POV-Ray : Newsgroups : povray.off-topic : Latest Logicsim build ... Server Time
28 May 2026 09:14:21 EDT (-0400)
  Latest Logicsim build ... (Message 1 to 10 of 29)
Subject: Latest Logicsim build ...
Date: 14 Jun 2010 08:06:44
Message: <4c161b54$1@news.povray.org>
Available at:
https://sourceforge.net/projects/logicsim/files/
~Mike
Subject: Re: Latest Logicsim build ...
Date: 14 Jun 2010 08:21:51
Message: <4c161edf$1@news.povray.org>
Mmm, somebody heard my typing. ;-)
Pretty icon, BTW.
I did think about mentioning some of the more amusing features of this
build... but I figured you already know about them anyway.
Date: 14 Jun 2010 09:18:13
Message: <4c162c15$1@news.povray.org>
> Pretty icon, BTW.
Do mention... I want to know.
What? the fact that if you wire a feeback loop the program just dies a
horrible death?
The fact that no menus work yet?
The irritation that when you go and change something on the property
grid the main window loses keyboard focus and it seems impossible to
regain it?
Really.. I want to know the bugs, though, if it isn't those issues. If
it is those issues, I'm aware of them. Right now I'm just trying to get
the basic pieces in.
~Mike
Date: 14 Jun 2010 09:43:36
Message: <4c163208$1@news.povray.org>
>> Pretty icon, BTW.
> horrible death?
> regain it?
No, more things like...
- If you select "OR gate", it inserts a NOR gate.
- NAND has the same truth table as NOR.
- If you change an input's value from the property pane, the simulation
doesn't update. (I didn't immediately notice the ability to "poke" the
inputs to change them. It's also mildly irritating that you have to
cycle through 0, 1 and Z.)
- You can't delete stuff, only add it. ;-)
- The selection marks look fine for 1-input gates, but for 2-input gates
it looks kinda weird having a box between the two inputs.
I was espectially ticked by the first two - but I didn't wanna sound
mean. ;-)
Date: 14 Jun 2010 10:36:30
Message: <4c163e6e$1@news.povray.org>
Crap! I must have screwed something up when building some of the other
items... That's a regression error. I'll have to take care of that.
Yeah, the sim isn't updating right now when the properties are altered.
There's reasons I'm not addressing this as of yet, mainly to do with the
fact that I'm going to rewrite the simulation core, and at that point it
won't matter how the property is altered.
Only if the input is 3-state do you have to cycle through the states.
Yeah, an annoyance for sure ... But, hey, pre-alpha. ;)
In truth I just haven't gotten around to coding some of the more trivial
things, yet.
The handles will eventually allow you to elongate the connecting pins,
and change orientation by drag on gates. Its not there yet. It might
make sense later, when it actually functions...
> mean. ;-)
No! This is good stuff! I need feedback like this Obviously I miss
things like this when coding the application.
~Mike
Date: 14 Jun 2010 10:45:22
Message: <4c164082$1@news.povray.org>
> Crap!
Uh, yes. ;-) That's a kind of elementary mistake, right there. (Which is
why I assumed you had already noticed it, but I guess not...)
Yah. ;-)
Well, yeah. The thing I'm writing is currently just a few miles of
function calls. It doesn't even *do* anything visible yet!
> things, yet.
Ain't that always the way? ;-)
Date: 15 Jun 2010 14:53:44
Message: <4c17cc38$1@news.povray.org>
I've just been prodding the 15-Jun build. I presume you know these
already, but...
Adding a tristate buffer works, but not a tristate inverter. Also,
neither the clock source nor the splitter work, but I guess that's
intensional.
For the first time, I tried actually wiring together a simple circuit.
Wiring seems to be quite buggy. Sometimes you join wires together and
they don't actually join. Sometimes they look like they aren't joined,
but when you connect the other end of the wire to something, suddenly it
works. And sometimes it's difficult to figure out just what on Earth is
going on. (Especially since you can't, say, delete the wires you've
already made. *g*)
Still, I've spent several days now just trying to build the internal API
to manage something like this, and I'm getting nowhere, rapidly...
http://blog.orphi.me.uk/
Date: 15 Jun 2010 15:52:15
Message: <4c17d9ef$1@news.povray.org>
>> Crap!
> Yah. ;-)
Well, the NAND = NOR thing was a total cluster****, I don't know what I
was thinking when I coded NAND. I have a feeling that code was probably
written at 1:00am on a Saturday morning. How it got by me testing it is
a total mystery. It was so obviously wrong for NAND.
The OR gate placing a NOR gate was interesting. I have a function that
checks the types and caches the last used values for later use. Since
OR, XOR and NOR all have the same basic drawing OR is the base class for
those, only changing a few minor details (such as the extra curve on the
input side of the XOR, and the output bubble on NOR), so, it would see
that it could be cast to an OR and consequently dump it into the
PreviousOrGate variable. Oops. I corrected the case with NOR, but
discovered XOR only after I uploaded the code.
Your own sim? How is it going? ( as far as the function calls go, I guess? )
>> trivial things, yet.
Yep.
~Mike
Date: 15 Jun 2010 15:59:32
Message: <4c17dba4$1@news.povray.org>
>>> Crap!
>> Yah. ;-)
Oh, one of *those*... ;-)
I generally just don't code anything at that hour. It never ****ing
works right anyway.
Heh, well, I did wonder. Actually, as I say, I just assumed that since
it was *so* wrong, you must already know about it but just haven't got
round to fixing it yet.
Pah. Mutable state is evil! ;-)
> guess? )
Very, very slowly. Like, I'm having trouble making it so that I can add
and remove wires and stuff efficiently and still be able to look up what
connects to what efficiently and...
(See my post about "highly redundant data structures.)
You, by comparison, have got something that *runs*. I'm still faffing
around with design choices.
Date: 15 Jun 2010 16:02:48
Message: <4c17dc68$1@news.povray.org>
> intensional.
Yep. Those aren't there yet.
> already made. *g*)
The problem, I think (aside from not being able to delete things...) is
kind of two-fold... Connecting the pins while on the surface seemed very
simple, some cases quickly become a royal PITA.... There are some
modifier keys in wiring that will cause some of the connection stuff to
behave differently, generally if it has an orange indicator, it should
be connected when you release the mouse button. The other half of it is
that it appears to have not connected because it doesn't always take the
characteristics of what you just connected it to until the other end is
connected to something else. This has more to do with the sim core, though.
There's also a major annoyance with-- for example-- altering the layout
of a circuit. You pull a wire from one location, leaving 2 wires
connected straight together, you then draw a new wire across that
junction (which happens to be invisible...) and it joins everything at
that intersection. One of the things I need to do is when reconciling
the wires, ensure any wires that are joined at the same angle get
consolidated into a single wire. After drawing wires for a few minutes I
was able to slice and dice a single wire into a dozen pieces. Nasty.
That happens with lots of things ;)
~Mike
