Subject: And just in case you had a big POV job to trace...
Date: 13 Jul 2010 11:36:40
Message: <4c3c8808$1@news.povray.org>
http://aws.typepad.com/aws/2010/07/the-new-amazon-ec2-instance-type-the-cluster-compute-instance.html
Rent a quad-core 2HT 2.93GHz 23G RAM 1.5TB disk compute engine for $1.60/hour.
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
Subject: Re: And just in case you had a big POV job to trace...
Date: 13 Jul 2010 11:57:22
Message: <4c3c8ce2$1@news.povray.org>
> $1.60/hour.
That's *dual* quad-core (i.e., total of 8 cores), apparently.
What I can't figure out is how it's possible to put 23GB of RAM into a
single PC. AFAIK, nobody makes motherboard that can do that...
(The other problem, of course, is that although it has 1.5TB of storage,
since you access the Internet at 8 mbit/sec, it would take a loooong
time to fill or empty that space. So it's only useful for temporary data
generated by the process itself.)
Date: 13 Jul 2010 12:53:20
Message: <4c3c9a00$1@news.povray.org>
On 7/13/2010 10:57 AM, Invisible wrote:
>> $1.60/hour.
Its a cluster .... there are 2 separate systems.
~Mike
Date: 13 Jul 2010 14:18:06
Message: <4c3cadde$1@news.povray.org>
It's probably virtualized, which lets you configure any odd amount of
memory you want, pretty much.
Jim
Date: 13 Jul 2010 14:21:31
Message: <4c3caeab$1@news.povray.org>
Le 13/07/2010 17:57, Invisible nous fit lire :
>> $1.60/hour.
Correct, 24GB of ram is more usual.
It might infact be a VM of 23GB... 1GB for the barebone.
Or a commercial cover-up, to avoid the issue of Gi/G, or whatever
24740416k is reported in system monitor of gnome as only 23.6GB, go figure.
Date: 13 Jul 2010 14:23:57
Message: <4c3caf3d$1@news.povray.org>
It *is* virtualised, but if the RAM doesn't physically reside on the
same system, you're going to see a jaw-droppingly *vast* performance
drop. (Which would kind of negate the whole point of those multiple CPU
cores...)
http://blog.orphi.me.uk/
Date: 13 Jul 2010 15:09:54
Message: <4c3cba02@news.povray.org>
> cores...)
Sure, but the system may well have 128 GB of memory installed in it (for
example), and only 23 GB allocated to that specific machine - that's my
point.
Jim
Date: 13 Jul 2010 15:26:45
Message: <4c3cbdf5$1@news.povray.org>
Invisible wrote:
>> $1.60/hour.
I think it has a quad-core 2 hyperthreads per core. At least, according to
the intel specs, if I read them right.
Date: 13 Jul 2010 15:27:37
Message: <4c3cbe29$1@news.povray.org>
It's an amazon compute server you're renting by the hour. Yes, it's in a VM. :-)
Date: 14 Jul 2010 04:11:05
Message: <4c3d7119$1@news.povray.org>
>> cores...)
> point.
And my point is "where the **** do you get a system that can handle more
than 16GB of RAM from?!"
Date: 14 Jul 2010 10:25:00
Message: <4c3dc8bc@news.povray.org>
"Invisible" <voi### [at] dev null> wrote in message
news:4c3d7119$1@news.povray.org...
From computer stores, where else? However, 16 is an odd number in days of
tripple channel. Consumer/prosumer mb's typically will top out at 24GB
(single cpu) or 48GB (dual cpu).
Date: 14 Jul 2010 10:48:47
Message: <4c3dce4f$1@news.povray.org>
Most if not all the motherboards I've seen top out at 8GB, actually...
Date: 14 Jul 2010 11:12:49
Message: <4c3dd3f1$1@news.povray.org>
Odd, pretty much all the motherboards I looked at for a single Intel i7
processor supported up to 24 GB.
Date: 14 Jul 2010 11:17:53
Message: <4c3dd521$1@news.povray.org>
http://tinyurl.com/25z4y9r
Date: 14 Jul 2010 11:51:25
Message: <4c3ddcfd@news.povray.org>
>> (for example), and only 23 GB allocated to that specific machine -
>> that's my point.
GIYF. ;-)
Hint: It's not your typical off-the-shelf desktop PC. We're talking
very specialized hardware here.
Jim
Date: 14 Jul 2010 13:02:08
Message: <4c3ded90$1@news.povray.org>
So it's in the same category as "where do you buy s bus" then?
Date: 14 Jul 2010 13:07:32
Message: <4c3deed4$1@news.povray.org>
Well, really, it's only "very specialized" if your business doesn't involve
large-memory computing. That sort of stuff is pretty off-the-shelf if you're
an engineering firm or a something like that.
Date: 14 Jul 2010 13:08:45
Message: <4c3def1d$1@news.povray.org>
> involve large-memory computing. That sort of stuff is pretty
> off-the-shelf if you're an engineering firm or a something like that.
Well, yeah - but I'm not going to find it going to the local Best Buy,
that's what I mean. :-)
Jim
Date: 14 Jul 2010 13:09:24
Message: <4c3def44$1@news.povray.org>
Or "where would I buy a more powerful laser than the laser pointer I
bought at Office Max"?
Jim
Date: 14 Jul 2010 13:09:57
Message: <4c3def65@news.povray.org>
It is indeed not a "Personal Computer" sort of thing. :-)
Date: 14 Jul 2010 13:12:54
Message: <4c3df016@news.povray.org>
Though it'd be nice to have one or three. ;-)
Jim
Date: 14 Jul 2010 13:59:47
Message: <4c3dfb13@news.povray.org>
I'll just rent em when I need em. :-)
It was funny, tho. I read someone talking about all the "nosql" databases,
and how people were complaining SQL doesn't "scale". He said "SQL scales
fine. What the people mean is that SQL doesn't scale if you want to use a
commodity piece of hardware like Amazon rents. This is what we have in my
office for testing:" and gives the stats on a 96-CPU 256G RAM SQL processor.
He says "That's the low-end base machine for testing, not the production
system."
Date: 14 Jul 2010 17:46:04
Message: <4C3E3022.3040404@gmail.com>
On 14-7-2010 17:17, Darren New wrote:
>> more than 16GB of RAM from?!"
or e.g. http://www.sgi.com/pdfs/4185.pdf
Date: 15 Jul 2010 02:35:02
Message: <4c3eac16@news.povray.org>
Le 14/07/2010 17:51, Jim Henderson nous fit lire :
>>> that's my point.
> GIYF. ;-)
Well, a 24GB system is expensive but main-street now.
(I built one in june): based on i7 implied triple channel memory, and
therefore most single i7-supporting motherboard are limited to 24GB.
Finding a set of 6 Ram-stick to fill the slots is rather easy too, as
memory-maker/seller make kit ready to install (and with warranty).
Motherboard: about 200€
Memory: about 800€
CPU: anywhere from 200 to 1000€
Box: from 50€ to 200€ (according to the cooling and other
easy-life-making: hand-screw, clip-on...)
and so on for the small details (mouse, keyboard, graphics card(s),
display...)
There you go, a system with more than 16GB.
Date: 15 Jul 2010 02:36:31
Message: <4c3eac6f@news.povray.org>
> GIYF. ;-)
What like this:
http://www.ebuyer.com/product/173974
Date: 15 Jul 2010 03:45:54
Message: <4c3ebcb2$1@news.povray.org>
> databases, and how people were complaining SQL doesn't "scale". He said
> "SQL scales fine. What the people mean is that SQL doesn't scale if you
> want to use a commodity piece of hardware like Amazon rents. This is
> what we have in my office for testing:" and gives the stats on a 96-CPU
> 256G RAM SQL processor. He says "That's the low-end base machine for
> testing, not the production system."
Presumably that's not x86 though.
Date: 15 Jul 2010 11:11:43
Message: <4c3f252f$1@news.povray.org>
I didn't look into it that deeply. Why would you think it's not?
Date: 15 Jul 2010 11:32:12
Message: <4c3f29fc$1@news.povray.org>
I got the impression that x86 CPUs are designed to communicate with only
a fixed number of peers.
For example, a socket 939 Athlon can only be run in a single-chip
configuration. But a socket 940 Opteron has an extra pin which enables
it to run in single-chip or dual-chip configuration. (But not
triple-chip or more.) In later Opteron generations, part of the model
number tells you what the maximum number of chips you can wire together
is. I gather Intel Xeon chips use a similar system.
Given that the reviews talk about 1-chip, 2-chip, 4-chip and even
8-chip, I very much doubt anybody has bothered to design a 96-chip part.
Who would they sell it to, after all? (And wouldn't it need 96 extra pins??)
