POV-Ray : Newsgroups : povray.off-topic : Interesting performance paper Server Time
1 Nov 2026 18:55:25 EST (-0500)
  Interesting performance paper (Message 1 to 39 of 39)
Subject: Interesting performance paper
Date: 12 Jun 2010 12:51:49
Message: <4c13bb25$1@news.povray.org>
Kind of like what Warp talks about w.r.t. cache lines, except with VM pages.
http://queue.acm.org/detail.cfm?id=1814327
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Subject: Re: Interesting performance paper
Date: 14 Jun 2010 05:24:52
Message: <4c15f564$1@news.povray.org>
> pages.
It's all just different levels of the memory hierachy.
It used to be that you had a block of RAM, all accessible in O(1) time.
Now you have virtual memory (which pretends to be RAM, but is orders of
magnitude slower), maybe three levels of cache (which pretends to be
RAM, but is orders of magnitude faster - except if it's another core's
cache, in which case it's *slower* than RAM again due to coherance
issues), and you could regard the CPU registers themselves as the
ultimate level-0 "cache".
The sad fact is, processors are now 1000x faster than they used to be,
but RAM is still roughly the same speed. And that means that if you
don't want your expensive new CPU to just spend 1000x more cycles doing
nothing, you need to have this memory hierachy. And *that* means that
the time complexity of your algorithm is now *irrelevant*. The *only*
thing that matters now is cache behaviour.
As the paper says, a stupid O(n^2) algorithm could be *faster* than a
sophisticated algorithm with O(log n) or even O(1) time-complexity, all
due to cache effects that shouldn't be there in the first place. Decades
of research and development ruined. Now we have no way to predict
performance, because it depends on cache behaviour, which intimately
depends on the specifics of a particular implementation, not on the
abstract properties of the algorithm used.
Possibly the worst part is that, unless you program in some horribly
low-level language, you have no control over any of this.
Date: 14 Jun 2010 10:16:16
Message: <4c1639b0@news.povray.org>
What you are referring to are mathematical papers, they do not consider
actual implementation on a machine, they are not meant to.  Computers have
always had different amounts of memory with different speeds and access
patterns, there are plenty of papers that take this into account.  You
cannot just take a mathematical paper and expect it to work as described on
a computer, you never have been able to.
> Now we have no way to predict performance, because it depends on cache
> behaviour, which intimately depends on the specifics of a particular
> implementation, not on the abstract properties of the algorithm used.
Sure, but it's always been like that and always will, there's nothing you
can do about it.
If your language/compiler is clever enough to switch around the order and
storage of your code, then it should be clever enough to optimise for the
memory structure of the machine.
Date: 14 Jun 2010 10:41:08
Message: <4c163f84$1@news.povray.org>
>> all due to cache effects that shouldn't be there in the first place.
>> Decades of research and development ruined.
> You cannot just take a mathematical paper and expect it to
> work as described on a computer, you never have been able to.
Back in the days of the 8-bit home computer, memory access really was a
constant-time operation that always took 1 clock cycle. Unfortunately it
seems that the larger a memory bank is, the slower it is to access. What
this means is that a 2.2 GHz CPU only runs at 2.2 GHz if you use a tiny
amount of data. If you try to random-access a large chunk of data,
suddenly the program slows down to the speed of the RAM bus.
I guess the only consolation is that my CPU's L3 cache is probably
bigger than the entire address space of the 6502...
> you can do about it.
It wasn't always like that - but, as you say, there's nothing you can do
about it.
> and storage of your code, then it should be clever enough to optimise
> for the memory structure of the machine.
Sure. But if it isn't, you can't do anything about it. You can't rewrite
the compiler, after all...
Date: 14 Jun 2010 11:07:58
Message: <4c1645ce$1@news.povray.org>
Am 14.06.2010 16:41, schrieb Invisible:
>> You cannot just take a mathematical paper and expect it to work as
(1) Home computers were toys.
(2) Capacity of memory basically has nothing to do with access speed.
The effect you describe for that 2.2 GHz CPU is the effects due to L1
and L2 caches - which aren't faster because they are smaller, but
because (a) they're closer to the CPU core and (b) they're using faster
(but more space-consuming) technology.
Date: 14 Jun 2010 11:12:55
Message: <4c1646f7@news.povray.org>
I saw at least one employee using a company-purchased C64 to run
accounting software to do actual, productive work.
They might be considered toys *now*...
Really? So having more bits to decode requiring more address decode
logic doesn't affect speed in any way? And neither does a larger die
area necessasitating longer traces?
