Aleph-null green bottles standing on the wall,
And if one of those bottles should accidentally fall,
There'll be Aleph-null green bottles standing on the wall.
(Then again, one presumes that the gravitational field generated by a
countably infinite quantity of green bottles would somewhat exceed the
Earth's own gravitation. Although, since it fills a transfinite volume
as well... hmm, interesting.)
My personal favourit:
99 bottles of TNT standing on the wall,
There's be no more bottles of TNT, and no more ****ing wall.
Alternatively,
c green bottles standing on the wall,
And if Aleph_null of those bottles should accidentally fall,
There'll be c green bottles standing on the wall.
though I suppose you need to be as old as me to talk about c rather than Aleph_1
If the wall was on earth, the bottles would have to decrease in size, and hence
mass, in order to fit on it, and no, I haven't decided what to do when the
volume of a bottle is less than that of a hydrogen atom.
I think it is:
99 bottles of nitro-glycerine ...
nitro being liquid and very susceptible to small shocks. I believe TNT is solid
and stable unless detonated by explosion.
The cardinallity of the continuum is equal to Beth-one, which is equal
to Aleph-one if and only if the continuum hypothesis holds. And the
continuum hypothesis is independent of the axioms of ZFC, so...
I wonder - is the volume of the universe infinite? (The volume of the
*obvservable* universe clearly isn't.)
For that matter, shouldn't a countable infinity of masses generate
enough gravity to collapse into a singularity?
> I think it is:
Apparently so. I was under the impression that they're both equally
unstable, but apparently not.
This paper will at least give you something to think about, but be warned
it's a bit hairy!
http://www.mso.anu.edu.au/~charley/papers/DavisLineweaver04.pdf
I think yo uhave to worry more about it being smaller than the Plank length.
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
I thought I remembered reading that someone had proven that to be the case
like 10 years ago or so, but perhaps I misremember.
Indeed, the point of TNT is to make Nitro stable enough to be useful.
On 7/6/2010 9:05 AM, Invisible wrote:
>> than Aleph_1
What is Aleph-null? Is it the set of all integers? or is it something a
little different. I know it's basically a different sort of infinity...
[A Quick wiki detour later] Oh, Aleph-Null is basically any infinite
set, Aleph-One would be a set of all ordinals (positive integers and 0)
.. Interesting
~Mike
> .. Interesting
Aleph-null is the *size* of a set (specifically, the set of natural
numbers). The technical term is "cardinality".
The set of all positive numbers (including or excluding zero) is
Aleph-null. In fact,
Aleph0 + x = Aleph0
Aleph0 * x = Aleph0
Aleph0 ^ x = Aleph0
assuming that x < Aleph0 (i.e., x is finite). For this reason, the set
of all integers (positive and negative) has size 2 * Aleph0 = Aleph0. In
other words, the set of all integers is THE SAME SIZE as the set of
positive integers. (So it really isn't especially important exactly
which set you use as your definition.)
Additionally, the set of all 2D coordinates has cardinality Aleph0 *
Aleph0 = Aleph0, so that's the same size too. The set of all rational
numbers also has the same size, as does the set of all algebraic numbers
(i.e., roots of polynomials - so that includes irrational square roots
and the like).
However, the set of all *real* numbers includes also transcendental
numbers - numbers which are not the root of any polynomial. And *this*
set has cardinallity Beth-one. And Beth-one > Aleph-null.
Aleph-one = 2 ^ Aleph-null
(Note that Aleph-null ^ 2 = Aleph-null, which isn't the same thing at all!)
If the continuum hypothesis is true then Beth-one = Aleph-one.
http://blog.orphi.me.uk/
Darren New wrote:
> I think you have to worry more about it being smaller than the Plank
> length.
What happens to objects smaller than the Plank length? Do they fall
between the cracks and drop out of the bottom of the universe or something?
Orchid XP v8 wrote:
>> length.
Mu.
The question is meaningless, because there is no such thing as "smaller than
the Plank length". It's like saying "what happens when it gets bigger than
the universe?" or "how long did it take before time started?"
(http://en.wikipedia.org/wiki/Mu_%28negative%29)
> Mu.
> The question is meaningless.
...as is my humour, apparently...
>> Mu.
I found the entire thing to be funny - and have shared it. :-)
Jim
Orchid XP v8 wrote:
> Mike Raiford wrote:
I found Invisible's summary to be a bit confusing, and also seemed to
have a semi-important error, so here's another quick summary:
The Aleph numbers are "cardinals" which means they represent the size of
sets. Aleph_0 is the first infinite cardinal, which is equal to the
size of the set of natural numbers. Aleph_1 is the next size that a set
can have which is larger than Aleph_0. Beth_1 is the size of the set of
all real numbers, and it can be proven that the size of this set is a
"larger infinity" than the size of the set of all natural numbers (so
Beth_1 > Aleph_0). It cannot be proven by standard set theory whether
or not Beth_1 = Aleph_1. Put another way, it is impossible to prove
whether or not there are sets which have a size between that of the
natural numbers and that of the real numbers.
> sets. Aleph_0 is the first infinite cardinal, which is equal to the size
> of the set of natural numbers. Aleph_1 is the next size that a set can
> have which is larger than Aleph_0. Beth_1 is the size of the set of all
> Beth_1 > Aleph_0). It cannot be proven by standard set theory whether or
> not Beth_1 = Aleph_1. Put another way, it is impossible to prove whether
> or not there are sets which have a size between that of the natural
Ok, that makes sense to me now. Yeah, I think my original post was a bit
mistaken ... I realized pretty quickly after Andrew's posting what it
meant, but I don't quite think I had the right words to express what I
was thinking.
~Mike
Am 06.07.2010 14:30, schrieb Invisible:
From all I know, TNT doesn't come bottled, nor does it explode from
just accidentally falling.
Unfortunately, "99 bottles of Nitroglycerine standing on the wall"
doesn't quite fit the rhythm...
>> 99 bottles of TNT standing on the wall, 99 bottles of TNT standing on
>> the wall, And if one of those bottles should accidentally fall, There's
I consider it 'artistic license'. Just go with it. ;-)
Jim
