POV-Ray : Newsgroups : povray.off-topic : Small math/programming problem Server Time
22 Jul 2025 08:23:46 EDT (-0400)
  Small math/programming problem (Message 1 to 10 of 25)
Subject: Small math/programming problem
Date: 30 Jun 2010 20:38:10
Message: <4c2be372$1@news.povray.org>
I was going through some old stuff on my hard drive, and I came across a
small code snippet which led to a cute little problem:
I have a number which is defined with the following bit of pseudocode,
with all variables representing ideal mathematical integers:
n = 2
for(a = n; a > 0; a--)
   for(b = n; b > 0; b--)
     for(c = n; c > 0; c--)
       for(d = n; n > 0; d--)
         n++;
print n
What are the last 10 digits of the result printed by this program?
Subject: Re: Small math/programming problem
Date: 30 Jun 2010 20:40:00
Message: <4c2be3e0$1@news.povray.org>
I just spotted a typo:  The code should obviously read:
n = 2
       for(d = n; d > 0; d--)
         n++;
print n
Since the version I gave didn't terminate!
> n = 2
>         n++;
> print n
Date: 1 Jul 2010 05:45:14
Message: <4c2c63aa$1@news.povray.org>
> n = 2
>         n++;
> print n
Damned mutable state! >_<
OK, well
   for(d=n; d>0; d--) n++;
is equivilent to
   n = 2*n;
so we have
   for(c=n;c>0;c--) n = 2*n;
which is
   n = n * 2^n;
so now we have
   for(b=n;b>0;b--) n = n * 2^n;
Now there's trouble. You see, initially we have
   n[0] = n
On the next iteration we have
   n[1] = n[0] 2^n[0] = n 2^n
But then we have
   n[2] = n[1] 2^n[1] = (n 2^n) 2^(n 2^n)
You can simplify this to
   n[2] = n 2^(n + n 2^n)
but that's still quite complex. More to the point, on the next iteration
it'll get even more complex, and I don't see a closed-form solution to this.
More to the point, by the time a=1, n=2048. That means that the b-loop
runs 2048 times. And when you consider that 2048 * 2^2048 is
6618522843404494295186406745839606161498952226757731129780294743557
0493724401440549267868490798926773634494383968047143923956857140205
4064027405360874460838310520368482324399959044049927980075147183260
4341057037983087046378008526061944441720519919712375121070497035272
7833755425876102776028267313405809429548880554782040765277562828362
8842383254654485203483075749433459903099416426669267233797295981858
3473505473250041540988386836142315991377081221877271190177224955315
3402287759789517121744336755350465901655205184917370974202405586941
2110653955407655676631932971733672542303136122441829419995004023881
95450053080383488
(i.e., 6.618 * 10^619), you realise that the very next iteration is
going to produce some absurdly *huge* number. This explains why the
program I wrote eats several GB of RAM without ever coming up with an
answer.
The difficulty, then, is coming up with an algorithm to compute the
least-significant digits of λ n → n 2^n without computing the entire
number. I'll have to go check my number theory; I don't recall the exact
details of the algorithm.
Date: 1 Jul 2010 06:12:19
Message: <4c2c6a03$1@news.povray.org>
You're asking for the last 10 digits of the answer. In other words, the
answer modulo 10^10. (Assuming you meant the last 10 *decimal* digits...)
In modular arithmetic,
   (X mod M) * (Y mod M) = (X * Y) mod M
In other words, we can reduce our running total to the least positive
reside class mod 10^10 and still get the same answer. Handling
billion-digit numbers is quite expensive, but piffling 10-digit numbers
are no match for the GMP.
Unfortimately,
   (X mod M)^(Y mod M) ≠ (X^Y) mod M
But fortunately,
   (X mod M)^Y = (X^Y) mod M
due to the first theorum. Better still,
   A+B = Y ⇒ (X mod M)^A * (X mod M)^B = (X^Y) mod M
by the usual first law of logarithms. This gives us the binary
exponentiation algorithm:
   x = 1;
   b = base;
   e = exponent;
   while (e>0)
     if odd(e) then x = x*b mod m;
     e = shift_right(e);
     b = b*b mod m;
At any time, you need to deal with numbers containing at most 20 digits.
So what's the answer? I make it
.....1,549,498,368
It took about 0.2 seconds to compute. I have very little confidence that
this is correct though.
Date: 1 Jul 2010 06:36:46
Message: <4c2c6fbe$1@news.povray.org>
> .....1,549,498,368
I recognise those last 6 digits!  I think I got them from my program, but
then my method was too slow to do any more digits in reasonable time.
Date: 1 Jul 2010 06:43:28
Message: <4c2c7150@news.povray.org>
scott wrote:
>> .....1,549,498,368
> but then my method was too slow to do any more digits in reasonable time.
Heh. Could be just fluke.
I'm still not 100% certain that my program works. For example, the
exponent is reduced as per the modulus too, which could affect the
answer. As a quick check, I tried rerunning with 20 digits:
.......1,225,862,901,549,498,368
So the digits don't change by making the calculation wider. Which
presumably means it's wide enough not to screw up the answer. (Or it's a
very big fluke. You never know - mathematics is like that!)
Date: 1 Jul 2010 07:52:00
Message: <4c2c8160$1@news.povray.org>
Next task, give us some indication of how big n is :-)
Date: 1 Jul 2010 08:22:19
Message: <4c2c887b$1@news.povray.org>
I can see I won't get much work done today...
OK, well we have
   d = λ n → n 2
   c = λ n → n 2^n
   b = λ n → c@n n
   a = λ n → b@n n
where "b@n" means "b applied n times".
If n = 100, then 2^n ≈ 10^30, while is a mere 10^2 times larger. As n
becomes larger, the difference becomes more and more insignificant. So,
we can approximate with
   c = λ n → 2^n
On that bases, the final result is guaranteed to be an exact power of 2.
We just need to figure out which one.
Using Knuth's "up-arrow notation", we have
   c = λ n → 2↑n
   b = λ n → 2↑↑n
   a = λ n → 2↑↑↑n
So the answer we seek is (approximately) 2↑↑↑2. In other words, the
pentation of 2 with 2. Unfortunately, I don't know of any efficient way
to compute the size of this ludicrously massive quantity.
Date: 1 Jul 2010 10:29:54
Message: <4c2ca662$1@news.povray.org>
Isn't that 4?
Date: 1 Jul 2010 11:25:28
Message: <4c2cb368$1@news.povray.org>
Invisible wrote:
> scott wrote:
>>> .....1,549,498,368
Nah. That would be a one in a million chance.
Wait, no, one in a million chances work out all the time!
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
