OK, so I ordered some more backup tapes, and inevitably the parcel that
arrived contains a big glossy flying for all the other stuff I could be
buying.
So I flick through it and go "hmm, that's interesting. You can buy an
LCD monitor for under £100 now? That's not bad. And a portable 320GB HD
for £30? Interesting. Oh, and some Adobe software for less than £100?
Now that *is* unusual. Ooo, and a 64GB SSD for £70? My, those have come
down in price."
Some of the items are more amusing. For example, if you look at any LCD,
one of the main specs they will quote at you is the viewing angle.
Because, unlike other display technologies, LCDs typically have a
pitiful viewing angle. So manufacturers have sunk millions into R&D to
find ways to increase the viewing angle.
Ah, but what's this I see? A "privacy filter"? Yes, it's a small piece
of plastic which is transparent only when viewed from certain
directions. In other words, you stick it to your screen to reduce the
viewing angle. WTF, people!? :-D
(Of course, The Real WTF is that this thing costs £40...)
Then we find products which are just mystifying. Specifically, there's a
video camera that caught my eye. Several very strange things are going
on here.
First of all, it's supposedly a video camera, and yet it costs less than
£2,000. Actually, it costs less than £500. To be blunt, it costs £75.
This is highly suspicious.
On the other hand, a stills camera costs £100 or more, and yet my
grandparents managed to buy one for £4. Needless to say, the image
quality was laughable.
And that's where it starts to get stranger. This camera manages to claim
that it shoots full-HD 1080p video. But if you scroll past the big shiny
newsprint and look at the technical specifications, you discover that it
has a piffling 7mm lens.
Quite why anybody would pay for an expensive 2MP photosensor and then
stick it behind a crappy 7mm lens I have no idea. The only possible
justification I can think of is "so that we can scream 'full HD' all
over the box".
Damn, some poor sap is going to buy this thing and be mighty
disappointed with the image quality...
The other puzzling thing is that the device fits in the palm of your
hand. (From the price and the lens size, we already know what kind of a
product this is, i.e., an expensive novelty item.) It says it records to
flash RAM, but surely full HD is going to fill that within minutes.
The product spec also claims it stores video as H.264, which surprises
me. I was under the impression that this requires some pretty serious
computer power (most especially for encoding).
Oh, and it's purple. WTF?
A bit more expensive than you mentioned, but this company makes some
pretty cool small HD cameras for outdoor use:
http://www.goprocamera.com/
The video quality is pretty impressive, it's on my list.
For 15 quid of SD card you can store 3 or 4 hours of full HD video. And
you can always buy more SD cards.
There are various levels of compression, I imagine a low power device is
not using some of the more extravagant features that a desktop PC would
use to increase the quality:bitrate ratio.
OK, that's pretty insane, right there. (Then again, nothing I'll ever do
will be cool enough to be worth filming, so...)
Also, it costs about 5x the price of this toy.
Spec claims it comes with a 4 GB flash card, but that's going to fill in
seconds I would imagine.
I was under the impression that the compression algorithm remains the
same regardless of what bitrate you select. Higher compression just
means that more of the data is discarded. The difference between, say,
Ogg Theora and WMV is the algorithm. Once you select an algorithm,
changing the bitrate just changes how much of the data gets kept.
Then again, I would think there's probably silicon for directly
computing DCTs and so forth by now...
"HD Hero 960" is only $180, which is only about 50% more than your camera.
Spec also claims it fills a 32 GB card in 4 hr 21m. So with the 4 GB
card I make that just over 30 mins. If it was me I'd buy a couple of
16GB cards, 2hr recording time per card seems pretty decent.
You want some options to play with? :-)
http://mewiki.project357.com/wiki/X264_Settings
The only one I heard about was the motion estimation algorithm,
obviously the better it can detect motion between frame the less bits
are needed to get a certain quality level. But there seems to be a load
more options to change stuff, in a battery powered device you would need
to carefully consider how much of an impact each had on battery life.
OK, I didn't see that splashed across the front page.
Then again, I'll bet the big glossy video was shot with the flagship
product. ;-)
They make flash cards that big now? Mmm, interesting.
I'm still surprised that you can fit 30 minutes into 4 GB. My camcorder
works with DVDs and it can handle less than 20 minutes, and that's only
standard definition. (And with far more compression than I'd like too...)
OK, so you can change the frequency weightings and how often a keyframe
is put in, and so forth. I'm not seeing much that fundamentally changes
the whole algorithm such that it might require less computer power.
I was thinking more the problem of "how can we encode this fast enough
to be realtime?" It's not like the device has an Intel Xeon quad-core in
there, is it. From what I've heard, H.264 is very hungry for computer
power. (Although, as I say, I imagine the really hungry bits probably
have custom hardware acceleration in a device like this.)
Nah... My 7D records 1080p HD video and can store probably about 15
minutes on a flash card that size.
Not uncommon, especially for HD video. The encoding is usually done by a
purpose-built chip, rather that software on a general-purpose CPU.
Right, but the algorithm invariably has a trade-off for quality v.s.
speed. It can spend more cycles determining which bits are best kept, or
spend less time and dump the bits to storage, not always getting the
most important ones.
Been that way for a while. DVD players, portable media players, mobil
phones, etc ... all have hardware to do this, now.
~Mike
Again... it doesn't need to ;) The signal processor is built for one
purpose: to change a stream of frames into a stream of H.264 encoded
data. If you build it with just that in mind, then you can meet the goal
of realtime compression, you don't need to worry about that chip being
able to run Windows 7 or Linux, or accessing various IO devices, or
doing your grandmother's taxes. You only need to worry about compressing
the data.
~Mike
A 4GB DVD can contain at least an hour of decent-quality video. And that's
just using MPEG-2. (Granted, HD video has a higher resolution, but with MPEG
the bitrate does not scale linearly with the resolution.)
MPEG-4 is a bit more complicated than that. It's not like it's JPEG.
So how come BluRay disks are 5x the storage capacity, yet still have
roughly the same run time? I thought it was because HD video requires
more space to store.
I thought it was more or less the case that *all* codecs work by
transforming the input, deciding how "important" each signal component
is, and then keeping only the most important bits, according to what the
requested bitrate was. I don't see anything there that makes a higher or
lower bitrate change the amount of compute power required.
(Well, OK, maybe I do. I know a some codecs do a DCT, quantise it, and
then entropy-encode the results. Bigger results = more stuff to encode.)
On DVDs you'd be limited to under 2 hours if you used the maximum
bitrate (around 10 MBit/s IIRC), so you are forced to use lower bitrates
if you want to include menus and other various extras on the disc. With
BluRay, even if you used an average of 30 MBit/s (which is extremely
high quality with h264, and likely never actually needed, it usually is
around half that) you have about 4 hours run time. This is why you can
fit two versions of an entire film (eg 2D and 3D version) on a single
disc, plus all the extras. That would be impossible on DVD.
The whole point of video compression is trying to find patterns
frame-to-frame to reduce the information needed to reconstruct the
correct video (otherwise you'd just have a series of JPEG images). The
longer and more detailed you search for such patterns, the lower bitrate
you will be able to achieve for a given level of quality, or
equivalently higher quality for a given bitrate.
What part of "privacy" did you misunderstand?
n
sts £75.
Let me blow your mind:
http://www.dealextreme.com/p/usb-rechargeable-1-3mp-pin-hole-spy-av-camer
a-disguised-as-sunglasses-tf-slot-42736
I've never understood that, unless a 2MP photosensor is actually cheaper
in
bulk than a lower quality one.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
Making every frame a keyframe reduces the computing and memory you need. Not
using any B frames significantly reduces the amount of memory you need. Not
doing motion prediction reduces how much compute power you need. (At least
for MPEG. I don't know H.264, but I'd assume it's similar.)
Exactly.
"That was fatal?"
> I've never understood that, unless a 2MP photosensor is actually cheaper in
Well, as technology advances it often quite ironically happens that
the older some technology gets, the more expensive it becomes to purchase.
The reason is simple: Lack of demand reduces supply, and low supply means
that the product becomes expensive to produce. Production lines get
upgraded for the newer technology (if not even dismantled outright), so
the older technology becomes more difficult to produce.
