POV-Ray : Newsgroups : povray.off-topic : Lane hoggers - how to deal with them? Server Time
17 Oct 2026 23:01:32 EDT (-0400)
  Lane hoggers - how to deal with them? (Message 1 to 50 of 108)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Lane hoggers - how to deal with them?
Date: 7 Jun 2010 04:26:53
Message: <4c0cad4d@news.povray.org>
(Note left/right here is for driving on the right, for driving on the left
countries reverse the left/rights).
Here we have two important rules for multi-lane roads, one is that you
should only move out to the left to overtake someone, and secondly you are
not allowed to pass anyone on the right side (there are some exceptions for
queues etc).  I know it's not like this in all countries.
As anyone who has driven probably knows already, the problem comes when
someone stays in the left lane when they are not overtaking anyone and you
want to go faster than them.  What are you meant to do if you are behind
them in this situation?  What if you are directly behind in the same lane,
or what if you approach them in the right lane?
I always wanted to ask someone in authority this question as appears there
is no perfect option.
For me I usually wait around 5 seconds behind them in the same lane, then
usually pull over to the right lane and wait there for a further 5-10
seconds leaving them plenty of space to pull over if they want.  If they
still do not move then I usually accelerate and swiftly pass on the right
being ready to move over into the hard shoulder if they suddenly decide to
change lanes.
My girlfriend says that I should flash them and not overtake on the right,
but IME this is easily interpretted as quite aggressive behaviour and could
lead to more problems (eg them still not moving over or even worse
deliberate braking or other aggressive behaviour).
What do you do?
Subject: Re: Lane hoggers - how to deal with them?
Date: 7 Jun 2010 04:39:19
Message: <4c0cb037@news.povray.org>
> right, but IME this is easily interpretted as quite aggressive behaviour
> and could lead to more problems (eg them still not moving over or even
> worse deliberate braking or other aggressive behaviour).
> What do you do?
IMO your girlfriend is right, undertaking is wrong. It seems the fashion
ATM is to indicate you are going to overtake and if the driver is nor
paying attention a short flash of your headlights generally does the trick.
Best Regards,
Date: 7 Jun 2010 06:00:00
Message: <web.4c0cc140b36819a6dd25f0b0@news.povray.org>
> > What do you do?
While I agree that undertaking is against the rules, I tend to do pretty much
what Scott does. Except that I keep going without any change in my speed, albeit
with a greater degree of alertness for sudden feckless lane-changes. My
reasoning is that it's probably safer to undertake than attempt multiple
lane-changes on a busy road (no other sort around here!)... and you never know,
maybe a 20-year-old 1.1L banger undertaking them will make it even more obvious
that they're in the wrong lane... :)
I strongly suspect that in the majority of cases, it is not simple
absent-mindedness but a deep-seated and utter lack of a) understanding of the
rules and b) common sense. MI5-issue wheel-laser on order.
Bill
Date: 7 Jun 2010 07:54:51
Message: <4c0cde0b@news.povray.org>
>> What do you do?
> trick.
Yes, I went through a phase of doing this, and most of the time it does
work.  I put this down to the fact that most of the drivers doing this are
just not thinking and totally unaware of what is going on around them, a
quick flash lets them know you are there, and then they know the correct
thing is to pull over.
But, I had a couple of occasions where my flash was interpreted as an
aggressive gesture, and the driver ahead reacted accordingly.  In one case
he didn't move over but gradually slowed down, in the other case he moved
over, but just as I was about to pass he swerved back in front of me causing
me to brake hard.  Since then I stopped flashing people to avoid risking
something like that happening again.
Date: 7 Jun 2010 08:22:42
Message: <4c0ce492@news.povray.org>
> case he didn't move over but gradually slowed down, in the other case he
> moved over, but just as I was about to pass he swerved back in front of
> me causing me to brake hard.  Since then I stopped flashing people to
> avoid risking something like that happening again.
