And I mean *really* deep:
http://www.youtube.com/watch?v=foxD6ZQlnlU
Years ago I asked here the question: "If you zoom enough into the
Mandelbrot set, will you finally find the Truth?"
If you watch that fullscreen from start to finish, with sounds on,
maybe you will.
> maybe you will.
That is deep!
I can't say I appreciate or like the music.
Thanks for posting, I like the 3D version. :-D
Best Regards,
It's not a question of liking it. It's a question of feeling it.
That's as deep as the zoom ;-)
Best Regards,
Very cool. Altho I'm not quite sure what his comment about the speed of
light is supposed to mean. :-)
Serving Suggestion:
"Don't serve this any more. It's awful."
I find it interesting that at the beginning of the movie, it zooms into
largely repetitive areas of the fractal (fringe areas where very similar
features are repeated over and over next to each other), and then for
the last two thirds, it zooms into one specific point of interest.
During the second part, you can see wheels with spokes, and the number
of spokes increases, slowly at first and then very quickly until the end
(which I won't "spoil" for those who haven't watched it). It's as though
bypassing all the repetitions in the first part is "winding up"
complexity that has to be "unwound" by zooming very deep into the
concentric circles in the second part. There's probably a mathematical
explanation for this.
- Slime
That is really, really deep. Everything a look at now appear to be
receding away from me.
It's also very pink. I don't know what this was rendered with, but it
seems to have a 256-colour limit, meaning that the colours repeat a hell
of a lot. I did a zoom not unlike this using POV-Ray. Obviously the AA
is all over the place, but it does mean I have unlimited colours, and I
can map them as I see fit.
The location chosen is very, *very* repetitive. I mean, really, if you
watch the first minute or two of the video, you've now seen everything
there is to see for the entire 10 minute marathon.
Ditto for the music, actually. It's just a drum beat with some
occasional accompaniment. I like trance music, but this is the kind of
thing I'd routinely skip over. There's just too much drum and not enough
notes. I also find it kind of interesting that I'm gazing at pristine
mathematical perfection while listening to distorted gurgling electronic
grunge.
Of course, what I'd really like to do some day is do a long fractal zoom
(or more likely a succession of them), and spend time tweaking all the
colours to the exact details of the fractal, and build some sort of
soundscape that complements each feature of it. Sadly, I am drastically
incapable of synthesizing such a transcendental fusion...
That's what I thought too. It reminded me of the old FractInt, which,
by default, saved to .GIF so it was limited to 256 colors as well.
*Googles*
Holy crap! FractInt is still maintained! There goes today's hope of
doing actual work.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
> doing actual work.
What, you didn't know that? ;-)
I used FractInt to produce all my stuff on Zazzle. Still, I keep meaning
to put together a "real" fractal renderer one of these days. One that
can handle 48 megapixel images without having to render them as
two-dozen GIF images rendered in a framebuffer that has to fit inside
"conventional memory" (!!) and then stitching them together into a giant
50MB GIF file. It's really slow...
Naturally POV-Ray won't cut it for such a deep zoom because it will
start glitching out at about 2^50 zoom factor (because 'double' only
has 53 mantissa bits). You need a software with multiple-precision
floating point numbers (or such a library, if you want to write the
program yourself). Of course rendering such deep zooms with such a
library will be slooooow (because software floating point is very slow,
and the amount of iterations required for such zoom levels doesn't help
the matter either).
> the matter either).
I wouldn't think it takes more iterations per pixel to do a deep zoom than
to do a surface zoom. (Of course, if you have the whole set in view, sure. I
mean when you're at 2^30 zoom, does it really take fewer iterations per
pixel than 2^70 zoom?)
Serving Suggestion:
The number of spokes jumps up and down most of the time. I tried to
guess how many there would be in the next generation to keep it a bit
interesting for me.
Let me spoil it for them ;) If you look at the first few minutes, you
know what the last shot will be.
> It's as though
I think most of it has a more easy artistic explanation. And possibly
also some technical explanation. It might be that this point that they
wanted to find at the end is more easy to find here. How much time would
they have spent in setting up this shot?
Darren New <dne### [at] san rr com> wrote:
> > the matter either).
It does. Each color band in the classically-colored Mandebrot set (which
is what is used in the video) represents one iteration. Now count how many
distinct color bands there are in the entire video (I have no idea, but
I'm guessing it's in the millions).
It's more like you don't *need* so many iterations for a 2^30 zoom to
look good as you need for a 2^70 zoom. You *could* use the larger amount
of iterations also for the 2^30 zoom, but it would change very little
(only pixels adjacent to the set would probably get different coloring).
> the matter either).
Povray runs out of steam long before you hit *that* limitation because of the
artificially low limit of 32000 set for the iterations.
>>> the matter either).
Maybe I've misspoken somewhere.
Figuring out what color to make one pixel near the end of the video doesn't
take more iterations than figuring out what color to make one pixel near the
start of the video?
