POV-Ray : Newsgroups : povray.off-topic : FFT Filter... easy. Server Time
7 Mar 2026 11:33:36 EST (-0500)
  FFT Filter... easy. (Message 1 to 6 of 6)
Subject: FFT Filter... easy.
Date: 27 Aug 2010 11:24:39
Message: <4c77d8b7$1@news.povray.org>
Sooooo ... I wanted to try to make an FFT filter.
Actually quite easy:
There's a couple tricks, of course. One being how the file is being
read. I read chunks 2*FFT Len... then seek back by FFT Len. This is so I
have enough extra data to do the overlap later.
The code that does the filtering isn't actually using the generated
filter (I was experimenting, and rather than mess with creating a filter
with a nice rolloff Like I set out to do, I just did a sharp cut at a
certain frequency, in this case its a high-pass filter...) The filter is
reflected from FFT_LEN to 2*FFT_LEN. This may not be necessary as I
believe the only thing it will affect is the resulting imaginary numbers
when the ifft is computed. Once the ifft is performed, the blocks are
blended using a Gaussian curve to eliminate any pops caused by abrupt
sample value changes. (This is also the reason the data is read in the
way it is, otherwise half the signal would be empty)
There is probably A LOT of improvement this could take, but its a neat
start. :D
Code follows (C#)
         const int FFT_LEN = 4096;
         static void Main(string[] args)
             double[] dr = new double[FFT_LEN*2];
             double[] di = new double[FFT_LEN * 2];
             double[] fr = new double[FFT_LEN * 2];
             FileStream fs =
System.IO.File.OpenRead(@"D:\Sample\sound.raw");
             for (int i = 0; i < FFT_LEN; i++)
                 fr[i] = 1/Math.Pow(1+(i)/(double)FFT_LEN, 2);
             int bytes = 0;
             byte[] samples = new byte[FFT_LEN*2];
             List<double> output = new List<double>();
             int time = 0;
             int ch = 0;
             int bl = (int)((fs.Length/FFT_LEN) / 40) / 4;
             while ((bytes = fs.Read(samples, 0, FFT_LEN*2)) > 0)
                 if(fs.Position != fs.Length)
                     fs.Seek(-FFT_LEN, SeekOrigin.Current);
                 time++;
                 if (time % bl == 0)
                     switch (ch)
                         case 0:
                             Console.Write(".");
                             break;
                         case 1:
                             Console.Write("\bo");
                             break;
                         case 2:
                             Console.Write("\bO");
                             break;
                         case 3:
                             Console.Write("\bX");
                             break;
                     ch = (ch + 1) % 4;
                 for (int i = 0; i < dr.Length; i++)
                     di[i] = 0;
                     if (i < bytes)
                         dr[i] = samples[i] - 128;
                     else
                         dr[i] = 0;
                 fft(FFT_LEN*2, dr, di, false);
                 for (int i = 0; i < FFT_LEN*2; i++)
                     // Convert to polar coordinates:
                     double m = Math.Sqrt(Math.Pow(dr[i], 2) +
Math.Pow(di[i], 2));
                     double p = Math.Atan2(di[i],dr[i]);
                     int n = i;
                     if (n >= FFT_LEN) n = -(FFT_LEN - (n + 1));
                     if (i < FFT_LEN-3000 || i > FFT_LEN+3000) m = 0;
                     dr[i] = m * Math.Cos(p);
                     di[i] = m * Math.Sin(p);
                 fft(FFT_LEN*2, dr, di, true);
                 if (output.Count > 0)
                     int start = output.Count - FFT_LEN;
                         double fn = Math.Exp(-Math.Pow(i, 2) / (2 *
Math.Pow(FFT_LEN/4, 2)));
                         //dr[i] += output[i + start];
                         dr[i] = dr[i]*(1-fn) + fn*output[i + start];
                 // Replace the last FFT_LEN samples with the samples in dr.
                 if(output.Count > 0) output.RemoveRange(output.Count -
FFT_LEN, FFT_LEN);
                 output.AddRange(dr);
             fs.Close();
             FileStream outF = File.OpenWrite(@"d:\sample\out.au");
             BinaryWriter bw = new BinaryWriter(outF);
             bw.Write(new byte[] { (byte)'.', (byte)'s', (byte)'n',
(byte)'d' });
             bw.Write(BE(24));
             bw.Write(BE(output.Count));
             bw.Write(BE(2));
             bw.Write(BE(44100));
             bw.Write(BE(1));
             for (int i = 0; i < output.Count; i++)
                 sbyte out_byte = (sbyte)Math.Min(Math.Max(output[i],
-127), 127);
                 //System.Diagnostics.Debug.Print("{0} = {1}",
output[i], out_byte);
                 //sbyte out_byte = (sbyte)(Math.Sin(i/100.0)*127);
                 bw.Write(out_byte);
             outF.Close();
             //fft(16, r, i, false);
             //System.Console.ReadKey();
         static byte[] BE(int n)
             byte[] bytes = BitConverter.GetBytes(n);
             return bytes.Reverse().ToArray();
         static void fft(int n, double[] rx, double[] ix, bool inverse)
             if (Math.Abs(Math.Truncate(Math.Log((double)n, 2)) -
Math.Log((double)n, 2)) > 0.00001)
                 throw new ArgumentException("n must be a power of 2");
             int hn = n / 2;
             int j = 0;
             // Reverse bit sort
             // Essentially, the indices bit order is reversed.
             for (int i = 0; i < n - 1; i++)
                 if (j > i)
                     double tr = rx[j];
                     double ti = ix[j];
                     rx[j] = rx[i];
                     ix[j] = ix[i];
                     rx[i] = tr;
                     ix[i] = ti;
                 int k = hn;
                 while (k <= j)
                     j -= k;
                     k >>= 1;
                 j += k;
             // FFT
             int m = (int)Math.Log(n, 2);
             int l1 = 1;
             // Each stage in the recomposition
             for (int l = 0; l < m; l++)
                 int l2 = l1;
                 l1 <<= 1;
                 double ur = 1;
                 double ui = 0;
                 double sr = (double)Math.Cos(Math.PI / l2);
                 double si = (double)Math.Sin(Math.PI / l2);
                 if (inverse) si = -si;
                 double tr;
                 double ti;
                 // Each Value in that state
                 for (j = 0; j < l2; j++)
                     for (int i = j; i < n; i += l1)
                         int i1 = i + l2;
                         tr = rx[i1] * ur - ix[i1] * ui;
                         ti = rx[i1] * ui + ix[i1] * ur;
                         rx[i1] = rx[i] - tr;
                         ix[i1] = ix[i] - ti;
                         rx[i] = rx[i] + tr;
                         ix[i] = ix[i] + ti;
                     tr = ur;
                     ur = tr * sr - ui * si;
                     ui = tr * si + ui * sr;
             if (inverse)
                 for (int i = 0; i < n; i++)
                     rx[i] /= n;
                     ix[i] /= n;
~Mike
Subject: FFT Vocoder = Not as easy [~150K]
Date: 27 Aug 2010 12:47:30
Message: <4c77ec22@news.povray.org>
Well.. Maybe... , but here's the output from a 512 channel vocoder using
a modified version of the posted code ;)
There's definitely room for improvement. One to keep the drone down
somehow, and two, to allow for higher resolution filters based by
overlapping slices.
Apologies for the sample used. I needed a quick spoken-word sound byte,
and ... well.. it was convenient.
~Mike
Download 'calvary2.mp3.mpg' (33 KB) Download 'out.mp3.dat' (135 KB)
Subject: Re: FFT Filter... easy.
Date: 27 Aug 2010 13:02:59
Message: <4c77efc3$1@news.povray.org>
You're aware that you can perform linear filtering operations without
using an FFT at all, right?
An FFT convolution is faster when the filter kernel is large, however.
> start. :D
I sat here and thought about posting the 8 lines or so of Haskell it
would take to do the same task. And then I realised that Warp would
complain that it's not processing the data in-place, so it has different
performance characteristics, and then I'd have to build both your
version and my version and do detailed timing statistics, which would
require me to install the MS .NET runtime and some sort of C#
compiler... Nah. I have better things to do with my Friday afternoon. ;-)
http://blog.orphi.me.uk/
Date: 27 Aug 2010 13:24:12
Message: <4c77f4bc@news.povray.org>
Well, yeah... of course. There's dozens of polynomials out there to do
it, too. But try designing an arbitrary filter with that. :D
The kicker is, all of those filter functions can be built using
capacitors, resistors and/or inductors.
Indeed. But using FFT makes filter design easier.
... And using FFT also makes doing a vocoder rather simple.
Thbbbbbbt.
~Mike
Subject: Re: FFT Vocoder = Not as easy [~150K]
Date: 27 Aug 2010 13:25:24
Message: <4c77f504@news.povray.org>
Another one ... same sample ... this sound rather ominous. Using a
square wave as the basis.
~Mike
Download 'out.mp3.dat' (102 KB)
Date: 27 Aug 2010 14:40:11
Message: <4c78068b@news.povray.org>
  I don't understand why.
