add blurred edges to primary evaluation channel
// and decrease all red values over time
R = R + .045*CA.b - .0203065;
// subtract blurred edge values from the green channel
G = G - .107*CA.b;
// prevent values from going below 0.0 (black) or above 1.0 (white)
R = clamp(R, 0.0, 1.0);
G = clamp(G, 0.0, 1.0);
B = clamp(B, 0.0, 1.0);
// carry values over to next iteration
gl_FragColor = vec4(R, G, B, 1.0);
That was a description of the *kind* of thing that happened to me on a
regular basis at my previous job, yes. Between the code and the people
providing the code, it was the most distasteful job I've ever had, really.
And that counts customer service at the deli.
"That was fatal?"
Ah! My son. You will realise, after years of study and training that the
circle can be completed and the mind’s control of the body is as nothing
to letting rip when the hammer of fate connects with the thumb of life.
So take yourself into the desert and kick the coyote until He gives you
the gift of fire.
Regards
> Ah! My son.
You aren't my father! No! No! (getting carried away with Star Wars
geekiabilia there)
> the gift of fire.
I've done that, but it really doesn't work. Expressing emotional turmoil
to desert creatures (or other socially arid inhabitants) doesn't really
accomplish much, although you /do/ get some exercise.
Sam
Profanity is my number one debugging tool.
"That was fatal?"
OK it's working now, very smooth.
Neither URL works for me on my work PC. I get a security warning asking
if I want to run the applet, and then a blank page. The new URL works
just fine on my home PC. I have no idea why there would be a difference.
(But I recall that this kind of thing is highly typical of Java. Isn't
that their slogan? Write once, test everywhere?)
I don't know about cellular automaton; it looks more like some sort of
reaction-diffusion system.
http://texturegarden.com/java/rd/
Then again, there are other types of differential equations which
apparently produce similar results. Which is why I find it quite
surprising that you claim this is a *discrete* system, not a continuous
one. It certainly doesn't look very discrete.
I also wonder whether the visible image on-screen actually represents
all the information in the frame, or whether there are details too faint
to see. Certainly the simulation behaves in a wonderfully unpredictable way.
Clicking the mouse is like detonating a high-yield nuclear bomb, and the
fallout usually dies away quickly, but sometimes inexplicably lasts for
a very, very long time.
It is worth noting that, certainly for RD systems, almost all
combinations of parameter settings do absolutely nothing interesting at
all. Only a tiny fraction of possible settings do anything remotely
worth watching. Finding these interesting bits is highly non-trivial.
And yet, you seem to have hit upon something quite interesting here.
It appears that the image boundaries are held at a constant state. You
might try toroidal symmetry (i.e., joining the edges together). Also, it
occurs to me that if you were to run a simulation and stack each
successive frame one on top of the other, you could make some rather
interesting 3D shapes.
(Alternatively, perhaps the algorithm generalises easily to 3D. I'm not
sure how easy to visualise that would be though...)
It still amuses me that way, waaaay back in 1997 or so, I was playing
with Java, trying to copy the output of the ground-breaking Geiss
visualisation for WinAmp. Of course, Geiss used hand-optimised machine
code for all the main loops, and still ran cripplingly slowly. (E.g.,
about 12 frames/second at 800x600, only rising to sane speeds at 320x240.)
Unsurprisingly, Java was orders of magnitude slower. I had it render at
256x256, and draw 4x larger on screen. And still it was absurdly slow.
(I didn't measure exactly how slow.)
And yet, your little Java applet sucks about 5% CPU out of my obsolete
AMD Athlon 2X 4200+ with its 2.2 GHz clock rate. How times have changed!
I'm curious to know how you manage to get it to render at a constant
frame rate, rather than "as fast as you can".
>> Ah! My son.
> geekiabilia there)
It is so easy. :-)
>> the gift of fire.
Just slap your computer, then.
Regards
lol!
>>> Ah! My son.
>> geekiabilia there)
> It is so easy. :-)
Just when you think you have it under control, someone cuts off your
hand and starts making outrageous parental claims :(
OK... . whoa, that's a lot of dust!
Cool.
Part of the problem is that I'm using OpenGL libraries, and the security
restrictions imposed by the new version of JRE is keeping the thing from
loading completely. In a few days (after the download is complete) I can
start signing my applets, which should help.
It /is/ partly a reaction-diffusion system. I've never made a "pure" RD
system, though the edge-finding portion of mine is considered a type of RD.
Oh yeah, I was there yesterday :) There's also another link at the same
site concerning fractal drainage patterns:
http://fd.alife.co.uk/model/plugin/index.html
When trying to model minimal surfaces, I inadvertently stumbled upon a
way to model such drainage patterns. What you see in my demo is the
result of the drainage ridges becoming stabilized. I think it might even
lead to a way for eroding height_field data.
No, it's definitely *not* discreet. After reading up on the definitions,
I'd have to say that it's most likely continuous. I guess I have lumped
all sorts of systems into the generalized term, "CA." There's a lot of
crossover. I'm pretty sure there is a continuous version of the Game of
Life (maybe still waiting to be found).