It sounds like you're saying that a 1 minute video takes fewer iterations
than a 10 minute video. Yes, that seems obvious.
But does drawing a 640x480 pixel section of the mandelbrot set (on the
border of course) that's 0.0001 on a size take fewer iterations than drawing
a 640x480 pixel section of the mandelbrot set that/s 0.000000000000001 on a
side?
I don't see how this works out, tho. If you have 256 colors, you (could) do
256 iterations for each pixel, regardless of the mapping of the cartesian
plane to the screen, yes?
Serving Suggestion:
> doesn't take more iterations than figuring out what color to make one
> pixel near the start of the video?
To be absolutely technically correct, computing pixels at a higher
magnification does not /necessarily/ require more iterations. However,
if the part you're magnifying is one of the "interesting" bits (i.e.,
not a screenful of flat colour) then yes, yes it does take more iterations.
> do 256 iterations for each pixel, regardless of the mapping of the
> cartesian plane to the screen, yes?
If you only do 256 iterations, then after a very modest zoom (30x or
so), you won't see any additional detail.
(I presume you meant "up to" 256 iterations, since the pixel's colour
indicates the exact number of iterations performed - or in this case,
the least significant 8 bits of the count, anyway...)
> start of the video?
It does.
The farther away you are from the border of the set, the fewer iterations
it takes for the complex numbers to bail out (ie. to exit the circle of
radius 2, which is usually what's used for this). The closer you get to
the border of the set, the more iterations it takes for it to bail out.
If you do too few iterations, points very close to the set will look like
they belong to the set even though they don't, and thus get wrongly colored
like the interior of the set (in other words, all color bands which are
closer to the set than the iteration amount will get colored black).
Zooming into the Mandelbrot set usually means zooming to some point which
is extremely close to the border of the set (any other place would be boring
because you would get a flat color after a little while). Zooming to a point
which is extremely close to the set means in practice that you are approaching
the border of the set, and hence you need larger iteration counts in order
to get the correct result. (If you don't increase the iteration count
appropriately, you end up having a wrongly-colored black image.)
As I said in my earlier post, with the classical coloring each color
band represents one iteration (in other words, all the pixels of that
color took the same amount of iterations to bail out). The pixels of a
color band immediately inside another color band took 1 iteration more
to calculate. If you count the total number of distinct color bands,
you will get how many iterations it took for (each of the pixels of) the
innermost color band to calculate.
In the video I estimate this count is in the millions.
No, I'm talking about individual images. The amount of iterations needed
to get a proper result depends on the zoom level.
> side?
Yes, if you are looking at the border of the set (and you want a result
which is correct).
The palette size doesn't affect how many iterations you need to perform
per pixel in order to get a correct image. It's simply that the iteration
count (before bailout) is mapped to the color palette, and you can do that
however you wish.
Why is there such a limit?
Is there such limit ? (in which version ?)
I do not see such limit to 32000 in mandel pattern in 3.7beta38 code.
And it does not seems to be present either in 3.6.1;
Now the actual code of mandelbrot's pattern computation might be
sub-optimal when compared to dedicated code. But that's another story.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
I stand corrected, in 3.6.1, it's a short;
And it is still so in 3.7;
It can probably easily be fixed by a change of type in the frame.h for
3.7 (Iterations field)
Thanks for the discussion, but are you saying there are some versions of povray
with a limit, or that I need to prove my assertion? As an animator I *am* stuck
with Megapov because I need some of the features that aren't allowed into the
3.5+x versions of povray.
Ah! I see. Very cool. Thanks for the insight! That makes sense now. I
hadn't connected it with "how close to the edge are you".
Serving Suggestion:
Le 02/11/2010 16:18, gregjohn nous fit lire :
First one. I first look at the parsing and usage of the iteration limit,
and see no limitation to 32000 (they all use int, which is expected to
be something like 31 bits value on most hardware).
Then I (too late) open the struct definition... to find that the value
is stored in an short.
Just out of curiosity (3.7 is so late that adding more features now is
probably a big no-no, and I'm not in charge of that anyway), which ones ?
i) camera_view
ii) STP
iii) advanced splines: it actually made a difference in the look of some of my
SDL- procedurally-generated mesh-based modeling, but might be hard to prove it
right now.
Feel free to deduct 10 points from my score if the latest 3.x were to have
actually most of these.)
Thanks also for checking on the Mandel code. I found that the iterations limit
of 32000 makes for "ugliness" at high mag long before the calculation precision
runs out. How about making that a double ! ;-)
Btw, that also explains why you need more mantissa bits to zoom deeper.
The complex numbers which start "on screen" don't stay there during the
iterative process. Instead, they orbit around and start escaping to
infinity (in practical implementations it's tested if they leave the
circle of radius 2, because it's easy to prove that if an orbit leaves
that circle it will inevitably escape to infinity). Thus you need to be
able to take some complex numbers which require a very high accuracy
(dozens and even hundreds of decimal places, depending on the zoom level),
and do calculations until they reach the circle-of-radius-2 limit.
