POV-Ray : Newsgroups : povray.off-topic : My computer doesn't like heat, what to do? Server Time
17 Oct 2026 21:13:27 EDT (-0400)
  My computer doesn't like heat, what to do? (Message 1 to 21 of 21)
Subject: My computer doesn't like heat, what to do?
Date: 13 Jul 2010 10:28:14
Message: <4c3c77fe@news.povray.org>
There's something wrong with my PC, and I don't know what to do about it.
  The CPU fan is really, really, really picky about the room temperature.
At something like 20-22 degrees celsius it's really content, and spins at
a moderately silent 2500-2700 RPM.
  Elevate the room temperature just by a few degrees, to something like 24
or 25 celsius, and the CPU fan immediately jumps to at least 3000 RPM, even
when the CPU is completely idle, and starts being annoying audible.
  A few degrees more, to something like 27-28 celsius, and the CPU fan goes
completely crazy, reaching speeds even exceeding 4000 RPM, which sounds like
a jet taking off. I'm afraid of keeping my PC running in this situation.
  At this moment the room temperature is 31 degrees celsius, the computer
case is open, the case fan is rotating at full speed (I have a case fan with
three speed settings), and I have a regular electric fan blowing air directly
inside the computer at full speed, yet the CPU fan is running at 3900 RPM,
even though the CPU is completely idle. I wouldn't even dare to try what it
does in a *normal* situation.
  In none of these situations does the actual CPU temperature exceed 50
degrees celsius. For example at this very moment it's 44 degrees. Yet the
CPU fan is going at 3900 RPM. I'm afraid of keeping the PC on for much
longer because it sounds like it's going to break at any moment.
  This isn't normal. A friend's PC runs almost silent even at these high
room temperatures. My Xbox360 runs very silently.
  I have no idea what the problem could be. Any suggestions? I can't use my
PC because I'm afraid it will break.
Subject: Re: My computer doesn't like heat, what to do?
Date: 13 Jul 2010 10:45:47
Message: <4c3c7c1b$1@news.povray.org>
> with
> directly
> it
The fan/BIOS is probably designed to run "silently" at CPU-idle and only
speed up once it gets loaded.  They are probably doing this by triggering at
a certain temperature (eg 35°C) which obviously gets messed up if your room
is already at 31°C.  Maybe there is a setting in the BIOS to control the fan
speed trigger temperatures?
Anyway, those temps and fan speeds seem completely normal to me (on my older
PC the CPU fan runs at 5000 rpm the whole time).  What CPU temp do you get
at full load?
You can buy a quieter fan if it's just the noise that's a problem.
Date: 13 Jul 2010 11:55:18
Message: <4c3c8c66$1@news.povray.org>
I would imagine the fan bearings are worn out. That's usually the cause
of excessive fan noice.
The good news (??!) is that if the fan does in fact stop spinning, the
PC should turn itself off before your CPU fries.
Date: 13 Jul 2010 12:51:56
Message: <4c3c99ac@news.povray.org>
Not necessarily. If the fan just sounds like a jet engine, it's probably
just a small fan spinning relatively fast. You may be able to get a
quieter fan, or if your case has a spot for it, a larger fan.
Yup. Thank goodness for automatic thermal shutdown.
Heh. The other day my wife's computer (a notebook) shut down
automatically, and she couldn't get it to come on again. I picked it up,
and noticed two things immediately. The bottom was scorching hot, and a
receipt flitted away as I picked up the computer.
Yeah, a receipt blocked the fan's input port. What really worried me was
the fact that the computer had gotten so hot that even the pins on the
VGA connector were too hot to touch! Scary... no permanent damage that I
can determine was done to the computer.
~Mike
Date: 13 Jul 2010 12:56:53
Message: <4c3c9ad5$1@news.povray.org>
Warp escreveu:
> Any suggestions?
move to Finland?
a game sig: http://tinyurl.com/d3rxz9
Date: 13 Jul 2010 16:02:20
Message: <4c3cc64c@news.povray.org>
"nemesis" <nam### [at] gmailcom> a écrit dans le message de news:
4c3c9ad5$1@news.povray.org...
> Warp escreveu:
>> Any suggestions?
> move to Finland?
Stop releasing greenhouse gases
Marc
Date: 13 Jul 2010 17:03:09
Message: <4c3cd48d@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de groupe de discussion
: 4c3c77fe@news.povray.org...
Some years ago it happened to my (old) Dell laptop. The fans started going
at full speed when they shouldn't have and the CPU slowed down for no good
reason. After some googling I found that someone had developed an utility to
control the fans manually and it worked perfectly. This utility is only for
Precision/Dell laptops (http://www.diefer.de/i8kfan/ ) but possibly
something like it exists for other brands.
G.
Date: 13 Jul 2010 17:35:28
Message: <4c3cdc20@news.povray.org>
> going at full speed when they shouldn't have and the CPU slowed down for
> no good reason. After some googling I found that someone had developed
> an utility to control the fans manually and it worked perfectly. This
> utility is only for Precision/Dell laptops (http://www.diefer.de/i8kfan/
> ) but possibly something like it exists for other brands.
I use the free program Speedfan.
http://www.almico.com/speedfan.php
Best Regards,
Date: 13 Jul 2010 20:00:25
Message: <4c3cfe19$1@news.povray.org>
news:4c3c77fe@news.povray.org...
> even
> like
> with
> directly
> it
>                                                          - Warp
Get a Zalman cooler, run it at lowest fan speed settings and enjoy a silent
computer that doesn't over heat.
Cheers Dre
Date: 14 Jul 2010 04:08:41
Message: <4c3d7089$1@news.povray.org>
 From the way Warp phrased it, I got the impression that this PC *was*
working fine, and now it's suddenly started doing this.
Usual reason for that is worn out bearings.
I tried to install Linux on my dad's laptop, and had an interesting
experience. The installer kept crashing at random points with random
error messages. Tried several times and it just wouldn't work. Then I
noticed that the underside of the machine was scalding hot. The fan
wasn't spinning at all. We assumed it was broken.
Then we rebooted the laptop, and immediately the fan started spinning
like crazy. I left it on the BIOS screen, and the fan's spinning away,
and I'm watching the temperature stats. Eventually the fan starts to
slow down, and eventually it completely stops spinning.
So I load up the Linux installer and start again. Same deal. Eventually
it crashes, and the laptop is once again burning hot, with no fan activity.
So I reboot it, and the fan starts spinning like crazy. I immediately go
back into the Linux installer, and start installing. Here's the thing -
the fan stays spinning at maximum speed, even long after the laptop is
stone cold.
Yes, that's right. THE FAN IS CONTROLLED IN SOFTWARE! How retarded is
that? Surely this is a serious fire hazard...
Still, it was a very old laptop. (Actually, it still is.)
Date: 14 Jul 2010 05:12:44
Message: <4c3d7f8c$1@news.povray.org>
No, because the machine will switch off (which is in hardware) long before
the chance of any fire breaking out.
Date: 14 Jul 2010 05:28:29
Message: <4c3d833d$1@news.povray.org>
> before the chance of any fire breaking out.
As I say, the laptop let itself get hot enough to randomly malfunction
without turning off. What makes you think it would turn off at some even
higher temperature?
(A more likely scenario is that whatever program it's running would
crash, causing the CPU to halt and therefore cool down again.)
Date: 14 Jul 2010 05:36:04
Message: <4c3d8504$1@news.povray.org>
> higher temperature?
Because that's what CPUs are designed to do.  It was probably the RAM that
was overheating giving corrupt data to the CPU.
Date: 14 Jul 2010 08:14:01
Message: <4c3daa09$1@news.povray.org>
Most can be controlled by software. Usually the BIOS is in charge, but
programs can also alter the fan speed. This is useful for more advanced
monitoring programs like SpeedFan.
My system at home has 4 fan ports on the motherboard (3 case, one CPU,
the CPU and 2 of the case fans can be controlled by PWM)
~Mike
Date: 14 Jul 2010 08:19:53
Message: <4c3dab69$1@news.povray.org>
> that was overheating giving corrupt data to the CPU.
Yep... There's usually a thermal sensor either on the die or on the
motherboard.
Some older AMD's I believe rely on the mobo's thermal shutdown. an AMD
chip can be damaged by heat before the mobo registers a problem. On the
Intel side, the chip will throttle down to a snails pace to try to
control the heat, if that doesn't work, it'll tell the mobo to shut off.
I'm not sure about the newer AMDs.
Another interesting thing that's fun to watch: On the later Intel Core2
chips, they have an adaptive multiplier. When the CPU is idle, it will
reduce its clock rate to save on energy and keep cooler when idle.
~Mike
Date: 14 Jul 2010 08:34:39
Message: <4c3daedf$1@news.povray.org>
> motherboard.
http://www.tomshardware.com/reviews/hot-spot,365-5.html
demonstrates how older AMDs had *no* thermal protection at all. They
even have a video of one of the CPUs actually smoking and glowing. Can
you spell "fire hazard"?
They added thermal protection a long, long time ago.
Yeah, most processors do that now (especially "mobile" ones). Initially
they just made it so that a certain temperature, the system powers off.
But later they had adjustable fan speeds and adjustable clock speeds,
and switching off cores and so on.
I'm still puzzled about this laptop though. Considering that fan control
is both trivially simple and utterly safety critical, why is it
controlled by the OS? Why isn't it hard-wired?
Date: 14 Jul 2010 10:46:09
Message: <4c3dcdb1@news.povray.org>
Generally the OS isn't in charge of the fan. Perhaps the linux distro
you're using detects the chipset and grabs control of the fan?
~Mike
Date: 14 Jul 2010 10:50:04
Message: <4c3dce9c$1@news.povray.org>
Why should it even be possible to control it in software? The correct
algorithm is simple: set the fan to the lowest setting that gives
acceptable cooling. Why would you want to be able to control it in
software at all?
(As it happens, once Linux was installed, the fan worked normally. Just
not while the installer was running...)
Date: 14 Jul 2010 11:08:42
Message: <4c3dd2fa$1@news.povray.org>
Because there's usually an IC on the motherboard that reads the temperatures
and controls the fan PWM.  This is mapped to memory so that the BIOS can
control it.  Obviously this means any software running (an OS, a special
program, etc) can also take control.
> The correct algorithm is simple: set the fan to the lowest setting that
> gives acceptable cooling.
That's what it does!  But you have to take into account that there are many
different fan and CPU combinations that will be used on a motherboard, not
giving the option to change the settings would be a bit limiting.  (Plus it
would make it hard for the BIOS to setup the IC, currently it just writes
the data to a certain memory address).
> Why would you want to be able to control it in software at all?
How else do you propose doing it, that isn't 10x more expensive than the
current method?
Date: 14 Jul 2010 11:43:56
Message: <4c3ddb3c@news.povray.org>
  Actually someone else (IRL) suggested checking the BIOS settings for the
CPU fan, so I did so.
  There's some kind of setting which makes the CPU fan target for a certain
maximum CPU temperature. This setting was disabled, so I don't know what the
CPU fan was doing. I tried enabling this (and the default target maximum
temperature seems to be 66 degrees, so I left it like that), and now the
PC is incredibly silent, yet the CPU keeps quite cool when idle (2500 RPM,
47 degrees celsius) even though the room temperature is still unbearably
high (30 degrees celsius at the moment).
  I'm monitoring closely the CPU temperature and fan speed, but it seems to
be quite stable. And incredibly silent.
Date: 14 Jul 2010 11:45:53
Message: <4c3ddbb1@news.povray.org>
  You didn't understand. I didn't mean to say that the CPU fan noise is
not normal. I said that the fan going at 4000 RPM is not normal (because
its normal speed is somewhere around 2500 RPM).
  Anyways, so far it seems that a BIOS setting fixed the problem.
