POV-Ray : Newsgroups : povray.off-topic : C++ destructor question Server Time
7 Mar 2026 11:33:26 EST (-0500)
  C++ destructor question (Message 1 to 7 of 7)
Subject: C++ destructor question
Date: 5 Aug 2010 15:27:25
Message: <4c5b109d@news.povray.org>
Speaking of RAII and all...
When an object is stuck into a standard collection in C++, and then the
collection goes out of scope, what order is defined on the destructors of
the things in the collection? I wouldn't imagine it's the order they were
inserted (at least for a random-access type collection).  Does a stack
destruct in a different order than a queue does, for example? Does a vector
always destruct on increasing indexes?  (An array doesn't call the
destructors of its element, does it?)
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Subject: Re: C++ destructor question
Date: 5 Aug 2010 16:04:28
Message: <4c5b194c@news.povray.org>
  Funny, I have never thought of that. If I had to guess, I'd say that
the standard leaves it up to the implementation.
  Arrays (either stack-allocated or dynamically allocated with 'new') are,
however, guaranteed to be constructed in the order of increasing indexes
and destroyed in the reverse order.
Date: 5 Aug 2010 16:31:06
Message: <4c5b1f8a$1@news.povray.org>
I can see where having a stack destruct as if it's popping things could be
useful, for example. The topic came up discussing the Go "defer" bit in
another thread.
OK. I'll look it up if it ever comes up.
Oh, so arrays do destruct. That's good to know. I guess that makes sense,
tho, now that I think about it, since the values get constructed if they
have constructors.
Date: 6 Aug 2010 07:44:38
Message: <4c5bf5a6$1@news.povray.org>
> of the things in the collection? I wouldn't imagine it's the order they
> were inserted (at least for a random-access type collection).  Does a
> stack destruct in a different order than a queue does, for example? Does
> a vector always destruct on increasing indexes?
See if you can discern the order of construction.  The safest
destruction reverses this order.
John
Date: 6 Aug 2010 07:54:08
Message: <4c5bf7e0@news.povray.org>
> have constructors.
  You would have a pretty bad danger of memory leak if arrays wouldn't
destroy their elements.
Date: 6 Aug 2010 11:24:47
Message: <4c5c293f$1@news.povray.org>
Yeah, I just wasn't thinking clearly, thinking "arrays aren't classes, so
they don't have destructors."
Date: 6 Aug 2010 13:42:12
Message: <4c5c4974@news.povray.org>
  Curiously, *all* primitive types in C++ have default constructors. At
least in syntax. (This default constructor initializes the variable to zero.)
It can be called like any other constructor. So you could have something
like:
    void foo(int i = int()) { ... }
  In other words, the foo() function takes optionally an int as parameter,
and if none is specified, it takes a default-initialized int instead.
  Of course the above is *completely* equivalent to:
    void foo(int i = 0) { ... }
so what's the point? It becomes important with (yeah, you guessed it)
templates. You can write something like:
    template<typename T>
    class MyClass
     public:
        void foo(T value = T());
and it will work even if T is a primitive type (such as int).
  (The default function parameter value is just one example of many
situations where it becomes useful.)