Thus the price of most technology experiences a strong U-shaped behavior
as time passes: When the technology is brand new, it's extremely expensive
(both because production costs are still high due to the lack of cheap
production lines, and to capitalize on the eagerness of early adopters).
Then it quickly gets cheaper and cheaper, until it reaches the bottom of
the price valley (and depending on the product it can become almost
ridiculously cheap compared to its original price). Then it stays there
for some time, and when the technology gets more and more obsolete, and
demand decreases, it starts becoming once again more and more expensive
to produce. Depending on the product, it may at some point become impossible
to purchase anymore (because nobody is making it), or extremely expensive
(even more expensive than when it was brand new).
This is the reason you eg. don't find half-gigabyte USB memory sticks
anymore, even though one could think that they would be very cheap to
produce. In fact, they might not be. They might actually be pretty
expensive to produce, which is why nobody does anymore.
It may also explain why it's cheaper to produce a camera with a 2MP
sensor than one with eg. 1MP.
That was what I had intended to imply, yes. :-)
It's more that the technology requires a shake-down period. Yields are
tremendously low until every one of the hundreds of precise steps gets
adjusted just right. A 10% yield on early runs is a good number.
You're also paying off the design. I have a friend who designed RISC chips
for one of the big CPU companies before ARM bought them out, and he told me
about half the cost of a chip over its lifetime is design costs. That is, if
you sell a total of $100million worth of CPUs over its lifetime, it costs
about $50million to design them and $50million to manufacture and distribute
them.
Oh, and if anyone cares, here's what the video from those glasses looks like:
http://darren.s3.amazonaws.com/PICT0001.AVI
http://darren.s3.amazonaws.com/PICT0003.AVI
"That was fatal?"
> The reason is simple: Lack of demand reduces supply.
I don't recall the details now, but the other day I discovered that
something like 128MB of PC100 RAM is more expensive than 1GB of PC3200.
Or similar. Which is quite bizarre, really...
Alternatively, if you're actually buying PC100, it means you have
something really critical that you need to keep working. (Rather than,
say, just replace the damned PC.) And if it's that critical, they can
charge you "sucker fees" (i.e., whatever they charge, you just have to
pay it, because you need it that badly).
In general though, I was under the impression that most technologies
don't dissappear, they just move down the food chain. For example, the
Z80 is still in production. It's extremely popular, apparently. And
rather cheap too. (I have no idea what the original sale price was, but
currently it's a few quid.)
http://blog.orphi.me.uk/
Intel stopped producing the 80386 a few years ago, so it does happen
with some products.
> with some products.
I've seen printers and so forth that use old x86 CPUs inside. I wonder
if Intel stopped manufacturing the 386, or just licenced the design to
somebody else?
The Z80 is the CPU of choice for things that need a low-power CPU. Like,
digital voice recorders, toasters, remote controls, etc.
"That was fatal?"
On 25/01/2011 06:28 PM, Darren New wrote:
>> keyframe is put in, and so forth. I'm not seeing much that
>> fundamentally changes the whole algorithm such that it might require
Presumably the bitrate is going to skyrocket if you do that though.
> Not doing motion prediction reduces how much compute power you need.
Does the standard actually allow that?
(Now that I think about it, the decoder algorithm is usually far more
tightly specified than the encoder...)
Engineers spend decades designing an LCD with a wide viewing angle, and
then a company sells you a device to narrow the viewing angle again. :-D
How absurd.
I'm reminded of Flanders & Swan:
I had a little gramophone,
I'd wind it round and round.
And with a sharpish needle,
It made a cheerful sound.
And then they amplified it,
It was much louder then.
And you sharpened fibre needles,
To make it soft again.
At any rate, all this device does is mean that anybody wanting to
shoulder surf needs to stand somewhat closer to you. It doesn't
magically stop people seeing what's on your screen, it just makes it
mildly harder. (For *you* as well as everybody else.)
http://www.dealextreme.com/p/usb-rechargeable-1-3mp-pin-hole-spy-av-camera-disguised-as-sunglasses-tf-slot-42736
An amusing novelty toy, I'm sure...
> in bulk than a lower quality one.
Well, perhaps. I rather suspect it's because most people think the
sensor is the *only* thing that determines picture quality, so they will
simply buy the camera with the highest pixel rating.
(I vaguely recall somebody did an experiment that went something like
this: Take a photograph. Make two edited copies of it. One is slightly
sharper, the other has slightly brighter colours. Ask people which one
they prefer. That's your control group. Now ask another bunch of people,
but first tell them that one picture came from a 2MP camera and the
other from an 8MP camera. Apparently the majority preferred the 8MP
image, regardless of which one you claim to be 8MP. In other words, what
the image actually looks like has no effect on consumer choice. People
are stupid.)
Indeed. Apparently there's significant demand for Z80 programmers.
Yes. Or the quality sucks ass.
I would think so. All you have to do is say you didn't find any motion. Or
perhaps only look for identical pixels at the identical place (i.e., motion
prediction of zero velocity).
"That was fatal?"
They need to not be behind you, is all. So, if you're a bank teller trying
to keep the customers from peeking, or you're sitting on an airplane
working, or ....
"That was fatal?"
You'd be shocked to learn that 8086 and even 8085 processors are still in
use. Generally (in my experience) in aviation, where high speed is less
important than reliability, stability, and the ability to operate without
generating a lot of heat (which increases the life of the chip).
Jim
> How absurd.
Of course, because when you're using your laptop on a long flight,
sharing company confidential information with everyone in your row is a
good idea.
Jim
> use.
Given that I said a little while ago that the Z80 is still wicked
popular... not really, no. ;-)
As I said, products don't "die", they just move down the food chain.
>> How absurd.
> good idea.
Then you shouldn't be using your laptop. Obviously.
(Besides, don't they insist that all electronic devices are turned off
for the duration of the flight?)
It would be only too easy for the guy behind you to peek between the
seats and see your screen - something which even this silly angle
limiter wouldn't prevent.
Only during take-off and landing. During the flight you can operate
electronic devices as long as they are in aeroplane mode. That is no
WiFi, Bluetooth or phone transmissions.
Regards
One could assume that if a 8086 was redesigned with modern technology,
it could be built to take a hundreth of the space, made to consume a tenth
of the energy and to produce a tenth of heat.
On the other hand, presumably doing so would cost money. Stamping out
copies of the design that already exists does not cost money. (Or
rather, it costs *almost* no money.)
Then again, I gather there's a thriving business in "IP cores"...
>> in use. Generally (in my experience) in aviation, where high speed is
>> less important than reliability, stability, and the ability to operate
>> without generating a lot of heat (which increases the life of the
>> chip).
> tenth of the energy and to produce a tenth of heat.
But there's no need to do so, the original design meets the specs and
requirements.
Jim
>>> and then a company sells you a device to narrow the viewing angle
>>> again. :-D How absurd.
>> good idea.
Obviously if you have work that needs to be done, that's not an option.
Absolutely not. During takeoff and landing. Once you're at altitude,
it's perfectly fine.
Sure, it's not intended to *prevent* it, just to make it harder.
Similar to the philosophy of putting a lock on your front door. Are you
seriously suggesting that you shouldn't lock your door because someone
who's determined to get in will find a way anyways?
Jim
On Thu, 27 Jan 2011 10:52:28 +0000, Stephen wrote:
> That is no WiFi,
And even today, WiFi is OK on many flights (as there are in-flight WiFi
services now on some flights).
Jim
A better analogy would be having a front door with no locks at all, and
just putting a little notice on it saying "please don't break in". It's
so utterly ineffective that there's no point doing it.
>> That is no WiFi,
I knew it was comming, didn't know it was here.
Regards
>> you seriously suggesting that you shouldn't lock your door because
>> someone who's determined to get in will find a way anyways?
So you leave your front door unlocked, then? What was your address? ;-)
Jim
>>> That is no WiFi,
Yeah, Delta has been doing it for about a year on selected flights, and
over the holidays, Google sponsored it (so it was free).
Interestingly, they seem to block wifi-capable cell phones (my cell
wouldn't connect to it), but my eReader (based on Android, same as my
phone) had no problems - so I sent text messages using my Nook (via
Google Voice) to let people know my flight was delayed but that we were
finally en route.
Jim
>> That is no WiFi,
Funny how much less dangerous it is when they can charge you money for it,
isn't it?
