Oh my God...
All week I've had various insects crawling over my monitor. But now
something really special has happened: there's an insect *inside* the
monitor. I can literally see it crawling around between the liquid
crystal layer and the backlight. Man that's irritating! >_<
http://blog.orphi.me.uk/
I pressed on the glass, and I think I squashed it. (At least, it's
stopped moving around now.) But now it's stuck in the middle of the
screen. Great.
Orchid XP v8 escreveu:
> screen. Great.
http://i257.photobucket.com/albums/hh240/sandras-1952/fly.gif
a game sig: http://tinyurl.com/d3rxz9
> screen. Great.
Why on earth would you squish it - it's only going to be in your way.
I was going to reply to your original post - 'at least it didn't die',
then I read this one.
We had a laptop that had that - It took about 3 years before the thing
decomposed enough to not cause an eye sore.
Well, a stationary black dot is slightly less irritating than a moving
black dot. (But only slightly...)
I'm just trying to figure out how the **** the critter got *in* there in
the first place! >_<
> I pressed on the glass, and I think I squashed it. (At least, it's stopped
> moving around now.) But now it's stuck in the middle of the screen. Great.
Haha, I'm surprised it could get in there (usually that gap is sealed as
best possible to stop dust getting in), but surely if you try to open it up
you will get all sorts of dirt and dust in there (unless you happen to have
a cleanroom) so it will probably look worse.
Just make a desktop wallpaper to cover it up :-)
That makes two of us.
It seems to be between the LC layer and the backlight, but it's hard to
tell. It might be between the glass and the LC.
> up you will get all sorts of dirt and dust in there (unless you happen
> to have a cleanroom) so it will probably look worse.
More importantly, if I take it apart it will never, ever go back
together again.
Gee, thanks. :-P
I got a zero dead pixel guarantee, but it didn't say anything about
small insects crawling inside the machine. >_<
I can promise you it's not between the LC and the glass! The LC is a few
microns thick sandwiched between two layers of glass and sealed around the
edge to stop any moisture getting in - ever.
>> to tell. It might be between the glass and the LC.
> few microns thick sandwiched between two layers of glass and sealed
> around the edge to stop any moisture getting in - ever.
I'm guessing moisture would be seriously suboptimal here?
Yes, even absolutely tiny amounts will make the LC useless.
Really? I thought it might just make the edges go a bit fuzzy or
something...
> something...
Something to do with how the moisture gets absorbed by the LC, of course it
starts from the edges wherever there is the "leak", but it quickly spreads
across the whole panel until you don't get any picture. I suspect the water
molecules are severely impacting on the electrical/optical properties of the
LC, and given that you're talking about a thickness of a couple of microns
you don't need many water molecules to mess things up!
>> something...
> it starts from the edges wherever there is the "leak", but it quickly
> spreads across the whole panel until you don't get any picture. I
> suspect the water molecules are severely impacting on the
> electrical/optical properties of the LC, and given that you're talking
> about a thickness of a couple of microns you don't need many water
I was under the impression that a liquid crystal is an organic molecule
dissolved in water. So I'm guessing changing the concentration is going
to fairly radically alter the optics of the material, and possibly even
turn it from a liquid crystal into a plain ordinary liquid.
Then again, I don't design LCDs for a living. ;-)
