POV-Ray : Newsgroups : povray.off-topic : That Friday feeling Server Time
17 Oct 2026 18:25:43 EDT (-0400)
  That Friday feeling (Message 1 to 18 of 18)
Subject: That Friday feeling
Date: 5 Nov 2010 08:54:27
Message: <4cd3fe83$1@news.povray.org>
Are you bored? Fancy a laugh? Read this:
http://www.datarecoverylabs.com/ultimate-computer-language-guide.html
Or rather, read this if you enjoy reading hilariously inaccurate
nonsense being passed off as definitive fact.
Subject: Re: That Friday feeling
Date: 5 Nov 2010 09:08:23
Message: <4cd401c7$1@news.povray.org>
Thinking about it, I could have just said "go look up Intelligent
Design"... :-P
Date: 5 Nov 2010 11:35:01
Message: <web.4cd423e1f7fc0b00f48316a30@news.povray.org>
"Haskell is a scripting language inspired by Python."
LOL
the rest is quite accurate.  Or might I say, *was*.  Because once upon a time C
indeed was high level and javascript was interpreted...
Date: 5 Nov 2010 11:56:36
Message: <4cd42934$1@news.povray.org>
> LOL
Yes. There's not a lot else you can really say to that.
Um...
"Bash is a type of Shell Script. Shell scripting languages are mostly
intended for automating system tasks, as opposed to offering truly
dynamic programming abilities."
"Forth is a Stack Computing Language. Basically the language represents
two virtual stacks to accomplish algorithms."
"Java is one of the first truly object oriented languages."
"PHP is a hypertext preprocessor."
"Perl is a command line language similar to C, and Shell Script."
"Ruby is a multi-paradigm language with syntax similar to Perl. It is
often compared to Java in as much as both languages borrow
object-oriented syntax pioneered by small talk."
"Tcl, like Perl, and other scripting languages, is an interpreted
scripting language designed mostly for console use. It is extensible
through high level languages like Java."
...still think it's accurate? :-P
Date: 5 Nov 2010 11:59:46
Message: <4cd429f2@news.povray.org>
  Why is C not considered a "high level language" anylonger, given that
once it was?
  AFAIK originally the idea with a "high level language" was a language which
abstracts away the machine code completely, allowing the same program to be
compiled for completely different and unrelated processor architectures. This
in contrast with assembly, which is a 1-to-1 correspondence between machine
code instructions and keywords, making the language completely tied to the
specific processor architecture and hence non-portable.
  Consider, for example, the x86, PowerPC, ARM, UltraSparc and DEC Alpha
processors. They are completely different architectures, and completely
incompatible with each other. The same machine code, or even the same
assembly program, which works in one of them will not work in the others.
However, the exact same C program can be compiled to all of them without
modification, and it will work in the same way in all of them. That's what
makes it "high level": It abstracts away the processor architecture.
  This is a rather concrete definition of "high level language". However,
at some point a much fuzzier definition was introduced, and this new
definition excluded C. What exactly *is* the precise new definition?
I have no idea. Why was it necessary to be introduced? I have no idea.
Date: 5 Nov 2010 12:06:24
Message: <4cd42b80@news.povray.org>
Warp escreveu:
> once it was?
I'm tempted to say because there are now much higher level languages
than C, whose implementations indeed use it mostly as portable assembly.
But then I remember Lisp was there when Dennis Ritchie was still a kid,
so C was actually never a high level language to begin with, and the
fact that it was created most specifically to allow to port Unix to
other platforms should be a good clue of its original intent...
a game sig: http://tinyurl.com/d3rxz9
Date: 5 Nov 2010 12:11:45
Message: <4cd42cc1$1@news.povray.org>
Invisible escreveu:
that's ok.
that is quite about it, too.
that is lame.
that is true.  They could add that it is really a severely limited Perl
with an annoying preprocessor builtin.
that is quite bad.  Perl is more like a portable Unix shell, sed, awk
and grep and all included...
that is quite lame too.  Ruby's main influences are indeed Smalltalk and
Perl, with a few influences from Scheme Lisp...
jesus!
Date: 5 Nov 2010 12:24:09
Message: <4cd42fa9$1@news.povray.org>
> that's ok.
Once we decide what the nebulous "truly dynamic programming abilities"
is even supposed to *mean*.
>> represents two virtual stacks to accomplish algorithms."
The program "represents two stacks" in order to "accomplish algorithms"?
> jesus!
The prosecution rests.
Date: 5 Nov 2010 12:32:36
Message: <4cd431a4$1@news.povray.org>
> once it was?
As I understand it, originally almost /everything/ was written in
machine code, by hand. Compared to that, C is a very, very high-level
language.
Today I can write programs in languages that are so high-level that they
sometimes don't even look like they should be executable. They almost
look like pseudo-code.
I guess that's the difference.
(And no, you can't objectively measure such a thing.)
Date: 5 Nov 2010 13:18:12
Message: <4cd43c54@news.povray.org>
> language.
  Well, C was invented in 1972, while LISP was invented in 1958, and the
latter is considered a very high-level language even today.
Date: 5 Nov 2010 15:55:06
Message: <4cd4611a$1@news.povray.org>
>> language.
Yeah. Maybe it's just because Lisp's abstractions are further removed
from the hardware.
Oh, wait. Lisp Machines.
http://blog.orphi.me.uk/
Date: 5 Nov 2010 19:50:01
Message: <web.4cd4974cf7fc0b00bc5b91720@news.povray.org>
> >> language.
> from the hardware.
only a reality in the early 80's...
Date: 5 Nov 2010 21:08:44
Message: <4cd4aa9c$1@news.povray.org>
> once it was?
I think it was only "high level" compared to assembler. FORTRAN was also a
"high level" language, for example.
I don't think there is a precise definition. The term got fuzzy when there
came more than one criterion for "high-level" ness. You have languages that
are more or less portable, languages that are more or less powerful,
languages that are more or less safe, languages that are more or less
strict, etc.  C used to be one of the highest level languages, but 40 years
later we have other languages that are much more abstract and powerful while
still having the same portability that C does, so C is no longer a "high
level" language.
It's like saying "A five-story building in Napoleon's day was a tall
building. Now it's not tall any more. What happened to the definition?"
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 6 Nov 2010 09:21:37
Message: <4cd55661@news.povray.org>
> level" language.
  How about instead of having just the false dichotomy of "low-level" and
"high-level" languages, there could be more options. Perhaps C could be
a "middle-level" language (because it's higher-level than asm but lower-level
than eg. Lisp).
Date: 6 Nov 2010 09:53:29
Message: <4cd55dd9$1@news.povray.org>
> than eg. Lisp).
I think most people today accept that there are highER and lowER levels
of programming languages. Machine code is obviously the lowest level of
all; authorities disagree about the exact ordering of the remaining
languages.
Date: 6 Nov 2010 10:32:27
Message: <4cd566fb@news.povray.org>
> > than eg. Lisp).
> languages.
  Could there be, in some cases, some ego-boosting involved, of the kind
"my language is higher-level than yours"?
Date: 6 Nov 2010 13:49:46
Message: <4cd5953a$1@news.povray.org>
I would certainly think so. While there are clearly a number of axes along
which "high level" (or "powerful") can be measured, the relative importance
is difficult to order.  Some people may find performance more important than
safety, and vice versa, for an obvious example. Others may find ease of
coding more valuable than assurance of correctness (leading to people
complaining about "bondage and discipline languages").
I was thinking about this lately, but I haven't had time to write up a whole
message. :-)
   Serving Suggestion:
Date: 7 Nov 2010 22:54:23
Message: <87d3qgjwp3.fsf@fester.com>
Warp <war### [at] tagpovrayorg> writes:
Because computers live in a binary world.
