POV-Ray : Newsgroups : povray.off-topic : The ups and downs of computing Server Time
11 Apr 2026 17:56:19 EDT (-0400)
  The ups and downs of computing (Message 1 to 8 of 8)
Subject: The ups and downs of computing
Date: 3 Dec 2010 11:34:16
Message: <4cf91c08$1@news.povray.org>
Some while ago, they added a feature to the Haskell compiler where you
can link Haskell libraries dynamically rather than statically.
However, this feature works only on Unix, because Haskell hates Windows.
*sigh*
But wait! What's this? The latest and greatest version of GHC just
released now supports Windows DLLs too. Cool!
...well, partly cool anyway.
Good things:
- Compiling the Hello World program with static libraries gives me a
518KB file, but with dynamic libraries that goes down to 13KB.
Bad things:
- The program doesn't actually /run/ any more. It can't find the
necessary DLLs. It seems that /you/ have to manually copy them to
somewhere sensible and/or alter the search path.
- Finding the DLL files is non-trivial. Rather than putting them all in
one folder, the installer scatters them across the filesystem in a
pseudo-random manner. (This is quite probably why the DLL loader can't
find them either.)
- Hello World requires the DLLs for the Haskell run-time system, Haskell
compiler primitives, foreign function interface, arbitrary-precision
integers, and of course the Haskell "base" library. That's 5 DLLs you
have to have in your search path.
- These five DLLs add up to 8MB. (!)
03/12/2010  03:55 PM            12,814 HelloWorld.exe
13/11/2010  12:16 AM         7,015,961 libHSbase-4.3.0.0-ghc7.0.1.dll
13/11/2010  12:18 AM            35,854 libHSffi-ghc7.0.1.dll
13/11/2010  12:16 AM           676,886 libHSghc-prim-0.2.0.0-ghc7.0.1.dll
13/11/2010  12:16 AM           394,520 libHSinteger-gmp-0.2.0.2-ghc7.0.1.dll
13/11/2010  12:18 AM           266,240 libHSrts-ghc7.0.1.dll
                6 File(s)      8,402,275 bytes
And you thought MSVBVM50.DLL was a pain! >_<
(I especially love the way that I'm not actually /using/ FFI or
arbitrary-precision integers, and yet I must have the DLLs installed.
But then, *I* am not using FFI, but the entire Haskell I/O system is
based on it. Similarly, file sizes are returned as arbitrary-precision
integers, so the DLL for that is required.)
In summary, I don't think I'll rush out and use this feature anytime soon.
Also entertaining is the way that several new features of the compiler
aren't accurately reflected in all of the documentation. (E.g., some
chapters claim that shared libraries don't work on Windows, while others
assert that they do...)
PS. I just tried compiling with dynamic libraries using an older version
of the compiler (i.e., one which supports it on Unix but not on
Windows). Rather than saying "sorry, this is not supported on Windows",
or even just "unrecognised flag name", instead it crashes with a
file-not-found error from GCC. Graceful failure, anyone?
Subject: Re: The ups and downs of computing
Date: 3 Dec 2010 12:16:02
Message: <4cf925d2$1@news.povray.org>
DLLs are searched the same place that .exes are searched, except with the
addition of the directory that the .exe is in, if there's also a magic file
that says "search this directory too" to circumvent DLL hell. :-)
Well, sure. Because you're not just selecting at link time the routines you
use.  If you have 30 Haskell programs installed, that's a net win.
You should, so you can report on success and failure, and improve the
product. You *are* one of only 38 beta testers, after all.
Welcome to open source, where by the time you're competent enough to fix the
documentation, you no longer need the documentation!
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 3 Dec 2010 16:53:41
Message: <4cf966e5$1@news.povray.org>
> the addition of the directory that the .exe is in, if there's also a
> magic file that says "search this directory too" to circumvent DLL hell.
I'm just loving the fact that installing the compiler and telling it to
compile something is broken out-of-the-box. The fact that it does
eventually works proves that somebody actually tested it, but one
wonders what the hell kind of testing they did while managing to miss
this one...
Also: What about DLLs registered in the... registry?
And didn't "DLL hell" get fixed, like, 10 years ago?
> you use. If you have 30 Haskell programs installed, that's a net win.
Apparently the compiler's dead code elimination works quite well. But
anyway, I guess you'd have to have quite a lot of Haskell executables
before the disk space and setup complexity of DLLs makes it even vaguely
worth the effort.
>> soon.
I'm sure the number of people testing on Windows is nearer to 2. Hell,
even Mac OS seems to get better support than Windows...
> the documentation, you no longer need the documentation!
Yeah, tell me about it.
http://blog.orphi.me.uk/
Date: 3 Dec 2010 18:19:13
Message: <4cf97af1$1@news.povray.org>
> this one...
Yeah, the same was true of the Eiffel compiler when I bought it. Eiffel, the
language for reliable software!
Anyway, chances are the person who tested it had already installed it and
wound up running it against a different file. It's the sort of thing that
happens when you've got a small shop instead of someone whose job it is to
spend extra time to make sure it works on a vanilla machine.
That's not DLLs. That's COM classes stored in DLLs.
It's not hard if every function is in a separate .o blob.
   Serving Suggestion:
Date: 6 Dec 2010 04:56:42
Message: <4cfcb35a@news.povray.org>
> worth the effort.
It's a huge win if you're repeatedly transferring the same programs to the
same machine (eg rolling out updates).  Also given that people downloading
your Haskell programs might also be looking at other Haskell programs, it
probably worth offering two versions to download (one that requires the
DLLs, one that doesn't).
Date: 10 Dec 2010 04:23:28
Message: <4d01f190@news.povray.org>
>> vaguely worth the effort.
> the same machine (eg rolling out updates). Also given that people
> downloading your Haskell programs might also be looking at other Haskell
> programs, it probably worth offering two versions to download (one that
> requires the DLLs, one that doesn't).
I haven't tested this (actually I /can't/ test this), but I have a
sinking feeling that the DLLs have to be generated by the same compiler
version as the executable using them.
That means that if you have two Haskell programs compiled with different
versions of GHC, they /still/ can't actually share DLLs.
(OTOH, since GHC 7.0.1 is currently the /only/ version of GHC in
existence that can create DLLs this way, currently it's a non-issue.
This is also the reason why I can't test it...)
Of course, if you're distributing a bunch of related Haskell programs
together, they will (presumably) all be compiled together, and they can
share DLLs.
Still, the idea of making a shared library that needs to be recompiled
for every patch-level release of the compiler is... uh... unappealing?
Date: 10 Dec 2010 04:25:51
Message: <4d01f21f$1@news.povray.org>
>> this one...
> the language for reliable software!
Heh, yeah. (Although... I thought it was actually Eiffel, the language
for *reusable* software?)
> and wound up running it against a different file. It's the sort of thing
> that happens when you've got a small shop instead of someone whose job
> it is to spend extra time to make sure it works on a vanilla machine.
Sounds about right.
Oh, right.
Yeah, there's an option to do that. It tends to produce thousands of
tiny object files, which sometimes freaks the linker out. (Apparently.)
It also takes /forever/ to compile and link.
Even with this option not selected though, the program still ends up
rather small. Certainly much, much smaller than 8MB. And I'm not sure how...
Date: 10 Dec 2010 11:04:59
Message: <4d024fab$1@news.povray.org>
Both. But mainly for reliable software.
No. Then you concatenate them all into a .a file.  A .a file is simply
essentially a zip file full of .o files.
With a .so, there's no way of knowing which functions the caller will call,
because linking happens after you've already distributed the .so file.
   Serving Suggestion:
