POV-Ray : Newsgroups : povray.off-topic : imperial vs metric Server Time
17 Oct 2026 20:14:46 EDT (-0400)
  imperial vs metric (Message 1 to 50 of 54)
Goto Latest 50 Messages Next 4 Messages >>>
Subject: imperial vs metric
Date: 23 Aug 2010 14:48:00
Message: <4c72c260$1@news.povray.org>
I think I figured out the real differences there. It's not the "power of
ten" stuff.  After having to decide between 0.2 liters of beer or 0.3 liters
of beer, I realized it's something different.
Imperial measurements are generally based on humans, so it's pretty
convenient for everyday usage.
Temperature: 0 is about as cold as you're likely to run into in most places,
100 is uncomfortably hot and basically body temperature.  50-75 is
comfortable for the most part.
Distance: As big as your finger (inch), your foot (foot), your arms (yard),
how far you can conveniently walk (mile).
Volume: A sip (spoonful), a mouthful (ounce), a mug full (pint), a bottle
full (quart), a bucket full (gallon), and about as much as you can
conveniently move by yourself (a barrel).
Weight: Again, a little bit almost unnoticeable size of a coin (ounce),
convenient to carry in one hand (pound), convenient for weighing people or
animals (stone, which nobody seems to actually use any more), about as much
as you can reasonably ship someplace (a ton).
All very convenient for human scales.
But metric wins for science.
The difference with metric is that it's easy to calculate big numbers.  In
imperial measurements, the next thing up from a mile is an AU, or a
light-year, or a parsec (assuming you want to call these "imperial" at all).
There's really nothing smaller than an inch, except fractions of an inch,
and nobody goes below a 64'th of an inch. There's nothing lighter than an
ounce, or heavier than a ton - no way to express the weight of an atom or a
planet.
Metric has the advantage that you don't get into weird problems with units
when you do science.  I don't think it really matters that things are
specifically multiples of 10 until you start getting into figuring out
ranges of numbers where exponents come into play. I'm not sure how the
interrelatedness of the numbers matters at all: is it really useful that
grams are defined in terms of the weight of a certain substance? I can't
imagine how that would be useful in science, especially when things like
"moles" and "c" are defined in terms of natural units.
In practice (for those of you who are used to metric), in every-day usage,
imperial weird units don't really cause the sort of problem that people seem
to think it causes. I no more have to frequently convert inches to miles
than you frequently need to figure out the number of minutes in a year. Once
you're talking miles, the number of inches is as immaterial as asking how
many miles are in an inch when you're measuring to construct a chair or
something. The worst stuff is measuring your room to be 12 3/4 feet, and
finding out carpet is sold by the inch or something.
    Quoth the raven:
        Need S'Mores!
Subject: Re: imperial vs metric
Date: 23 Aug 2010 15:43:54
Message: <4c72cf7a@news.povray.org>
  I don't really agree with that. The metric system makes it trivial to
switch between units as needed without the need of any calculations
whatsoever.
  For example, a person can be 180 cm tall, or 1.8 meters tall, or 1 meter
80 cm tall. All three of these are completely and trivially exchangeable
with each other without the need to do any kind of mental calculations
whatsoever.
  This makes it much more intuitive and easy to quickly get a grip on
everyday measurements, as compared to familiar measurements (such as
your own height). For example, if someone tells you "the stick is 160 cm
long", then you immediately get a mental image of how long it is if you
yourself are 180 cm tall: It's something like a head less than you.
  If someone told something like "it's 2 meters tall", then once again
you can immediately grasp how much it is, compared to yourself: You know
that you are 1.8 meters tall, so 2 meters is a bit more, something like
a head taller.
  Note that two different units were used here, centimeters in the first
case and meters in the second, yet the amount of mental work to get a
notion of the length of the stick was exactly the same. No additional
mental work whatsoever was needed because two different units were used
in the two examples.
  In some cases it may be handier to use centimeters if you need that kind
of accuracy, while in other cases it's more practice to use meters because
you are not intending to be that accurate. The great thing is that in either
case it's equally easy to understand what kind of measurements we are talking
about without having to do any mental math.