Maybe it wasn’t the flash that was interpreted as an aggressive gesture.
How close were you driving to the car?
Tailgating is one of the things that irritate me most.
My worst habit is “hogging” the centre lane on three lane roads. I just
refuse to drive in the slow lane when I know that every couple of
minutes I will have to pull out and cross at least one lane.
Best Regards,
Date: 7 Jun 2010 08:28:01
Message: <4c0ce5d1@news.povray.org>
scott wrote:
> What do you do?
I've had a few problems with the CLOC. (Center Lane Owners Club.)
Annoying, isn't it? Still, sometimes there just isn't a lot you can do.
Date: 7 Jun 2010 08:48:40
Message: <4c0ceaa8$1@news.povray.org>
Yeh me too, personally I have two distances that I usually use.  One for "I
am happy to go the same speed as you", which I guess is around a 4 second
gap.  The other is "i want to go faster, please move over when you can", but
it certainly is not anything close to tailgating, usually still the largest
gap on the road!
> refuse to drive in the slow lane when I know that every couple of minutes
I don't mind people doing that, as long as it is not so busy that they are
causing people behind to slow down unnecessarily (when people in lane 2 have
to either brake or pull out into lane 3 thus causing people already in lane
3 to brake).  The worst is when you come up behind a middle-lane hogger, you
can't overtake on the correct side because there's a train of cars going
20mph faster than you, and the "slow" lane is empty, thus you have to slow
down and wait for no reason or perform an illegal undertake.
BTW there's nothing wrong with changing lanes every couple of minutes, most
autobahns here away from the cities are 2-lanes, and unless you drive 50 or
150 mph you'll be changing lanes usually at least once a minute.
Date: 7 Jun 2010 08:51:04
Message: <4c0ceb38$1@news.povray.org>
>> What do you do?
On 3-lane roads it less of a problem (I've very rarely seen an outside lane
hogger on a 3 lane road that wasn't going really fast), you can usually
overtake CLOCs eventually without issue.
Date: 7 Jun 2010 09:05:00
Message: <web.4c0ced81b36819a6dd25f0b0@news.povray.org>
> gap on the road!
The worst is when you leave a gap and someone pulls up and slides into it, like
"ooh a couple of feet clearance, that'll do". It's not their gap, it's mine!
Date: 7 Jun 2010 09:14:01
Message: <4c0cf099@news.povray.org>
>> gesture. How close were you driving to the car?
> "I am happy to go the same speed as you", which I guess is around a 4
> second gap. The other is "i want to go faster, please move over when you
> can", but it certainly is not anything close to tailgating, usually
> still the largest gap on the road!
My definition of tailgating is when I can’t see the front wheels of the
car behind, in my rear view mirror. The other thing I forgot to mention
are those drivers who overtake you and pull in about 4 feet in front of you.
>> just refuse to drive in the slow lane when I know that every couple of
> are causing people behind to slow down unnecessarily (when people in
> lane 2 have to either brake or pull out into lane 3 thus causing people
> already in lane 3 to brake).
Right.
> middle-lane hogger, you can't overtake on the correct side because
> there's a train of cars going 20mph faster than you, and the "slow" lane
> is empty, thus you have to slow down and wait for no reason or perform
That is inconsiderate. :-(
> most autobahns here away from the cities are 2-lanes, and unless you
> drive 50 or 150 mph you'll be changing lanes usually at least once a
> minute.
Yes every couple of minutes is OK, I was being imprecise. It is the car
that is travelling at 80 – 90 mph (at least) in the LH lane that pulls
out into the RH lane. Overtakes and returns into the LH lane only to
repeat the manoeuvre 10 seconds later that gets on my wick.
Best Regards,
Date: 7 Jun 2010 09:25:03
Message: <4c0cf32f$1@news.povray.org>
scott wrote:
>>> What do you do?
> lane hogger on a 3 lane road that wasn't going really fast), you can
> usually overtake CLOCs eventually without issue.
The fun happens when you have a CLOC travelling at 50, so some truck
decides he wants to overtake it at 55. So you now have the CLOC blocking
the middle lane, and the truck blocking the fast lane.
I've seen it result in utter mayhem as a huge queue develops in the fast
lane, and in the middle lane because people haven't grabbed the fast
lane soon enough, and *then* some rich twat in his expensive BMW comes
along and undertakes along the slow lane and then tries to dice around
with the traffic merging from the correct side...
All this trouble and strife just because some foreigner doesn't know how
to drive properly. :-P
Actually, I recall that on my driving theory test, one of the questions
was about this. Something like "which lane do you use?" and the options
were "any lane", "the lane with the least traffic in it", "the left
lane" or "the left lane except when overtaking". If you didn't know,
some of those other options do actually sound plausible... I guess a lot
of people don't know. (Or just aren't paying attention to where they're
going...)
Date: 7 Jun 2010 09:37:07
Message: <4c0cf603$1@news.povray.org>
> left countries reverse the left/rights).
> are not allowed to pass anyone on the right side (there are some
> exceptions for queues etc).  I know it's not like this in all countries.
> you want to go faster than them.  What are you meant to do if you are
> behind them in this situation?  What if you are directly behind in the
> same lane, or what if you approach them in the right lane?
> there is no perfect option.
> then usually pull over to the right lane and wait there for a further
> 5-10 seconds leaving them plenty of space to pull over if they want.  If
> they still do not move then I usually accelerate and swiftly pass on the
> right being ready to move over into the hard shoulder if they suddenly
> decide to change lanes.
> What do you do?
I am not aware of any law in my jurisdiction prohibiting passing on the
right, so that's what I would do.  If the lanehog thinks this is rude,
then maybe he/she/it ought to learn some manners and make the maneuver
unnecessary.
And why should passing on the right be any more dangerous than passing
on the left?  Drivers are supposed to check for other vehicles when
performing any lane change.
My peeve has always come on portions of divided highways where there are
two lanes in each direction:  The driver being passed is going at a
certain speed (say, 60 mph), and the driver who is passing is going just
slightly above that speed (say, 60.1 mph), so that by the time he gets
past and goes into the non-passing lane (if he does), I and a dozen
others are backed up behind him.
John
Date: 7 Jun 2010 09:44:26
Message: <4c0cf7ba$1@news.povray.org>
Extra fun: Some guy is doing 65 MPH, so you go to overtake. But as soon
as you do this, the driver wakes up and decies to speed up. And no
matter how fast you go, you can't get past.
Date: 7 Jun 2010 09:49:16
Message: <4c0cf8dc@news.povray.org>
Yep, Somebody parked on my bumper and flashing their headlights are not
going to get the desired result from me.
It's a bit annoying when someone rides your bumper as you're in the
passing lane and overtaking. I generally don't have a desire to drive
80mph down the road, but I also don't want to be stuck by the ninny
driving 60mph when the speed limit is 70mph.
What's worse is when you're stuck behind someone driving at 50mph, and
the fast lane is  moving at 80mph.
Eh, my view on it is this for 3 lanes each way:
* The left lane is passing. Use this to overtake, don't hang out for too
long, get back over when it is safe to do so.
* The right lane is for vehicles entering/exiting the freeway. Hanging
out in this lane means you'll need to deal with those who don't seem to
want to merge at the flow of traffic.
* The center lane is best for general driving. Provided you move to the
right well before your exit comes up so you're not cutting someone off.
On a related note:
* The acceleration lanes for entering the freeway ARE NOT PASSING LANES.
DO NOT ATTEMPT TO PASS VEHICLES IN THIS LANE. You'll run out of road and
cut off the vehicle you're passing, or worse. This is my biggest pet
peeve, and has happened numerous times at one particular spot on the way
home. I actually had one kid try to run me off the road after blasting
my horn at him for nearly taking out my front bumper as he attempted
this maneuver.
