POV-Ray : Newsgroups : povray.off-topic : Web page construction Server Time
22 Jul 2025 08:16:30 EDT (-0400)
  Web page construction (Message 1 to 10 of 35)
Subject: Web page construction
Date: 12 Sep 2010 08:21:36
Message: <4c8cc5d0$1@news.povray.org>
OK, here's a couple of little questions that somebody here might know
the answer to...
1. Suppose I have something like
   <h1>Introduction</h2>
   <p class='buttons'><a href="javascript:ShowHide()">(Show/hide)</a></p>
   <div id='intro'>
   ...real content...
Without any CSS, this renders as something like
   Introduction
   (Show/hide)
   ...real content...
Is there some way I can style it so that it shows up more like
   Introduction
   (Show/hide)
   ...real content...
or even
   Introduction (Show/hide)
   ...real content...
If so, how do I do it?
2. I want to build a file tree where you can collapse or expand tree
nodes. The obvious way to do this is with the <ul> element. However, I
also want each file to have attributes, a creation date, and so forth,
and all these columns should line up vertically. The obvious way to do
that is with a table. But it can't be a table and a list at the same time!
I could use nested tables I suppose, but nested tables are EVIL! Is
there some more semantically-transparent way that I can do this?
   Root                               2009-09-12  Ahsc
     Resources                        2009-09-10  Ahsc
       Main.css                       2009-09-10  Ahsc
       Main.js                        2009-09-10  Ahsc
     Packages                         2009-09-12  Ahsc
       ansi-terminal                  2009-09-12  Ahsc
http://blog.orphi.me.uk/
Subject: Re: Web page construction
Date: 12 Sep 2010 09:30:18
Message: <4c8cd5ea$1@news.povray.org>
Le 12/09/2010 14:21, Orchid XP v8 nous fit lire :
> the answer to...
you meant </h1>, right ?
>   <div id='intro'>
>   ...real content...
>   Introduction
>   (Show/hide)
>   ...real content...
>   Introduction
>   (Show/hide)
>   ...real content...
> or even
>   ...real content...
without css ? in plain html 1.0 ? No chance without breaking some bits.
<p> will always force a line-feed/spacing
<h..> is alone on its line.
<h1>Introduction <a href="...">(Show/hide)</a></h1>
is the best you can have. (with a <br/> before starting the <a> if you
want, but I do not like it.)
Now, if you want to show/hide the <div>, why do you need to do that
outside the div itself ? And why javascript ?
if it is not done with css, rather show it always and do not display the
hide/display mechanism.
BTW:
<h1>Introduction</h1> (that's bad, as only 1 h1 per page, so, unless the
page's object is introduction (to what ?).. you got a content's issue.
<h1>Subject of page</h1>
<h2>Introduction</h2>
is probably better.
You need to tag your date & attribute (with span), and have the css to
position them at absolute horizontal position (in em or ex! or you will
get issue with fontsize/resize by user)
That way, you nest your <ul><li>, and each line (<li>) got its semantic.
<ul>
<li>Root<span class="datum">2009-09-12</span><span
class="attributes">Ahsc</span><ul>
<li>Resources<span class="datum">2009-09-12</span><span
<li>Main.css<span class="datum">2009-09-12</span><span
class="attributes">Ahsc</span></li>
<li>Main.js<span class="datum">2009-09-12</span><span
</ul></li>
<li>Packages<span class="datum">2009-09-12</span><span
<li>ansi-terminal<span class="datum">2009-09-12</span><span
</ul></li>
</ul></li></ul>
Date: 12 Sep 2010 11:58:36
Message: <4c8cf8ac@news.povray.org>
>> the answer to...
Uh, yes.
Oh, no, I meant "what CSS do I need to apply to make this happen?"
It's outside so that hiding it doesn't also hide the button that unhides
it. ;-) As for "why JavaScript"... um, what other possibilities exist?!
> BTW:
> is probably better.
Well, yes, it's an incomplete page fragment.
> position them at absolute horizontal position.
OMG, that works?? o_O
I thought absolute positioning only allows you to position an item
absolutely with respect to the browser window. I didn't think you could
make just *one* coordinate absolute. (And even then, I thought the
coordinates are relative to the browser window, not the page.)
Clearly some research is required...
Date: 12 Sep 2010 13:35:18
Message: <4c8d0f56@news.povray.org>
Le 12/09/2010 17:58, Orchid XP v8 nous fit lire :
My favorite source of information for web-design.
http://www.alistapart.com/
Do not hesitate to use the right margin for Topics search
Date: 12 Sep 2010 14:15:00
Message: <web.4c8d181c6a6928bc400de6340@news.povray.org>
> the answer to...
>    <div id='intro'>
>    ...real content...
>    Introduction
>    (Show/hide)
>    ...real content...
>    Introduction
>    (Show/hide)
>    ...real content...
* { padding: 0; margin: 0; }
div { margin-top: 3em; }
> or even
>    ...real content...
h1, .buttons { display: inline; }
no, the obvious way in this day and age is to just use jQuery:
http://jquery.org/
like:
http://homework.nwsnet.de/news/ea21_turn-nested-lists-into-a-collapsible-tree-with-jquery
And if you are fed up with web design and web pages and want to develop web apps
instead, go for http://cappuccino.org/
Both big, damn-useful and open-source frameworks of pure cross-platform
javascript glory.  No doubt one of the most relevant languages today...
Date: 13 Sep 2010 04:05:42
Message: <4c8ddb56$1@news.povray.org>
Turn off margins on *everything*? Isn't that a little OTT?
>> nodes. The obvious way to do this is with the<ul>  element.
> http://jquery.org/
Um... JQuery is a library for writing JavaScript. How is that relevant
to building a static web page?
> like:
So... you transform the page on the client-side? Why in the name of God
would you do that?
No. I am merely building static pages, not complex web apps.
Date: 13 Sep 2010 11:01:07
Message: <4c8e3cb3@news.povray.org>
On 12/09/2010 01:21 PM, Orchid XP v8 wrote:
> Introduction
> (Show/hide)
> ...real content...
Apparently, you can use the position: property for this. This property
has several possible values, almost none of which do what their names
suggest:
position: static is the normal flow-based positioning (?!)
position: relative lets you shift an element in relation to its usual
position (without affecting anything else around it).
position: fixed fixes the element's position relative to the browser window.
position: absolute fixes the element's position relative to the first
enclosing element who's position: attribute isn't static (usually the
entire page (!!))
So, by enclosing the entire section in some kind of block-level element
and setting its position to "relative" (but not actually moving it), you
can then set the show/hide button to "absolute", which then allows you
to position it *relative* to the enclosing block (WTF?) Best of all, the
rest of the flow now behaves as if that button wasn't there.
Only trouble is, now I've gone from having too much space to having not
enough... >_<
> or even
> ...real content...
As far as I can tell, this is impossible.
Date: 13 Sep 2010 11:14:57
Message: <4c8e3ff1$1@news.povray.org>
>> ...real content...
"This next test is impossible..."
I guess that was pretty much guaranteed to result in abject failure, eh?
Apparently simply setting
   h1 {display: inline;}
somehow *doesn't* make <h1> display inline, but if you also make the
following <p> tag inline, the correct result is obtained. I have
absolutely no idea why the hell that works, and whether it works in all
browsers or whether it's just a Firefox bug.
(As an aside, IE7 seems totally unable to display this particular XHTML
page at well, which is weird...)
Date: 13 Sep 2010 12:48:07
Message: <4c8e55c7@news.povray.org>
Invisible escreveu:
yes, but does exactly what your example needed.
In any case, it's very common to find that rule in most css files and
then specify padding/margin per element in need.
>> http://jquery.org/
You wanted a file tree to collapse or expand tree nodes and that is best
served on the client via javascript.
>> like:
> would you do that?
so you don't need to waste bandwidth?
Think GMail:  they serve a mostly static page containing complex
javascript that then occasionally asks the server to check for new data
and then have those small data changes served rather than process lots
of html and server side languages just to serve a tiny bit of changed data.
a game sig: http://tinyurl.com/d3rxz9
Date: 13 Sep 2010 12:55:02
Message: <4c8e5766$1@news.povray.org>
Invisible escreveu:
>>> ...real content...
http://www.w3.org/TR/CSS2/visuren.html#display-prop
It's "inline" in relation to previous element.  But h1 in your code has
no previous element.  p has h1 as previous element, and thus get inlined
next to h1 when it too gets display:inline.
no, weird is to expect IE to be able to display standards-compliant
content.  Sometimes it does, most times doesn't.
