OK, so particles aren't waves.
http://arstechnica.com/science/news/2010/07/born-rules-quantum-mechanics-survives-triple-slit-test.ars
(They don't seem to do a very good job of particles either, for that matter.)
Now tell me again we know what happened before the big bang?
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
Darren New <dne### [at] san rr com> writes:
Well, because they're neither.
As I said many threads ago, I never liked the whole particle + wave
duality. What they are acts neither like a macro particle, nor as a
mathematical particle, nor as a macro wave. It's just in a category of
its own.
Electrons aren't waves. They aren't simple particles either. Why can't
they just teach it that way?
It would be nice to know what they are, not only what the aren't.
"So, the authors built a triple-slit system, set up so that they could
open and close each of the slits. One of the three ended up not
opening fully, which actually created a small source of error in the
experiments."
I'm wondering: Then why didn't they fix the defective slit and start
over?
Le 24/07/2010 07:57, Warp nous fit lire :
They are electrons. Now, you wanted a seizable simile... sorry, no such
thing at your scale.
You can't use the word being defined in its definition. That's a
circular definition.
Well, they're electrons. QM describes how they behave. They don't behave
like anything else. They are (insert all of QM theory here).
> over?
If I had to guess, I'd say it's because it wasn't until they analyzed the
results that they realized the slit was broken, at which point they didn't
have time to repeat the experiment before the paper publishing deadline.
Me, I'm more surprised that nobody before this had ever *actually* tried it
with three slits.
I also discover I no longer understand how QM works nearly as much as I
thought I did. :-)
> like anything else.
Given that electrons are fermions and that electrons are not the only
fermions, I wouldn't say that's true.
>> like anything else.
I think you know what I'm saying. They don't behave like anything
non-quantum. The difference between electrons and other fermions is the
numbers you plug into the same equation.
"Warp" <war### [at] tag povray org> wrote in message
news:4c4aa2da@news.povray.org...
can't
You don't. Much as you observe an orange and call it an orange, you observe
an electron and call it an electron. The "problem", if any, is with our
insistence that an electron should behave like an orange, or anything else
from our macro world. It doesn't have to and it doesn't: It behaves like an
electron.
IOW, there is no such thing as wave-particle duality, or rather, the term
should not have survived once the scientists got over their initial shock
and realized the implicit assumption that an electron should behave either
like an orange or a guitar string was unwarranted and ultimately false.
> can't
> electron.
Why is "it would be nice to know what they are, not only what the aren't"
being interpreted as "I want electrons to be compared to oranges or to
guitar strings"? That's not what I'm saying.
You are also telling me what electron's aren't, not what they are.
And "electrons" is not the answer because, as I said, that's a circular
definition (which is what I was objecting to above).
This is what they "are" as best as anyone can tell:
http://en.wikipedia.org/wiki/Quantum_electrodynamics
Warp <war### [at] tag povray org> writes:
Well, they're entities governed by a wavefunction.
I can't tell you what they are with respect to *macroscopic* notions,
because they don't behave like any macroscopic object.
And lo On Sat, 24 Jul 2010 16:43:53 +0100, Darren New <dne### [at] san rr com>
did spake thusly:
> it with three slits.
I think this is the first *successful* attempt, I think the problem lay in
the complexity of the analysis.
> thought I did. :-)
Who does :-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
> thought I did. :-)
If learning about quantum mechanics does not deeply shock you, you
really haven't learned it. (Some physicist said this a long time ago.)
John
John VanSickle wrote:
>> I thought I did. :-)
Well, I thought I had a decent surface-level understanding of what the
predictions would be in a particular case, without the ability to do the
actual calculations. Now I find out that my naive understanding of how to
do the calculations is wrong, as I have no rule that says anything about two
slits being more privileged than three slits.
