POV-Ray : Newsgroups : povray.off-topic : Coders vs Programmers Server Time
28 May 2026 02:42:13 EDT (-0400)
  Coders vs Programmers (Message 1 to 6 of 6)
Subject: Coders vs Programmers
Date: 15 Nov 2010 14:32:35
Message: <4ce18ad3$1@news.povray.org>
For example, a coder will add logging to their server code that tells them
what the server is doing.  A programmer will add logging to their server
code that tells customer service what the server is doing.  :-)
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Subject: Re: Coders vs Programmers
Date: 15 Nov 2010 16:44:01
Message: <4ce1a9a1@news.povray.org>
  Are you using "coder" as a synonym for something like "hacker"?
Date: 15 Nov 2010 18:11:37
Message: <4ce1be29@news.povray.org>
No.  A coder is someone who knows how to write code, but doesn't know how to
build an overall program. I used the term earlier here but I couldn't
remember where, so I didn't go look it up.
Coders are the people who say "I don't need to document my library, because
the code *is* the documentation."  Or "here's documentation of all the
routines, but no documentation on the required order to call them, or what
happens when there's an error, or ..."
You get the coder vs programmer distinction in all fields, tho, as far as I
can tell.  For example, in retail, it's the difference between "cashier" and
"salesman".
   Serving Suggestion:
Date: 15 Nov 2010 18:36:03
Message: <4ce1c3e3@news.povray.org>
  Perhaps I would use the term "developer" instead of "programmer" in that
case. "Developing" a software usually entails more than simply writing its
source code.
Date: 15 Nov 2010 19:29:46
Message: <4ce1d07a$1@news.povray.org>
> source code.
That works too. :-)
   Serving Suggestion:
Date: 16 Nov 2010 11:15:21
Message: <4ce2ae19$1@news.povray.org>
> them what the server is doing.  A programmer will add logging to their
> server code that tells customer service what the server is doing.  :-)
A proper software engineer will use logging to tell the user what has
happened and use trace for the service teams :-P
