POV-Ray : Newsgroups : povray.off-topic : Omniscience Server Time
17 Oct 2026 18:25:36 EDT (-0400)
  Omniscience (Message 1 to 11 of 11)
Subject: Omniscience
Date: 10 Nov 2010 22:23:44
Message: <4cdb61c0@news.povray.org>
Is it possible for a non-deterministic turing machine to solve the halting
problem of deterministic turing machines?  That is, can I use a NDTM as an
oracle for DTMs?  I don't think so, right?  There's no way to check your
guess is correct, basically?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Subject: Re: Omniscience
Date: 10 Nov 2010 22:34:36
Message: <4cdb644c@news.povray.org>
> halting problem of deterministic turing machines? That is, can I use a
> NDTM as an oracle for DTMs? I don't think so, right? There's no way to
> check your guess is correct, basically?
Since you can simulate a NDTM with a DTM (at the expense of an
exponential increase in time), no.
Date: 11 Nov 2010 00:31:40
Message: <4cdb7fbc@news.povray.org>
That's what I thought, but I'd figure I'd check.
   Serving Suggestion:
Date: 11 Nov 2010 10:47:43
Message: <4cdc101f$1@news.povray.org>
As a sort of philosophical point, if you believe the Church-Turing
thesis, then anything which could solve the halting problem for DTMs
wouldn't resemble an "algorithm" and would instead have to be either a
black box or quite bizarre.  You can often use this intuition to
correctly eliminate whole classes of architectures since they still look
"algorithmy", like NDTMs or QBIT-based quantum computers etc.  If you're
interested in more, the keyword you're looking for is "hypercomputation".
Date: 11 Nov 2010 15:34:48
Message: <4cdc5368@news.povray.org>
It actually came up during an argument someone was making, pointing out that
an omniscient god is contradictory to free will.  I simply pointed out that
an omniscient god is contradictory to logic at all, free will or not, so
trying to use logic to disprove the existence of an omniscient god is silly.
   Serving Suggestion:
Date: 11 Nov 2010 16:05:36
Message: <4CDC5AA0.8010108@gmail.com>
> that an omniscient god is contradictory to free will. I simply pointed
> out that an omniscient god is contradictory to logic at all, free will
> or not, so trying to use logic to disprove the existence of an
So you are trying use logic to show that you can not use logic? Let's
take this outside to the next metalevel.
Date: 11 Nov 2010 16:10:22
Message: <4cdc5bbe$1@news.povray.org>
To the best of my knowledge this argument was first dealt with (IIRC) by
St. Augustine.  The analogy with the way in that that my knowledge of
your *past* actions doesn't mean that they weren't made freely.  If
you're willing at accept a view of God existing outside of time, then it
doesn't seem to unreasonable to also posit that God's knowledge doesn't
conflict with free will in much the same way.
It's been a while since I heard the argument though, so I'm probably
missing some elements.
How so?  I only see an obvious argument like that for a particular sort
of omnipotent God, rather than a merely omniscient one.
Date: 11 Nov 2010 16:22:03
Message: <4cdc5e7b$1@news.povray.org>
No, my stance was that arguing logically about religion at all is silly. :-)
Primarily because you're talking about a supernatural being who by
definition is outside the realm in which logic works.
   Serving Suggestion:
Date: 11 Nov 2010 16:23:42
Message: <4cdc5ede$1@news.povray.org>
That's generally the argument I've heard, yes. Or succinctly, it's not that
God knows what you'll do, it's that God will always have known what you did. :-)
If God is omniscient, then he knows whether every program will halt or not.
   Serving Suggestion:
Date: 11 Nov 2010 16:46:29
Message: <4cdc6435$1@news.povray.org>
Sure, but I don't see how that's a logical contradiction.  All it means
is that God has abilities/knowledge that are non-algorithmic (an
assertion I'm sure would be agreed with by almost any theist).  It's
still possible to logically reason to a degree about things which are
non-computable, and certainly no logical contradiction in asserting the
existence (at least in a Platonic sense) of things which aren't computable.
The furthest I can see your argument being pushed would be to limit the
sort of reasoning we can apply when talking about God, where it implies
that we can't know *everything* about God through logic, but I don't see
how it implies that we can't know *anything*, or that the sort of
omniscience you describe is incompatible with logic.
Perhaps I am misunderstanding the point you are making?
Date: 11 Nov 2010 16:57:51
Message: <4cdc66df$1@news.povray.org>
>> not.
I didn't say it was impossible. I said it was illogical, by which I meant
logically contradictory. I don't think you can use algorithmic logic to
disprove the existence of everything that isn't algorithmic logic.
> non-computable,
Sure.
Logical inevitability, actually, since we've already proven such things
exist logically.
Well, the usual argument is that God can't exist because the following
features of God are logically contradictory: Omniscience, free will,
omnipotence, etc etc etc.
I'm pointing out that if you accept God is omniscient at all, then you have
proven that God is not constrained by (formal) logic, at which point trying
to prove his nonexistence via logic isn't going to work. Or you're going to
have to use some other form of logic (maybe one that's paraconsistent) in
order to reason logically about omniscient creatures.
   Serving Suggestion:
