There's something very special about today. I have all but lost count of
the number of stupid questions I've been asked so far. Yesterday almost
nobody spoke to me. Since thing the day before. But today, everybody
seems to want to ask silly questions.
My mum called me to ask whether to leave the birthday card I haven't
signed yet at home so that I can sign it. (Duh.)
My grandad phoned to ask where my mum is, but I was driving, and by the
time I'd stopped driving and had a chance to call him back, he'd found
her anyway.
One of our project managers asked me what the difference between
"tab-deliminted text file" and "pipe-delimited text file" is.
But so far, at just after 2PM, the current winner is this:
"How can I convert milivolts to microsiemens?"
It could be worst: "How can I convert Volts to Sieverts ?"
Now, hide & run... farer!
I dunno. None of those sound like silly or stupid questions to me.
Eiffel - The language that lets you specify exactly
that the code does what you think it does, even if
it doesn't do what you wanted.
X-ray tube.
What's the difference between tab-delimited and pipe-delimited? Well,
let me see now... one of them is a file who's fields are delimited by
tab characters, and the other uses pipe characters instead. What, you
couldn't figure that out all by yourself?
Should you leave the card for me to sign? Actually no; just hand it over
blank. It'll be fine, right?
The final question is less stupid. Although trying to convert milivolts
to microseimens would be like trying to convert miles per hour into
pounds per square inch. (But in SI units at least...)
And lo On Fri, 18 Jun 2010 14:20:28 +0100, Invisible <voi### [at] dev null> did
spake thusly:
Have to agree with Darren, I've heard stupider.
> Yesterday almost nobody spoke to me.
Have I missed something?
> But today, everybody seems to want to ask silly questions.
Or should she fake your signature so as to get it in the post, or shall
she bring it down to you, or should she give it to X to pass on to you.
Context is king.
> her anyway.
Hardly stupid unless you were out of the country to which the answer would
be "How the hell should I know?"
Again if you know what delimited means you can guess, but if you don't
"what's a pipe?"
Well, we all have off days.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Oh, sure, I've heard _worse_.
These aren't stupid on the scale of Verizon Math Fail, but stupid on the
scale of "for goodness sake, go away and stop pestering me!"
No, but I apparently missed a couple of keys on my keyboard.
(That should of course be "same thing the day before".)
> Context is king.
Well, since I'll be home in an hour or so and I'm coming to where the
card needs to be taken... it's fairly self-evident that leaving the card
there is the thing to do. (The alternative I suppose is to take the card
over there blank and I'll sign it when I get there - but this seems less
optimal.)
>> the time I'd stopped driving and had a chance to call him back, he'd
>> found her anyway.
> would be "How the hell should I know?"
Well, you know, I almost *never* know where the hell my mother is. Why
ask me? Phone her! (In retrospect, maybe they did. She never ****ing
answers anyway...)
> "what's a pipe?"
I'm still trying to figure out why the hell she wanted to know, but
anyway...
This was the least-stupid question of them all, IMHO.
(It turns out we have a machine that takes measurements in microseimens,
but some software we use needs a value in milivolts. And while they are
completely different dimensions, if you knew the properties of the
machine, it's conceivable that a constant conversion factor actually
exists...)
> exists...)
You have a machine that displays measurements in microseimens.
Internally it will probably measure them in millivolts or milliamps. For
conversion you need to make sure that the conversion should be linear,
it might not be.
Best Regards,
>> exists...)
> For
> it might not be.
Given what the machine does, it seems plausible that the conversion is
perfectly linear.
A more important question is whether the conversion factor is *constant*
or not...
>>> exists...)
>> For conversion you need to make sure that the conversion should be
>> linear, it might not be.
> perfectly linear.
> or not...
If it is linear then the conversion factor must be constant. Not taking
hysteresis into account.
You need the input specs for the software.
Best Regards,
>> perfectly linear.
>> or not...
What give you that idea?
It may be that the conversion is perfectly linear, but that the
conversion factor depends on the chemical composition of what you're
analysing. So each time you analyse a set of samples, there is a linear
conversion, but it's different each time.
It turns out the software itself can do the necessary conversion, so
problem solved...
If one doesn't know that "pipe" is a character or that the file has fields
or whatever, then no. Plus, of course, the question isn't "what's the
difference" but "which should I use?" If you haven't figured out that
mapping of "what I asked" to "what information I'm looking for", then *you*
are the one that's silly. ;-)
Better than if it arrives too late perhaps.
You're not even spelling it consistently, so who are you to argue? ;-)
And in this case the right answer is "multiply by ..." to convert the units.
Again, you're thinking the question asked is silly, while what's actually
likely to be happening is you are answering the question asked rather than
providing the information requested. I used to be really bad and did this
all the time, until I figured out that every time someone asked a "silly"
question, what they wanted was for me to figure out first what confusion
would cause them to ask that question, *then* answer the question they
*should* have asked.
The right answer to *this* question is likely "what are you trying to do
that you would need to convert those units, because I can't think of any
measurement that would involve both sets of units."
> anyway...
Because a program asked, or someone asked her for the file in one of those
two formats, etc.
> the difference" but "which should I use?" If you haven't figured out
> that mapping of "what I asked" to "what information I'm looking for",
> then *you* are the one that's silly. ;-)
I'm still trying to think of any software that's capable of producing
such files. (And, therefore, where the hell this person even found those
names from...)
>> over blank. It'll be fine, right?
There's no possibility of that. I'm personally going there anyway, so...
*gasp* You mean some guy who was sent to a school for people with
learning difficulties due to his total inability to read and write
actually spelt something wrong? GIVE ME A ****ING BREAK! It's old, OK? I
can't spell. We get it. Can we please move on now?
> units.
Fortunately, since I'm having this conversation with a scientist who
comprehends how SI units work, I didn't have much difficulty explaining
what the problem was. We both quickly concluded that there is no
universal way to do the conversion, although in the specific instance
we're looking at there probably is a conversion (but that doesn't help
because we don't know what it is).
> actually likely to be happening is you are answering the question asked
> rather than providing the information requested.
As I say, this is the least-silly question I got asked. It's more in the
relm of "dude, that's really quite random" than "that's a stupid thing
to ask".
>>> perfectly linear.
>>> or not...
Because hat's what linear means.
> analysing.
For measuring mho's?
That is what you are measuring in the machine.
Only if the cross sectional area or length of the sample is different.
You really need to read up on the physical properties of materials.
Best Regards,
I think he was just teasing ... hence the smiley. But, yeah, spell
checkers and all :) <-- See the smiley ... no insult intended.
Actually, you spell better than most people on the net... (in general,
here is another story, but the people here appear rather intelligent.)
~Mike
Mike Raiford wrote:
> But, yeah, spell checkers and all.
I have tried on multiple occasions to make the Thunderbird spellchecker
work. It's not having any of it. I have no idea why...
(I also cannot make Firefox spell-check in English, only American. It
doesn't seem to matter how many times I install the UK dictionary, it
will not correctly spell-check.)
T-bird's spellchecking works for me, albeit sometimes the dictionary is
a bit anemic.
Did you make sure the language selected is English - UK? Sometimes I
wish the English - US dictionary accepted both spellings of words, such
as realize vs realise, since I'm constantly tripped up by the "z"
spellings of such words, I prefer the "s" spelling. Though for things
like color vs colour, I prefer dropping the unnecessary "u" ;)
~Mike
> a bit anemic.
Nope. Every time I spell-check something, it tells me that *every* word
is mis-split. (I.e., the dictionary is empty.) No matter how many times
I install a dictionary, I can't make this work. I've given up trying.
From what I remember, sometimes there's an error and the dictionary
doesn't even install, and sometimes it does install but then there's no
option to select it or any evidence that it was ever installed.
> Sometimes I
Sometimes I think we should just nuke the whole English language and
design something that actually ****ing works.
Unfortunately, this is impossible.
> names from...)
Excel? Pretty much every program that exports tabular data can do it with
tabs, and most UNIXy programs wind up putting pipes in when necessary.
(Basically, systems that generated tabular data intended to go over the
internet as email before the abomination of using XML for that became common
has an option to use pipes.)
So she was asking if she should bring it so you can sign it there, or
whether you're going home first. Seems easy.
It just makes it hard to look up what the question is when you don't spell
the critical word right, is all. :-) If he was actually asking how to
convert volts to seimands, yes, it would be silly. :-)
> to ask".
And my point is that there's almost no question that's a stupid thing to
ask. There's only literal interpretation of questions that someone is asking
without enough information to know what question they should be asking. If
you think a question is stupid, it's because you already know the answer. So
give it to them. :-)
Didn't they try that with Esperanto?
Oh, yeah ... you did say impossible. Improbable is probably more
accurate. ;)
~Mike
>> those names from...)
> Excel?
Excel can *import* text files with all sorts of strange delimiters.
However, it seems to be unable to *create* anything except CSV or
tab-delimited; there's no option for pipe-delimited.
Given that she already knows that I'm coming home, the answer seems
pretty self-evident.
http://blog.orphi.me.uk/
Well, sure. I mean, it's not like the resistence of a diode varies with
voltage.
Oh, wait, actually that's exactly what it does. :-P
So what makes you so certain that passing a current through a sample
can't cause some kind of chemical reaction that affects its electrical
characteristics, given that we don't even know what the hell this
machine is or what it does?
Fortunately, that's pretty easy to work around with a scripting
language. Export tab delimited and then use something like awk to
replcae the tabs with pipes = job done.
Jim
Oh, sure, I'm not disputing that. I'm just wondering where the hell some
random user who can barely operate Notepad has heard of pipe-delimited
files from...
> files from...
Probably a vendor that they interact with who said "we need/will provide
files in this format".
I interact with a company that delivers exams and a company that tracks
exam results and certifications; the typical user of the systems they
provide is non-technical, and they provide data in that type of format -
it's actually fairly widely used because "|" isn't often part of actual
data.
The perhaps surprising thing is that Excel and oocalc both don't have an
option built in for exporting files in that format, given that they are
so widely used.
Jim
Am 22.06.2010 16:46, schrieb Darren New:
> If you think a question is stupid, it's because you already know
> the answer. So give it to them. :-)
Nice point ;-)
>> files from...
I got the impression that she created one of these files by mistake, and
then whoever else she was interacting with rewrote the spec to match.
Which still leaves the question "how the hell did you manage to do this
in the first place?" Oh well.
> so widely used.
Yeah, I had assumed it would be there...
> voltage.
For a start you know what units it measures and you can research how to
measure “admittance”.
Of course passing a current through a material affects its properties.
Even a resistor will change its resistance as you pass a current through
it and it heats up. The trick is to use as small a current or voltage as
will work and let the material reach its working temperature.
Electronics is not all zeroes and ones, you have to think physical
properties as well.
As for a material having a chemical reaction: If it were to have a
reaction that changed its properties adversely then that is the wrong
way to test it. Someone who understands the problem will come up with a
solution.
Best Regards,
> Nice point ;-)
There are no stupid questions only stupid answers.
Or as I often say, ask a stupid person, get a stupid answer.
Best Regards,
There are no stupid questions. Only stupid people asking questions.
I might argue the *"Only"* if I were that sort of person. ;-)
Best Regards,