Anyhoo ... back to better subjects.. ;)
~Mike
Date: 7 Jun 2010 10:04:23
Message: <4c0cfc67$1@news.povray.org>
> you.
So long as they are going faster than me (so the gap is increasing) I don't
mind that so much.  Another thing which is funny is the people who overtake
you, pull back in, and then slow down forcing you to overtake them back!
> that is travelling at 80 – 90 mph (at least) in the LH lane that pulls out
> into the RH lane. Overtakes and returns into the LH lane only to repeat
Yeh that's an unnecessary risk to take, generally if I can see that nobody
is behind me I don't pull back over unless it is quite a big gap (ie I
wouldn't actually be overtaking anyone for the next 2 minutes).  If there is
a car behind me I usually try to estimate how quickly he will pass me if I
move over (you can usually tell quite well from how quickly they approached
you).  If the driver is obviously wanting to go pretty quickly and looks
like he has a powerful car then I'll move over into a quite a small gap,
knowing that I can probably pull back out again pretty soon without having
to slow down at all.
Date: 7 Jun 2010 10:07:24
Message: <4c0cfd1c@news.povray.org>
Also, you are meant to ACCELERATE in these lanes!  On Saturday I followed a
car that stayed at a steady 40-50 km/hr and attempted to join a pretty empty
autobahn where the cars were doing ~120 km/hr.  When you're stuck behind one
of these people there isn't much you can do, and you will be the one who
gets the horn blast and flashing lights for pulling out so slowly.
Date: 7 Jun 2010 10:10:38
Message: <4c0cfdde@news.povray.org>
> were "any lane", "the lane with the least traffic in it", "the left lane"
> or "the left lane except when overtaking". If you didn't know, some of
> those other options do actually sound plausible... I guess a lot of people
> don't know. (Or just aren't paying attention to where they're going...)
Thing is, you can get that question wrong and never drive on a motorway, let
alone have these things explained to you, then you get your full driving
license.  It's no wonder so many people get it wrong.
Date: 7 Jun 2010 10:14:35
Message: <4c0cfecb@news.povray.org>
> past and goes into the non-passing lane (if he does), I and a dozen others
IIRC we recently got a law here that said you are not allowed to overtake
for longer than 45 seconds.  It's meant for trucks (they are all physically
limited to 90 km/hr in Europe) but I think it applies to cars too.
As usual though, I doubt it will ever get enforced, the police much prefer
to just leave a speed camera for a day so they can go off and do other
stuff.
Date: 7 Jun 2010 10:14:55
Message: <4c0cfedf$1@news.povray.org>
> let alone have these things explained to you, then you get your full
> driving license.  It's no wonder so many people get it wrong.
They say that air travel is statically the safest way to travel. And it
is! Think about it: Any random weirdo can apply and get a provisional
driving license and go drive around (theoretically with a qualified
driver supervising them) the same day. WTF is *that* about??
By contrast, becoming a commercial aviation pilot takes years. And there
has to be two of you. And the entire plane undergoes regular mechanical
checks. (Theoretically you're supposed to check your tires every time
your drive your car. HOW MANY PEOPLE DO THIS??) And you've got air
traffic control directing you. And... get the picture?
Date: 7 Jun 2010 10:43:02
Message: <4c0d0576$1@news.povray.org>
scott wrote:
>  which I guess is around a 4 second gap.
Four seconds *is* tailgating at any speed where you're worried about going
faster.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 7 Jun 2010 10:45:08
Message: <4c0d05f4$1@news.povray.org>
scott wrote:
> you're stuck behind one of these people there isn't much you can do,
Look ahead, recognise it, fall back before you even get to the ramp, and let
the bozo get into traffic before you hit the gas yourself to get up to speed.
