POV-Ray : Newsgroups : povray.off-topic : time Server Time
17 Oct 2026 18:25:46 EDT (-0400)
  time (Message 1 to 4 of 4)
Subject: time
Date: 22 Nov 2010 07:34:18
Message: <4cea634a$1@news.povray.org>
On Unix there's a useful little utility usually referred to as
"time(1)". Using it, you can run a command and time how long it takes to
run and how much memory it uses.
Does anybody know of something similar on Windows?
One of the various Windows Resource Kits contains TIMEIT.EXE which
allows you to time the execution of a process, but it doesn't give you
any memory usage information.
System Internals do all sorts of interactive process monitoring tools,
but I can't find anything scriptable.
Subject: Re: time
Date: 22 Nov 2010 11:31:49
Message: <4cea9af5$1@news.povray.org>
Process monitor or powershell are probably your best bet.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Subject: Re: time
Date: 3 Dec 2010 09:11:43
Message: <4cf8fa9f$1@news.povray.org>
Process monitor also isn't scriptable (and seems to focus on recording
process events, rather than the sort of running totals I'm interested in).
PowerShell's Get-Process command happily lists out voluminous data about
all the processes in the system. Now if I can just figure out how the
**** to use the command syntax...
Subject: Re: time
Date: 3 Dec 2010 12:10:31
Message: <4cf92487$1@news.povray.org>
Performance monitor is what I meant.
I have found that adding "tutorial" on the end of what you're interested in
and googling tends to give useful results. (I'm not being snarky here. Just
pointing out that "tutorial" seems to be the word people have settled on.)
Search MSDN, too.
And of course it depends what OS you're running, as this is the sort of
thing that seems to change a lot between releases. If you're doing XP,
http://stackoverflow.com/questions/97590/whats-the-best-tool-to-track-a-processs-memory-usage-over-a-long-period-of-time
You just monitor the process, then after the fact look at the logs.
   Serving Suggestion:
