POV-Ray : Newsgroups : povray.off-topic : Firebug Server Time
1 Nov 2026 14:35:00 EST (-0500)
  Firebug (Message 1 to 39 of 39)
Subject: Firebug
Date: 20 Oct 2010 11:42:17
Message: <4cbf0dd9$1@news.povray.org>
I forget who suggested this, but I have a Firefox extension named
Firebug installed on my work PC. This allows me to do several rather
interesting things. And utterly fails to allow me to do several other
things.
I mainly use it for looking at the document tree. Firefox itself will
only show you the text it loaded from disk. If you use the DOM to modify
the document, there is *no way* to discover what Firefox is actually
rendering. To my great relief, Firebug offers a way to see what the
document tree looks like *now*, not when it was first loaded. So I can
see whether my scripting has built the correct document tree or not.
It also appears to have some facilities related to tracking down
complicated style cascades, which I shall probably never need to use, ever.
A couple of days ago, I discovered that it has a JavaScript debugging
feature. Now that sounds quite useful, but unfortunately it doesn't
appear to actually, you know, *work*.
- There's a button you can press that makes it so that next time a
script runs, it immediately pops up in the script window. Unfortunately,
pressing "step into" has the effect of "step over" approximately 85% of
the time. This is the utter height of uselessness. Click a button and it
says "this would cause Foo() to run". So you click "step into"... and it
steps *over* Foo(), without showing you what's happening. Very helpful.
- As far as I can tell, breakpoints don't work. Like, I have a button
that runs Bar() when you click it. So I put a breakpoint on Bar(), and
click the button. The script runs, but no breakpoint. Again, very helpful.
- It seems Firebug is unable to handle function calls where the function
to be called is not statically known. For example, if there's a Foo()
function defined, and you do
   Foo(5);
then you can step into Foo(). However, if instead you do
   var Bar = Foo;
   Bar(5);
then Firebug apparently has *no clue* what function you just called.
This is extremely limiting when you consider that my entire application
is fundamentally based on this type of thing.
I wonder if any of this is likely to be fixed anytime soon?
Subject: Re: Firebug
Date: 20 Oct 2010 11:48:09
Message: <4cbf0f39$1@news.povray.org>
OH MY GOD! >_<
It seems breakpoints work, but *only* if the exact line you put the
breakpoint on contains a line of executable code.
So if you put the breakpoint on the function name, nothing happens. If
you put the breakpoint on a line within the function that happens to be
blank, nothing happens. If you put the breakpoint on a line that just
contains a comment, nothing happens. *Only* if the line contains at
least one executable statement does the breakpoint fire. WTF?
Date: 20 Oct 2010 12:17:06
Message: <4cbf1602$1@news.povray.org>
Invisible wrote:
>  WTF?
This is called "bedding in."  It happens in all software (and, for that
matter, in every bit of technology you need to practice with to learn). Now
that you know that, you'll never try to breakpoint a comment again. In a
year from now, when people bitch about how crappy the debugger is, you'll
say "works for me! Must be your problem."
That's why you have to take everything people say about how great or how
crappy some large well-know system is (like an OS or an office suite) with a
grain of salt, especially when it's primarily a UI discussion.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 20 Oct 2010 12:25:26
Message: <4cbf17f6@news.povray.org>
Invisible escreveu:
as Darren said.  Works the same in Delphi.
regarding var B = Foo; B(), I have no clue.
a game sig: http://tinyurl.com/d3rxz9
Date: 20 Oct 2010 13:55:26
Message: <4cbf2d0e$1@news.povray.org>
> Now that you know that, you'll never try to breakpoint a comment again.
Well, so far this has tripped me over at least 17 times since I
discovered what the problem was.
> In a year from now, when people bitch about how crappy the debugger is,
> you'll say "works for me! Must be your problem."
I can't believe that such a trivially fixable issue isn't fixed... In
fact, I can't believe that nobody caught this in testing. When you fire
up a debugger with support for breakpoints, literally THE FIRST THING
you're going to do is try to stick breakpoints on top-level functions.
How did this miss this?!
The next thing, of course, is that if I put a breakpoint on line 137, I
now have to guess whether that means execution halts *before* line 137
runs or *after* line 137 runs. In any normal debugger I could just put
the breakpoint on line 136 or line 138 (assuming they're empty), but nooo...
I really can't believe somebody would go to the extreme lengths required
to build something as complex as a debugger, and then release it while
it's trivially broken. I mean, the effort to fix this glitch compared to
the effort of developing the debugger in the first place...
Anyway, I guess none of this is going to fix my algorithm. I suppose
it's a miracle that you can debug JavaScript at all. But *damn*!
http://blog.orphi.me.uk/
Date: 20 Oct 2010 16:06:46
Message: <4cbf4bd6@news.povray.org>
Or, for that matter, the Visual Studio debugger, FWIW. But, Visual
studio does something "clever": It moves the breakpoint if its not on a
valid line to the next valid line once it has the debugging info for the
module the code file belongs to.
~Mike
Date: 21 Oct 2010 02:20:21
Message: <4cbfdba5$1@news.povray.org>
I can. That's exactly why the people who write the code should not be the
people to test the code.  And that's exactly why code without documentation
is worthless.
> When you fire
Not if you wrote the debugger yourself and you know it only breakpoints on
executable code.
Welcome to Open Source!
I can completely understand a debugger for an interpreted language only
being able to stop on executable lines. I can understand it especially if
the interpreter wasn't written with breakpointing it in mind. If the person
writing the interpreter for example compiled code into bytecodes and then
marked each bytecode with what line it came from, and the guy writing the
debugger stopped as soon as you hit a bytecode with the matching line
number, and he can't tell what lines are valid to breakpoint on before the
code is running because that's when the bytecode is generated, I'd think it
would take a crapload of work to fix that "bug".
Actually, I thought it was pretty cool when I could put a breakpoint in code
invoked by a web request and have it breakpoint. Man, I wish I had that
capability when I was first writing CGI scripts.
   Serving Suggestion:
Date: 21 Oct 2010 02:23:00
Message: <4cbfdc44@news.povray.org>
I thought it was kind of funky-clever how they figured out when a statement
ended.  They analyze the code and count pushes and pops, and a statement
ends when the evaluation stack pops the last value off.  That's the
definition of "one statement" in the CIL - the code between the first push
and the matching pop that empties the data/operand stack.
   Serving Suggestion:
Date: 21 Oct 2010 04:18:18
Message: <4cbff74a$1@news.povray.org>
>> required to build something as complex as a debugger, and then release
>> it while it's trivially broken.
The next thing I'll be hearing is "patches welcome"...
> if the interpreter wasn't written with breakpointing it in mind. If the
> person writing the interpreter for example compiled code into bytecodes
> and then marked each bytecode with what line it came from, and the guy
> writing the debugger stopped as soon as you hit a bytecode with the
> matching line number, and he can't tell what lines are valid to
> breakpoint on before the code is running because that's when the
> bytecode is generated, I'd think it would take a crapload of work to fix
> that "bug".
You realise that the UI already highlights the lines that have code on
them, right? So the code to figure this out already exists. All you have
to do is look at where the user put the breakpoint, and select the
nearest line that's executable. The only possibly-tricky thing is having
the breakpoint set on line X+N put appear to be set on line X.
Failing that, you could just refuse to set a breakpoint on a line if it
doesn't contain any executable code. That would be even more trivial to
implement.
And yet Firebug does neither of these things.
> code invoked by a web request and have it breakpoint. Man, I wish I had
> that capability when I was first writing CGI scripts.
I'm still trying to find a way to run CGI binaries (note: binaries, not
scripts) without having to install and configure Apache or something
like it.
It seems there are plenty of light-weight HTTP servers, but all of them
either lack CGI support entirely, or only support CGI *scripts* (usually
in a single language).
Date: 21 Oct 2010 04:26:26
Message: <4cbff932@news.povray.org>
I wouldn't have called that "clever". I would have called that "the most
basic functionality that any non-toy debugger would be expected to
have". Certainly I've never seen a debugger with this limitation
before... (Although I can't claim to have used all that many debuggers.)
Date: 21 Oct 2010 12:18:58
Message: <4cc067f2$1@news.povray.org>
> them, right?
No, I haven't used it that much.
*You* should realize that I was speaking in more general terms. The kind of
statement "This has to be trivial" or "This has to be obvious" is often
mistaken, just like "this is obviously impossible" has been slowly being
beaten out of your vocabulary.  ;-)
Now, I will say, when I bought a compiler for a language touting how easy it
is to write correct programs, and I got it out and pushed the button for
"make me a Hello World skeleton project to start with", then pushed the
"Compile" button and got syntax errors, I felt like "how could you release
such a POS as an expensive compiler?"  So I'm not saying it's never justified.
I would just move the breakpoint. What would be tricky is if you click
between two functions - do you breakpoint the last line of the previous
function or the first line of the next function?
> like it.
tclhttpd?
I'm pretty sure tcl httpd supports CGI and FastCGI.  If not, it's pretty
trivial to do so. Basically, copy some header crap into environment
variables, pipe the incoming request to stdin of the CGI, and pipe the
stdout back to the browser.
   Serving Suggestion:
Date: 21 Oct 2010 12:19:32
Message: <4cc06814$1@news.povray.org>
Note he didn't call it clever. He called it "clever".
   Serving Suggestion:
Date: 22 Oct 2010 04:22:49
Message: <4cc149d9$1@news.povray.org>
> of statement "This has to be trivial" or "This has to be obvious" is
> often mistaken, just like "this is obviously impossible" has been slowly
> being beaten out of your vocabulary. ;-)
>> So the code to figure this out already exists. All you have to do is
>> look at where the user put the breakpoint, and select the nearest line
>> that's executable. The only possibly-tricky thing is having the
Or you could do that, yes.
Or the first statement outside of a function? Or just refuse to set a
breakpoint there? There's several possible options.
>> them either lack CGI support entirely, or only support CGI *scripts*
>> (usually in a single language).
Constructing and parsing HTTP headers yourself also isn't all that
hard... and yet it turns out to be unexpectedly non-trivial to do a
really good job of it yourself. Especially when you're not actually
trying to write a web server, you just want something to test your CGI with.
Date: 22 Oct 2010 11:49:24
Message: <4cc1b284$1@news.povray.org>
> hard...
It didn't *used* to be. Now so much crap has been added to HTTP to support
everyone using it for something other than hypertext transport that yeah,
actually parsing the headers and doing the protocol turns out to be pretty
non-trivial.
   Serving Suggestion:
Date: 22 Oct 2010 11:53:38
Message: <4cc1b382@news.povray.org>
On 22/10/2010 04:49 PM, Darren New wrote:
>> hard...
> support everyone using it for something other than hypertext transport
> that yeah, actually parsing the headers and doing the protocol turns out
> to be pretty non-trivial.
http://www.w3.org/Protocols/HTTP/AsImplemented.html
Woah! That's pretty... um... special, right there.
Hmm, I wonder if any modern software actually handles HTTP 0.9 correctly?
Date: 22 Oct 2010 12:17:39
Message: <4cc1b923$1@news.povray.org>
Yep. Like all good protocols ;-) it doesn't have a version number in the
first version. That's why the "HTTP/1.0" comes at the end of the request
instead of the beginning.
*Almost* everything since then has been to deal with the fact that HTTP
isn't being used for transporting hypertext, or to add all the features that
all the other data transfer protocols already had.
Most web browsers do, yes. When I want to see if something is actually
running a web server, I'll often telnet in by hand and just "GET /" to see
that I get some sort of answer.
   Serving Suggestion:
Date: 22 Oct 2010 12:20:40
Message: <4cc1b9d8$1@news.povray.org>
Oh, and it's also the first internet protocol that said you had to be able
to handle any kind of line terminator.
   Serving Suggestion:
Date: 25 Oct 2010 11:31:48
Message: <4cc5a2e4$1@news.povray.org>
On Wed, 20 Oct 2010 18:55:25 +0100, Orchid XP v8 wrote:
> When you fire
Not me, because it seems obvious that only code that executes can be
halted by a breakpoint.  I can't think of a debugger I've ever used that
lets you set a breakpoint on non-executable code.  Or if I have, I've
never needed to use that functionality.
Jim
Date: 25 Oct 2010 16:53:00
Message: <4cc5ee2c@news.povray.org>
>> When you fire
It's pretty self-evident that if you put a breakpoint on the name of a
function, you want it to break every time that function is called.
(It's also pretty self-evident that having some visual feedback about
where you can and can't put breakpoints would help enourmously.)
Date: 26 Oct 2010 09:56:42
Message: <4cc6de1a$1@news.povray.org>
Remember: The function declaration is just that: A declaration. It has
no code. Depending on the compiler and execution environment the actual
code will be the first statement with the potential addition of
declarations of variables with assignment.
On the second point. Yeah, I agree it would be nice.
~Mike
Date: 26 Oct 2010 11:27:32
Message: <4cc6f364$1@news.povray.org>
Perhaps, but it's also self-evident that the function *name* isn't
executed, so it makes no sense to set a breakpoint on a line that
contains non-executable code, since a breakpoint interrupts the flow of
*executable* code. ;-)
Now *that* I can't argue with. ;-)
Jim
Date: 26 Oct 2010 11:38:18
Message: <4cc6f5ea$1@news.povray.org>
> executed
Oh really?
Until now, I haven't seen a debugger that prohibits you putting
breakpoints on (say) a completely empty line. I mean, hell, isn't the
debugger's job supposed to be to make your job *easier*? :-P
Heh. All it needs now is for some helpful soul to suggest that I submit
a source code patch. :-P
Date: 26 Oct 2010 11:54:46
Message: <4cc6f9c6$1@news.povray.org>
>> executed
> Oh really?
Yes, really.  A function name is non-executable code - it's a reference.
>> so it makes no sense to set a breakpoint on a line that contains
You've never used Borland's C compiler then.  Or MASM, or TASM. ;-)
How exactly does it make the job easier if the debugger lets you set
breakpoints in places that logically make absolutely no sense?
Well, submit a patch. ;-)
You're welcome.
Jim
Date: 26 Oct 2010 12:05:33
Message: <4cc6fc4d$1@news.povray.org>
I'd argue that setting a breakpoint on a function name means the code breaks
every time that function is called.  That seems pretty logical to me.
Date: 26 Oct 2010 13:33:59
Message: <4cc71107@news.povray.org>
> no code.
That's your inner nerd speaking.
The actual answer is "if he tries to put a breakpoint on the function name,
he wants to breakpoint when the function is called, so we'll actually put
the breakpoint on the first executable statement of the function."
This is exactly the way in which open source software tends to suck: written
by geeks, for geeks, which is great unless you're not a geek. :-)
   Serving Suggestion:
Date: 26 Oct 2010 17:37:41
Message: <4cc74a25$1@news.povray.org>
>> reference.
> breaks every time that function is called.  That seems pretty logical to
> me.
If I want to do that, I'll set it up on the first line of executable code
in the function.  That makes logical sense to me.
If I go into, say, the NetWare kernel debugger (which I have spent many,
many months in), I can set a breakpoint at a "function", but the function
is a reference to the first executable line of machine code inside the
function IIRC (Now I think of it, it might be on the call itself - I may
need to restart my VM and look again at that).
Jim
Date: 27 Oct 2010 08:43:01
Message: <4cc81e55$1@news.povray.org>
On 10/26/2010 12:33 PM, Darren New wrote:
>> no code.
I don't think it's inner :)
> written by geeks, for geeks, which is great unless you're not a geek. :-)
YES! Exactly. Though I do like some OSS projects. But this is a major
issue with OSS is it tends to be developed with exactly that mindset.
~Mike
Date: 27 Oct 2010 08:50:10
Message: <4cc82002@news.povray.org>
"Patches welcome."
Date: 27 Oct 2010 12:11:25
Message: <4cc84f2d$1@news.povray.org>
> "Patches welcome."
Oh, yes, that works great.
Problem: Only programmers are comfortable with the program.
Solution: Submit code.
Yeah. Think about that one.
   Serving Suggestion:
Date: 27 Oct 2010 17:20:26
Message: <4cc8979a@news.povray.org>
>> "Patches welcome."
I suspect that the open source model can work - but only for the
products that are so popular that there's a crapload of users trying it
out, and a crapload of developers sufficiently motivated to fix the
"boring" stuff.
Obligatory XKCD reference: http://xkcd.com/619/
Date: 27 Oct 2010 17:41:35
Message: <4cc89c8f$1@news.povray.org>
Or for software developed for use by developers (i.e., compilers, editors,
etc) or software developed by companies that sell software-complements, like
hardware. OpenOffice didn't show up because programmers wanted to write an
office suite. OpenOffice showed up because Sun wanted to sell SPARCstations
and couldn't without having MS Office on them.
   Serving Suggestion:
Date: 28 Oct 2010 01:26:18
Message: <4cc9097a$1@news.povray.org>
On Wed, 27 Oct 2010 14:41:35 -0700, Darren New wrote:
> OpenOffice showed up because Sun wanted to sell SPARCstations and
Well, OpenOffice was previously StarOffice, made by the company
StarDivision.  It was originally closed-source and cross-platform.  Sun
bought StarDivision, but Sun certainly didn't start the OpenOffice
product.
Jim
Date: 28 Oct 2010 04:10:04
Message: <4cc92fdc$1@news.povray.org>
> product.
Sun? Heh. I'm still getting used to the fact that now when I install
OpenOffice, it was Oracle plastered all over it. (I'm pretty sure under
Sun the corporate branding was much less in-your-face. Also, the colour
scheme was nicer. Oracle has given it a kind of blank-white look, like
they didn't finish it or something...)
Date: 28 Oct 2010 10:20:48
Message: <4cc986c0@news.povray.org>
On 10/27/2010 7:50 AM, Invisible wrote:
> "Patches welcome."
<rips a square of canvas> Here's your patch ;P
~Mike
Date: 28 Oct 2010 11:40:16
Message: <4cc99960$1@news.povray.org>
>> product.
That's one reason I use the Novell edition. :-)
Jim
Date: 28 Oct 2010 11:47:54
Message: <4cc99b2a$1@news.povray.org>
Actually, come to think of it, I'm still getting used to the fact that a
huge, highly successful company like Sun somehow got bought by a much
smaller company like Oracle. You wouldn't have thought they could do that...
Date: 28 Oct 2010 13:35:42
Message: <4cc9b46e$1@news.povray.org>
> Sun bought StarDivision, but Sun certainly didn't start the OpenOffice
> product.
No, but they open-sourced it.  I.e., it wasn't free software, it was
commercial software that turned into libre software.
   Serving Suggestion:
Date: 28 Oct 2010 15:42:05
Message: <4cc9d20d$1@news.povray.org>
>> product.
True, I had forgotten that part of the process - StarOffice and
OpenOffice coexisted for a while and it's been 10 years.... :-)
Jim
Date: 28 Oct 2010 15:43:04
Message: <4cc9d248$1@news.povray.org>
>>> under Sun the corporate branding was much less in-your-face. Also, the
>>> colour scheme was nicer. Oracle has given it a kind of blank-white
>>> look, like they didn't finish it or something...)
> that...
It happens all the time.  I worked in the food & drug retail industry
before coming to Novell, and the company I worked for was acquired by a
smaller company (both were in the Fortune 50, though).
Jim
