POV-Ray : Newsgroups : povray.off-topic : And just in case you had a big POV job to trace... Server Time
12 Apr 2026 01:13:07 EDT (-0400)
  And just in case you had a big POV job to trace... (Message 1 to 10 of 42)
Subject: And just in case you had a big POV job to trace...
Date: 13 Jul 2010 11:36:40
Message: <4c3c8808$1@news.povray.org>
http://aws.typepad.com/aws/2010/07/the-new-amazon-ec2-instance-type-the-cluster-compute-instance.html
Rent a quad-core 2HT 2.93GHz 23G RAM 1.5TB disk compute engine for $1.60/hour.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Subject: Re: And just in case you had a big POV job to trace...
Date: 13 Jul 2010 11:57:22
Message: <4c3c8ce2$1@news.povray.org>
> $1.60/hour.
That's *dual* quad-core (i.e., total of 8 cores), apparently.
What I can't figure out is how it's possible to put 23GB of RAM into a
single PC. AFAIK, nobody makes motherboard that can do that...
(The other problem, of course, is that although it has 1.5TB of storage,
since you access the Internet at 8 mbit/sec, it would take a loooong
time to fill or empty that space. So it's only useful for temporary data
generated by the process itself.)
Date: 13 Jul 2010 12:53:20
Message: <4c3c9a00$1@news.povray.org>
On 7/13/2010 10:57 AM, Invisible wrote:
>> $1.60/hour.
Its a cluster .... there are 2 separate systems.
~Mike
Date: 13 Jul 2010 14:18:06
Message: <4c3cadde$1@news.povray.org>
It's probably virtualized, which lets you configure any odd amount of
memory you want, pretty much.
Jim
Date: 13 Jul 2010 14:21:31
Message: <4c3caeab$1@news.povray.org>
Le 13/07/2010 17:57, Invisible nous fit lire :
>> $1.60/hour.
Correct, 24GB of ram is more usual.
It might infact be a VM of 23GB... 1GB for the barebone.
Or a commercial cover-up, to avoid the issue of Gi/G, or whatever
24740416k is reported in system monitor of gnome as only 23.6GB, go figure.
Date: 13 Jul 2010 14:23:57
Message: <4c3caf3d$1@news.povray.org>
It *is* virtualised, but if the RAM doesn't physically reside on the
same system, you're going to see a jaw-droppingly *vast* performance
drop. (Which would kind of negate the whole point of those multiple CPU
cores...)
http://blog.orphi.me.uk/
Date: 13 Jul 2010 15:09:54
Message: <4c3cba02@news.povray.org>
> cores...)
Sure, but the system may well have 128 GB of memory installed in it (for
example), and only 23 GB allocated to that specific machine - that's my
point.
Jim
Date: 13 Jul 2010 15:26:45
Message: <4c3cbdf5$1@news.povray.org>
Invisible wrote:
>> $1.60/hour.
I think it has a quad-core 2 hyperthreads per core. At least, according to
the intel specs, if I read them right.
Date: 13 Jul 2010 15:27:37
Message: <4c3cbe29$1@news.povray.org>
It's an amazon compute server you're renting by the hour. Yes, it's in a VM. :-)
Date: 14 Jul 2010 04:11:05
Message: <4c3d7119$1@news.povray.org>
>> cores...)
> point.
And my point is "where the **** do you get a system that can handle more
than 16GB of RAM from?!"