I gather that part of the problem is that having traces on the
motherboard operating into the GHz frequency range isn't very feasible.
(For reasons such as trace length and electronic interference.) But that
would still mean that theoretically you could make a single chip that
contains a couple of CPU cores plus (say) 2GB of RAM. The fact that
nobody has ever done this indicates that it isn't possible for whatever
reason.
Date: 14 Jun 2010 11:37:32
Message: <4c164cbc@news.povray.org>
Sure, but just as an example, what's the fastest way to sort a 10 KB array
when you have 16 KB or RAM?  The mathematically efficient way won't
necessarily be the quickest if you need to read/write to tape/disc rather
than just using RAM.  Also some operations were free (eg shifting when
adding, other obscure things like that), a general mathematical paper won't
take that into account when telling you the "best" algorithm for a task.
>> can do about it.
So your early 8bit computer could write to the tape at the same speed as
RAM? :-O
If your compiler changes the order that data is stored, or the order you
access it, but doesn't take into account how this affects performance, then
IMO it's broken.  Use a different compiler that either leaves the order
alone (so you can optimise it yourself) or optmises it for you.
Date: 14 Jun 2010 11:45:55
Message: <4c164eb3$1@news.povray.org>
>> a constant-time operation that always took 1 clock cycle.
> array when you have 16 KB or RAM?  The mathematically efficient way
> won't necessarily be the quickest if you need to read/write to tape/disc
> rather than just using RAM.
Then you use a specialised external-sort. More to the point, you *know*
that you're going to need an external-sort. Your program doesn't just
magically run 500x slower than you'd expected.
> when adding, other obscure things like that), a general mathematical
> paper won't take that into account when telling you the "best" algorithm
> for a task.
Sure. But if one algorithm takes 5,000 operations (some of which might
be free) and another takes 72,000,000,000 operations, which one is
fastest? On the computers of old, the answer was self-evident. Today, it
might well be that the latter is actually faster.
> RAM? :-O
More like in the early days, if it didn't fit in RAM, you just couldn't
do it at all. Today if it doesn't fit in RAM, the OS makes the computer
pretend it has more RAM than it does (with the *minor issue* of a vast
slowdown and halving the life of your harddrive).
>> rewrite the compiler, after all...
> then IMO it's broken.  Use a different compiler that either leaves the
> order alone (so you can optimise it yourself) or optmises it for you.
How about if the order just plain isn't defined in the first place? Or
if the runtime system is storing auxhilery data which you don't know about?
Date: 14 Jun 2010 11:56:00
Message: <4c165110$1@news.povray.org>
No it's not. RAM used to take several microseconds. Drum memory was on the
order of miliseconds.
Only irrelevant if all the data you need fits in cache. If you have a 300Gb
data set like the paper says, your L1 cache isn't going to be nearly as
important.
Date: 14 Jun 2010 11:58:31
Message: <4c1651a7$1@news.povray.org>
Of course it does. You have speed-of-light delay and address line cascading
to decode. The slowness isn't due primarily to accessing the memory cells.
It's due to the cascade of gates you have to go thru to decode the address
to figure out which cell. That's why video memory can be so much faster than
CPU memory - there's an access pattern (the video beam scan) that can be
used to speed up address decoding.
Date: 14 Jun 2010 11:59:18
Message: <4c1651d6@news.povray.org>
What makes you think nobody has done this?
Date: 14 Jun 2010 12:27:57
Message: <4c16588d$1@news.povray.org>
> do it at all.
Not even close to true. People took it into account. You don't think
WordStar could handle a document >64K?  Indeed, the whole point of an
external sort was to handle what didn't fit in RAM.
Nowadays, people throw processing at it and let the OS handle paging.
And of course, you still get people dealing with the heirarchy explictly,
like google, who even deals with the heirarchy of "on a disk on the same
machine, on a disk on a different machine in the same rack, on a disk on a
machine in a different rack in the same building, on a disk on a machine in
a different building in the same state, etc."
Date: 14 Jun 2010 12:37:08
Message: <4c165ab4$1@news.povray.org>
Am 14.06.2010 17:12, schrieb Invisible:
I don't think so. Essentially, all you need to decode an address is a
huge AND gate with some inputs inverted (and no, multi-input gates are
/not/ normally designed as a tree of 2-input gates - they're simply
extend on the 2-input gate design by adding just a few inputs and
transistors more). Of course you need more of those gates, and therefore
stronger drivers for the address lines to deal with the parasitic
capacitance of the gates' inputs.
That, yes. But that's negligible compared with the distance between CPU
and memory slot.
AFAIK, the most time-consuming thing about DRAM is the time it takes to
charge, discharge or read out the capacitors comprising the memory cells.
> reason.
I guess it's impractical, because...
(1) RAM requirements are pretty different, so you'd need a lot more CPU
models (which would skyrocket the development, maintenance and
production set-up costs per CPU) - and you couldn't just buy a few extra GB.
(2) You wouldn't win much speed because DRAM technology is inherently
slow, and SRAM technology (as used in caches) is prohibitively large
(3) I might be wrong, but I guess producing DRAM memory in a 40nm
process would be ineffective: You do want certain minimum dimensions for
the capacitors and insulation anyway, in order to reduce self-discharge
effects.
(4) Integrating 2GB into the CPU would require a lot of additional die
space even with DRAM, increasing the per-die production cost - not only
because you get less CPUs out of a wafer, but also because increasing
the die space gives you an increased per-die probability of a failure,
reducing production yield.
Date: 14 Jun 2010 12:58:50
Message: <4c165fca$1@news.povray.org>
In theory true. In practice, there's a certain amount of fan-in you can
handle in any one gate.  The limit is about 8 inputs, afaik. My knowledge on
this particular bit is probably several fab generations out of date.
Date: 14 Jun 2010 13:38:51
Message: <4c16692b$1@news.povray.org>
Am 14.06.2010 18:58, schrieb Darren New:
> on this particular bit is probably several fab generations out of date.
Even then, you'd have some log8(N) dependency of gate levels needed,
where N isn't even the amount of memory, but the number of address lines.
1 level:   8 address lines - up to 256 words (*)
2 levels: 64 address lines - up to 16 Exawords
(* where the word size solely depends on your data bus width)
If main memory sizes should increase with the same speed as today, that
should give us another 20 to 30 years until a computer for private or
office use will need 3 levels of address decoding gates in its RAM modules.
Date: 14 Jun 2010 13:50:39
Message: <4c166bef$1@news.povray.org>
Am 14.06.2010 17:58, schrieb Darren New:
> cascading to decode. The slowness isn't due primarily to accessing the
> memory cells. It's due to the cascade of gates you have to go thru to
> decode the address to figure out which cell. That's why video memory can
> be so much faster than CPU memory - there's an access pattern (the video
> beam scan) that can be used to speed up address decoding.
If gates are so slow, how come SRAM is so much faster? After all, even
the memory cells themselves consist of gates there.
I guess the advantage of the access pattern in video memory is a
different one: It allows easy /prediction/ of the next address to fetch,
so readout of DRAM cells can be initiated well before the data is
actually needed, so it's available just in time - farewell latency.
Date: 14 Jun 2010 14:20:37
Message: <4c1672f5$1@news.povray.org>
Am 14.06.2010 17:45, schrieb Invisible:
>> tape/disc rather than just using RAM.
Which is just the point to learn from this: You should (ideally) know
that the very same is true for today's computers, so that you know where
such "magical" slowdowns come from, and what can be done against it.
> do it at all.
Nonsense. Datacenters have been using slow memory, such as magnetic
tapes, for ages. "If it all fits in RAM, then congratulations!" would
have been closer to the mark back then I guess.
I'd rather put it this way: Today, if it doesn't fit in RAM, the OS
helps you "juggling" the memory chunks to work on. (And if it doesn't
fit in L1 or L2 cache, the CPU provides essentially the same service.)
Which makes life much easier in a world where you don't know how much
RAM you'll have when programming the software. (Back then, you /did/
know the specs of the one machine you wrote your programs for.) Plus, it
allows much easier and faster (and therefore more economical) design of
software where runtime performance doesn't matter that much.
(As for harddrive life, I guess that depends on your harddrive.)
Date: 14 Jun 2010 14:26:08
Message: <4c167440$1@news.povray.org>
I'm not really following...
Except ... you need that fan-in for each word you address. Now you have a
problem of fan-out, as well, if I'm visualizing what you're saying correctly.
In theory, any logic function (including an entire CPU) can be built from
two levels of gates. In practice, the fan-in and fan-out kills you, because
you can't have 256 fan-outs going into each of 256 additional gates.
Date: 14 Jun 2010 14:27:25
Message: <4c16748d$1@news.povray.org>
Well, DRAM adds its own slowness, yes. But even with SRAM, having 16 gig of
SRAM is going to be slower than having 1 Meg of SRAM.