Date: 7 Jun 2010 10:47:16
Message: <4c0d0674$1@news.povray.org>
Yep. Or on a road with restricted passing, and going uphill you can't pass
but going downhill you can, and the bozo decides he'll just press the pedal
the same regardless of how steep a hill he's going up or down.
Date: 7 Jun 2010 12:06:47
Message: <4c0d1917$1@news.povray.org>
> let the bozo get into traffic before you hit the gas yourself to get up to
> speed.
The problem is on this particular on-ramp there is quite a sharp corner
right before it, where the normal speed is about 50-60, so at this point I
had no idea the person wasn't going to accelerate out of the corner as
usual.
But yes, I try to use that method whenever possible.
Date: 7 Jun 2010 12:18:17
Message: <4c0d1bc9@news.povray.org>
> I had no idea the person wasn't going to accelerate out of the corner as
> usual.
Yep, we have that here too. And it's uphill, and a blind curve (well, blind
given it's a 70MPH expressway) for the people not merging, and the merge
length is only a few car lengths, and there's an exit right after that
people on the expressway are angling towards too.
I've learned to watch the goobers even before getting to the ramp, and I've
learned to hang back anyway in case.  But I try to avoid that ramp when I
have a choice, too, just because it's so poorly engineered.
Date: 7 Jun 2010 12:30:47
Message: <4c0d1eb7$1@news.povray.org>
> What do you do?
I typically give the left lane drive plenty of room - I do not like to
tailgate.  Then when I see they have lost and lots of room to move over
I will creep up slightly and if the do not move over I will flash my
lights.  Usually that works without trouble.  If they still do not move
over I will move over and undertake - tho I loathe doing it - but at
times there is little other choice.
I am frustrated by people who immediately try to undertake at the
earliest opportunity - I will get out of their way, when it is safe to
move over where I am not too close to the car I just passed.
Those who drive in the undertaking lane are causing a traffic hazard.  I
find it ironic that a lot of them think they are making things safer -
"I am going fast enough and anyone who passes is an idiot that is going
to cause an accident."  Yet they do not realize that they themselves are
causing that 'idiot' to make risky moves that can endanger lives of
everyone around.
My philosophy is to respect all other drivers on the road.  Give them
plenty of room and move out of their way when practical and safe.  I
don't care how fast someone drives - it's just how they drive and react
to others on the road.
Date: 7 Jun 2010 12:49:47
Message: <4c0d232b@news.povray.org>
Are you sure? About the 'only', I mean.  New York State Law does say
that the driver of an overtaken vehicle shall give way to the right in
favor of the overtaking vehicle on audible signal, 'except when
overtaking and passing on the right is permitted' (which it probably is
in the situations you are describing)
and secondly you
In NY traffic Law the notion of 'safely' comes into it.  So if you
cannot pass to the right 'safely' then you cannot do it.  But in
general, if there are two or more unobstructed traffic lanes in the same
direction, you are allowed to pass on the right. (Got a copy of Vehicle
& Traffic Law for State of New York right in front of my eyes here, it's
Section 1123)
> What do you do?
I would pass safely to the right unless I really needed that lane to
exit or turn, in which case I would just follow the other car.  Which
brings up something you haven't factored in.  Certainly around metro NY
multi-lane roadways are complex to the point where drivers cannot assume
that the left lane will function solely as a passing lane for any great
distance.  You constantly have traffic entering or exiting the roadway
from the left, and navigating here is often about lane choice well in
advance of a maneuver you want to make.
In the hyper-pressurized driving conditions around NYC one common
practice is to give a soft waring toot before passing, if the
circumstance seems a little unconventional, (ie. to the right in some
situations,) or potentially dangerous in some way.
