After much research, I believe that I have found the way to a girl's
heart...
...it's through her superior vena cava, just like anybody else's heart! :-P
Good god.. he's making cardiology jokes.. :/
~Mike
>> heart! :-P
I'm still waiting for Andrel to pop up and go "actually it's through the
inferior vena cava" or something. :-.
>> heart! :-P
Well, at least he is trying to. I decided not to correct him, because
that would be too easy for me.
Hey, I spent about 2 hours researching that. OK, it's not the same as a
lifetime, but I tried. (Wikipedia is surprisingly unhelpful here...)
At least I didn't say it was through the aorta. (That, of course, would
be the way *from* the heart, not *to* it.) I bothered to get that much
right. ;-)
I won't even fathom a guess as to what is wrong ... This is something
well beyond my domain.
~Mike
> right. ;-)
yes and no ;) Blood exits the heart via the aorta, but it used to be the
standard entry point for catheters if you wanted to go to the left
ventricle (where many arrhythmias originate). Nowadays the route via the
right atrium, though the atrial septum, to the left atrium and from
there to the left ventricle is also often used.
BTW as you rightly guessed, that implies that the vast majority of
catheterizations go via the inferior vene cava. Entering via the
superior vene cava is very uncommon, except for the wires of a pacemaker
or ICD (I guess you ended up in webpages describing those procedures).
In principle you can also enter via the right outflow tract and there
are also in general 4 lung venes (that transport oxygenated blood from
the lungs to the left atrium). Of the top of my head I don't know of any
procedure that uses any of those entry points.
To complete the picture you can also us a sternotomy or a laporoscopic
procedure, but don't try that at home.
>> would be the way *from* the heart, not *to* it.) I bothered to get
>> that much right. ;-)
Heh. I don't know if it's a rule of the Internet, but it probably should
be: For any conceivable topic, somebody else will know way, way more
about it than you. :-}
I would have thought trying to enter against the flow of blood through
the single largest blood vessel in the entire human body would be quite
difficult - then again, I'm sure many people far more knowledgeable than
me have actually tried this out. Also, I guess it would depend on where
the hell you're trying to actually get to in the first place...
Hmm, OK.
Actually, I just looked up the major blood vessels of the heart and
tried to figure out which name goes with which tube on the diagram.
(You'd think this would be easy... you'd be wrong.) I eventually
determined that the two vena cavae are where the majority of blood
enters from, and arbitrarily selected the superior one.
Firstly because "superior" sounds better [although in fact I gather it
just means "higher up" in medical jargon], and partly because I imagined
the route from the brain to the heart. Most people perceive their body
looking down from where their head is. (Not that this has anything
remotely to do with the surgical feasibility of inserting stuff from
that direction...)
Yeah, the heart is a double-pump, so there ought to be *two* entrances
in theory. (There are apparently more because humans have two lungs, and
because blood from above and below returns through different routes.)
On a completely unrelated note, apparently in some animals the heart is
a single pump, and in yet others it's just a tube that sort of squirts,
and there are no blood "vessels" at all. The internal organs just sit in
a soup of... well, it's not even blood, it's haemolymph.
Then again, apparently some animals don't have red blood cells, the
haemoglobin just floats in solution. Larger animals don't do that
because to have enough haemoglobin to transport sufficient oxygen, their
blood would be like treacle. So RBCs evolved which are packed with this
oxygen-transport protein, but the blood remains liquid.
In other news, I spent a really absurd amount of time on Wikipedia. o_O
Yeah, that or any other medical procedure even remotely involving your
heart! o_O
Although I did hear about an off-duty medic who saved someone from a
collapsed lung on an airoplane using a tube and a coathanger or
something random like that...
Funny stuff, blood. Everybody seems to think it's red. Certainly if you
spill it, everything within an 8-mile radius is coated scarlet and it
looks like a chainsaw massacre has happened (when actually you merely
got a paper cut)! But from what I've seen, blood is nearer black than
red. I mean, if you get any real *quantity* of the stuff. It's very dark
indeed.
Reminds me of the last time I had a nose bleed. Sure, it's only a small
volume of blood. But it gets *everywhere*. And it feels really, really
hot against your skin. Almost scalding hot. It really makes you feel
like something very serious is happening - especially when it's dripping
fast.
Somewhat unrelated, but... I remember my dad working on some plasma
samples. He proffered a tube at me and said "well, you can definitely
tell which volunteers had a good breakfast!" I swear, the amount of cow
lard floating on the top of some of these samples was discusting! :-S
http://blog.orphi.me.uk/
>> the standard entry point for catheters if you wanted to go to the left
except that in this case you knew I would be such a somebody.
> difficult
As you point out, it is big. Catheters are thin.
>> pacemaker or ICD (I guess you ended up in webpages describing those
>> procedures).
> that direction...)
IIRC the first catheter insertion was via the arm, so that would have
been the superior side. Aside, I think that you as a programmer would be
more careful in selecting an apparently arbitrary choice of two.
Especially if you know they are not interchangeable. Why didn't you go
for e.g. the vena cava without mentioning wither inf. or sup.?
>> any procedure that uses any of those entry points.
with in most cases two venes entering from each lung (indeed an inferior
and a superior).
> and because blood from above and below returns through different
> routes.)
In humans (and mammals and birds and probably also the reptiles and
fishes) it starts out as a tube with peristaltic contractions only later
the two separate circulations are formed. E.g. crocodiles have a single
chamber, but don't make the assumption that therefore their heart is
more primitive. For them that functions better than any 4 chambered
heart would do.
Pity that given your interest in this topic (and in e.g. MathML) that
you seem to be stuck in MK.
I think we noticed, and on WA.
> heart! o_O
I am not sure that sternotomy is 'remotely' involving hearts. I have
been present at quite a number of procedures where this was the approach
to open the heart and treat the inside.
>> should be: For any conceivable topic, somebody else will know way, way
>> more about it than you. :-}
Well, perhaps. But if I posted something about, say, iambic pentamiter,
somebody here would probably turn out to be an expert on the subject.
Well, I was going for comic effect rather than technical accuracy. A
long technical term sounds more impressive.
> and a superior).
OK, I didn't read that far.
>> is a single pump, and in yet others it's just a tube that sort of
>> squirts,
> heart would do.
Well, the word "primitive" means "simpler", and it's sometimes taken to
mean "less evolved". And people seem to think that simpler is worse, and
more complex is better. Then agian, people think that worms are "less
evolved" than humans - but they severely out-number us, so they can't be
doing it that badly wrong...
Heh. I'm "interested" in many, many topics. Fractals, data compression,
encryption, statistics, artificial intelligence, digital signal
processing, sound synthesis, logic design, biology, evolotion... the
list goes on.
The GHC User Manual has a section "for over-interested souls". I think
this is possibly the term that describes me...
Ah WA... Very cool, but not especially useful. Like the data glove, it
seems to be a solution in search of a problem.
> list goes on.
Yeah, describes me to a tee as well. Add chemistry and quantum physics
on top of that.
Indeed. Quite a fun toy, though.
~Mike
>> list goes on.
> on top of that.
Dude, this is povray.off-topic, the off-topic forum for users of a
Turing-complete ray tracer that supports implicit surfaces and
volumetric sampling of user-defined functions. I think "over-interested
souls" probably covers the entire damned group! ;-)
And I could add chemistry, electronics, and a whole bunch of other stuff
too. It's just that eventually you have to stop typing.
For sure. Although it seems to be extremely good at utterly failing to
comprehend what you mean.
Also, and this is the annoying part, WA is supposed to be this
"revolutionary" system that will "make everything computable for
anybody". The trouble is, it's powered by Mathematica, Wolfram's
flagship product, which retails for about £8,000 or so. (!!!) As a
result, WA is deliberately crippled (i.e., it won't answer certain
questions even though it could) in order to force you to buy Mathematica.
My personal feeling is that they should add a "pro" version for money
that *does* solve every problem that the backend engine can handle. And
then, instead of saying "WA doesn't know what to do with your input", it
should actually *say* "you need the pro version to do that".
But anyway, flames aside...
>>> squirts,
>> later the two separate circulations are formed. E.g. crocodiles have a
>> single chamber, but don't make the assumption that therefore their
>> heart is more primitive. For them that functions better than any 4
>> chambered heart would do.
A crocodile heart may be more complex than a human heart, it is e.g.
capable of adjusting the mixing of oxygenated and non-oxygenated blood
according to how much is needed. That helps in keeping submerged for
long times.
> Then again, people think that worms are "less
All animals alive today have evolved for exactly the same amount of
time. If you count generations, smaller animals are in general more
evolved than larger
> processing, sound synthesis, logic design, biology, evolution... the
> list goes on.
About 70% of these would have been useful in a job application here.
I think that would also describe me, although I prefer to describe my
interests as broad but not shallow.
Or a set of answers in search of a search.
OK, well here's something you might know the answer to:
Does dancing around like a crazy thing for a few hours count as "a good
cardio workout"?
(Obviously dancing something slow probably doesn't count. But something
like my favourit dance, Rock & Roll, is really very energetic. At least,
it is if you do it right...)
>>> way more about it than you. :-}
sorry
> cardio workout"?
I actually haven't a clue what a cardio workout is. Except that it a
term used by people that work out in a gym. I am definitely not one of
those.
Good dancing seems to be by using a lot of muscles, hence I would assume
that it may be a usefull workout anyway. (Yet IANAD)
I wouldn't be too sure about that. Moving slow also involves alot of
muscle tension. Google for tai chi (with current temperatures I am too
lazy for even that).
> But something like my favourit dance, Rock & Roll, is really very
> energetic. At least, it is if you do it right...)
It's aerobic exercise that gets your heart rate high and keeps it high.
Usually meaningful only in contrast to an anaerobic which is like lifting
weights to give your muscles strength.
So, dancing would be cardio unless you're *really* out of shape.
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
Heh. What, like so fat that it's a physical feet to actually list that
much flab out of the chair?
Actually, come to think of it... My mother has fat on her fat's fat, but
one thing I have noticed is that her legs appear to be 100% solid muscle
mass...
