POV-Ray : Newsgroups : povray.off-topic : Merge hundreds of images together? Server Time
7 Mar 2026 13:27:37 EST (-0500)
  Merge hundreds of images together? (Message 1 to 10 of 15)
Subject: Merge hundreds of images together?
Date: 2 Jul 2010 12:26:43
Message: <4c2e1343@news.povray.org>
Using Linux?
A BIT on-topic; Pictures produced using POV animation.
gives a poor result.
Subject: Re: Merge hundreds of images together?
Date: 2 Jul 2010 13:29:14
Message: <4c2e21ea@news.povray.org>
Shay <sha### [at] nonenone> wrote:
> Using Linux?
  What do you mean by "merge"?
Date: 2 Jul 2010 13:43:41
Message: <4c2e254d$1@news.povray.org>
>> Using Linux?
Average.
Date: 2 Jul 2010 14:02:43
Message: <4c2e29c2@news.povray.org>
> >> Using Linux?
> Average.
  You could always use this:
http://warp.povusers.org/PovUtils/average/
  Of course I wrote that like a millenia ago, and it's just horrible.
Maybe I should make a new version supporting PNGs instead...
Date: 2 Jul 2010 14:10:23
Message: <4c2e2b8f$1@news.povray.org>
Am 02.07.2010 18:26, schrieb Shay:
> Using Linux?
Why not use POV-Ray for the job?
Date: 2 Jul 2010 14:10:44
Message: <4c2e2ba4$1@news.povray.org>
Shay wrote:
> Average.
If it's really hundreds of images, to the point where simply averaging them
together fails due to lack of sufficiently deep alpha channels (or some
such), then the best bet is probably to find NetPBM (aka PBMPlus) and turn
them all into textual PPM files. (Actually, I suspect ImageMagick can turn
any file into a PPM file too, for that matter.)
Then write a simple program that reads all the files, does the average with
longs instead of integers, and then writes out a PPM file you can turn back
into whatever format you want to use.
If you use the textual version of PPM, you can open it in a text editor and
deduce the format pretty easily, if you don't want to track down the actual
specs.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 2 Jul 2010 14:16:22
Message: <4c2e2cf6$1@news.povray.org>
convert xyz.png -compress None xyz.ppm
Then edit xyz.ppm in a text editor. You'll get a header (P3), the X, Y, and
maximum data value, then X*Y ascii integers.
Read em, average em, convert em back.
Date: 2 Jul 2010 14:26:51
Message: <4c2e2f6b@news.povray.org>
  Has the limit of 256 elements in a pigment map (and other types of map)
been removed?
Date: 2 Jul 2010 17:34:11
Message: <4c2e5b53$1@news.povray.org>
Shay wrote:
>>> Using Linux?
I wrote a utility to do this a while back (but I'm on vacation so
unfortunately I won't be able to find and post it for a while).  At any
rate, the trick was to average pairs of images in a binary tree pattern
until you're left with a single image at the root.  In this way you
avoid the problems with limited precision that you get using the naive
approach.  So long as you have a utility to average a pair of images it
should be easy to write a script to do this.
Date: 2 Jul 2010 17:55:30
Message: <4c2e6052@news.povray.org>
I think that's only going to work if you have a number of images that's a
power of two. Certainly merging 3 images this way isn't going to balance them.
