POV-Ray : Newsgroups : povray.off-topic : scanline predator Server Time
17 Oct 2026 19:25:46 EDT (-0400)
  scanline predator (Message 1 to 22 of 22)
Subject: scanline predator
Date: 13 Oct 2010 22:43:04
Message: <4cb66e38$1@news.povray.org>
One thing I can't figure out...
How do you do a ghost or predator effect on a graphics card, like with
opengl or directx or something like that?  I.e., as a vertex/pixel shader.
I understand how you do shadows, and reflections, and how to do something
like a lens bloom where you post-process the whole image.  What I am not
sure I've figured out is how to post-process only part of the screen you can
see. I.e., if the "predator" walks behind a tree, you want the parts you can
see to distort what's behind it, but you don't want to distort the tree he's
behind.
The only thing I can think of is that you save the depth map along with the
image, and then you only post-process the things at the same depth as the
model of the predator, or something like that.  But how do you know what
that is? Re-render just the predator in a separate buffer?
Alternately, you *could* render everything twice, with the predator having a
pixel shader that just made it white, everything else being black. But then
you're rendering the whole scene three times.
Is there a better way to do that?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Subject: Re: scanline predator
Date: 14 Oct 2010 04:12:29
Message: <4cb6bb6d@news.povray.org>
> the image, and then you only post-process the things at the same depth as
> the model of the predator, or something like that.
I'm not entirely sure what you are looking for, but your pixel shader
"strength" could depend on depth, so it blends out smoothly once a certain
distance away from the target depth.
> But how do you know what that is? Re-render just the predator in a
> separate buffer?
A lot of hardware won't give you access to the depth buffer, so APIs
typically don't expose the depth information (or if they do they have a very
slow backup method or it might just fail, so I wouldn't use it).
If your platform supports multiple render targets then the simplest solution
would be to just render the depth info simultaneously to a separate FP32
texture as you go along.  This can obviously then be used by the post
processing shader.
If not you might be able to squeeze the depth data into the alpha channel,
so long as you don't need it for anything else and are happy with 8bit
resolution of the depth info.  Just set the alpha component of your pixel
output colour to a suitably scaled depth at the end of the pixel shader.
I was trying to come up with an alternative that involved rendering full
screen quads with various depth/stencil options, but couldn't come up with
anything.  I have a niggling feeling something should be possible that way
though...
Date: 14 Oct 2010 05:30:19
Message: <4cb6cdab$1@news.povray.org>
> having a pixel shader that just made it white, everything else being
> black. But then you're rendering the whole scene three times.
I was under the impression that most complex GPU effects require
rendering the entire scene multiple times (in addition to rendering
things in a very specific order). But hey, what would I know?
Date: 14 Oct 2010 05:43:48
Message: <4cb6d0d4@news.povray.org>
> I was under the impression that most complex GPU effects require rendering
> the entire scene multiple times (in addition to rendering things in a very
You usually want to try and avoid rendering the *entire scene* multiple
times, as this usually involves many relatively slow state changes within
the GPU (ie switching textures and vertex buffers etc).  Since complex pixel
shaders became available, this has largely reduced the need for multi-pass
rendering.  However some effects still need multiple passes, and in these
situations you try to minimise the amount of stuff drawn multiple times (eg
for a reflection texture you might omit small objects).  DX10 has helped
quite a lot here, as it allows you to process a piece of geometry once, yet
output it to several render targets.  If you need to do this for a large
number of models it saves a huge amount of time compared to the DX9 method.
Another interesting idea is deferred shading.  With this as you go through
the geometry of your scene you don't calculate final lit colour values, but
values to describe the 3D surface at each screen pixel (texture colour,
normal, shinyness etc).  This is relatively fast as no lighting calculations
are done.  Then once you've drawn all the geometry you end up with a simple
2D array of what is visible.  With this you can then run a pixel shader over
it to calculate the final colour values.  The advantage is you don't have to
put your lighting code in the shaders for each model, the lighting
calculations only get done for pixels that are visible in the final image,
and it is very cheap to add more lights to the scene.  Example here:
http://www.youtube.com/watch?v=hBtfryQBAlk
Date: 14 Oct 2010 13:46:31
Message: <4cb741f7$1@news.povray.org>
>> with the image, and then you only post-process the things at the same
>> depth as the model of the predator, or something like that.
> certain distance away from the target depth.
I probably phrased it poorly.
Basically, I want to apply a screen-space shader but only to parts of the
scene occluded by a model which is in turn partially occluded by other parts
of the scene.
So imagine say a magnifying glass. It makes what's behind it bigger (which
is easy to do with a second pass over the screen data), but it doesn't make
what's in front of it bigger.
The APIs I'm using definitely expose the depth buffer. One of the tutorial
programs I have renders the scene into a depth buffer from the POV of the
light source, then uses that to figure out if a pixel is lit or shadowed
from the POV of the camera.  This of course draws all the geometry twice.
Since the effect I want is only from the POV of the camera, I'm trying to
figure out if I can do it without rendering the entire scene twice.
> solution would be to just render the depth info simultaneously to a
> separate FP32 texture as you go along.  This can obviously then be used
> by the post processing shader.
Sure. I'm trying to figure out a simple way to apply that, tho. I can do
that, I'm just not sure how to efficiently figure out *both* when the ghost
is the closest thing to the camera at a particular pixel *and* what color
the pixel would be behind the ghost.
All I can think of, using the depth buffer, is to render the entire scene
into a depth buffer with the ghost, then a second time without the ghost,
and where the depth buffer has changed, that's where I apply the
post-processing effect.
Or maybe I can do something funky, like render everything except the ghosts,
put the ghosts in last, and somehow take advantage of that, but I think
everything goes through the pixel shader. Maybe something like telling the
pixel shader *not* to render the pixel, but managing to save the final
locations in a different render target?  I don't think I have a way of doing
that. Maybe have two render targets, one where I draw the ghost in the
normal place to get the depth, and the other where I set the ghost's depth
waaaaay back, making the ghost effectively out of the picture. Then I apply
the post-process to pixels whose depth doesn't match the depth-map of the
normal place.  I am pretty sure I can't resolve the target without
destroying the 3D information, so I can't render everything except the
ghost, snapshot the scene, and then add in the ghost.
Maybe I can at least depth-sort the models and only render the models whose
bounding box is in front of the back of the ghost, so I only have to
calculate what occludes the ghost.  (And of course, once the ghost is far
enough away, he's too hard to see anyway, so don't even bother to render it.)
> with anything.  I have a niggling feeling something should be possible
> that way though...
I think it's efficiently getting the stencil to start with that's the
problem. Running it through a second pass to draw the ghost effect shouldn't
be bad.
   Serving Suggestion:
Date: 14 Oct 2010 15:50:31
Message: <4cb75f07@news.povray.org>
  I don't know the answer, but I wouldn't be surprised if the stencil buffer
is involved (probably in conjunction with the depth buffer).
  The basic idea of the stencil buffer is so laughably simple that one
would hastily think that it has no practical use. In practice people have
developed incredible applications to the stencil buffer, including
dynamic shadowing, planar reflections, outline drawing and portal
rendering.
Date: 14 Oct 2010 15:53:16
Message: <4cb75fac@news.povray.org>
scott escreveu:
> through the geometry of your scene you don't calculate final lit colour
> values, but values to describe the 3D surface at each screen pixel
> (texture colour, normal, shinyness etc).  This is relatively fast as no
> lighting calculations are done.  Then once you've drawn all the geometry
> you end up with a simple 2D array of what is visible.  With this you can
> then run a pixel shader over it to calculate the final colour values.
> The advantage is you don't have to put your lighting code in the shaders
> for each model, the lighting calculations only get done for pixels that
> are visible in the final image, and it is very cheap to add more lights
> to the scene.  Example here: http://www.youtube.com/watch?v=hBtfryQBAlk
it's pretty much lazy evaluation for rendering. :)
a game sig: http://tinyurl.com/d3rxz9
Date: 14 Oct 2010 17:50:03
Message: <4cb77b0b$1@news.povray.org>
> rendering.
Ah! Ok, now that you mention it, I suppose I could render the ghosts with a
shader that puts 1's in the stencil buffer and 0's everywhere else, and then
use the result to do the post-process step.  I never really saw an example
of using the stencil buffer, but now that you mention it, it's entirely
likely that's exactly what it was intended for. I'll have to study up how
you can get a shader to write to it.
   Serving Suggestion:
Date: 15 Oct 2010 04:42:48
Message: <4cb81408@news.povray.org>
> parts of the scene.
> make what's in front of it bigger.
You could do something like this (as Warp said, the stencil buffer is useful
for stuff like this).  You need to be careful to not switch the depth buffer
in steps 1 and 5 (don't know if that's possible or not in your API,
otherwise it might get complicated to make sure the ghost geomtry renders
correctly in step 8).  It is a little bit complex because you do not have
access to the depth/stencil buffer when that is also the render target.
1. Set render target to temporary one
2. Render scene without ghost normally, but set stencil writes to always 0
3. Render ghost geometry without writes to RGBA, but stencil write of always
1
4. Switch the render target to the actual back buffer
5. Render a full-screen quad to simply copy over the entire temp buffer RGBA
contents
5. Set your special effect pixel shader
6. Set stencil pass function to equal 1
7. Render a full-screen quad at the depth of the ghost (this will avoid
affecting anything infront of the ghost)
8. Render the ghost normally
Sure, if you write depth on purpose to a special render target, what is not
normally available is the "internal" depth/stencil buffer that the GPU uses
to do depth and stencil tests during normal rendering.  So you're usually
having to duplicate the depth buffer if you want to use it in a non-standard
way.
Date: 15 Oct 2010 04:44:31
Message: <4cb8146f@news.povray.org>
I assumed you guys had already thought of that... ;-)
(Besides, I don't _actually_ know what the stencil buffer is. I just
assume it does approximately what its name says it does.)
Date: 15 Oct 2010 04:47:40
Message: <4cb8152c@news.povray.org>
> a shader that puts 1's in the stencil buffer and 0's everywhere else, and
> then use the result to do the post-process step.  I never really saw an
> example of using the stencil buffer, but now that you mention it, it's
> entirely likely that's exactly what it was intended for. I'll have to
> study up how you can get a shader to write to it.
The problem is reading from it, AFAIK you can't read from the stencil buffer
in a pixel shader on most hardware, all you can do is tell the GPU to run
your shader or not, depending on certain criteria of the stencil buffer.
Date: 15 Oct 2010 10:09:06
Message: <4cb86082@news.povray.org>
  Basically a stencil buffer is a screen-sized buffer in the graphics card's
memory where you can "accumulate" values. For example, you can tell the
GPU "when you draw this triangle, for each pixel of the triangle increment
the equivalent value in the stencil buffer by one". (It's possible to "draw"
triangles to the stencil buffer only, rather than on screen.)
  Sounds simple, and it is. It's, however, incredible what kind of uses
it can have. For example dynamic shadowing using shadow volumes uses the
stencil buffer (basically, each shadow volume polygon facing the camera
increases the equivalent stencil buffer values, and each shadow volume
polygon facing away from the camera decreases it, and thus from these
values you get the places on screen which are inside the shadow volumes).
Date: 15 Oct 2010 12:27:40
Message: <4cb880fc$1@news.povray.org>
> buffer in a pixel shader on most hardware, all you can do is tell the
> GPU to run your shader or not, depending on certain criteria of the
> stencil buffer.
Ah, OK. That shouldn't be a problem here, tho, because I want to run the
ghost's pixel shader where the ghost is and not where he isn't, without any
additional decisions. :-)
   Serving Suggestion:
Date: 15 Oct 2010 12:34:42
Message: <4cb882a2$1@news.povray.org>
Do you have any good bookmarks for that sort of stuff? Or am I off to google
to try to guess which is best to study? :-)
   Serving Suggestion:
Date: 15 Oct 2010 12:43:57
Message: <4cb884cd@news.povray.org>
  Not really, but you could try: http://nehe.gamedev.net/
Date: 15 Oct 2010 13:05:17
Message: <4cb889cd$1@news.povray.org>
> always 1
> RGBA contents
I was following you up until 7. First, since the ghost is a model, I'm not
sure what the single "depth" would be. But OK, assuming I'm not actually
intersecting geometries with the ghost, I can work with that.  However,
doesn't step 5 destroy the original depth information? That was the step I
couldn't figure out how to get around. If I've turned the 3D models and such
into a flat quad, I've lost the original depth information there.
Secondly, I'm not sure what 7 is for at all. Maybe you're thinking something
different for "render ghost" than I am? Does step 8 mean "render the parts
of the ghost you can't see through" or something?  Do you mean that 7 will
combine the stencil buffer with the depth buffer somehow? Wouldn't the
stencil buffer already be 0 where there's something occluding the ghost?
> not normally available is the "internal" depth/stencil buffer that the
> GPU uses to do depth and stencil tests during normal rendering.  So
> you're usually having to duplicate the depth buffer if you want to use
> it in a non-standard way.
True. I think keeping two copies of the depth buffer is less overhead than
rendering all the geometry twice, tho.  That's really the bit I'm trying to
avoid.
   Serving Suggestion:
Date: 15 Oct 2010 13:08:19
Message: <4cb88a83$1@news.povray.org>
The TOC looks interesting. Thanks!