You can see the mantissa limit being hit when you zoom enough into the
set when you start getting rectangular artifacts. As stated, standard
double-precision floating point variables allow a zoom factor of something
around 2^50 before you hit the limit.
> As stated, standard
But povray's iterations limit of 32000 causes one to lose details far before you
get to that.
Le 02/11/2010 20:09, gregjohn nous fit lire :
Well, their might be room for better usage of the structure:
iterations, ext_type & int_type are all stored as short so far.
* iterations could well be extended to an unsigned int (does negative
iteration make sense ?) (I'm afraid of a per-pixel-loop of more than
2^32, as the next step would be 2^64 (it might have a portability issue
too) even at 2 Giga operation per second, that's only 2 x 2^30 loop per
second, at best 2^32 needs a few seconds, we do not want to wait for
2^34 seconds for one pixel (even per core...). So 32 bits for the
iterations should be enough, shouldn't it ?
* both *_type are 0 to 6... they could share a byte (it's worthless on
current architecture, they can probably have their own byte anyway,
allowing fancy extension from 7 to 127 or 255 if anyone ever come with
such new different conversions from computation to the map)
And looking at the type, I wonder why there is not already something like:
(for exterior, i guess; as for interior, it's a constant)
return (Iterations % (Factor+1))/Factor
(or simile)
mesmerizing...
yeah, only took the time to watch it now...
Me too. I didn't watch it previously because it was posted on 10/31, so
I expected it to end with me getting the sh** scared out of me by a loud
scream and a picture of Linda Blair popping up.
Francois Labreque <fla### [at] videotron ca> writes:
> doing actual work.
Not well maintained, though.
>> doing actual work.
No, there is that.
Then again, most of the recent questions on the FractInt mailing list
are "how do I make FractInt run under Windows XP?" or "how do I make an
MS-DOS boot disk?"
It's a powerful little program, for sure, but I fear it has been
somewhat left behind by now...
Is it open source? It would seem to be the kind of thing that isn't hard to
keep up to date, at least at the core.
Serving Suggestion:
> >> doing actual work.
> No, there is that.
> MS-DOS boot disk?"
I would recommend XaoS. It might have all the features of fractint, but
most fractals can be zoomed in real-time, which makes it cool.
>> >> doing actual work.
>> No, there is that.
>> MS-DOS boot disk?"
I'd love to see a screensaver like that =)
-Nekar Xenos-
> to keep up to date, at least at the core.
Yeah, the source code is completely open.
On the other hand, the entire UI is text-mode fun and games using BIOS
calls, and the entire graphical engine revolves around either calling
the BIOS or directly poking magic numbers into hardware registers.
(Wanna guess why it doesn't work under Windows any more?)
On top of that, the entire program fundamentally assumes you're working
with 6 bits per channel and palette graphics. These assumptions are not
easy to change. (E.g., all of the external file formats describe colours
as triples of integers between 0 and 63.)
Really, it would be simpler and quicker to just start again. And indeed
many modern fractal programs understand FractInt parameter files as a
sort of de facto data standard. (Although none of them have the layers
upon layers of backwards compatibility that FractInt itself has, and
AFAIK none of them can read the data chunks that FractInt embeds in the
GIF files it writes.)
Then again, I'm not really aware of any freeware program that has quite
the range of scope that FractInt has. Most of them seem to plot just one
kind of fractal, and that's it...
On the other hand, it seems to be comparatively slow. And it doesn't
have arbitrary precision, so you can only zoom in so far. (Then again,
FractInt's arbitrary precision mode makes continental drift look fast,
so...)
It also has an annoying habit of sometimes "forgetting" to finish
rendering an image. Like, when you zoom in it's all blocks, and
gradually the resolution increases. But sometimes, it stops increasing
before it's finished.
Comparatively slow? You can use XaoS to zoom into the Mandelbrot set
(and other fractals) in real-time. Fractint isn't that good.
> (Then again,
> so...)
Btw, "continental drift" is an obsolete theory. "Plate tectonics" is the
currently accepted one.
(Of course you are talking figuratively, but I couldn't help but nitpick.)
FractInt seems to render things quite a bit faster than Xaos. I haven't
actually measured it, it just seems more responsive. And you don't need
to zoom in very far before you have to frequently stop zooming and let
Xaos catch up with redrawing the image, so you can see where to go next.
(It probably doesn't help that Xaos uses boundary-trace to draw the
image in certain instances, and the display updates very, very
infrequently while it does this. With FractInt, you can see what's
happening while it does this. It's kind of mesmerising, actually...)
It's news to me that continental drift isn't the same thing as plate
tectonics...
> tectonics...
Wikipedia is your friend.
