POV-Ray : Newsgroups : povray.off-topic : Musing on the Halting Problem Server Time
7 Mar 2026 10:02:08 EST (-0500)
  Musing on the Halting Problem (Message 1 to 10 of 30)
Subject: Musing on the Halting Problem
Date: 7 Oct 2010 10:43:35
Message: <4caddc97$1@news.povray.org>
Ah yes, it is impossible to write a computer program that can analyse
any possible computer program and tell you whether it halts in a finite
number of steps.
After reading about Cantor's diagonal argument, the cardinality of the
continuum, Turing degrees, and other mind-blowing stuff, it seems that
the *reason* the Halting Problem is undecidable boils down to this:
If there was a Magic() subroutine that could take the object code to
your whole program and tell you whether it halts or not, then you could
write a BlackMagic() subroutine that calls Magic(BlackMagic()) and then
purposely does the opposite of whatever Magic() claims that it's going
to do. Hence, it is impossible for Magic() to yield the correct answer,
since BlackMagic() will do the opposite of whatever Magic() claims it
will do.
Interestingly, even if you build some kind of hyper-computer that can
solve the Halting Problem, then by the argument above you could define a
new Hyper-Halting Problem which the hyper-computer would be just as
powerless to solve.
Looking the other way, the argument above doesn't work if the program to
be analysed isn't allowed to call Magic(), or perhaps one of the
operations used within Magic(). Which seems to just restate the fact
that a system can only prove results about systems weaker than itself.
Oddly enough:
http://mathworld.wolfram.com/HaltingProblem.html
"The halting problem is solvable for machines with less than four states."
That doesn't quite sound right...
The Halting Problem cannot be solved. You cannot write a program which
can decide for *every possible program*. But can you write one for "the
kind of programs that human beings tend to write"?
Well, first of all, good luck finding a rigorous definition for "the
kind of programs that human beings tend to write". But, assuming you
find one, the argument above still seems to apply. In other words, if it
*is* somehow possible to write a program that can determine whether
hand-written programs halt, the solution program cannot be hand-written. (!)
Another puzzling thing: Deciding whether a program halts within, say,
1000 steps *is* trivially solvable. Just run the program for (up to)
1000 steps, and see if it halts.
It's quite obvious that that ought to work. However, it looks like the
argument above should still apply, making it impossible to solve this
problem.
So what happens if you implement Magic() this way? Does BlackMagic()
halt or not halt? It seems that BlackMagic() would immediately call
Magic(), which would immediately begin simulating BlackMagic(), which
would immediately call Magic(), which would start simulating
BlackMagic()... Eventually, at some point, the top-level Magic() would
give up on its simulation and report back to the top-level BlackMagic()
that BlackMagic() takes more than 1000 steps to execute. Whereupon...
...Magic() has already used up thousands of cycles, and therefore
BlackMagic() can't be contrary and halt in less than 1000 cycles to
invalidate the analysis. Ah, trixy!
So it seems that the fallacy of solving the Halting Problem is in
Magic() being able to predict the outcome of an infinite number of
cycles of work with some finite number of cycles of processing.
Interesting...
That suggests another interesting question: Can you write a program that
takes any possible terminating program, and yields the same result in
strictly fewer steps? (E.g., if program P yields a result in K steps,
program Q given program P as input yields the same result in only K-1
steps.)
Unlike the Halting Problem, nobody would seriously expect the answer to
be no. Which is interesting, because when you think about it, they're
very similar programs really.
If Magic(P) computes the same thing as P but takes exactly 1 fewer
steps, then Magic(Magic(P)) computes the same thing in 2 fewer steps.
And by induction, by applying Magic() enough times, any result can be
computed in zero steps, which is impossible. Hence, Magic() does not
exist (or at least, doesn't work properly).
Here we're talking about *computation* compression, which is not unlike
the *data* compression case. If a compression algorithm could always
compress data by at least 1 bit, you could compress anything into zero
bits. And, conversely, decompress zero bits into anything. The latter is
obviously impossible.
The way the theorem is usually phrased is that "K bits can represent 2^K
possibilities, but K-1 bits can only decompress into 2^(K-1)
possibilities, which is *half* as many". I suppose you could relate the
number of cycles that a program runs for to the number of possible
outputs it can generate and prove it that way...
I note with some interest that if it's impossible for a program to not
halt, then the Halting Problem becomes [trivially] solvable. That's
cute. But why is it true? Because BlackMagic() tries to not halt if
Magic() says it should halt. It non-termination is impossible, then
BlackMagic() cannot have its evil way.
In fact, it seems that Magic() can function correctly so long as you
can't implement BlackMagic(), or something equivalent to it. So if you
want to know how to make the Halting Problem tractable, maybe you just
need to look at what components are required to implement BlackMagic()
[assuming that Magic() already exists].
For example, it appears as if it ought to be possible to implement
Magic() as a partial function that is defined only for programs that do
not call Magic(), nor contain an instruction sequence isomorphic to it.
In reality, I guess that might be quite a big limitation. For example,
there is Rule 30. This cellular automaton can be computed by the logic
function Y' = X xor (Y or Z). So I imagine with just a few bitwise (or
even integer arithmetic) instructions, you could implement Rule 30. And
it's known to be Turing-complete. Oh dears...
Subject: Re: Musing on the Halting Problem
Date: 7 Oct 2010 11:59:11
Message: <4cadee4f$1@news.povray.org>
That's just one of the proofs. The diagonalization proof is another. There
are many programs (most?) that you can prove you can't analyze.
Yes. There are a number of problems about sets of integers that you can
prove are true and can prove are unprovable in more powerful mathematical
systems. I.e., Godel's incompleteness doesn't apply only to Godel strings.
To translate it out of Wolfram self-congratulation-speak, he's saying that
there are no three-state turing machines that are UTMs.
It *can*, if your machine isn't sophisticated enough to represent the integers.
Can you solve the halting problem for all computer languages with no
indefinite loops?  Of course - they all halt.
I don't know why you think a machine with less than four states represents
programs humans tend to write.
This is nonsense. I have no idea what you're trying to say. Where did
"hand-written" come into it?  You're attacking a straw man.
Funny enough, infinities make things much more complicated. That's why
virtually every bit of math deals with infinities.
> problem.
What argument? The one about programs written by hand?
What way? By asking how many steps? No, you have a completely different
function.  Figuring out if something halts in 1000 steps is done completely
differently from figuring out if it halts ever, exactly because if the
answer is "no" then you can't simulate the thing you're analyzing long
enough to figure it out.
> Interesting...
Yes, exactly.
> steps.)
No.
> be no.
I suspect, given your later writing, you meant "yes" in that sentence.
Especially on a TM.  A TM that runs for 1000 cycles can't write to 1001
cells. Which is, incidentally, why you only get "unbounded" output from a
TM, not infinite output. If you give a TM an infinite tape,it will never all
get used up.
Sounds like you're on your way to Rice's Theorem.
http://en.wikipedia.org/wiki/Rice%27s_theorem
The halting problem only makes sense in the context of partial functions.
Not really.
Right. Exactly. There are an infinite number of programs isomorphic to
BlackMagic, and you can't tell which they are. Plus, even if you disallow
BlackMagic, you still haven't proven the existence of Magic. You've just
ruined one proof of it.
Look back over the diagonalization argument. There's no mention in there of
what gets computed for who or what. It (basically) shows there are more
partial functions than there are complete functions, so no complete function
will be able to list all the partial functions.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 10 Oct 2010 03:57:59
Message: <4cb17206@news.povray.org>
> will do.
  That's just the simplest proof. It doesn't mean it's the only one, or
that the only way of making an undecidable algorithm is by making it call
the halting problem solver itself.
  While this is not a proof of anything, it's however, a marvelously simple
example of why solving the halting problem is extremely difficult:
  "A program that goes through all even numbers and checks if one of them
is a counter-example to the Goldbach's conjecture. The program terminates
when it finds the first such number."
  An algorithm which solves the halting problem would prove (or disprove)
the Goldbach's conjecture with its answer (if the answer is "it never
halts", then it proves the conjecture, while the answer "it halts"
disproves it, and this disproval would be valid even if it couldn't give
the counter-example).
  How could an algorithm resolve whether that program will ever halt or not?
Top mathematicians have struggled with that problem for over 250 years, to
no avail. A program which solves the halting problem for any given program
would make proving basically *all* mathematical problems trivial.
  While, as said, this is not a proof that it's not possible, it gives a good
idea why it would be a tremendously difficult problem to solve.
Date: 10 Oct 2010 10:25:57
Message: <4cb1ccf5@news.povray.org>
FWIW, Rice's Theorem basically say *any* property that some but not all
functions have can be turned into the halting problem. So if there's
anything non-trivial you want to find out about what a function computes,
it's just as impossible to compute as the halting problem is.
   Serving Suggestion:
Date: 10 Oct 2010 12:35:04
Message: <4cb1eb37@news.povray.org>
  One interesting thing about the example I mentioned is that the program
in question is quite short. I'm sure you could write the program in 2 or 3
lines of Haskell (of course it has to assume integers of unlimited size and
an unlimited amount of RAM). Yet proving whether this extremely short program
will ever terminate has puzzled top mathematicians for over 250 years.
Date: 10 Oct 2010 20:34:30
Message: <4cb25b96@news.povray.org>
> number of steps.
How does a person go about deciding the same problem?  Or is that
impossible, too?
Tim Cook
http://empyrean.freesitespace.net
Date: 10 Oct 2010 21:29:07
Message: <4cb26863$1@news.povray.org>
>> number of steps.
> impossible, too?
That's impossible too.
Is this true or false:   "I am lying."
That's just one of the sorts of problems.
Note that there are many individual problems where you *can* figure this
out. It's just that there's no way to figure it out for *all* problems, and
no way of categorizing in advance which ones you can figure it out for and
which you can't.
   Serving Suggestion:
Date: 11 Oct 2010 04:11:39
Message: <4cb2c6bb$1@news.povray.org>
My favourite one is determining whether a point belongs to the
Mandelbrot set. The program to do this is about 3 lines long. Depending
on which point you choose to investigate, the program will either loop
forever (indicating that the point belongs to the M set) or halt after
finite iterations (indicating that the point belongs to the complement
of M).
The trouble is, the most celebrated single property of the M set is that
it's absurdly complicated.
When I was a teenager, I used to think that maybe instead of blindly
iterating the equations, you could use the geometric properties of the
set to figure out the answer faster. But now I realise that since the
geometric forms repeat to infinity as well, there are still points which
would be just as slow to categorise that way.
In fact I've seen how there are different ways of representing real
numbers (ratios, continued fractions, radicals, etc.), and for almost
every one, there are some real numbers that do not have a finite
representation. It seems reasonable that no matter what algorithm you
use for determining membership of M, there will still be cases requiring
infinity iterations.
No matter which way round you look at it, it's just not solvable in
finite time, *every* time.
And this is just one of the possible computer programs you could write.
We haven't even considered any of the more complicated generalised sets
one might contemplate. An algorithm that knows the special properties of
every single set mathematically definable so that they can all be
resolved in finite time? I double it...
Date: 11 Oct 2010 11:58:05
Message: <4cb3340d$1@news.povray.org>
The proof involving BlackMagic() is only a very slight variation on
diagonalisation. (That argument seems to work by constructing a binary
function over the program and its input, and then constructing a
function from it which is different by construction from any possible
computable function, demonstrating that the halting function isn't
computable. Or something like that.)
>> to be analysed isn't allowed to call Magic(), or perhaps one of the
> mathematical systems. I.e., Godel's incompleteness doesn't apply only to
> Godel strings.
Well, let's face it, who actually understands what the hell Godel's
incompleteness theorems actually say?
> that there are no three-state turing machines that are UTMs.
Oh, right. That's quite trivial...
> integers.
Which is the conclusion I also came to a few lines down. ;-)
>> "the kind of programs that human beings tend to write"?
> represents programs humans tend to write.
No, this is a new line of thinking, not an extension of the previous one.
I'm thinking "you can't solve the Halting Problem for any possible
program, but you use solve it for *useful* programs?" But, evidently, no
you can't.
Really? I had no idea that was true.
>> problem.
No, the one about using BlackMagic() to break Magic().
>> Interesting...
> Yes, exactly.
When you state it like that, it becomes "well *duh*, of *course* you
can't do that!" And yet, stated the original way, it looks like figuring
out whether a program halts ought to be "really easy" for some reason...
>> that takes any possible terminating program, and yields the same
>> result in strictly fewer steps?
> No.
And nobody is surprised about this. (As I intended to type...)
>> 2^K possibilities, but K-1 bits can only decompress into 2^(K-1)
>> the number of cycles that a program runs for to the number of possible
> a TM, not infinite output. If you give a TM an infinite tape,it will
> never all get used up.
Never? Or only after infinite time? *Is* there an "*after* infinite time"?
Now I know why mathematics generally tries to avoid infinity whenever
possible...
>> Magic() says it should halt. If non-termination is impossible, then
Yeah, I still don't quite understand Rice's theorem. It seems to say
that *everything* is impossible, despite the fact that we actually *do*
it almost every single day. So that can't quite be right...
> of what gets computed for who or what. It (basically) shows there are
> more partial functions than there are complete functions, so no complete
> function will be able to list all the partial functions.
If that's actually how it works, then the fact that there are more
partial than total functions is so jaw-droppingly self-evident that it's
quite a small proof.
Date: 11 Oct 2010 12:34:58
Message: <4cb33cb2@news.povray.org>
> impossible, too?
  There are some programs that if you can prove if they will halt or not,
you will receive 1 million dollars.
