Say you have something like this, as a list of endpoints, not as a raster:
http://www.puz.com/sw/amorphous/theory/amz1.jpg
Any idea how one would go about finding the paths amongst this? I.e., given
just the endpoints of the line segments as floats, and without rasterizing
it, how would you find your way from any point in the maze to any other point?
In a raster-based maze, you can just flood fill out from your goal,
incrementing the distance for each step, and then trace back along
descending distances. (I.e., use a flood-fill to set the value in each room
to be the distance to the exit, then always turn towards lower numbers.)
But that technique assumes you have a fixed set of positions to test.
You could rasterize this, perhaps at very high resolution or something,
staying away from the walls by some number of pixels, and then go from
there, but that seems even more overkill than generating the thing in the
first place.
I'm thinking you could probably triangulate all the areas between verticies.
I.e., build a list of triangles between verticies that don't contain any
other verticies, and then use the center of each triangle or something to
represent the "cells", then flood-fill from there as appropriate. Does that
sound like it would work out? It sounds like a lot of brute-force to find
those triangles given nothing but the segment endpoints. I wonder if you
could build the maze that way in the first place, plopping down a bunch of
randomish triangles and *then* drawing edges. Hmmmm...
Serving Suggestion:
"Don't serve this any more. It's awful."
> verticies. I.e., build a list of triangles between verticies that don't
> contain any other verticies, and then use the center of each triangle or
> something to represent the "cells", then flood-fill from there as
> appropriate. Does that sound like it would work out? It sounds like a
> lot of brute-force to find those triangles given nothing but the segment
> endpoints. I wonder if you could build the maze that way in the first
> place, plopping down a bunch of randomish triangles and *then* drawing
> edges. Hmmmm...
That's how to do it. If you turn the wall line segments into loops, You
can treat the maze like a complicated polygon and triangulate it as
such. It's not too hard to do yourself, but there's also libraries that
do it for you. Then just pathfind the resulting mesh.
- Slime
> given just the endpoints of the line segments as floats, and without
> rasterizing it, how would you find your way from any point in the maze
> to any other point?
Took me some time to realize you were supposed to find the way in the
background.
> room to be the distance to the exit, then always turn towards lower
> numbers.)
> the first place.
> edges. Hmmmm...
Can't you use the fact that the walls separate in two sets (see attach).
E.g. by using that every triangle visited by your path contains 2 blue
and one red vertex (or vice versa).
Download 'amz1.jpg' (321 KB)
Preview of image 'amz1.jpg'
> background.
Me too. But I'd read the algorithm. (It's described on the wiki page for
maze algorithms.)
Well, only if you want the one path from entrance to exit. That doesn't work
if you want to reach arbitrary goals within the maze - i.e., if you weren't
starting at an edge, for example.
Serving Suggestion:
On 15-11-2010 19:51, Darren New wrote:
>> background.
> maze algorithms.)
which one?
> work if you want to reach arbitrary goals within the maze - i.e., if you
> weren't starting at an edge, for example.
True, but I wasn't sure if it should solve also that general case. The
picture did suggest it wasn't.
For a more general approach I guess I would use something like dead end
filling and building a graph of all paths. Something like that is of
course also needed for the special red/blue path.
>>> background.
>> maze algorithms.)
> which one?
http://en.wikipedia.org/wiki/Maze_generation_algorithm
Basically, it's a link to an external site that, if you read between the
lines, you can figure out he draws segments of random length and direction
from various points along the lines.
Yeah, I was just trying to figure out how to *fill* something that's
described with just line segments. Hence, the title of the post.
But turning it into adjacent triangles, some of which have "walls" and some
of which don't, should do the trick.
Or even, if I wanted a slightly different maze, a bunch of random triangles,
some of which are filled in, so the walls are all different thicknesses too.
Serving Suggestion:
> verticies.
FWIW, it looks like
http://en.wikipedia.org/wiki/Delaunay_triangulation
is getting me on the way. It's the inverse of
http://en.wikipedia.org/wiki/Voronoi_tessellation
which looks like what Pov-ray uses for crackle.
Serving Suggestion:
On 16-11-2010 4:35, Darren New wrote:
>> verticies.
> FWIW, it looks like
I was thinking about that too,but you can not guarantee that existing
walls are part of the triangles. You need an additional program to flip
edges until all are in the correct order.
I think this may also work:
(first close the exit in order to get one graph)
create a list by a depth first search over the entire tree and note
every node number going down and up.
make an emty list of triangles
repeat
- find three consecutive points that form a triangle with a positive area
- add that triangle to your list of triangles
- remove middle point from list
until list contains 2 elements (both sides of the entrance)
>> verticies.
> FWIW, it looks like
you can use it to generate such a maze though
Download 'amaze.png' (28 KB)
Preview of image 'amaze.png'
>>> verticies.
>> FWIW, it looks like
Probably even more useful if I include the triangles.
Algorithm:
- generate random points in a field (in this case surrounded by lines of
fixed border points, and I removed points to close to one another to get
a more even distribution).
- create a delauney triangulaton
- find all edges of the triangles
- pick a starting triangle
- repeat
- find a triangle that was not used yet and shares an edge with this one
- if you can not find one try another used triangle until you do
- remove the edge
- mark new triangle as used
- pick a new used triangle (I first try this new one, seems to give
nicely complicated mazed, other choices give other mazes.)
- until all triangles are used
remaining edges form the walls of a maze.
Download 'amaze2.png' (30 KB)
Preview of image 'amaze2.png'
andrel wrote:
> Algorithm:
That was actually the algorithm I came up with, just about. I was goign to
use the normal Kruskal algorithm
http://en.wikipedia.org/wiki/Maze_generation_algorithms
except with triangular rooms.
Got that working. (It was surprisingly harder than it looks. :-)
Working on figuring that out next.
> - repeat
> one
> - remove the edge
Yep, that's Prim's algorithm.
I was also thinking, just stylistically, to treat triangles like walls also,
so you could have a much bigger triangle with walls of varying widths. This
will let me have (say) a maze of cliffs and crags (i.e., where instead of
walls you have deep chasms), or a maze of paths through water or lava or
something you can't really cross.
This is the unit test for my rectangular maze code:
http://www.youtube.com/watch?v=X2mkwcfEd_8
Serving Suggestion:
On 16-11-2010 18:16, Darren New wrote:
> andrel wrote:
>> Algorithm:
> to use the normal Kruskal algorithm
>> of fixed border points, and I removed points to close to one another
>> to get a more even distribution).
Was it?
That is where using Matlab comes in handy.
>> - repeat
>> - remove the edge
Possibly, it was the most obvious way to me. I am not surprised that
somebody else though of it before. ;)
> also, so you could have a much bigger triangle with walls of varying
> widths. This will let me have (say) a maze of cliffs and crags (i.e.,
> where instead of walls you have deep chasms), or a maze of paths through
> water or lava or something you can't really cross.
I think you (and me) should use in in POV somewhere.
Haven't got a clue what is going on.
BTW, do you have code to do that sitting about? I've found various
algorithms, but the speed with which you threw that together seems
impressive. :-)
Serving Suggestion:
That's why it's not a public link yet.
1) Create all the rooms with possibly-destructable (grey) walls.
2) Caller marks some rooms as "pre-open" (green), blocked (red) or post-open
(blue). So, the top left green might be a tennis court, the bottom left
green might be a drive and parking lot, the red in the middle might be a
building, the other red might be a swimming pool with a path around it, and
the blue might be where a part of the maze burned down after it was built.
So "green" acts as one big room, while "blue" has the possibility of adding
loops to the maze.
3) Mark blocked walls and walls open inside a blocked area.
4) Repeatedly pick a grey wall and examine the rooms on either side. If the
rooms are connected, make the wall black. If they're not, make the wall
white, then flood fill the smaller area to mark it as connected to the
larger area (the yellow). Stop when you've examined all walls.
5) Blow up any walls son the border of a blue room, even if that means
creating a new connection between rooms already connected.
Then, some demos of the path-finding:
A) Pick a goal room in Cyan.
B) Flood-fill from that room with the distance to the goal.
C) Put a logo in another room.
D) Repeatedly move the logo to the adjacent room with the lower
distance until you get to the goal.
Serving Suggestion:
> impressive. :-)
D=delaunay(X,Y);
sorry, I though I said I was using Matlab ;) I think it is even in the
standard library.
> I've found various
> impressive. :-)
The speed may also be explained by having experience with these
functions, doing a lot of triangulations and writing toolboxes to
support that. Actually I was home today to create a number of meshes
though they are mostly quads and not triangles. This was a nice break
from mousing all the time. And I did create programs to build and solve
mazes before, but haven't we all?
well, here is your own special planet where there is just one path
between each point on the surface ;)
Download 'maze3.png' (333 KB)
Preview of image 'maze3.png'
Sweeeet. I bet you could make some sort of sci-fi out of that concept.
Serving Suggestion:
> Serving Suggestion:
Pretty cool, and sci-fi for sure; it's a similar concept to how the great river
on Riverworld must be, covering the entire planet surface with a single river
having huge unclimbable cliffs on each side, all the way to the source.
www.McGregorFineArt.com
>> Serving Suggestion:
My idea was indeed that it could be used in a sci-fi scene, except I
hadn't a clue what the context should be. That is why I did not spend
much time on the details of this scene.
If anyone has a great idea or wants to use such a tree of lines that
span a sphere or plane, just ask. For me it was fun to prove that it
could be done, that's all. I guess I am not going to take this further.
Unless someone got another challenge...
> to any other point?
> numbers.)
I almost forgot that this threat started with this question.
Attached is your a-mazeing planet. All 'mountains' (grey) and all
'rivers' (blue) are connected. There is also exactly one path between
two mountain-nodes and between two river-nodes. (I think the last two
lines are equivalent, but I don't feel like proving that ATM.)
If your maze is the rivers, walk over the mountain ranges. If the
mountains are the maze use the boat.
Both are simple connected trees, so to find your way around any tree
traversal routine will do.
I hope this answers your question ;)
Download 'darrenworld.png' (491 KB)
Preview of image 'darrenworld.png'
Very cool. Thank you. :-)
No, but the rest of the thread did. :-)
Serving Suggestion:
