POV-Ray : Newsgroups : povray.off-topic : Hungarian notation Server Time
17 Oct 2026 23:02:37 EDT (-0400)
  Hungarian notation (Message 1 to 23 of 23)
Subject: Hungarian notation
Date: 4 Jun 2010 15:51:08
Message: <4c09592c$1@news.povray.org>
OK, I officially hate it.
In this crap codebase, people used a bunch of hungarian notation, then
changed types around without fixing all the names.
So we have bunches of declarations like
   char * ulXYZ;
   unsigned char ulPDQ;
   long* pszABC;
Gah. It's worse than useless noise. It's useless wrong noise, that even
makes the useful noise suspect enough to be useless.
If your IDE isn't good enough to tell you the type of the variable, it's not
good enough to help you rename it when you change the type.
I think the same goes for putting "m" or "g" or whatever in for member or
global variables, etc.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Subject: Re: Hungarian notation
Date: 5 Jun 2010 04:10:18
Message: <4c0a066a$1@news.povray.org>
Epic, epic failure.
Now I remember why I never liked the Hungarian notation - and I only
ready about it!
http://blog.orphi.me.uk/
Date: 5 Jun 2010 04:25:04
Message: <4c0a09da@news.povray.org>
  Why? When I started using those, my own code became much easier to
understand to me months later. When I have code along the lines of:
    void Foo::doSomething()
        mCounter += someValue;
or:
        gCounter += someValue;
as opposed to:
        counter += someValue;
the first two are much clearer than the third one. The third one doesn't
make it clear at all where 'counter' might be defined, while in the first
example it's clear that it's a member variable of the Foo class, and in
the second one it's clear that it's not. In the third one it could be
anything.
Date: 5 Jun 2010 10:06:57
Message: <4C0A5A01.2080701@gmail.com>
> or:
> as opposed to:
> anything.
The objection is not to hungarian notation per se*. It is about using it
wrongly. Like any other method of (in-line) documentation, if it does
not match the source it is worse than no documentation at all.
*) though there is the danger that using it without IDE support to
enforce the correct use, will almost certainly lead to mismatches.
Date: 5 Jun 2010 10:24:53
Message: <4c0a5e34@news.povray.org>
> wrongly.
  That kind of complaint seems kind of moot. Of course if you use any naming
convention wrongly, the code becomes crap. If I do this:
    int multiply(int x, int y)
        return x + y;
then that code is crap, of course. It uses the wrong name for what the
function is doing.
  Why object about wrong usage of hungarian notation in particular?
Date: 5 Jun 2010 10:37:42
Message: <4C0A6136.1070900@gmail.com>
>> wrongly.
>         return x + y;
> function is doing.
Darren seems to have found a nice collection of them that made his life
a bit less enjoyable.
Date: 5 Jun 2010 13:33:01
Message: <4c0a8a4d$1@news.povray.org>
Because, as I said in the first post, the easiest way to maintain the
hungarian notation correctly is to use an IDE sophisticated enough you don't
need hungarian notation to start with.
It's the same reason people prefer "self-documenting code" over "comments".
And the hungarian notation isn't generally useful enough (especially in
something like C) to warrant going thru the code base to fix it by hand when
you change a declaration.
To be fair, this is the first time I've seen this happen so blatently, but
it's an excellent reason to avoid it in the future. :-)
Date: 5 Jun 2010 13:45:47
Message: <4c0a8d4b$1@news.povray.org>
For the same reason. When you move it from being a member variable to a
function argument, or from a private member variable to a protected member
variable or a public member variable, you have to go and find and rename
them. And most of the time, it's visual noise.
I far, far prefer taking the 10 seconds at the start to come up with an
unambiguous name that is clear how global the variable is.
Maybe prefixing something with "g" to mean global (altho "s" to be static
might be better?;-) makes some sense, if your program has maybe two or three
actual globals. But for member variables vs arguments vs locals? No, that's
all right in front of you.
And "mCounter" is a member variable of... what class? I have
GameComponent -> DrawableGameComponent -> Boll -> StackableBoll ->
StackableScreen -> UIScreen -> MenuScreen -> OptionScreen -> PlayOptionScreen.
Where in that chain would something as poorly named as "mCounter" be found? :-)
For that matter, where in that chain would you find the static/global
"NextDrawAction"?  (Hint, if you just think about what those names might be,
(and knowing that "Boll" is my name for what MVC calls "Controller") there's
really only two likely answers.)
Is it? Or is it a member variable of a base class of the Foo class?
Why would I do that, when I can hover the mouse over the name and have it
come up and say "int Bar::Counter instance variable"? Or click "Go to
definition" to change the type?
Anyway, I'm not saying it's necessarily bad. For one thing, C doesn't let
you invent your own scopes (static, global, member,auto, etc) etc, and
people don't encode the visibility (public, protected, etc) in those names,
so the likelihood of having to change from a function argument to a member
variable, or from a global to an auto is very low.
The other problem with the hungarian stuff is that people will typedef
things, so you have code like
     DRM_RESULT result = DO_SOME_DRM_CRAP(pszName, i32Size, ...)
Why does "result" not get a hungarian flag? What flag would you put there?
The whole point of typedeffing DRM_RESULT is to abstract away the type.
As soon as you put hungarian on your variables, you've eliminated the
benefit of typedefs to control the type, which is a far better way of doing it.
Date: 5 Jun 2010 13:55:30
Message: <4c0a8f92$1@news.povray.org>
Oh, also, I'd write this as
   this.counter += someValue;
or
   Foo::Counter += someValue;
if I thought it needed disambiguation at a particular point.
I often see people do
   void SetStuff(int xxx, int yyy, char* zzz)
      mXxx = xxx;
      mYyy = yyy;
      mZzz = zzz;
where I would either do
   this.xxx =xxx;
or I'd give the arguments different names
   void SetStuff(int newXxx, int newYyy)
     xxx = newXxx;
     yyy = newYyy;
I suggested that to someone who was in the habit of putting m_ and g_ and
such on the fronts of variables, and he started naming every argument with
the word "new" on the front.  I don't think he got what I was saying.
The point is to give every variable, even arguments and autos, a name that
indicates their function. Then I almost never need disambiguation.
Date: 6 Jun 2010 15:53:46
Message: <4c0bfcca@news.povray.org>
> don't need hungarian notation to start with.
My IDE uses different colors for global variables and member variables.
No need for m_ or g_ if the colors say enough :)
Date: 6 Jun 2010 16:17:00
Message: <4c0c023c$1@news.povray.org>
Yep. That's what I'm saying. By the time your IDE is smart enough that
changing the scope of a variable isn't a tedious process of hunting down all
the references and changing the name, it's probably already recoloring
things so you can tell without the prefix.  All the prefix is doing is
putting into ASCII the stuff the compiler already knows, and making you
manage it by hand. (Which is true of an awful lot of C coding, come to think
of it. :-)
Date: 7 Jun 2010 10:25:34
Message: <4c0d015e@news.povray.org>
  I have never understood this obsession some people have with "visual
noise". It seems that anything that exist to make a name more unambiguous
is always classified as "useless visual noise".
  Something is "visual noise" when it makes the code *harder* to read
because the "noise" is interfering with your capability of easily
understanding the code.
  Something which in some situations might not convey any additional
information to you is not "visual noise". You might use the word "redundant"
in the sense that it conveys the same information in more than one way (at
least in the context in question), but that's completely different from
"noise", which is something that is disruptive and makes it more difficult
to get the actual information.
  For example, you might have something like this:
    int Point::getX() { return x; }
  If you follow a naming pattern like being discussed here, it might instead
look like:
    int Point::getX() { return mX; }
  That's not "visual noise". It's not any harder to read and understand. You
might call it "redundant" (at least in this specific context, as the function
is so short and straightforward), and that's fine, but it's not "noise".
  You could even have it like this:
    int Point::getX() { return this->mX; }
  Now it's doubly-redundant because the same information (ie. that 'mX' is
a member variable of Point) is basically told three times, but it's still
not "visual noise". It's still pretty clear, readable and easy to understand.
  Where the 'm' prefixes start helping is when you have much more complicated
member functions which refer to local variables, function parameters, global
variables and member variables, especially when the names of the variables
are much less obvious.
  A common naming convention makes it much easier and unambiguous. Readers
don't have to start guessing if it's really a global variable or not.
  There may be dozens of member variables, and the place where the member
variables are declared may be far away from the place where they are used
(they may even be in a completely different file). Seeing right away when
a variable is a member helps understanding such code.
