http://www.haskell.org/communities/11-2010/html/report.html
Well, there goes the rest of my week...
So far I've already read about all manner of crazy stuff:
+ GHC 7.0 is in development, featuring more new bells & whistles than is
sane for any one system to have.
- The "Jenga" of the type checker has been replaced.
- Improvements to the inliner yield 80% speedups in some cases.
- There's a new LLVM backend.
- There's a new, faster I/O subsystem.
- A long-standing glitch with Parallel Strategies has been fixed.
(And in the process tonnes of new functionality is available.)
- There's work on improving numerical performance (finally!)
- I read a paper where somebody benchmarked the standard containers
library and managed to make it go about 25% faster.
- We might finally get concurrent GC too.
- Microsoft Research is funding further development of Haskell's
parallel capabilities. (!) There's some talk of an MPI binding.
- There's more DPH improvements.
- Tonnes of other stuff too small to mention.
+ UHC (the Utrecht University compiler for Haskell) contains a bunch of
interesting stuff. Most particularly, they're using an interesting
Attribute Grammar for performing tree transformations. It turns out this
is simpler and easier than writing the transformations in Haskell -
which is rather surprising, given how good Haskell is at data
transformations...
+ There's a big long paper about The Reduceron. It's basically an FPGA
processor for running Haskell (or something like it).
- First there's a great long section where they explain their design
decisions and various theoretical benchmark results.
- Then they describe the actual design of the hardware, and the
various decisions they chose there, and what the final thing looks like.
- Finally they measure the performance of the thing. And it's not too
shabby. A program running on the Reduceron is about 4x slower than the
same program compiled with GHC and running on an Intel Core 2 Duo at
3GHz. Which is very, very impressive when you consider that the
Reduceron runs at a piffling 96MHz. (!) On the other hand, no
floating-point support yet...
God only knows what I'll find when I scroll down further...
Invisible escreveu:
> - A long-standing glitch with Parallel Strategies has been fixed. (And
amazing news, huh?
concurrent GC is almost as hard as solving a halting problem... ;p
that SPJ guy sure has some ballz.
whoa!
how about an OpenCL port. ;)
a game sig: http://tinyurl.com/d3rxz9
> amazing news, huh?
Have *you* tried it? :-P
Seriously, analysing the structure of a huge chunk of data while it's
still being modified is no picnic.
I said MSR is funding it. I didn't say why. It might be nothing to do
with SPJ. There /are/ other people getting paid to use Haskell, you
know. ;-)
> whoa!
Oh, I gather somebody's doing that for their PhD thesis...
But still, modern CPUs are especially designed for the way normal
programs work. Functional programs work in a totally different way;
maybe by designing the hardware differently, it can go faster? It's
worth at least trying it out to see how it goes.
...and now I'm reading about Agda, a programming language which has
MELTED MY MIND! >_<
> > amazing news, huh?
If Haskell requires a garbage collector, it means that objects are not
strictly scope-bound (in other words, objects can outlive the scope where
they were creted, rather than being automatically destroyed when the scope
ends). This, consequently, means that objects are not handled by value, but
by reference (or pointer, or whatever you want to call it), which is a
requirement if you want to share the same object with more than one other
object. I know next to nothing about Haskell, but the little I have seen
doesn't look like it would be reference-based code. It *looks* to me like
everything is handled by value.
Could give a simple example which demonstrates the need for a GC?
Warp escreveu:
>>> amazing news, huh?
kinda weird your reasoning there. Java passes things by reference and
still needs a GC. I don't quite see the linking between the need for a
GC and passing things by reference or by value.
In normal Haskell code, all data is immutable. It's therefore impossible
to tell whether it's being passed by reference or by value; either
choice makes no difference to the end result. It only affects
performance. This is probably why Haskell "looks like" it passes by value.
I always used to think that creating a data structure who's size is not
statically known required handling it by reference. However, C++ somehow
manages to do this by value, so it seems my assumptions are incorrect.
In fact, thinking about it, you probably /could/ implement Haskell
without GC. It would just be far less efficient, that's all.
Anyway, as an example: Consider the function
linear a b x = a*x + b
You probably think that this function takes three numbers and returns a
number computed from them. Strictly speaking, this isn't true; in fact
this function takes three numbers and returns /an expression/ containing
them. What the caller actually gets back is a reference to the root of
an expression tree. For example, if I do "linear 2 3 5", I get back a
reference to the root of a tree that looks like
* 3
2 5
If I try to /use/ this value, this will execute the (+) function. The
first thing this does is inspect its arguments, which causes the (*)
function to execute. After it executes, the tree looks like
10 3
2 5
There are now two items of garbage: the 2 and the 5. Further, after (+)
finishes executing, we have
13
10 3
2 5
So now there's 4 items of garbage (2, 5, 10, 3).
The real situation is of course a bit more complicated than this, but
you get the idea.
nemesis <nam### [at] gmail com> wrote:
> Warp escreveu:
> >>> amazing news, huh?
> still needs a GC.
Isn't that what I said above? You write as if I had said the exact
opposite (ie. that languages using references don't need GC).
If you handle objects by reference, and you can pass references around,
it means that objects can be shared and that the lifetime of these objects
is not bound to the scope where they were created. If objects outlive the
scope where they were created, you need some kind of GC to destroy them
(unless the language is such that leaking objects is ok).
No, dynamically allocated objects can only be handled with a pointer.
You can of course wrap that pointer so that it looks and behaves like
the allocated object itself, but as if handled by-value (including being
scope-bound).
For example you can handle an instance of std::vector or std::string
by value, but internally they contain a pointer to dynamically allocated
memory (which they manage).
It would be less efficient because it would require always deep-copying
data when it's passed around?
> * 3
> 2 5
> 10 3
> 2 5
> 13
> 10 3
> 2 5
> you get the idea.
It looks like a really inefficient way of computing a simple calculation.
Warp escreveu:
doh! I read it wrong...
Basically. Deep-copying and duplicating.
If I say
X is a list [1, 2, 3]
Y is a list prepending 0 to X
Z is a list prepending 9 to X
then X is still out there only once, and Y and Z point to it. Lists are
"linked lists" rather than array-like lists.
>> you get the idea.
It's a lazy calculation. Hopefully the compiler can figure out when it
doesn't actually need to do that.
Serving Suggestion:
"Don't serve this any more. It's awful."
However, as I understand it (keeping in mind that I don't actually know
Haskell) it does have the implication that it can be much harder to
reason about the efficiency of a program, since it depends quite a bit
on what tricks the compiler can use. This is in contrast to a language
like C where the relative simplicity of the compiler means that the
approximate performance is much more obvious.
It seems like a pretty common double-edged sword. Smarter systems often
allow you to do things more easily at the cost of the need for more
mental space required to know when the smart system will fail and how to
correct it.
Yep.
> correct it.
I think the best model is something SQL-like. Where you express the
semantics of what you want, and then in a separate place say "by the way,
here's hints to make it faster."
It's also the case that, generally speaking, there are on occasion things
you can make more efficient in a higher-level language than a lower-level
language, simply because there's more information about intent there. As in,
it's way easier for C to micro-optimize my call to memcpy() than it is to
micro-optimize my while loop that does semantically the same thing. And it's
way easier for the SQL interpreter to figure out the best access pattern
than it is for my C compiler to analyze my code along with the BDM to figure
out how to optimize access.
Unfortunately, there are relatively few high-level languages that actually
give you the option of telling the system how best to optimize stuff, even
tho the concept has been around for ages.
Serving Suggestion:
> scope-bound).
I see. (I think!) So, presumably, when you copy std::vector "by value",
all it's actually copying is the reference to the real data?
That's one reason.
The other reason is that Haskell expressions are not restricted to being
*trees*. They can be general *graphs*. This is how you implement a
common sub-expression such that it only gets computed once - a very
useful thing to be able to do (obviously). I'm not quite sure how this
would interact with a non-GC implementation.
>> you get the idea.
It is. That's why there's an entire optimiser pass dedicated to removing
all these steps if possible. If a, b and x are just plain ordinary
integers, it's highly likely that the final machine code will just chuck
those variables into machine registers and do the usual binary
arithmetic directly.
Of course, all of this graph reduction /is/ pointless for a simple piece
of arithmetic. But if we choose a less trivial example, it becomes clear
why it's useful. For example, that old chestnut of the Fibonacci
function where the output depends on the output. That's impossible in a
normal language, but trivial in Haskell.
(Obviously no programmer in history has actually /needed/ the Fibonacci
numbers. And if they did, there's a well-known O(1) algorithm for them
anyway. It's just an example.)
> MELTED MY MIND! >_<
Idris is similar, with moderately less mind-meltation. Even so, all of
the documentation is clearly written for somebody already familiar with
the idea and just wanting to learn the actual syntax.
It's provable (no, not a typo of "probable", different thing) that, in
the general case, the problem "will this line of code ever be executed?"
is an unsolvable problem. Hence a compiler can make that decision only
in the most trivial cases.
Actually, when you assign an std::vector object to another, whether it
performs a deep-copy of the data or if it uses some copy-on-write mechanism
to perform lazy copying depends on the library implementation, but AFAIK
most if not all library implementations use deep-copying.
Thus, if you assign one std::vector object to another, all the data it
contains will be copied as well.
Of course if you want copy-on-write instead, then you can create your own
"vector" which does that. (I have actually done precisely this for some
projects because of the benefits of this technique.)
More tractable is "if X is executed then Y is definitely executed". For
example, the arguments to (+) [over integers] will always be executed.
Therefore, any code that calls (+) can just pass two integers, rather
than bothering to build a graph of heap objects to pass.
It would be one thing if the compiler knew about the special properties
of built-in functions like (+). But in fact it performs a "strictness
analysis" pass which infers this information for all user-written code.
http://blog.orphi.me.uk/
