POV-Ray : Newsgroups : povray.off-topic : Damn that's sweet. Server Time
7 Mar 2026 11:31:52 EST (-0500)
  Damn that's sweet. (Message 1 to 10 of 23)
Subject: Damn that's sweet.
Date: 26 Jul 2010 18:29:20
Message: <4c4e0c40$1@news.povray.org>
http://www.theregister.co.uk/2010/07/23/ibm_z196_mainframe_processor/
(Big-ass mainframe CPUs)
I didn't know people were still putting decimal math circuits into CPUs.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Subject: Re: Damn that's sweet.
Date: 27 Jul 2010 09:05:15
Message: <4c4ed98b$1@news.povray.org>
Used to program the ancestors of this in assembler.  S370 and S390
instruction sets.  The 'packed decimal' format was really perfect for
banks and similar.  Hardware memory to memory add, subtract, multiply
large precision numerics with exact precision.  'ZAP' (Zero and Add
Packed) was one of the most common instructions in almost any assembler
program.  And the main numeric data type in IBM COBOL translated to
these underlying instructions.
There is a fair chance that your money is still held and processed in
this format today.
Date: 27 Jul 2010 09:15:03
Message: <4c4edbd7@news.povray.org>
Paul Fuller <pgf### [at] optusnetcomau> wrote:
> The 'packed decimal' format was really perfect for banks and similar.
  I really can't understand why. The user doesn't need to know how
integers are represented internally, so why would he care?
Date: 27 Jul 2010 09:29:52
Message: <4c4edf50$1@news.povray.org>
You know that 1/10 can't be exactly represented in binary, but can be
represented exactly in decimal, right?
Date: 27 Jul 2010 09:52:34
Message: <4c4ee4a2@news.povray.org>
Why not just store the total pence/cents in an int?
Anyway, I thought banks worked internally to fractions of a pence/cent and
only rounded for statements etc?
Date: 27 Jul 2010 10:41:39
Message: <4c4ef023@news.povray.org>
  And 1/3 cannot be represented exactly in *any* base being currently
used in any computer system. So what?
  Besides, 1/10 isn't an integer, so what would BCD integer registers
help that? Any solution you devise will also work with plain binary
registers as well.
Date: 27 Jul 2010 10:49:32
Message: <4c4ef1fc$1@news.povray.org>
Financial transactions don't involve units of 1/3. They *do* frequently
involve 1/10, however. (And 1/100, and smaller.)
> registers as well.
Oh, well, if it's only *integer* arithmetic then yeah, I have no idea
what the advantage would be.
Date: 27 Jul 2010 11:01:49
Message: <4c4ef4dd$1@news.povray.org>
Because when you're talking about thousands of dollars as the smallest
increment, that wastes space.  Because when you add dollars to pennies to
fractional pennies, you need to do the scaling anyway.  Because when you
print out the number, you wind up doing a whole bunch of divide-by-10's
anyway, and lots and lots of financial processing involves printing out numbers.
And usually (at least in modern standards) these numbers go up to something
like 38 digits. So why would an "int" be better than packed decimal in terms
of processing speed?
Anyway, yes, that's basically what this is doing, except with appropriate
scaling.  Your question is like asking "why not just store the floating
point number without the exponent?"
The oldest mainframe I worked on has a "scientific" unit (the floating point
coprocessor) and the "business" unit (the decimal math coprocessor). The
business unit had things like scatter/gather memory moves, packed decimal,
and the equivalent of BASIC's "print using" (which I think COBOL called an
Edit field).
> and only rounded for statements etc?
Depends what you're doing.  Interest is probably in fractions of a cent.
Statements are to the penny. Taxes are to the dollar. Etc.
Date: 27 Jul 2010 11:05:23
Message: <4c4ef5b3@news.povray.org>
> help that?
It's a scaled integer. Part of the decimal math mechanism includes aligning
the decimal points.
> registers as well.
Yes, and so would floating point, if you made the registers big enough.
And, like floating point, it would be quite the PITA to translate scaled
integer numbers into something you could print efficiently, compared to
using BCD.
COBOL has "display" types (packed BCD) and "computation" types (two's
complement integers), depending on what you want to do with them.
Why would plain integers be *better* than packed BCD for this sort of
application? You're going to need specialized instructions if you want to
run fast in either situation.
Date: 27 Jul 2010 11:14:04
Message: <4c4ef7bc@news.povray.org>
Oh I see, so it's like a base-10 float?
> something like 38 digits. So why would an "int" be better than packed
> decimal in terms of processing speed?
It would avoid the need for custom hardware, but obviously it works out
faster per $ to get the non-standard CPUs if that's what they actually use.