  If it's written as-is, without any reference or qualification, it's rather
obviously a member of 'this' (or whatever your language might call it). If
it has a reference or qualification, then it's obviously a member of that
class. One ought to know which class' member function one is reading and
trying to understand.
  And since member variables are never in the public or protected parts of
classes, there can be no ambiguous usage in a derived class member function.
  (Yes, I know some people put them in the public part of their classes,
and then write derived classes which refer to them directly without any
qualifications. But these are the same people who would use hungarian
notation in the wrong way, etc. Bad code is always bad code.)
> I have
  Which class' member function are you reading? If it's an unqualified use,
it's a member of that class. (If it isn't, then you have breached good OOP
guidelines.)
> "NextDrawAction"?
  Same thing as with member variables.
  If it's a member variable of the base class, then the OO design is crappy.
No member variables in the public (or protected) interface.
  You don't realize that you are actually acknowleding the problem: You
acknowledge that if the name of the variable is so ambiguous, you need a
specialized program to tell you where it might be defined because otherwise
it's very difficult to know. Hence the name is ambiguous, and it's not
possible to easily know what it's referring to unless you do some research
or use some program to find the declaration.
  "I just use an IDE to tell me" is not a solution. It's an acknowledgement
that there is a problem.
Date: 7 Jun 2010 11:11:39
Message: <4c0d0c2b$1@news.povray.org>
Yep, you got it.  I have to mentally edit out the qualifiers as I'm reading
the code to understand what it's trying to do.
I don't have to guess. I read the code.
You're probably doing it wrong if they're in a different file. Or you're
using a language that unnecessarily makes it necessary.
I'm confused. You're telling me a subclass shouldn't refer to a superclass's
members? Why is there even the concept of "protected" if a subclass
shouldn't refer to a superclass?
When you're using properties, that's what you're *supposed* to do. That's
what they're for.
>> I have
> guidelines.)
Nonsense. The menu title is as much a member of the Options screen as it is
a member of a StandardMenuScreen as it is a member of a MenuScreen.  How are
you supposed to set it if there's no accessibility from outside the class?
How does the Options screen set the MenuScreen's title if the Options screen
can't access any members?
What makes you think it's a variable?  I use properties for all that sort of
stuff.  And why are variables in the public or protected interface bad design?
Don't confuse "C++ is easier when I do this" with "Good OOP design in general."
I disagree. It's an acknowledgment that automated maintenance of that
information is more effective than manually maintaining it. It's no more a
problem to use the IDE to do that than it is to declare something "const" in
C++ instead of how you would handle it in C. It's using the tools we have to
reduce the burden on the programmer.
I'm generally against redundancy in programs. Adding things to the code that
the compiler can already provide for me is something that I find has always
been problematic.
If I had no IDE, no syntax coloring, and I was using a language where
figuring out what file something is declared in is a difficult and
time-consuming problem, I'd probably suck it up and start labeling variable
names with information about where I declared them. (Except, of course, in
my work job, they can't even get the type declarations consistent, let alone
something as unenforced as "m" and "g" flags. I'm lucky if I can guess which
processor the code runs on.)
Date: 7 Jun 2010 11:37:05
Message: <4c0d1221@news.povray.org>
  Then I don't understand it. To me the qualifiers make the code easier to
read, not harder. (And no, I'm not talking about hungarian notation here.)
  Even a couple of years from now?
  At least you acknowledge that the member variable declarations may be
very far away from their usage, making it hard to connect the two while
casually browsing the code, because you didn't nitpick about that part.
> members?
  A subclass cannot refer to a superclass' members because it has no access
to them. They are private.
  You put member functions and abstract types there (for the derived class
to use).
  A member variable in the protected section is as bad as in the public one,
hence you don't put member variables in the protected section.
> what they're for.
  If the getter/setter of a member variable has the exact same name as the
member variable (which in itself is a braindead idea IMO), you can still
put a qualification in front of the call.
  Of course a getter/setter should not be named like the member variable
itself. Naming a member function mCounter is not a good idea because that
notation should be reserved for member variables, not member functions.
> >> I have
> > guidelines.)
  Odd question. By calling a member function to set it up, of course.
  You shouldn't even *know* from the outside that the class has such a member
variable. It's private info.
  Because we are talking about the naming convention of member variables.
Member functions are a different story.
  Buy some good book about object-oriented programming sometime.
  I'm not confusing anything. I'm talking about good object-oriented
programming principles.
  It is a problem when you need the IDE in order to understand the program.
  Code readability should not rely on IDEs. It's precisely that reliance
that produces unreadable code which is hard to understand.
  Are you against readability?
> been problematic.
  Having to resort to a compiler or IDE in order to understand a program is
a tell-tale sign that the program could have been written better.
  Take into account that maybe others will have to read your code, and they
might not have that fancy IDE at hand at the moment, yet they may have to
understand your code. Relying on IDEs for readability is a bad idea.
Date: 7 Jun 2010 11:59:07
Message: <4c0d174b@news.povray.org>
OK. I find it's like having misspellings and bad punctuation in prose. It
makes me stumble and have to figure out whether it's part of the name or not.
Even after someone has gone and changed it from a global to a member
variable without updating all the names, yes. :-)
Yep. But with a decent language and/or IDE, it doesn't really matter how far
away the member variables are, or what file or superclass they're in. I
don't feel the need to have a naming convention help me harness the full
power of the language if the compiler already does that.
I fail to see how a superclass with all members private can be useful.
Unless you're using "member" to mean "instance variable" rather than
"instance function" or something.
> to use).
Why?
And what about member properties?
>> what they're for.
It doesn't. But the syntax is that of a variable. Plus, C# has "anonymous
properties", which are properties where the compiler generates a name for
the variable acting as the store of the value, in case you want to have
properties for the future but they really could be variables now.
I.e.,
    x.a = 27;
does not tell you whether "a" is a variable or a function in C#.
What if you use variable syntax for getters and setters, just like C++ lets
you use array subscripting syntax for function calls?
If I have a string that's the title of the menu in a base class, and it's a
property that uses variable syntax, what should I name it and how would I
refer to it in the subclass?
>>>> I have
>>> guidelines.)
I *am* calling a member function to set it up. The member function is
invoked by me saying
    Title = "Game Options";
What should I name that?
I don't even know from *inside* the class that declares it what the member
variable is called.
And what exactly is the difference, theoretically speaking? Syntax?
Implementation? Future-proofing the code?
Is a getter/setter pair syntactically invoked like a variable and whose
underlying storage is inaccessible even to the class declaring the
setter/getter a member variable or a member function?
So you don't know either?
I know nothing in OOP that says exposing member variables that act like
variables is a bad idea. I know it's a bad idea in C++ and a few other
languages, and I know that some other languages (like Eiffel and C#) make it
not a bad idea. The worst that happens is if you change your mind you have
to recompile the code that uses it.
Indeed, having functions unassociated with classes and having global
variables at all is a much worse OOP design than having variables exposed in
the class interface.
But I don't. I can look up whether it's a global or not just fine without an
IDE. I don't feel the need to encode that into the names, is all.
I agree. However, I'm not depending on the IDE to make the code readable.
You're begging the question.
>> been problematic.
Having to resort to a naming convention to tell the reader what you already
told the reader is a tell-tale sign that the program could have been written
better too.
Especially if you're going to assert that "mCounter" is always a member
variable of *this* class.
I'm not relying on the IDE for readability. I'm having the IDE assist me in
easily finding the declaration of the variables I'm using. Whether it's a
member variable or a global variable is of much less interest than the type
of the variable, and I don't encode that into the name either.
Since 99.5% of all my variables are either auto declared where used,
function arguments on the same screen as the code I'm reading, or member
variables, putting "m" before every variable that isn't declared on the same
screen as I use it is visual noise to me. I have an entire video game with a
total of one count-em one global variable, and the purpose of that variable
is to pass information between methods invoked off a linked list of
instances about what the previous instance (whichever got selected) wants
the next instance to do.
Date: 7 Jun 2010 12:03:23
Message: <4c0d184b$1@news.povray.org>
I find this (to steal the example from the other group):
std::vector< std::string > v1 = someFunction();
std::vector< std::string > v2;
std::transform( v1.begin(), v1.end, v2.begin(), std::bind1st(
std::not_equal_to<
std::string >( "" ) ) );
for( std::vector< std::string >::iterator i = v2.begin(); i != v2.end();
++i )
    std::cout << *i << std::endl;
much harder to read than this:
vector< string > v1 = someFunction();
vector< string > v2;
transform( v1.begin(), v1.end, v2.begin(), bind1st( not_equal_to<string >(
for( vector< string >::iterator i = v2.begin(); i != v2.end(); ++i )
   cout << *i << endl;
And IMO I definitely count all those repeated "std::" as noise in the code
that does very little to enhance my understanding but severely slows down
the speed I can read and type it.
Sure if you want very formal code with no chance of ambiguity the 1st is
better, but the longer lines and extra typing put me off.
Date: 7 Jun 2010 13:37:03
Message: <4c0d2e3f@news.povray.org>
  You magically know from the name of the variable that someone changed its
scope?
  As I said, you are just acknowleding that there *is* a problem in the
naming which has to be solved by using an IDE.
  This whole thread has been about variables. Nobody has talked about
functions.
> > to use).
> Why?
  Because from the point of view of the derived class the member variable
is public, and thus with all the drawbacks.
  Getter and setter functions are a separate issue. We are not talking
about member functions here. (Or at least I am not.)
> >> what they're for.
  If you want to use confusing syntax, that's up to you. ("Not only do not
I know if this is a local, global or member variable, I don't even know if
this is actually a property of this class or any of its base classes." Way
to add even more confusion.)
> I.e.,
>     x.a = 27;
  Since classes don't have public member variables, it is a function (even
if the syntax is confusing). Haven't you learned already?
  Getters and setters are member functions, not member variables, and hence
other naming conventions apply to them.
  You use getter and setter functions, which are named with the proper naming
convention for member functions.
  Well, if you deliberately want to make it ambiguous and confusing, that's
up to you. But remember that others may need to read and understand your
code. That "Title" doesn't make it at all obvious what it might be and
where it might be declared.
  Abstraction. A member variable is part of the internal implementation of
the class, while a public member function is part of its abstract public
interface which should usually reveal as little as possible about the
internal implementation details of the class.
  I'd call it confusing.
  Then maybe you should learn more about object-oriented programming
principles, then?
  If you expose a member variable, you are exposing an internal
implementation detail and thus making your class less abstract, making
it harder to modify later. Internal implementation details should be
hidden as well as possible so that changing these details becomes easier
without breaking the rest of the program.
  It's not a compiler-technical issue. It's an issue of program design.
It has nothing to do with a specific programming language.
  Well, usually you shouldn't have global variables in a well-designed
program. As for not having free functions, I don't quite get it. What's
wrong with having some convenience functions?
  That's the problem: You have to "look it up". The name itself tells you
nothing. You have to study the rest of the code in order to understand what
the function is doing, and the name of the variable is giving you no hints
on where you might start looking.
  However, if you see from the name that it's eg. a member variable, then
there aren't many places you have to look for it.
  This becomes especially useful when there are dozens of different variables
being referred to in a function.
  Seemingly you are, given how much you advocate using an IDE to look up
variable definitions.
  I'm not. You are against redundancy. Are you also against redundancy when
it makes the code more readable?
> >> been problematic.
> better too.
  Haha.
  If it isn't, then your program is badly designed and hard to understand.
  You are making contradictory statements. In one place you say that you
don't need any special naming conventions because you just use the IDE to
tell you where variables are defined, and here you are telling that you are
actually *not* using the IDE for readability.
  The type of the variable doesn't help you find its declaration. A naming
convention telling you where to look does.
Date: 7 Jun 2010 13:42:54
Message: <4c0d2f9e@news.povray.org>
> std::not_equal_to<
> ++i )
  Of course it doesn't help that the indentation sucks.
>    cout << *i << endl;
  Well, I find the first example easier to read (after proper indentation)
because I see much faster with a quick scan which names are from the
standard C++ library and which are local variables or reserved keywords.
  You might as well argue that all the ';' symbols are "noise in the code"
which add nothing and make it more difficult to read and write (after all,
the example would be completely unambiguous and parseable without them).
  Of course to others the ';' symbols actually make the code easier to
read because they are a visual clue to quickly see where a statement ends
and the next begins.
  I have never, and will never understand some people's infatuation with
brevity.
  In programming brevity is not a virtue. If you want brevity, check the
IOCCC.
Date: 7 Jun 2010 14:34:45
Message: <4c0d3bc5@news.povray.org>
> scope?