Date: 14 Jun 2010 14:35:00
Message: <4c167654$1@news.povray.org>
Well, there is that, yes. But I (and presumably everybody else) would
prefer it if we could actually make RAM really, really fast...
If stuff is being swapped out just because it isn't being used right
now, that's fine. But watch a program trying to random-access several GB
of data when you don't have multiple GB of RAM. It's an extremely
efficient way to give your HD a *very* strenuous workout! ;-)
http://blog.orphi.me.uk/
Date: 14 Jun 2010 15:19:22
Message: <4c1680ba@news.povray.org>
Am 14.06.2010 20:34, schrieb Orchid XP v8:
>> it allows much easier and faster (and therefore more economical)
>> design of software where runtime performance doesn't matter that much.
... which will never ever again happen for main memory, at least not in
the sense of being equally fast as whatever caches we'll be using then:
We'll always have to live with memory being arranged in multiple tiers
of different speed.
Sure, but some HDs are designed for this type of life.
BTW, it's not harddrive life that worries me in such situations, but the
bare struggle to get the system's attention back. Try killing a
swapping-mad program when it keeps thrashing the task manager out of
main memory... >_<
Date: 14 Jun 2010 15:29:18
Message: <4c16830e$1@news.povray.org>
> main memory... >_<
Heh. Fun... Actually, the one I usually have trouble with is Alt+Tab
from a game back to the Windows desktop. Takes several lifetimes in both
directions. No idea why.
One thing I discovered back at uni: If your Java program accidentally
goes into an infinite loop, it dies almost instantly with a stack
overflow. If your Smalltalk program accidentally loops forever, it's
usually a few minutes before you realise that it's actually filling the
entire VM address space with garbage. Now try stopping it. :-)
Literally, it's so determined to follow your instructions as efficiently
as possible that for a while you don't even realise what's wrong. It
just looks like it's "busy".
Of course, infinite loops are much, much more common in Smalltalk. A
very common idiom is to write
#new
   super new.
   ...stuff...
But if, by some slip, you instead write
#new
   self new.
   ...stuff...
...then calling #new immediately calls #new, creating an endless
allocation loop. o_O
Date: 14 Jun 2010 17:40:01
Message: <web.4c16a0dd7fcd67b84f28787e0@news.povray.org>
> overflow.
That's just because the VM only claims a small amount of RAM to start with...
quite irritating actually, it took me ages to work out I had to increase its
allocation to get my fractal plotter to be able to hold a decent image :-)
(but then it was too slow anyway so I rewrote it in C)
Date: 14 Jun 2010 18:03:13
Message: <4c16a721$1@news.povray.org>
> main memory... >_<
Hell, even if it's just copying big files, you have the same problem.
Date: 15 Jun 2010 04:03:20
Message: <4c1733c8$1@news.povray.org>
Au contrare, what makes you think that somebody *has* done this?
Date: 15 Jun 2010 04:07:23
Message: <4c1734bb$1@news.povray.org>
>> overflow.
Smalltalk seemed to be very, very good at handling large amounts of
objects in RAM. It didn't complain or anything, it just got on with it.
Unfortunately, usually the only reason for this happening was programmer
error. :-/
Haskell (or rather, GHC) is similar. It will happily eat several GB of
VM very quickly. The difficulty isn't figuring out how to allocate
enough space; it's finding the magic CLI switch that tells it to quit
rather than eat all available RAM!
(There's a switch that makes it die if the program tries to allocate
more than X. If you happen to know that your program can only possibly
require a few MB, set this switch and if there's a bug, the program will
die rather than kill you.)
Date: 15 Jun 2010 04:09:19
Message: <4c17352f@news.povray.org>
In other news... I get the impression that the world is probably heading
towards NUMA anyway. Not sure precisely how that changes the picture -
other than making it much, much more complicated...
(I'm not sure, but I think it might mean that you have explicit control
over what is stored where and when it gets moved, which could be a win
if compilers are smart enough to do the right thing.)
Date: 15 Jun 2010 11:00:02
Message: <4c179572@news.povray.org>
You just go and do it. I'm sure the sorting algorithm fits in the remaining
6KB.
Or did you get those two numbers backwards?
Date: 15 Jun 2010 11:59:01
Message: <4c17a345$1@news.povray.org>
Well, two gig is a bit high, but several hundred meg is not uncommon.
