POV-Ray : Newsgroups : povray.off-topic : The frustration that is MathML Server Time
17 Oct 2026 22:12:37 EDT (-0400)
  The frustration that is MathML (Message 1 to 13 of 13)
Subject: The frustration that is MathML
Date: 6 Jul 2010 09:54:42
Message: <4c3335a2$1@news.povray.org>
OK, so I realise nobody else gives a damn, but it's frustrating the hell
out of me. All I want to do is convert a tiny, minute, small, simple,
little, trivial, diminutive, insignificant little formula into MathML. I
have just spent literally an hour trying to achieve this tiny task, and
so far have failed miserably. I can't find any web page anywhere on the
face of the Internet that will perform the trivial conversion required
for me.
Wolfram have a page that will turn a Mathematica expression into MathML.
But there isn't any way of writing the construct I want in Mathematica.
The first hit from Google is this:
http://www.orcca.on.ca/MathML/texmml/textomml.html
This is THE EXACT THING THAT I WANT. So imagine my utter rage that IT
DOESN'T ACTUALLY WORK! >_<
I also found this:
http://www.maths.nottingham.ac.uk/personal/drw/lm.html
This works, BUT... I still cannot ACTUALLY VIEW THE MARKUP. I can make a
web page, put some LaTeX markup in it, and load the page, and Firefox
displays it correctly. However, it WILL NOT show me what MathML has
actually been generated. It only shows me the source code it loaded from
disk, not what it was ultimately transformed into.
At this point, it seems that the only option I have left open to me is
to spend 4 days reading through the incomprehensible MathML spec
document. All so that I can convert a piffling 3 characters into MathML...
(I wouldn't mind, but I don't even know if using MathML will actually
fix the problem anyway!)
Subject: Re: The frustration that is MathML
Date: 6 Jul 2010 12:46:38
Message: <4c335dee@news.povray.org>
So add a button you can click when it's done to dump out the DOM that the
javascript created.  That'll be a good oppotunity to learn javascript and
DOM processing.
(Or take a look at it in firebug or something?)
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 7 Jul 2010 05:02:41
Message: <4c3442b1$1@news.povray.org>
> the javascript created.  That'll be a good oppotunity to learn
> javascript and DOM processing.
I guess I could do... It's just intensely frustrating when I wanted to
just quickly test something and I end up having to spent an hour or so
coding, testing and debugging something. I am literally astonished that
there isn't a website that will just *do* all this for you. It's not
exactly a complex transformation, it's just difficult to do by hand...
Never heard of Firebug. However, I just installed it, and in about 20
seconds flat I got what I wanted.
If only I knew about this thing sooner...
Subject: Re: The fun of MathML
Date: 7 Jul 2010 08:20:29
Message: <4c34710d$1@news.povray.org>
Heh, I've never seriously tried to use MathML before. On the plus side,
it does solve the problem I had (i.e., various math symbols have Unicode
codepoints, but don't exist in any known typeface). On the other hand...
it's a tad verbose.
With TeX, if you want to write "x" as a mathematical variable rather
than a piece of text, you simply say "$x$". But by the power of MathML,
if you want to do this in DocBook, you write
   <inlineequation>
     <math xmlns="http://www.w3c.org/1998/Math/MathML">
       <mrow><mi>x</mi></mrow>
     </math>
   <inlineequation>
which is somewhat more typing. There's probably some trick that removes
the need to keep typing in the XML namespace URL every time, but even
then you'd still have
   <inlineequation><math><mrow><mi>x</mi></mrow></math><inlineequation>
which is a lot of typing considering that only one single character of
that will appear in the final output.
Now I see why people like to use specialised editors to write this
stuff. ;-) Typing HTML by hand is trivial, but this stuff is just
mental. (!)
Date: 7 Jul 2010 11:20:36
Message: <4c349b44@news.povray.org>
Glad to have helped!
You don't write much complex javascript, is all. :-)
Date: 7 Jul 2010 11:22:39
Message: <4c349bbf$1@news.povray.org>
Oh, only a Mandelbrot plotter and an LZW demo and a Huffman
encoder/decoder and...
Date: 7 Jul 2010 11:41:03
Message: <4c34a00f$1@news.povray.org>
It's not complex javascript until you start dicking with the DOM. :-)
Date: 7 Jul 2010 11:46:54
Message: <4c34a16e$1@news.povray.org>
...and how do you think the Mandelbrot plotter, you know, plots? :-P
(I got the trick from Slime, by the way.)
Also, my cubic equation solver works by basically opening a new frame
and dynamically generating the entire content that should go in there.
(I don't even remember how now...)
Date: 7 Jul 2010 16:21:59
Message: <4c34e1e7@news.povray.org>
I would think that a Mandelbrot plotter, an LZW demo and a Huffman
encoder/decoder would be a /lot/ more complicated than anything you
could do with the DOM.
http://isometricland.com
Date: 7 Jul 2010 16:24:27
Message: <4c34e27b$1@news.povray.org>
> mental. (!)
I wish it were suipported by browsers though. I've got a handful of
equations scattered around my website, and it would make the equations
look a little flashier than plain text.
Date: 8 Jul 2010 04:06:10
Message: <4c3586f2@news.povray.org>
>> mental. (!)
Which what were supported? MathML? Seems to work out of the box with
Firefox.
(Actually no, I think there were a tiny few symbols missing until I
installed the Math Fonts pack...)
Date: 8 Jul 2010 13:13:31
Message: <4c36073b$1@news.povray.org>
Well, the LZW demo doesn't use the DOM at all. There's just a field, and
it reads the contents of that field, and modifies some other fields, all
in response to clicking a form button.
The Mandelbrot plotter, on the other hand, does use the DOM.
Specifically, I borrowed this trick from Slime: You have a grid of
invisible whitespace elements, and you use the DOM "style" property to
apply CSS styling that turns these elements different colours, greating
primitive "pixels".
Obviously, web browsers are not even slightly designed for this, so it's
horrifyingly inefficient...
http://blog.orphi.me.uk/
Date: 13 Jul 2010 06:22:18
Message: <4c3c3e5a$1@news.povray.org>
>   <inlineequation>
>     </math>
>   <inlineequation>
It's also incorrect. That should be a closing tag at the bottom, and the
correct namespace URL has the domain name www.w3.org (no "c").