   Serving Suggestion:
Date: 16 Oct 2010 18:33:37
Message: <4cba2841$1@news.povray.org>
I pretty much follow *how* that works, but I'm not sure why you would do
that over doing it some other way. It would seem that calculating the shadow
volumes is something relatively compute-intensive for something moving.
Is it a trade-off between computing the volumes and then being able to just
render things essentially once, rather than rendering the whole scene from
the POV of multiple lights or something?
   Serving Suggestion:
Date: 17 Oct 2010 08:50:45
Message: <4cbaf125@news.povray.org>
  There are two competing algorithms for rendering real-time dynamic shadows
with current graphics hardware: Shadow volumes and shadow mapping. They use
completely different approaches to achieve the same (well, similar) result.
  As you might guess, there's no "better" algorithm. It's always about
compromises. One algorithm is better at some things and worse at others.
  Shadow volumes allow rendering pixel-perfect shadows (in fact, even
sub-pixel-perfect if you are using antialiasing). This accuracy is
completely independent of the distance between the shadowed area to
the shadowing object or to the light source causing the shadow. It also
requires less RAM (the shadow polygons are numerous, but polygons are
quite memory-light compared to bitmaps; the only other memory needed is
the stencil buffer.)
  The disadvantage of shadow volumes is that they are considerably more
complicated to implement, and their speed is heavily dependent on the
geometry of the scene. (Also soft shadows are not possible with the
basic algorithm, although I have heard of an expanded algorithm which
would support soft shadows, probably at the cost of rendering speed.)
  Shadow mapping is easier to implement and often (although not always)
faster. Its problem is that it you always have to make a compromise between
accuracy and memory usage (the larger the shadow maps, the more accurate
the result, but the more RAM is required; more accuracy might also affect
rendering speed by some amount). Also, the accuracy is heavily dependent
on the distance between the surface being shadowed and the shadowing surface
as well as the light source (the larger the distance, the blockier and
less realistic the shadow becomes).
  Shadow mapping has also another advantage over shadow volumes: Certain
shadowing effects are extremely light to do with shadow maps because they
require no rendering at all (to get the shadows), while with shadow volumes
you would need to run the full shadow-polygon-creation-and-rendering process
to get the same effect. For example, if you want a moth flying near a lamp,
you can "cheat" and add the moth's shadow to the correspondent shadow maps
algorithmically (instead of rendering the moth with the GPU as usual), and
thus even complex such shadows take virtually no rendering time.
Date: 17 Oct 2010 12:58:45
Message: <4cbb2b45$1@news.povray.org>
Thank you for the detailed explanation. I figured the algorithms had
different strengths, but I couldn't figure out just from understanding the
basics of the algorithms what the strengths were.
Huh. I always wondered why old games had very pixelated jaggy shadows, but
now that you mention it, if you do the shadow projection on a very small
depth buffer, that's just what you'd expect. Cool.
Yeah, I can see that.
XNA even has a constructor for the Matrix class where you give it a point
and a plane, and it constructs a transform that maps a point to where it
would cast a shadow onto that plane. I guess that's exceedingly fast as long
as you're only casting shadows onto flat surfaces, like running across
simple terrain or inside a corridor or something.
Now, if only I could get inspired to actually sit down and work on my next
game, I'd be good. :-)
   Serving Suggestion:
Date: 18 Oct 2010 04:15:25
Message: <4cbc021d@news.povray.org>
>> 0
>> always 1
>> RGBA contents
If you wanted everything behind the ghost in the scene to be affected, then
I would set the "depth" to the furthest away point of the model (but maybe
experiemtn, I don't know how much of an effect it would have with
intersecting geometry).
> But OK, assuming I'm not actually intersecting geometries with the ghost,
> I can work with that.  However, doesn't step 5 destroy the original depth
> information?
No, you should be able to control the RGBA render target and the
depth/stencil target separately.  In DirectX you call
SetDepthStencilSurface.  For my algorithm I assumed a single Depth/Stencil
surface would be persistent throughout the whole process,
It applies the shader as you requested here: "Basically, I want to apply a
of the scene."
> Does step 8 mean "render the parts of the ghost you can't see through" or
> something?
I assume your actual ghost model has varying levels of transparency,
otherwise there would be no point in applying some shader to the scene
behind it.  Step 8 means render the ghost as normal - of course the
background will already be distorted somehow due to Step 7.
Date: 18 Oct 2010 11:31:13
Message: <4cbc6841$1@news.povray.org>
Oh, I see. OK.
In my imagination, it was totally transparent. Hence the subject line. But
OK, I see what you're saying here.
Again, thanks for the help!  Seems what I was missing was the stencil buffer.
   Serving Suggestion:
