POV-Ray : Newsgroups : povray.off-topic : More web madness Server Time
1 Nov 2026 15:32:12 EST (-0500)
  More web madness (Message 1 to 18 of 18)
Subject: More web madness
Date: 22 Sep 2010 06:40:10
Message: <4c99dd0a$1@news.povray.org>
Take a small page, such as
<html>
<body>
<script type="text/javascript">
document.write("Hello world");
</script.
</body>
</html>
This works fine in Firefox, although it renders in quirks mode. (As
you'd expect.) Now slap an XHTML DTD onto it, and suddenly it completely
stops working. Instead, if I open the "error console", I get
   Error: uncaught exception: [Exception... "Operation is not supported"
  code: "9" nsresult: "0x80530009 (NS_ERROR_DOM_NOT_SUPPORTED_ERR)"
WTF?
Yeah, that's real helpful. :-P
Subject: Re: More web madness
Date: 22 Sep 2010 06:53:40
Message: <4c99e034$1@news.povray.org>
On 22/09/2010 11:40 AM, Invisible wrote:
> WTF?
After some investigation, it seems that all the DOM stuff works, just
not document.write(). Again, WTF?
Date: 22 Sep 2010 09:50:22
Message: <op.vjfsqez8mn4jds@phils>
And lo On Wed, 22 Sep 2010 11:40:08 +0100, Invisible <voi### [at] devnull> did
spake thusly:
> <html>
> <body>
> </script.
> </body>
> </html>
Works for me with a XHTML Strict in FF 3.6.10
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 22 Sep 2010 09:54:01
Message: <4c9a0a79$1@news.povray.org>
Interesting. Doesn't work for me with FF 3.5.6...
Date: 22 Sep 2010 13:04:43
Message: <4c9a372b$1@news.povray.org>
Invisible escreveu:
>> WTF?
document.write is not part of DOM:  you can see it simply writes new
content to the page, doesn't work by manipulating trees and nodes as in
DOM.  It's a relic from pre-standardized Netscape days..., like the
blink tag... :p
a game sig: http://tinyurl.com/d3rxz9
Date: 23 Sep 2010 04:06:36
Message: <4c9b0a8c$1@news.povray.org>
I know that.
> DOM. It's a relic from pre-standardized Netscape days..., like the blink
> tag... :p
Well, that's very nice, but as far as I can see, there's no equivalent
way of doing what document.write does.
PS. Did <blink> ever get removed from the DTD? I really hope so...
Date: 23 Sep 2010 14:19:45
Message: <4c9b9a41@news.povray.org>
Invisible escreveu:
> I know that.
>> tag... :p
what? like:
var foo=document.getElementById("foo");
var p=document.createElement("p");
var txt=document.createTextNode("Text in the paragraph!");
p.appendChild( txt );
foo.appendChild( p );
or something like that (it's been a while I last fiddled with DOM)...
not as practical as document.write, of course...
Date: 23 Sep 2010 15:39:13
Message: <4c9bace1$1@news.povray.org>
> what? like:
In particular, it works *only* if you tag the place where you want the
generated content to go, or you know enough about the static structure
of the document to be able to navigate to it.
My usual trick is to do document.write("JavaScript is enabled."). It's a
nice, simple way of determining whether the browser supports JS and has
it enabled. It's also useful for not showing buttons for features that
require JS if JS is not available...
http://blog.orphi.me.uk/
Subject: Another day
Date: 28 Sep 2010 07:57:41
Message: <4ca1d835$1@news.povray.org>
OK, here's a great one:
Does anybody know how to make it so that images show up normal size on a
web page, but shrink to fit the paper when the page is printed out?
(Yes, I realise that printing a web page is 92% guaranteed to fail in
all possible cases...)
Subject: Re: Another day
Date: 28 Sep 2010 08:22:09
Message: <4ca1ddf1@news.povray.org>
  By providing a printable version of the page, as some websites do.
Date: 28 Sep 2010 08:27:16
Message: <4ca1df24$1@news.povray.org>
Google CSS Media. That should at least get you started.
~Mike
Date: 28 Sep 2010 09:55:19
Message: <4ca1f3c7$1@news.povray.org>
OK, so adding
   @media print
     img {max-width: 100%;}
causes all images to be scaled to fit the width of the paper.
Unfortunately the image height remains completely unchanged, wildly
distorting the image aspect ratio. (!)
You'd think there would be an option for "preserve aspect ratio", but as
far as I can tell, there isn't...
Date: 28 Sep 2010 10:26:13
Message: <4ca1fb05$1@news.povray.org>
> OK, so adding
>   @media print
I get a pleasant result (at least in preview from Firefow) with
img {max-width: 17cm; max-height: 24cm; background: white ;color:#000; }
inside a <link rel="stylesheet" href="../style/print.css"
type="text/css" media="print" />
Beware of transparent images, background is a good idea!
You might want to take care of page-break after title:
h1 {  page-break-after:avoid}
h2 {  page-break-after:avoid}
h3 {  page-break-after:avoid}
h4 {  page-break-after:avoid}
/* up to your usual depth */
At least it try to give some clue to the paging engine.
As well as printing the actual URL of link (because on paper, a printed
visual of link is useless):
a:link:after, a:visited:after{ content: " (" attr(href) ") ";
font-size: 90% }
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 28 Sep 2010 10:44:24
Message: <4ca1ff48@news.povray.org>
>> OK, so adding
>>    @media print
This requires you to know what the dimensions of the paper are, and what
the correct aspect ratio of every image is. I'd prefer it if there were
some way to have the browser scale images in proportion, but I'm not
seeing any way of doing that.
Isn't that part of the default CSS rules anyway? Certainly the
pagination looks fairly plausible right now.
> font-size: 90% }
That's true - not that the correct document I'm working on contains any
links...
Date: 28 Sep 2010 12:19:08
Message: <4ca2157c$1@news.povray.org>
nemesis wrote:
> Invisible escreveu:
>> I know that.
>>> tag... :p
> what? like:
Maybe like outputting mismatched tags to the browser?  What's the equivalent of
document.write("<table>")
    Quoth the raven:
        Need S'Mores!
Date: 29 Sep 2010 03:58:10
Message: <4ca2f192$1@news.povray.org>
Le 28/09/2010 16:44, Invisible a écrit :
>>> OK, so adding
>>>    @media print
Yes and No.
Notice we set max-*, not width & height... so the max-* does not define
any ratio: in firefox preview, at worst one of the max is inforced (and
the other dimension remains lower) if the number of pixel reach the
dimension... If the picture is smaller, it is not expanded.
(Problem: we do not have access to the DPI either!)
the problem with "100%" is that it is relative to the container... an
absolute size would be better: I used "cm" but you can search for some
units more appropriate (hint: CSS3 vm/vh/vW ?) (viewport...)
Date: 29 Sep 2010 04:03:10
Message: <4ca2f2be$1@news.povray.org>
> Yes and No.
> Notice we set max-*, not width&  height... so the max-* does not define
Yes. And I had *hoped* that by setting only the maximum width, Firefox
would figure out that the height should be similarly adjusted. But no...
Yes. And if the container is the entire page, it means that the image
ends up the exact right size for whatever size of paper you happen to be
using (which I cannot know ahead of time).
Date: 29 Sep 2010 11:15:04
Message: <op.vjsvbkaxmn4jds@phils>
And lo On Tue, 28 Sep 2010 14:55:18 +0100, Invisible <voi### [at] devnull> did
spake thusly:
> OK, so adding
>    @media print
Not sure what you're trying to do as
img {width: 20%;}
@media print {img {width: 100%;}}
Takes a 50% screen width image and fills the width of my print preview up
whilst retaining the proportions of the height. Modifying the print style
width adjusts to the page and the height shifts accordingly. This works in
Firefox, Opera, and hey Chrome doesn't have a preview... nope that printed
out fine.
The attachment is for a width of 20% and 10% respectively.
Phil Cook
Download 'printwidth.png' (19 KB)
Preview of image 'printwidth.png'
