POV-Ray : Newsgroups : povray.off-topic : Wavelet Server Time
28 May 2026 05:18:55 EDT (-0400)
  Wavelet (Message 1 to 10 of 12)
Subject: Wavelet
Date: 14 Sep 2010 08:07:49
Message: <4c8f6595$1@news.povray.org>
A couple demos:
http://math.hws.edu/eck/math371/applets/Haar.html
This is what's used in jpeg compression...
And is rather clever, when you think about it.
Take a signal, repeatedly break it up into pairs of low and high
frequencies, subsample those segments, and place them back into the buffer.
Now, once that has been completed, discard the samples that have the
lowest amplitudes.
Rebuild the signal with the remaining samples. You've dropped a ton of
data, but still have a very close approximation of the original data.
Another use of wavelets: Fourier analysis of signals.
Break the signals down using wavelets, then take each section of the
decomposition, and run a Fourier transform on each section. The lower
frequencies will be pushed into the higher bands, allowing for higher
frequency resolution of the lower frequencies.
(Typically, with a Fourier transform low frequencies don't have very
good resolution, since the progression of frequencies are such:
1x 2x 3x 4x 5x 6x 7x 8x 9x ...
If the frequency band you're interested in is close to the fundamental
of the transform; you have huge jumps in frequency. take the first two
samples: Fundamental and double the fundamental. Nothing in between.
Move that to the right:
32x 33x 34x 35x 36x 37x 38x 39x ...
Now you step between the fundamental at 32 and the next highest sample
is 1.03x so, now you're looking at samples with this sort of stepping:
1x 1.03x 1.06x 1.09x 1.12x 1.15x ...
Much more precision in the frequency domain. The time domain, obviously
will suffer for these lower frequencies. You can't pinpoint as
accurately where they are in time, due to the slowness of their
oscillation. There are ways, I think, of getting around this, but I
haven't gotten that far in my understanding.
~Mike
Subject: Re: Wavelet
Date: 14 Sep 2010 09:40:13
Message: <4c8f7b3d$1@news.povray.org>
On 14/09/2010 01:04 PM, Mike Raiford wrote:
> A couple demos:
No, I'm fairly sure JPEG uses the Discrete Cosine Transform. Now
JPEG2000 really *does* use some manner of wavelet transform (although I
don't remember which one).
I'm not at all clear on exactly how it does that.
> lowest amplitudes.
Most transform coding methods work not by *discarding* points, but by
*quantinising* them according to how "important" they are deemed to be.
This one seems a little unusual in that respect.
It's not Fourier analysis if it's not a Fourier transform. ;-)
In fact, you can apparently decompose any function into the sum of a
suitable set of basis functions. (I believe that the set of basis
functions is required to be "orthogonal" and "complete", but beyond that
they can be anything.) Depending on what basis functions you choose,
discarding or quantinising points will distort the reconstructed
function in different ways. The trick is to find a good set of basis
functions for the problem in question.
(E.g., for audio data, sine waves are the obvious candidate. The only
question is whether they should be finite or not. For image data, the
solution is less obvious.)
Apparently there's a limit to how much precision you can get in time and
frequency. Increasing the resolution of one necessarily decreases the
resolution of the other. This is apparently due to the Heisenberg
uncertainty principle. (Which is interesting, since I thought that
applies only to quantum mechanics, not to general mathematical phenomena...)
Date: 14 Sep 2010 10:00:59
Message: <4c8f801b$1@news.povray.org>
>> A couple demos:
http://en.wikipedia.org/wiki/Jpeg#JPEG_codec_example
Nice to know I'm right for once. ;-)
> Now
http://en.wikipedia.org/wiki/JPEG_2000#Technical_discussion
It's the Discrete Wavelet Transform (DWT).
Date: 14 Sep 2010 10:27:12
Message: <4c8f8640$1@news.povray.org>
Ah.. You're right, it is JPEG2000.
>> buffer.
Using a pair of filters, low pass and high pass in a bank,
so you filter low frequencies, this becomes the first stage, which is
downsampled by 2.
Let see, this is a nice diagram:
http://en.wikipedia.org/wiki/Discrete_wavelet_transform#Cascading_and_Filter_banks
Apparently, once the filters are run over it, you can downsample each of
the filtered components. The low pass can then be filtered again How
reducing the sample rate of the high pass data doesn't discard data I'm
not sure, yet.
Right. *But* you can drop every other sample because of the Nyquist limit!
ERRRR... Frequency domain analysis. In the end you're doing Fourier
transforms on each portion you've separated out in the decomposition.
> phenomena...)
Interesting. It makes sense, though. Low frequencies change relatively
little in the time domain. You can tell when it occurs, when exactly a
peak is, but now how it changes if delta-t is less than the frequency of
the wave.
~Mike
Date: 14 Sep 2010 10:44:29
Message: <4c8f8a4d$1@news.povray.org>
>>> buffer.
Doesn't look like any kind of lowpass or highpass filter response to me.
Looks more like it's rearranging the order of the samples or something.
> downsampled by 2.
> not sure, yet.
When downsampling, frequencies above the Nyquist limit get reflected to
the other side of the Nyquist limit. Usually this means that the high
frequencies collide with the low frequencies - but if you've already
filtered out the low frequencies, all that happens is that the spectrum
gets flipped upside-down. You can completely reverse this process by
upsampling and then flipping the spectrum back the right way round
again. QED.
Yes. I was just pointing out that other transform codings work in a
rather different way.
>> phenomena...)
> the wave.
Weird, but true. And since quantum particles ARE ALSO WAVES, you start
to understand why this might be true...
Date: 15 Sep 2010 10:43:42
Message: <4c90db9e@news.povray.org>
>>>> buffer.
What it appears to be doing is for every 2 samples:
The first of the pair gets the same positive value on its respective
sample in the first and second half. The second of the pair is then
added to the sample on the first half, and subtracted from the sample on
the second half.
Subsample and repeat the desired number of times.
> again. QED.
OK, Makes sense.
Right.
~Mike
Date: 15 Sep 2010 10:56:00
Message: <4c90de80$1@news.povray.org>
> the second half.
So for every pair of samples, it simply computes the sum and the difference?
Date: 15 Sep 2010 11:19:50
Message: <4c90e416$1@news.povray.org>
>> the second half.
> difference?
Recursively, yes...
~Mike
Date: 15 Sep 2010 11:44:24
Message: <4c90e9d8@news.povray.org>
>> difference?
> Recursively, yes...
Right. Well if you say "it calculates the sum and the difference of each
pair of samples", suddenly it becomes pretty obvious what it's doing,
and why it's reversible.
It also explains why the partial reconstructed wave is the shape it is.
And it suggests that having fewer terms available is going to futz with
the high frequencies first.
(Then again, this sort of transform is probably more useful for
time-domain signals like image data rather than frequency-domain data
like sound.)
Date: 15 Sep 2010 15:02:45
Message: <4c911855$1@news.povray.org>
>>> difference?
>> Recursively, yes...
> like sound.)
Right! But, the trick also gives better frequency resolution at lower
frequencies, simply because of the subsampling that takes place.
~Mike