  The same goes for most of the other everyday units. For example it's
easy to grasp that "516 grams" is about as heavy as a half litre of
water (because 516 grams is close to half a kilogram). Again, no mental
calculations neeed. And so on.
Date: 23 Aug 2010 16:33:33
Message: <4c72db1d$1@news.povray.org>
> whatsoever.
>   meter
> whatsoever.
You're making a mental calculation there - you're dividing by 10.  It's
easy, but that doesn't mean there's no calculation at all.
Jim
Date: 23 Aug 2010 16:35:01
Message: <web.4c72da5d2ce1a5d8f48316a30@news.povray.org>
> whatsoever.
> whatsoever.
well put.  The thing about Imperial Units is... is it 10 of my foot or 10 of my
daughter's foot?  makes for a substantial change...
Date: 23 Aug 2010 17:04:26
Message: <4C72E26A.3020701@gmail.com>
>> whatsoever.
>>   meter
>> whatsoever.
Oh come on, you are not dividing, just shifting the decimal point.
Date: 23 Aug 2010 23:53:54
Message: <4c734252$1@news.povray.org>
Which by definition, mathematically, is division (or multiplication if
it's the other direction).
"Shifting the decimal point" isn't a recognised mathematical operation,
well, it wasn't when I took maths.  Multiplication and division are.
Just because one takes a shortcut doesn't mean it's a different operation.
Jim
Date: 24 Aug 2010 02:10:00
Message: <web.4c7361442ce1a5d81d5b3dfa0@news.povray.org>
still, it doesn't demand any calculation at all to correlate 1.80 meters to 1
meter and 80 cm or to 180 cm.  They are all equivalent, even in digits...
Date: 24 Aug 2010 04:24:20
Message: <4c7381b4@news.povray.org>
> liters of beer, I realized it's something different.
Yes, It is what you are brought with. :-P
> (yard), how far you can conveniently walk (mile).
It's true then. Americans don't walk much. :-P
> or animals (stone, which nobody seems to actually use any more), about
> as much as you can reasonably ship someplace (a ton).
We use stones for weighing people. For instance I am 12 stones but I
would like to be 11 and a half. Or 11-7, that is 11 stones 7 pounds or
73 Kg.
> There's nothing lighter than an ounce,
What about a dram (not a "wee dram" ;-) ) there are 16 of them in an
ounce and 437.5 grains in an ounce.
> usage, imperial weird units don't really cause the sort of problem that
> people seem to think it causes. I no more have to frequently convert
> inches to miles than you frequently need to figure out the number of
> minutes in a year. Once you're talking miles, the number of inches is as
> immaterial as asking how many miles are in an inch when you're measuring
> to construct a chair or something. The worst stuff is measuring your
> room to be 12 3/4 feet, and finding out carpet is sold by the inch or
> something.
This is true but I would measure the length to be 12' 9" or 12 foot 9
(inches is understood).
Best Regards,
Date: 24 Aug 2010 04:56:05
Message: <4c738925@news.povray.org>
So long as you don't need to convert between units or do any calculations.
Buying carpet was one example, another is when you tell me you weigh X
pounds and I usually deal with stones, I have no clue whether that's a lot!
Or if you measure someones height with a tape measure marked in inches,
what's that in feet? Or if you are following a recipe that calls for 10 oz
of flour and you want to make 4x the quantity for a party, how much flour do
you weigh out if your scale is in pounds and ounces?  These calculations may
seem relatively simple if you're good at mental arithmetic, but people who
aren't struggle (all of the ones above I've witnessed at least once).
Yes, it's very odd looking through an imperial science text book where every
formula has some bizarre constant like 537.4 in it!
