There is a wide-spread belief that PDF is just a kind of "binary version
of" PostScript. For example,
http://ansuz.sooke.bc.ca/software/pdf-append.php
"PDF is basically PostScript with compression and some document
structuring conventions that supposedly make it easier to do operations
like concatenation."
This is a wholly inaccurate description.
First: PostScript is, surprisingly, a general Turing-complete
programming language. (Not many people seem to know this.)
PostScript and PDF do share similarities, and this apparently leads some
people to believe that they are "the same thing". This is manifestly not
the case.
There are many technical differences between the two, but let me skip
straight to the really big difference: PDF IS NOT TURNING-COMPLETE!
This single difference is probably the largest advantage of PDF for its
intended purpose - representing finished *documents*.
A PostScript file is basically an arbitrary computer program that can
optionally (!) generate printed pages as a side-effect of its execution.
Note that it's completely possible to write PostScript programs that do
normal file I/O and generally do what programs in any other languages
do. (It's just that nobody ever actually does this.) It's not uncommon,
though, to have a PostScript file that doesn't actually print anything,
it just configures the printer for a different mode, or installs a new
font or something.
A PS file is a linear sequence of operators and operands, not unlike an
assembly language program. In particular, it's tricky to find "page N"
in a PS file. In the general case, you basically have to execute the
whole program until N pages have been emitted, because page N could be
produced inside a for-loop, or some other control structure. (And the
"emit the page now" command could be arbitrarily renamed during the
execution of the program, so it's no good just doing a textual search
for it.)
A PDF file is a random-access container of "objects", some of which
describe what to print on the page. The page description language lacks
flow control (no branching, looping or conditional execution) and
doesn't even have variables. It's literally just a list of coordinates.
This is COMPLETELY DIFFERENT to PostScript!
In PDF, if you want 10 lines, you have to actually write ten line
descriptions. In PS, you could just write a program loop.
In addition, while a PS file is a linear series of program tokens that
must be executed to yield pages, a PDF file is random-access. It is
filled with self-contained "objects" which may be accessed in any order.
Actually there is a nominated "root object", which links to the other
objects to form a graph. (It's not actually a *tree* since it contains
cycles - e.g., each page points to the "next" and "previous" pages.)
Most especially, each page in a PDF file is completely independent.
Nothing that has happened in any other page has any effect at all on the
current page. There are "document structuring conventions" for
PostScript which urge you to avoid affecting later pages in the current
one, but nothing *enforces* this. It's just a "convention" that you're
supposed to follow. With PDF, it's hard-wired into the document spec.
Pages *cannot* affect each other, the end.
A PDF file also contains a crapload of metadata that a PostScript file
does not. A PS file prints pages. Using something like Ghostscript, you
can view those pages on screen rather than print them. But still, PS is
for printing. PDF is for printing *and viewing*. It can contain
*hyperlinks*. It can present electronic forms that you can fill in. It
can contain JavaScript to validate those forms. It can contain metadata
such as title, author, date, etc. Pages can be numbered. (Why? Well, in
case you have blank pages or title pages which are not numbered. So you
might want "page 1" to actually be the third sheet of paper.) You can
even set up a PDF file to be like a PowerPoint slide show.
In short, PostScript is an executable program. PDF is a passive data
container. And this makes the latter infinitely more easy to deal with.
Also - not many people know this - you can write a PDF file as plain
ASCII! All the main document constructs are plain ASCII. Usually various
objects are compressed to save space (particularly fonts, images and
page descriptions), but it *is* possible to write PDF files using
Notepad. (You'd be insane to try, of course, but it's doable.) PDF can
also be encrypted.
So there we have it. PDF is *not* a binary PostScript. The two *do* have
the same drawing operators. (Draw a line, draw a 3rd-order Bezier
spline, draw a circular arc, transform the coordinate space, etc.) But
that's the sum total of their similarity. (Indeed, PDF supports
transparency, which PS curiously does not. PS supports "spot colours",
which PDF does not. PS has support for special printer instructions that
PDF does not. PDF supports various interactive features like hyperlines
and forms that PS does not. And so on.)
> of" PostScript.
Interesting thing I've read somewhere: PDF is derived from .ai (Adobe
Illustrator). You can just rename a .pdf to .ai and it will open in
Illustrator. This works most of the time but not always. I've also tried
renaming .ai files to .pdf and it doesn't open in Acrobat...
-Nekar Xenos-
>> version of" PostScript.
Having never used or even seen Illustrator, I couldn't comment. I'd
imagine whatever the file is named, it's looking for the magic number at
the start to decide what to do with it.
There was once a rumour that if you rename a PostScript file to PDF,
Acrobat Reader would be able to open it. This isn't true, and when you
consider that PDF is just a data format while PostScript requires a
language interpreter to actually *execute* it, it's not surprising really.
Le 2010-10-01 05:38, Invisible a écrit :
> But still, PS is for printing.
Not necessarily. It may have been designed by Apple fro printing, but
the display system on the the NeXT Cube (Steve Jobs' foray into the
high-end workstation market, while on a break from Apple) was
Postscript-based, instead of being X11-based, like the other workstations.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
That's true. My real point is that the design goal for PS was as a
language for controlling physical printers (which is why it has
sophisticated colour management, spot colours, screen print settings,
etc.) while PDF was aimed at documents you can read on a screen as well
as print (and hence PDF has interactive features that PS does not).
Of course, PS is a programming language. You can quite easily add any
features to it that aren't there as standard. (E.g., by default there's
no way to do transparency, but you could design a PS-based system that can.)
... was a pale and lame light next to the beauty that was NeWS, where
*everything* was Postscript and thereby eliminated 95% of the problem X has
with slow network links, as well as all the crap focus-lock BS you need when
things happen asynchronously.
Serving Suggestion:
"Don't serve this any more. It's awful."