Date: 15 Jul 2010 12:06:34
Message: <4c3f3209@news.povray.org>
I wonder if POV-Ray 3.7 could be compiled for this monster:
http://en.wikipedia.org/wiki/Jaguar_%28computer%29
It has more cores than the maximum number of threads POV-Ray would use for
an average-sized image (iow. you basically get a core for each square to which
the image is subdivided by POV-Ray for rendering).
A giant poster-sized image could perhaps require rendering more than one
square per core...
Date: 15 Jul 2010 12:21:32
Message: <4c3f358c@news.povray.org>
> square per core...
I think the first job should be rendering a 300 DPI 1:1 scale image of the
computer it ran on. :-)
Date: 15 Jul 2010 13:05:31
Message: <4c3f3fdb$1@news.povray.org>
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6426353&Sku=E145-2082
I'm thinking one that supports 4-way SLI is probably a gaming system. ;)
Supports up to 48GB of ram, dual hex-core xeons ... yeah..
A bit pricey, though.
~Mike
Date: 15 Jul 2010 13:38:21
Message: <4c3f478d$1@news.povray.org>
http://www.cray.com/Products/XT/Specifications.aspx
Opterons ... x86 ;)
http://www.ewiz.com/detail.php?p=MB-H8DGUF&c=fr&pid=ea8e96795a53689a8306610b250b775faaf92905edde9d71f42a3e02a2c3931c
So, its a dual chip mobo ... unless you make it yourself like Cray ...
24 cores is probably enough.
> pins??)
Cray has, but then, it's a purpose-built machine.
~Mike
Date: 15 Jul 2010 13:57:13
Message: <4c3f4bf9@news.povray.org>
On Thu, 15 Jul 2010 08:35:00 +0200, Le_Forgeron wrote:
> Well, a 24GB system is expensive but main-street now. (I built one in
> june):
The fact that you built it demonstrates it's not "off the shelf" - it's a
custom build. ;-)
Jim
Date: 15 Jul 2010 13:58:49
Message: <4c3f4c59$1@news.povray.org>
On Thu, 15 Jul 2010 08:36:30 +0200, scott wrote:
>> GIYF. ;-)
> What like this:
Yes. Now go to Best Buy and buy a system based on that system board.
That's what I'm talking about when I say "off the shelf". I can get
laser pointers pretty much anywhere I go, but to get something more
powerful, you have to go to a place like Wicked Lasers - yes, you can buy
stuff "off the shelf" from them, but they're a specialty vendor, which is
my point.
Jim
Date: 16 Jul 2010 03:46:54
Message: <4c400e6e$1@news.povray.org>
It seems nearly all boards for i7 take up to 24 GB, and certainly in the
"mainstream" shops here you can buy i7 systems for a normal price.
Date: 16 Jul 2010 03:53:35
Message: <4c400fff$1@news.povray.org>
> Opterons ... x86 ;)
Yes, a conspicuous number of supercomputers use Opteron and not Xeon.
>> pins??)
I meant that the CPU has to be designed to operate with X number of
peers - so you'd have to design a Opteron or whatever with pins for 96
other peers. Which presumably AMD haven't done.
Date: 16 Jul 2010 08:31:36
Message: <4c405128$1@news.povray.org>
http://en.wikipedia.org/wiki/Beckton_%28microprocessor%29#Beckton
"The 75xx models have four QuickPath interfaces, so it can be used in
up-to eight-socket configurations, while the 65xx models are only for up
to two sockets."
Also... They make 8-core Xeons now?! o_O I bet those a cheap.
Date: 16 Jul 2010 08:40:24
Message: <4c405338$1@news.povray.org>
Bugger that:
http://en.wikipedia.org/wiki/List_of_AMD_Opteron_microprocessors#Twelve-core_Server_processors
Heh. 12-core chips in a 2- or 4-socket configuration? That's, like, 48
cores or something! That's crazy...
(Then again, last I heard Opteron isn't as fast as Xeon.)
Date: 16 Jul 2010 11:44:45
Message: <4c407e6d$1@news.povray.org>
Shows how recently I've purchased a system. :-)
Jim
Date: 16 Jul 2010 12:50:40
Message: <4c408de0@news.povray.org>
I actually have pretty free access to about 50 computers of about this
capability, but exactly the opposite problem -- not enough free time to
do any serious POVing that would warrant their use.
Date: 16 Jul 2010 13:19:21
Message: <4c409499$1@news.povray.org>
I know that feeling well as well.
Jim
Date: 16 Jul 2010 14:03:10
Message: <4c409ede$1@news.povray.org>
Surely there's profit to be made there! ;-)