"That was fatal?"
>>> That is no WiFi,
> it, isn't it?
Yeah, I've noticed that as well.
Jim
In the UK, on some trains, there are some coaches that are designated
"quite zones". No laptops, music players or phones are allowed. You even
have to turn your book pages quietly.
> finally en route.
Do you mean that your phone could not get onto the internet?
A colleague, who could not get a phone signal at a hotel I stayed at
recently, was able to phone home (to France) via Skype on the hotels WiFi.
Which reminds me: How did the passengers on the doomed 7/11 flights
manage to phone home and leave messages?
Regards
There are times I'd really like that, especially flying. :-)
>> finally en route.
> Do you mean that your phone could not get onto the internet? A
> WiFi.
Yes, my phone couldn't connect to their wifi to get on the 'net. It
would get an address and then immediately be dropped. I'm guessing they
have something that knows the MAC address ranges for various devices and
blocks the ones that are cell phones - probably so people don't have to
remember to turn off their cell signal (which you're still not allowed to
use).
There's probably nothing that prevents the cell signal from being used,
and if the plane is already doomed, turning on a cell phone isn't likely
to make things worse.
Jim
I know what you mean. :-)
>> WiFi.
> use).
Nanny State ;-)
I'm surprised they got a signal, that's all.
Regards
>> they have something that knows the MAC address ranges for various
>> devices and blocks the ones that are cell phones - probably so people
>> don't have to remember to turn off their cell signal (which you're
>> still not allowed to use).
> Nanny State ;-)
Thhhpt! :-) Technically, that's not the state, that's the airline. ;-P
>> likely to make things worse.
I'm not, radio coverage is generally not a problem - the two reasons I've
heard for turning off a cell phone are interference with the onboard fly-
by-wire systems (something I still doubt, though not as much as I used
to) and because the cell towers can/used to be confused by seeing phones
switching towers so quickly. The latter probably isn't as big of a
concern any more for the carriers, and probably doesn't cause problems
(per se) but just a lot of extra bandwidth used to switch the signal from
one tower to the next, only to have it change again almost immediately.
Jim
On 27/01/2011 10:50 PM, Jim Henderson wrote:
>> Nanny State ;-)
Reel it in, I've got a bite. ;-)
That surprises me.
> to)
I've been in a turbine control room when someone used a hand held radio.
The dials went round the clock and the annunciator board lit up like a
Christmas tree. So I can see that being possible.
I can't see that being much of a problem to life and safety.
Regards
The primary reason not to do this is that your phone will be in range of
many more towers than you normally would be. For some cell systems, this is
a Bad Thing, for performance, capacity, and possibly even for routing. It
probably has nothing to do with the actual plane electronics.
"That was fatal?"
> is a Bad Thing, for performance, capacity, and possibly even for
> routing. It probably has nothing to do with the actual plane
> electronics.
Well, I do recall that the Mythbusters tested this myth, and it rated
"plausible" with relation to the electronics. Still, I've been on plenty
of planes where people have not turned off their phones and they all made
it to their destination without incident...
Jim
>>> Nanny State ;-)
> That surprises me.
It would depend on the tx strength of the signal, but it doesn't surprise
me.
What does surprise me is that in a moving aircraft, the GPS receiver in
my phone is useless.
>> fly- by-wire systems (something I still doubt, though not as much as I
>> used to)
I could as well, but then again, there are lots of wireless signals
flying around in open space, but I would expect something that's designed
to fly through the air to have some shielding against it.
>> from one tower to the next, only to have it change again almost
>> immediately.
True.
Jim
Not all of them are. My brother has a trace from his exercize watch that
shows him flying across country.
Especially that in which the general public will be flying. I'm not
surprised there are industrial settings where following the rules is more
important than in an airplane passenger compartment.
"That was fatal?"
>> electronics.
Um, yeah. That's waht I was saying. It's not a problem for the airplane.
It's a problem for the phone carriers.
"That was fatal?"
>> That surprises me.
> me.
In the UK, you’re lucky if you can get reception in a park never mind a
plane.
Never tried. Any excuse to switch it off.
OK these were handhelds with power to reach the horizon.
Regards