> way.
The video surfaces are not scaled down, but they /do/ use linear
interpolation, so there is inter-pixel testing going on. I didn't use
noise for the field, but when you click the mouse, it sprays
randomly-valued pixels locally. That's the only randomization present.
Well, it was a theory that actually worked! Usually when I hit upon
something, the next phase is the small adjustment of values, to express
what's truly going on. It's hard to tell exactly /what/ needs to be
changed beforehand, since each subsequent generation becomes more and
more difficult to predict. But that's what makes these systems so much
fun :)
Yeah, the library I'm using for the GLSL doesn't allow me to tell OpenGL
to wrap a texture. Which means I need to make a function, which means
things will slow down somewhat, though not appreciably.
> Also, it
I should try that. I don't see why it couldn't be done (unless I run out
of RAM).
I'm sure a 3D version would work just fine, but would be hecka slow.
I've thought about stacking 2D surfaces and testing between them. The
current setup (768x768) amounts to 589,824 pixels. A 64x64x64 stacked
planes setup would be 262,144 pixels total. But such a setup would
require more pixel samples to be taken, and some sort of way to test the
nearest surfaces. To visualize it, I could use alpha transparency and a
simple bump-mapping technique. But there are other problems with doing
all of that that I haven't resolved.
Whoa, that's pretty fast! I've gotten no better with SDL and C++...
Yeah. Java, as a rule, just isn't that fast.
Most of the work is being done on your graphics card. That's why GLSL
appeals to me so much: I can quickly type out an idea and see it play
out in real-time. I didn't even realize the potential until I saw some
of Milkdrop's presets... At one point I was like, "Wait a minute! That's
the Game of Life, running at 60FPS! Fullscreen!!!" I didn't get much
sleep that night.
It /is/ running all-out, but it's possible that either Processing or the
graphics hardware is capping the frame rate.
Sam
Security restrictions block OpenGL? Man, whatever next...
Hmm, OK.
I see... I think.
>> all.
> fun :)
Fun and frustrating at the same time, usually. ;-)
>> 320x240.)
Well, a tiny inner loop custom-coded in assembly... Go check out Project
Euler. Apparently people really do still write assembly by hand. Go figure!
No kidding. It certainly wasn't back in 1997.
Wait - it's written in *Java* and yet it can access the *graphics card*??
How is that even possible?
Oh, well, no wonder its fast then. The graphics card is purposely
engineered to eat calculations like this for breakfast.
> sleep that night.
Yeah, Milkdrop basically 0wnz. Created by the same guy as the old Geiss
plugin too... That is one talented guy!
I wish to God I could figure out how half of Milkdrop works. There are
some amazing 3D effects which cannot be done in realtime, and yet it
does them in realtime, even though that's clearly impossible.
Right. I assumed it way rate-limited because it wasn't using all
available CPU power.
>>> geekiabilia there)
>> It is so easy. :-)
There, there, there. :-)
Hot dust?
Regards
It's not. It's using a library interface between Java and OpenGL probably
written in C or C++. Hence the security restrictions people were talking about.
The CA is written in Java, but the graphics code is still in C-ish and
shader language and such.
Back to that again? ;-)
"That was fatal?"
>> of RD.
> Hmm, OK.
It's the edge technique described in Milkdrop's preset authoring page.
When used carefully, you can produce reaction/diffusion and "skin dot"
effects.
> I see... I think.
From Wikipedia's stub on Continuous automaton:
"A continuous automaton can be described as a cellular automaton
extended so the valid states a cell can take are not just discrete (for
example, the states consist of integers between 0 and 3), but
continuous, for example, the real number range [0,1]."
You can enforce discrete rules into continuous CA, hence my argument
that there can be some crossover between the two. This is *probably*
something you would have to do to make a continuous version of Conway's GOL.
Last night I began producing a "hard" version of continuous CA in which
ships are born or killed based on area evaluation. It's looking to be a
promising method. Already, it has managed to produce three main types of
"ships," all relatively huge. In fact, it's nothing /but/ ships :S
>> fun :)
I don't find it frustrating at all <G>
Robust code, of course.
Evidently there are some security issues involved with allowing an
applet to access graphics hardware, which is likely the reason the new
version of JRE is so intolerant.
It's really not that difficult to learn (mastering it OTOH...). It draws
graphics (shapes, dots) to a texture residing on a screen-wide, flat
quad mesh (the detail of which can be changed through settings) and then
recycles the drawn graphics for the next frame. The quad mesh can be
warped to "push" the graphics around. Many 3D effects are created by
slightly altering the mesh. Then there are two pixel shaders allowing
you filter all the graphics. The first pixel shader can let you to
produce CA, reaction/diffusion, etc., since it "recycles." The other
shader is the final composite function that lets you apply a pixel
filter without affecting the next frame.
Some of the 3D effects which look too detailed, and seem to exist on a
per-pixel level, are probably effects created by a 2D shader.
Oh yeah, the common link between the reaction/diffusion link you posted
and the drainage pattern link I posted is this: http://www.cell-auto.com/
There are many interesting things to be found there :)
Sam
