POV-Ray : Newsgroups : povray.off-topic : More guitar Server Time
17 Oct 2026 19:25:43 EDT (-0400)
  More guitar (Message 1 to 18 of 18)
Subject: More guitar
Date: 10 Oct 2010 12:53:05
Message: <4cb1ef70@news.povray.org>
Made a couple of new videos:
http://www.youtube.com/watch?v=DG7gUo5v2K0
http://www.youtube.com/watch?v=uQ-hOV3cW2g
Subject: Re: More guitar
Date: 10 Oct 2010 13:13:04
Message: <4cb1f420@news.povray.org>
Nice. I've always liked greensleeves, and that was a nice version.
I'm a little surprised you can do tremolo that way on an instrument with
frets.  Only a little surprised, mind, but I thought the idea of the frets
was to make sure the string length was always the same even if your finger
was a bit off.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 10 Oct 2010 13:26:55
Message: <4cb1f75e@news.povray.org>
> was a bit off.
  If you make a vibrating motion with your finger, it will change the
tension of the string just so slightly, giving you a slight tremolo
effect. Of course it's not as pronounced as you can do eg. on a violin
or other fretless instruments (where the tremolo is not really a question
of changing the tension of the string but its length), but clearly audible
nevertheless (especially if you emphasize it).
  Of course you could also pitch-bend by stretching the string upwards or
downwards, but that's not really a tremolo.
Date: 10 Oct 2010 14:44:44
Message: <4cb2099c$1@news.povray.org>
I like you version of Greensleeves, too.
But, and there is always a “but”, you look so serious, as if you are
taking a test. A more relaxed performance would make it better. I say
this as a positive criticism.
Best Regards,
Date: 10 Oct 2010 15:39:34
Message: <4cb21676@news.povray.org>
Stephen <mca### [at] aoldotcom> wrote:
> you look so serious
  I'm Finn.
Date: 10 Oct 2010 15:47:54
Message: <4cb2186a$1@news.povray.org>
On 10/10/2010 8:39 PM, Warp wrote:
> Stephen<mca### [at] aoldotcom>  wrote:
>> you look so serious
>    I'm Finn.
I know that, but it is not against the law to look as if you are
enjoying yourself :-P
Best Regards,
Date: 10 Oct 2010 16:33:10
Message: <4cb22305@news.povray.org>
> >> you look so serious
> >    I'm Finn.
  I *am* enjoying myself. You just don't understand the subtleties of
the Finnish male expressions... :P
Date: 10 Oct 2010 16:42:11
Message: <4cb22523@news.povray.org>
>>>> you look so serious
>>>     I'm Finn.
I stand corrected ;-)
Best Regards,
Date: 10 Oct 2010 18:10:38
Message: <4cb239de$1@news.povray.org>
> frets was to make sure the string length was always the same even if
> your finger was a bit off.
Both are very good recordings - really liked them both.  Technically,
though, what Warp was doing wasn't a tremolo, but was vibrato (a slight
vibration in pitch). :-)
Jim
Date: 10 Oct 2010 18:22:50
Message: <4cb23cba$1@news.povray.org>
TIL...
Don't blame me, I play percussion. ;-)
   Serving Suggestion:
Date: 10 Oct 2010 21:58:59
Message: <4cb26f63@news.povray.org>
> TIL...
LOL
Date: 11 Oct 2010 12:41:31
Message: <4cb33e3b@news.povray.org>
Jim Henderson <nos### [at] nospamcom> wrote:
> Technically,
  It seems that "tremolo" has wildly varying meanings depending on the
context, the instrument and even different versions of the same instrument.
For example "tremolo" on classical guitar means a completely different thing
than "tremolo" on an electric guitar (at least when talking about the
so-called tremolo arm).
  Curiously, if you look at the wikipedia page for "tremolo", it utterly
fails to explain what it means, in a way that is easily understood. (It
also utterly fails to explain that it means completely different things
for different instruments.)
  Even when "tremolo" is used as a form of vibrato, there's still
disagreement on what their difference is. Some argue that "vibrato" is
a variation of frequency, while "tremolo" is a variation of amplitude.
(In the case of a guitar vibrato, it's actually both: Increasing the
tension of the string increases the frequency and decreases amplitude
because of conservation of energy, and vice-versa.)
Date: 11 Oct 2010 13:50:07
Message: <4cb34e4f$1@news.povray.org>
>> Technically,
I understood it to mean that tremolo is playing two different notes in quick
succession, while vibrato is changing the pitch of one note. So you
technically wouldn't be able to do "vibrato" on a clarinet, but you could do
tremolo with fast fingers.
If an instrument doesn't have a digital pitch (i.e., trombone vs tuba,
violen vs clarinet, etc) then distinguishing the two can be confusing, I'd
guess.
   Serving Suggestion:
Date: 11 Oct 2010 16:16:39
Message: <4cb370a7$1@news.povray.org>
>> Technically,
> instrument. For example "tremolo" on classical guitar means a completely
> different thing than "tremolo" on an electric guitar (at least when
> talking about the so-called tremolo arm).
Yeah, the so-called "whammy bar" on a guitar is sometimes called a
tremolo arm/bar, but it causes a fluctuation in amplitude rather than in
pitch.  The Wikipedia page does make mention of that as a not-entirely-
accurate usage.
I understood it pretty well, and it seemed consistent to me - though the
implementation on different instruments would be different - different on
a violin than on a marimba, for example.
> disagreement on what their difference is. Some argue that "vibrato" is a
> variation of frequency, while "tremolo" is a variation of amplitude. (In
> the case of a guitar vibrato, it's actually both: Increasing the tension
> of the string increases the frequency and decreases amplitude because of
Hadn't thought about it that way, but yes, I suppose that's true.  :-)
Jim
Date: 11 Oct 2010 20:15:48
Message: <4cb3a8b4$1@news.povray.org>
> quick succession,
Isn't tremolo a type of trilling, or am I misunderstanding again?
   Serving Suggestion:
Date: 11 Oct 2010 20:26:39
Message: <4cb3ab3f$1@news.povray.org>
On Mon, 11 Oct 2010 17:15:46 -0700, Darren New wrote:
>> quick succession,
It can be, but usually it's just the repetition of the same note, but it
can be two notes in a double-stop (whereas a trill is just between a note
and the note above/below it).
Jim
Date: 12 Oct 2010 04:40:00
Message: <web.4cb41beb9b8ef25a196b08580@news.povray.org>
Nice guitar work there. Particularly enjoyed Greensleeves (because I'm more
familiar with it.) And the CGI looks so REAL  ;-P
I've played electric guitar in bands for more years than I care to remember, but
classical acoustic guitar still gives me difficulty--mainly because I never
learned to pick correctly with my fingers (and fingernails.) So I...uh...avoid
it. You do it well.
Electric guitars are easier to play, too! (That's IMHO, of course.) Because of
lower 'action', in most cases.
Curiously, I've always thought of 'tremolo' as simply a sinusoidal volume
change, effected by my guitar amp's 'tremolo' electronics. Yet, when trying to
discuss  string bending/finger vibrating with fellow guitarists, I also use that
word (or 'trill', which is probably incorrect.) When it comes to using the
whammy bar on my electric guitar to get a 'warbling' pitch, I never think of it
as 'tremolo', just pitch change. Never heard any of my musician friends use
'tremolo' in that context either. But then again, I'm self-taught (i.e., by
ear)--so I never really learned ANY of the proper guitar or music nomenclature.
BTW (a small musicical detail): I always thought that the 'lead' line in
Greensleeves (when played in your Am key) went like this:
A..C.....D..E....F#E..D.....B..G etc.
In other words, an F# note rather than an F. But that could be my own faulty
memory of the song.
Ken
Date: 12 Oct 2010 11:34:54
Message: <4cb4801e@news.povray.org>
> memory of the song.
  You hear both versions. I don't know which one is the correct. I like
the version using F because it sounds a bit sadder.