Date: 24 Aug 2010 08:37:37
Message: <4c73bd11$1@news.povray.org>
> calculations. Buying carpet was one example, another is when you tell me
> you weigh X pounds and I usually deal with stones, I have no clue
> whether that's a lot! Or if you measure someones height with a tape
> measure marked in inches, what's that in feet? Or if you are following a
> recipe that calls for 10 oz of flour and you want to make 4x the
> quantity for a party, how much flour do you weigh out if your scale is
> in pounds and ounces?  These calculations may seem relatively simple if
> you're good at mental arithmetic, but people who aren't struggle (all of
>> units when you do science.
> every formula has some bizarre constant like 537.4 in it!
Is it really any weirder than 273.15?
Likewise, I don't think 9.81 is a more convenient constant than 32.2!
My biggest beef with the imperial units is that I usually screw up the
16th and 32nds marks on my measuring tape and end up cutting my planks
just a little too short.  It is much harder to mix up the cm and mm lines.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 24 Aug 2010 09:35:54
Message: <4c73caba$1@news.povray.org>
Sorry I meant the unnamed numerical constants in equations, rather than the
official named constants like 'g'.  I was just used to seeing simple
equations in text books with no numbers in them (just symbols) yet in one of
my books they use imperial units and almost every equation has some
numerical constant in it.  On top of that they find it necessary to write
the units needed for every quantity, which I guess have to tie up with the
constant.  It just looks messy (and presumably quite hard to remember),
that's all.
Date: 24 Aug 2010 09:44:21
Message: <4c73ccb5@news.povray.org>
Shifts are perfectly legitimate mathematical operations. Many of the
things computers do couldn't be done easily without a shift operation :P
~Mike
Date: 24 Aug 2010 09:56:04
Message: <4c73cf74$1@news.povray.org>
Well, I mean, there's a small multiple right? It's not like you can only
drink one pint of beer, either. :-)  Walking somewhere between 0.1 and 10
miles is convenient. Outside that, you're going to measure in yards or
you're going to take a horse.
> 73 Kg.
Cool. Where is this?
I wasn't sure if a dram was imperial or not.
Yes, exactly. The construction rulers here measure in both inches and feet,
so it's trivial to get either measurement in situations where people use
both scales.
    Quoth the raven:
        Need S'Mores!
Date: 24 Aug 2010 12:11:04
Message: <4c73ef18@news.povray.org>
>> operation.
Binary shifts are multiplication and division as well. :P
Jim
Date: 24 Aug 2010 12:11:45
Message: <4c73ef41@news.povray.org>
>> >> It's easy, but that doesn't mean there's no calculation at all.
> to 1 meter and 80 cm or to 180 cm.  They are all equivalent, even in
> digits...
But not in decimal points.  It's still division/multiplication by 10, no
matter how you describe how it looks.
Jim
Date: 24 Aug 2010 12:18:02
Message: <4c73f0ba$1@news.povray.org>
What you want is binary rotations. ;-)
http://blog.orphi.me.uk/
Date: 24 Aug 2010 12:45:39
Message: <4c73f733$1@news.povray.org>
Just pulling your leg Cuz. ;-)
>> 73 Kg.
Here's a clue
http://tinyurl.com/6zz4l7
It has a crown, does it not? :-)
> feet, so it's trivial to get either measurement in situations where
> people use both scales.
We're going metric and have rulers with inches on one edge and
centimetres on the other. (Rotated 180 degrees so you can't do a direct
comparison/conversion.)
Best Regards,
Date: 24 Aug 2010 13:44:52
Message: <4c740514$1@news.povray.org>
Stephen wrote:
> Here's a clue
I don't know. That doesn't do anything except give me a blank page.
Yeah, that's how our measuring tapes are too. Except the inches side has
both feet+inches and inches.
    Quoth the raven:
        Need S'Mores!
Date: 24 Aug 2010 14:33:58
Message: <4c741096$1@news.povray.org>
Stephen wrote:
> Here's a clue
Oh, it downloaded a MP3. OK. Nevermind. Very cute.
    Quoth the raven:
        Need S'Mores!
Date: 24 Aug 2010 15:21:37
Message: <4C741BD1.5080705@gmail.com>
>>> operation.
yes and no. Conceptually yes, in a hardware implementation on a chip no.
That is why they are so much cheaper than real multiplicatons and
division. The same goes for wetware. But I appreciate your stubbornness.
Date: 24 Aug 2010 15:33:19
Message: <4c741e7f$1@news.povray.org>
>>> :P
That depends on whether the bits actually get rotated.  From my
recollection of x86 assembly, it's a shift, not a rotation. :)
Jim
Date: 24 Aug 2010 15:34:21
Message: <4c741ebd@news.povray.org>
>>>> operation, well, it wasn't when I took maths.  Multiplication and
>>>> division are. Just because one takes a shortcut doesn't mean it's a
>>> :P
That still doesn't mean it isn't mathematically a multipilcation or
division - the operation doesn't change just because you took a
shortcut. ;-)
I figured you - of all people - would. ;-)
Jim
Date: 24 Aug 2010 16:33:26
Message: <4c742c96$1@news.povray.org>
> division.
If you're using a compiler where a shift by a constant is cheaper than a
division by a constant, you're in trouble.
    Quoth the raven:
        Need S'Mores!
Date: 24 Aug 2010 17:03:10
Message: <4c74338e$1@news.povray.org>
>>>> :P
> Jim
My recollection, of course, has changed now that I re-read this, I
remember ROR and ROL operators, which do in fact rotate.  I just remember
using SHL and SHR more frequently.
Jim
Date: 25 Aug 2010 05:28:26
Message: <4c74e23a$1@news.povray.org>
>> Jim
Whether your processor supports it or not, binary rotations exist. You
can implement them the hard way if you must. I've seen a few block
ciphers that use 'em too...
Date: 25 Aug 2010 05:32:06
Message: <4c74e316@news.povray.org>
On 24/08/2010 7:33 PM, Darren New wrote:
> Stephen wrote:
>> Here's a clue
Cute, that's me :-)
Best Regards,
Date: 25 Aug 2010 09:16:56
Message: <4c7517c8@news.povray.org>
> > division.
  He was talking about hardware, not about compilers.
Date: 25 Aug 2010 11:28:26
Message: <4c75369a$1@news.povray.org>
>>> division.
Yes, I knew that. :-)
    Quoth the raven:
        Need S'Mores!
Date: 25 Aug 2010 16:26:21
Message: <4C757C80.6040403@gmail.com>
>>>> :P
> shortcut. ;-)
that is what I said, or at least tried to.
we aim to please
Date: 25 Aug 2010 16:28:29
Message: <4C757D00.9000105@gmail.com>
On 25-8-2010 17:28, Darren New wrote:
>>>> division.
>>> than a division by a constant, you're in trouble.
Even so I do not understand the remark. Do you mean that a compiler
should not be aware what is cheaper (in time) to do the same thing? Or
that that is not the case anymore, in which case I beg to differ.
Date: 26 Aug 2010 16:15:27
Message: <4c76cb5f$1@news.povray.org>
>>> Jim
>> remember using SHL and SHR more frequently.
Well, that's why I said what I said about my faulty recollection. ;-)
Jim
Date: 28 Aug 2010 03:01:30
Message: <4c78b44a$1@news.povray.org>
> units when you do science. I don't think it really matters that things
> are specifically multiples of 10 until you start getting into figuring
> out ranges of numbers where exponents come into play.
If you've taken physics, the real help comes in the fact that the
majority of units are some multiple of other units with no other factors
to throw in (and thus, misremembered at times).
For example, one Watt (unit of power) is equal to one Joule (unit of
energy) per second.  One horsepower (imperial unit of power) is equal to
some silly number of foot-pounds per second.
John
Date: 28 Aug 2010 13:52:25
Message: <4c794cd9$1@news.povray.org>
Sure. That comes from having only one unit of measurement for each
fundamental thing you're measuring. On the other hand, you still get some
arbitrary factors in there, like moles or parsecs.
If I asked you how much power it took to lift what a horse could, or how
many pounds of force you had to push a foot-long lever with, you'd once
again have those arbitrary scale factors thrown in. ;-)
I'm not saying metric isn't easier. I'm pointing out that imperial stuff,
since it's based on people, is very poor at measuring things that aren't
approximately relevant to people, like the weight of planets or the size of
atoms.
    Quoth the raven:
        Need S'Mores!
Date: 28 Aug 2010 19:05:00
Message: <web.4c7995992ce1a5d81d5b3dfa0@news.povray.org>
> atoms.
It's not just that: imperial isn't precise.  I asked before and it was ignored,
but should I measure 10 foot to be the distance traveled by my 10 of my steps or
10 of my daughter steps?
Besides, you need to put true mental calculations at work to convert between
units, instead of simply moving the point forward or backwards between
centimeters, meters and kilometers...
Date: 28 Aug 2010 19:53:39
Message: <4c79a183$1@news.povray.org>
>> atoms.
Well, *now* it is precise. Obviously it wasn't precise when it was
formulated.  I think the foot, however, was the size of some specific king's
foot. And the metric measurements have changed definitions over the years as
well.
Sure, because there are different units, unlike the SI measurements which
only have one unit per fundamental element being measured. I still have to
put mental calculations forth to translate between seconds and meters, or
between meters and light-years, or between watt-hours and watt-months, or
between moles and grams, because they're different units based on arbitrary
physical properties. The fact that one has to translate between inches and
feet isn't really any more of a problem than the fact that metric
measurements have to translate between seconds and years.
    Quoth the raven:
        Need S'Mores!
Date: 29 Aug 2010 05:17:43
Message: <4c7a25b7$1@news.povray.org>
> king's foot. And the metric measurements have changed definitions over
> the years as well.
Henry I of England, but not his bare foot.
>> between
> which only have one unit per fundamental element being measured. I still
> have to put mental calculations forth to translate between seconds and
> meters, or between meters and light-years, or between watt-hours and
> watt-months, or between moles and grams, because they're different units
> based on arbitrary physical properties. The fact that one has to
> translate between inches and feet isn't really any more of a problem
> than the fact that metric measurements have to translate between seconds
> and years.
I would say less of a problem, actually. Constantly doing mental
arithmetic helps keep the mind active. I’ve noticed, here in the UK, the
lack of ability in young people who grew up learning the metric system.
I assume that they did not have to do sums like:
What is the cost of 3 yards 1 foot of material @ 2/6 a yard.
Ans: 8/4 That is 8 shillings and 4 pence.
Best Regards,
Date: 29 Aug 2010 05:49:44
Message: <4c7a2d38@news.povray.org>
Le 29/08/2010 11:17, Stephen nous fit lire :
>> the years as well.
>>> between
>> and years.
Why stop at only mental activity, let's also take into account the year
of mint, as it used to be.
And each mint (and that could each city) could have its own agenda for
the weight of its pounds & guinea.
May be I can slice some pounds in two, or scrap enough of them to make a
new one...
Shilling has been dropped in 1971... and the penny is now decimal.
But we can mix pound, shilling (at 20 per pound), pences (at 240 per
pound) and new pences (at 100 per pound) with guinea (1 pound 1 shilling)
Oh, I call in the Bretton Woods system, in which I could exchange 1
pounds for $4.03...
Date: 29 Aug 2010 11:55:36
Message: <4c7a82f8@news.povray.org>
> the weight of its pounds&  guinea.
Now you are being silly. ;-)
> new one...
That is why coins are milled. To stop people like you shaving or
clipping coins. :-P
But some of us remember the days of L.s.d. man ;-)
Morning town Crescent!
> pounds for $4.03...
I remember my father calling a half crown (12.5p) a half dollar.
Best Regards,
Date: 29 Aug 2010 12:48:49
Message: <4c7a8f71@news.povray.org>
Well, yes. There's also the problem with imperial measures that the king
would go around declaring that a barrel in London is somewhat larger than a
barrel outside of London, thereby lowering the cost of beer in the capital
city and stuff like that.