Date: 15 Jun 2010 13:11:11
Message: <4c17b42f@news.povray.org>
Like I said, it seems there's a relationship between capacity and speed,
such that by the time you get to this size, there wouldn't be much speed
advantage to putting it on-chip.
Date: 15 Jun 2010 14:46:29
Message: <4c17ca85@news.povray.org>
In all the cases I know about, the problem was not that, but that there was
a concern that there was a cap on the amount of memory.
Either you need X meg of memory to do what your chip is designed to do, or
you want an arbitrary "lots" of memory. (E.g., you're either building a
phone that doesn't run apps not installed when you built it, or you want to
run as many apps at once as you want.)  If you ever want to add RAM, you
need to have the interface stuff for it anyway.  If you don't ever want to
add RAM, chances are you don't need more than a few hundred meg to support
your single-chip application.
Date: 15 Jun 2010 15:07:05
Message: <4c17cf59@news.povray.org>
On 6/14/2010 2:29 PM, Orchid XP v8 wrote:
>> the bare struggle to get the system's attention back. Try killing a
>> main memory... >_<
You can do it in C#, too .. I forget exactly what I was writing, but I
threw something into an infinite loop that allocated objects and added
them to a list. A split second after I hit F5 to run the program, I
realized my mistake. That was enough time for it to allocate some 4GB of
memory, By the time I reacted to stop the program it had ballooned up to
10GB.
64 bit is great, but try dealing with that sort of memory stress (My
system has 4GB of memory ...)
~Mike
Date: 15 Jun 2010 15:10:00
Message: <4c17d008$1@news.povray.org>
Generally that kind of thing isn't so bad though. All the garbage that
gets paged out never gets paged back in again. Assuming you can page in
the code to stop the damned thing, once it's been killed the system
takes a little while to page all the live stuff back in, and then it
goes back to normal.
Now, when your program is actively *using* several GB of RAM... that's
not so fun. (!!)
Date: 15 Jun 2010 16:15:31
Message: <4c17df63$1@news.povray.org>
> not so fun. (!!)
Photoshop did this ... I was building an image out of a stack of shots
with several shots at full resolution 16-bit per channel color. The
algorithm that determines which parts were in sharpest focus apparently
set out to spread itself out as much as possible in memory.
I walked away for a few minutes after starting the process, came back
and tried to switch to my browser, and found the system unresponsive. It
stayed that way for about 30 min before task manager finally appeared.
Again, 10GB of memory, but actively working with that 10GB. I had other
stuff I hadn't saved yet, and wanted a chance to save, so I waited ....
before I killed PS.
~Mike
Date: 15 Jun 2010 16:18:36
Message: <4c17e01c$1@news.povray.org>
>> not so fun. (!!)
> before I killed PS.
Pff. Accidentally write some Haskell code with the wrong strictness
properties and watch it swallow several *hundred* GB by mistake... It's
not even funny.
Usually very easy to kill though, if that's any consolation. (The key,
as I said, is to set the maximum heap size to something smaller than
physical RAM - especially if you know your program isn't supposed to
need lots of RAM anyway...)
Date: 15 Jun 2010 16:45:59
Message: <4c17e687$1@news.povray.org>
Sometimes when you kill a big process, it actually does have to read
everything back in, to run finalizers or whatever, and to generally
deallocate memory.  It's not unusual to hit ctrl-C on a CLI-driven program
and have it take a minute or more to exit even if you're not catching signals.
Date: 16 Jun 2010 04:00:19
Message: <4c188493$1@news.povray.org>
> program and have it take a minute or more to exit even if you're not
> catching signals.
I haven't seen that problem with programs I've written myself (which
obviously don't use finalisers), but I've seen other software do this...
Date: 16 Jun 2010 04:31:30
Message: <4c188be2$1@news.povray.org>
>> array
> remaining
> 6KB.
Actually I was thinking about algorithms that are not in-place (eg radix
sort).  Whilst in a mathematical sense they might seem to be faster, if you
start having to use slower storage (where some other algorithm doesn't) then
obviously this might no longer be the case.
Date: 28 Jun 2010 06:57:02
Message: <4c287ffe$1@news.povray.org>
>> overflow.
Actually, I think this is probably bogus.
Any object data goes in the heap, not the stack. A *stack* overflow
indicates a sequence of method calls nested too deeply.
Heck, Haskell programs (more exactly, GHC-compiled Haskell programs)
often die from a *stack* overflow very quickly. But they don't die from
*heap* exhaustion (unless you set the magic flag).