Date: 7 Jun 2010 13:02:23
Message: <4c0d261f$1@news.povray.org>
you can read Section 1123 here:
http://ypdcrime.com/vt/article25.htm
Date: 7 Jun 2010 13:28:26
Message: <4c0d2c3a@news.povray.org>
I've found this thread quite interesting; I learned that one should never
undertake (never heard it called that before; "pass on the right" is how
it was explained to me), and so I try to avoid doing that myself.
I agree with your philosophy, though, and I wish more people held that
idea.  When driving a ton or more of metal at 65+ MPH on the freeway, a
little respect goes a long ways towards saving lives.
Jim
Date: 7 Jun 2010 13:56:26
Message: <4c0d32ca@news.povray.org>
Undertaking implies death and shows disapproval. I never do it.
LOL In the UK doing a ton means driving at 100 mph.
Best Regards,
Date: 7 Jun 2010 14:00:29
Message: <4c0d33bd$1@news.povray.org>
It used to be customary here to beep or flash your lights when passing a
heavy goods vehicle. I don’t know if people still do it.
Best Regards,
Date: 7 Jun 2010 14:35:54
Message: <4c0d3c0a$1@news.povray.org>
>> LANES. DO NOT ATTEMPT TO PASS VEHICLES IN THIS LANE.
> a car that stayed at a steady 40-50 km/hr and attempted to join a pretty
> empty autobahn where the cars were doing ~120 km/hr. When you're stuck
> behind one of these people there isn't much you can do, and you will be
> the one who gets the horn blast and flashing lights for pulling out so
> slowly.
Gah!  Yet another peeve... but, yeah. Needless to say merging onto a
70mph road at 50mph is not going to win you any friends.
~Mike
Date: 7 Jun 2010 14:38:58
Message: <4c0d3cc2$1@news.povray.org>
>> never undertake (never heard it called that before; "pass on the right"
>> is how it was explained to me), and so I try to avoid doing that
>> myself.
LOL, I missed that definition entirely. :-)
Interesting, I didn't know that. :-)
Jim
Date: 7 Jun 2010 14:40:28
Message: <4c0d3d1c$1@news.povray.org>
Same here - I flash my lights (when an 18-wheeler is looking to move
over, for example), and I occasionally flash my lights with 'normal'
traffic, but that's pretty rare unless someone seems to be being almost
intentionally stubborn about moving over.
I rarely use the horn.
Jim
Date: 7 Jun 2010 14:51:02
Message: <4c0d3f96$1@news.povray.org>
>> the car behind, in my rear view mirror. The other thing I forgot to
>> mention are those drivers who overtake you and pull in about 4 feet in
>> front of you.
> don't mind that so much.
Right!
> overtake you, pull back in, and then slow down forcing you to overtake
> them back!
You call that funny?
LOL
>> car that is travelling at 80 – 90 mph (at least) in the LH lane that
>> pulls out into the RH lane. Overtakes and returns into the LH lane
>> only to repeat the manoeuvre 10 seconds later that gets on my wick.
> nobody is behind me I don't pull back over unless it is quite a big gap
> (ie I wouldn't actually be overtaking anyone for the next 2 minutes). If
> there is a car behind me I usually try to estimate how quickly he will
> pass me if I move over (you can usually tell quite well from how quickly
> they approached you). If the driver is obviously wanting to go pretty
> quickly and looks like he has a powerful car then I'll move over into a
> quite a small gap, knowing that I can probably pull back out again
> pretty soon without having to slow down at all.
Good driving IMO.
Best Regards,
Date: 7 Jun 2010 15:06:35
Message: <4c0d433b@news.povray.org>
Too true ;-)
You don't? < 10 mph over the speed limit seems to be OK here, even from
the Polis
Borrow Bill's MI5-issue wheel-laser, ;-)
Do you remember the toy that made machine gun and Ray Gun noises that
fitted on your dashboard?
I think that you are allowed to beep your horn in that case.
> [Snip]
That is exactly how I view it. (If you read left for right)
> On a related note:
> this maneuver.
I’ve been doing a lot of 200 plus mile journeys on motorways, this last
year.
I’ve noticed our two lane slipways are now segregated (by white lines)
so that outside lane joins the motorway first and the inside lane joins
about a quarter of a mile later.
Best Regards,
Date: 7 Jun 2010 15:09:21
Message: <4c0d43e1@news.povray.org>
O_O ???
Best Regards,
Date: 7 Jun 2010 15:13:20
Message: <4c0d44d0$1@news.povray.org>
> O_O ???
Not *that* horn, the one in the car. ;-)
(Largely because of where the switches are positioned - by the time I
remember, the moment has passed)
Jim
Date: 7 Jun 2010 15:30:28
Message: <4c0d48d4$1@news.povray.org>
>> O_O ???
LOL I know that feeling ;-)
Best Regards,
Date: 7 Jun 2010 16:00:46
Message: <4c0d4fee$1@news.povray.org>
I used to get frustrated when I went to honk the horn and found I was
just pressing on the airbag. ;-)
Jim
Date: 7 Jun 2010 16:11:49
Message: <4c0d5285@news.povray.org>
Oh! You’re still talking about cars. ;-)
Best Regards,
Date: 7 Jun 2010 16:13:10
Message: <4c0d52d6$1@news.povray.org>
Indeed - I don't want to know where your switches are located. ;-)
Jim
Date: 7 Jun 2010 16:17:40
Message: <4c0d53e4$1@news.povray.org>
On 07/06/2010 9:13 PM, Jim Henderson wrote:
> Indeed - I don't want to know where your switches are located.;-)
'Nuff said.
Best Regards,
Date: 7 Jun 2010 16:21:18
Message: <4c0d54be$1@news.povray.org>
> the Polis
Depends on the city, really. I generally try to keep it 5 or less over.
10 over can be pushing it if you have a city that's particularly
interested in using the highway as a revenue stream
I think I do... :)
I'm sure its permissible... But this is Texas, and Texans lurrrve their
guns. :)
~Mike
Date: 7 Jun 2010 16:37:59
Message: <4c0d58a7$1@news.povray.org>
I think you just found the switch to the overshare light.
Date: 7 Jun 2010 16:40:59
Message: <4c0d595b$1@news.povray.org>
>> the Polis
Our Motorways don't belong to cities.
> I think I do... :)
You must be old :-P
> guns. :)
F*ck! I forgot that. :-)
Best Regards,
Date: 7 Jun 2010 16:48:29
Message: <4c0d5b1d$1@news.povray.org>
Whatever turns you on...
http://blog.orphi.me.uk/
Date: 7 Jun 2010 16:51:31
Message: <4c0d5bd3$1@news.povray.org>
Here the city can patrol any road that passes through it for traffic
infractions. regardless of who maintains it.
>> I think I do... :)
> You must be old :-P
Not that old! And I was a mere kid when those things came out. :)
>> guns. :)
heh...
~Mike
Date: 7 Jun 2010 17:36:54
Message: <4c0d6676$1@news.povray.org>
We have a separate branch of the police for road traffic, similar I
suppose to your highway patrol.
>>> I think I do... :)
>> You must be old :-P
>>> guns. :)
> heh...
Don't you mean "He Haw" :-)
Best Regards,
Date: 7 Jun 2010 18:25:01
Message: <web.4c0d70e6b36819ac26879a20@news.povray.org>
> > slowly.
As an aside, on the few occasions I've driven in the US, I was amazed how short
the acceleration/deceleration lanes were for exits... this was in the MA/NH area
so I don't know if it's the same everywhere. Our slips roads in the UK are often
3x as long!
Date: 7 Jun 2010 18:47:03
Message: <4c0d76e7$1@news.povray.org>
It depends if the roads were built after the surrounding area was built up.
Most ramps are plenty long enough, unless it would mean tearing up
historic[*] buildings or something to give the room.
[*] Historic for the USA, of course.