    Quoth the raven:
        Need S'Mores!
Date: 29 Aug 2010 12:51:57
Message: <4C7A9043.3070605@gmail.com>
>>> stuff,
>>> size of
>>> atoms.
>> ignored,
> the years as well.
Such changes occur for good reasons. E.g. in the triple
time/velocity/length you can define any two and the third can then be
measured. Originally the speed of light was the quantity to measure.
Nowadays that is a constant, otherwise the theoretical physicists would
be very upset.
If you define the length then you can measure how long one second is. Or
you define a meter and then you can measure how much time a photon takes
to traverse that distance. Which one you choose simply depends on what
you can measure most accurately. If your error in a meter is, say, one
in 10^12 and in a second it is one in 10^10, it is unwise to take the
second as definition, because the maximal achievable precision of a
length measurement will then drop to one in 10^10.
I hope all imperial units are now defined as fractions of the metric
ones or we will need two committees to decide when to change the places
of meters and seconds. However, if you look at the wiki page about
imperial units some conversions are exact, whereas others are given to
be exact to 4 or 5 decimal places. Much larger than the scientific
uncertainty in the values, so that supports nemesis' claim, although
perhaps not in the way he/she meant.
Date: 29 Aug 2010 13:51:07
Message: <4c7a9e0b$1@news.povray.org>
> than a barrel outside of London, thereby lowering the cost of beer in
> the capital city and stuff like that.
LOL, not quite, declaring that a barrel in London is somewhat larger
than a barrel outside of London, thereby getting more tax and making it
dearer.
Best Regards,
Date: 29 Aug 2010 13:57:39
Message: <4c7a9f93@news.povray.org>
No, you can't do that, because it's the 29th of the month, so diagonals
are not allowed... ;-)
Jim
Date: 29 Aug 2010 14:10:25
Message: <4c7aa291@news.povray.org>
But using the “Bretton Woods system” allows me to move in a chess knight
like manner.
BTW Humph Celebration Concert tomorrow
http://www.bbc.co.uk/programmes/b00tj5qp
If you can’t get it I’ll record it if it’s on listen again.
Best Regards,
Date: 29 Aug 2010 18:55:54
Message: <4c7ae57a$1@news.povray.org>
Of course.
Honestly, I have no idea. I know they're more precise than the size of some
king's shoe or how far Fred can march in 15 minutes.
> the wiki page about imperial units s
Wow. That's messier than I thought. ;-)
    Quoth the raven:
        Need S'Mores!
Date: 30 Aug 2010 13:25:32
Message: <4c7be98c$1@news.povray.org>
> like manner.
Not in the last week of the month, though.  And you thought you could
sneak that past me. ;-)
> http://www.bbc.co.uk/programmes/b00tj5qp If you can’t get it I’ll record
Cool, I should be able to get it from listen again (I've been pulling
Proms concerts that way), but if I can't, I'll let you know.
Jim
Date: 30 Aug 2010 18:23:53
Message: <4c7c2f79$1@news.povray.org>
OK, I downloaded it from listen again. A bit too much jazz for my liking.
Best Regards,
Date: 30 Aug 2010 21:59:39
Message: <4c7c620b$1@news.povray.org>
> liking.
I'm pulling it now, so no need to keep it if you don't want to. :-)
Jim
Date: 31 Aug 2010 12:05:14
Message: <4c7d283a@news.povray.org>
On 31/08/2010 2:59 AM, Jim Henderson wrote:
> I'm pulling it now, so no need to keep it if you don't want to.:-)
Tickety boo
Best Regards,
Date: 3 Sep 2010 18:23:40
Message: <4c81756c@news.povray.org>
> Tickety boo
We really enjoyed it - but we also enjoy good Jazz.  :-)
Jim
Date: 3 Sep 2010 18:29:24
Message: <4c8176c4$1@news.povray.org>
On 03/09/2010 11:23 PM, Jim Henderson wrote:
> but we also enjoy good Jazz.:-)
There is such a thing? :-)
Best Regards,
