POV-Ray : Newsgroups : povray.off-topic : Be afraid Server Time
7 Mar 2026 11:36:29 EST (-0500)
  Be afraid (Message 1 to 10 of 39)
Subject: Be afraid
Date: 10 Aug 2010 07:53:05
Message: <4c613da1$1@news.povray.org>
http://tinyurl.com/33pb6gq
I think this is a fairly stunning illustration of the way in which the
difficulty of solving a polynomial equation skyrockets as the degree of
the equation increases.
Subject: Re: Be afraid
Date: 10 Aug 2010 07:56:07
Message: <4c613e57@news.povray.org>
Actually, you know what?
http://tinyurl.com/3686x2y
Date: 10 Aug 2010 08:15:40
Message: <4c6142ec$1@news.povray.org>
Solving Third & Fourth degres polynomials is known since a long time (I
have a book with that which was printed in the 60')
Now, the sad thing is it soon stop working for fifth and higher.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 10 Aug 2010 08:17:39
Message: <4c614363$1@news.povray.org>
I'll bet to hell nobody actually *uses* the formulas above though. (!)
I thought it only stops working in terms of "elementary" functions? As
in, there are more specialised functions you can use to go a little bit
higher still.
Also, I thought it was a case of being impossible to write a single
closed-form formula for the solution to an arbitrary high-order
polynomial. Like, if the polynomial has a special form, it might still
be solvable (possibly easily).
Date: 10 Aug 2010 08:29:38
Message: <4c614632$1@news.povray.org>
Probably not.  If you consider that most - if not all - computers
calculate square roots by using an iterative method, it would probably
be faster to use it on the original polynomial than to use it 8 times on
smaller polynomials, as in the solution you linked to.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 10 Aug 2010 08:30:39
Message: <4c61466f$1@news.povray.org>
Humans have a tendancy to make substitution of variables instead.
> higher still.
Yes, of course x^9 + a x^6 + b x^3 + c = 0 is just a rewrite of y^3 + a
y^2 + b y + c = 0, with y = x^3.
Solving fifth and higher requiers usually to get a first root, then
dividing the polynomial by (x-root) to reduce the degre (and start
over). Sometimes it is possible to extract a second degre polynomial
instead... that is where all the "(a+b)²=a²+2ab+b²" and the like come
handy when trying to move to the formula to a product instead of a sum)
Date: 10 Aug 2010 08:34:50
Message: <4c61476a@news.povray.org>
  More info on that subject:
http://en.wikipedia.org/wiki/Abel%E2%80%93Ruffini_theorem
Date: 10 Aug 2010 10:22:52
Message: <4c6160bc$1@news.povray.org>
Hmm, interesting. I thought the theorum states that there is no single
formula that covers all possible polynomials of a given degree. However,
Wikipedia asserts something far stronger: It seems to claim that you can
construct a single, fixed polynomial who's solutions (which are also
fixed) cannot be expressed by radicals.
This indicates that there are some algebraic numbers that are not
expressible by radicals. (And yet, the *definition* of an algebraic
number is one expressible by radicals...)
Date: 10 Aug 2010 10:40:44
Message: <4c6164ec$1@news.povray.org>
Am 10.08.2010 13:56, schrieb Invisible:
Yeah, sure. I recite that daily from memory before I go to sleep...
Date: 10 Aug 2010 11:04:12
Message: <4c616a6c$1@news.povray.org>
Now there's a question: How do you unambiguously recite complex
mathematical expressions out loud?