No. I'm saying if you name the variable "gCounter" everywhere, and then
decide you really need to be able to have more than one instance, then you
better rename it to mCounter everywhere you use it, or you've made it even
*harder* to understand than if you hadn't flagged it at all.
Basically, your prefixes are comments, and wrong comments can be worse than
no comments.
Now, I already granted that such doesn't happen very often, but that's the
point I'm making here.  Let it go long enough with sufficiently careless
programmers, and you'll have this problem. Using an IDE will prevent that
problem.
No. I'm acknowledging that if your class is so complex that you can't easily
figure out where the variable is declared, chances are good that a naming
convention isn't going to help all that much.
Or, to put it another way, I've tried it. It didn't do anything for me.  It
didn't help my understanding, even when reading code written by the guy who
did things that way.  That doesn't mean it's right or wrong. It just means
that asserting it's always appropriate is probably incorrect.  If I can't
figure out that a variable is a member variable from its name without the
flag, chances are I'm picking a crappy name for that member variable.
Something like "mCounter" for example.
For example, "CounterOfInstancesCreated" is obviously going to most likely
be a class-level static variable. "CounterOfMenuEntries" is probably an
instance variable in the class "Menu". It probably sizes the array
"MenuEntries" in the class Menu. "CounterOfEntriesUpdatedSoFar" is probably
a local variable. "CounterOfEntriesToRemove" is probably a function argument.
> functions.
Well, *I* was. I can't help you started putting arbitrary limitations on how
you use your language without telling me. :-)
Now, if you wanted to argue that you put "m" in front of private local
variables to distinguish them from properties, you might have a point there.
But then that defeats the purpose of using properties.
>> Why?
You haven't told me what the drawbacks are. I suspect the drawbacks are
specific to languages where function calls don't look like variable
accesses. If your getters and setters look like variable assignments, why
would it be problematic to have actual variables in the public interface?
OK. Since pretty much all my non-private variables are accessed via
getter/setter functions (i.e., properties), then I don't see a problem here.
Well, (A) it's part of the language, so it's not really confusing syntax,
and (B) it's hiding whether it's a variable or a function for exactly the
same reason you're making private variables private.
>> I.e.,
>>     x.a = 27;
Um, sorry. "Warp's C++ programming style" doesn't define C# syntax, I fear.
OK.
Huh. And the proper naming convention for that in C# is to make it look like
a member variable. Funny that.
There's nothing in front of it (like this. or something) so it's a property
or variable declared in this class or a superclass thereof. It's really not
confusing or ambiguous.
Well, there ya go then. If I declare a property, then it's a function that
syntactically looks like a variable. It reveals very little about the
implementation, in that there need not be a backing variable at all.
Plus, if I make it a variable, technically I can replace *that* with a
function call in the future, with a simple recompile of the users of that
code, because the syntax is the same.
A property says "if you can set this and get this, then what gets returned
from the 'get' is almost certainly what you assigned with the 'set'."
It's only confusing if you don't know the language, and no more confusing
than having to find which implementation of a virtual function a given call
site invokes.
That's because you're not used to it. It's basically a way of defining a
getter/setter pair that makes it clear it's a getter/setter to the caller.
No I'm not. Part of the API for a menu screen is the title of the menu and
the color it's drawn in. That's not an implementation detail.
But you said right there it is, you see. If the syntax for assigning to or
from a variable is the same as the syntax for calling a getter or setter,
then you can trivially change from using a variable to using functions in
the future.
It would be like me arguing that C++ functors should have a different syntax
than functions for invocation, because otherwise it's confusing. No, that's
the *point* - if the user has to know whether it's a property or a variable,
*then* your design is bad.
I didn't say there's something wrong. I said it's not OOD.
> nothing.
I have to look up whether it's an int or a float, too. I don't encode that
into the variable name either. Certainly if you're arguing that "mCounter"
is good style, then surely "m_pszTitle" is good style.
I would argue that *this* is the problem. :-)
It's also a problem that properties eliminate for getter/setter code: You
know from the fact it's a property what it's doing. Indeed, the whole reason
C# has properties is to eliminate the whole problem of "this used to be a
variable and now I have to do something to calculate it instead" or vice versa.
There's already not a lot of places I have to look for it. If I stick with
only having variables be private, I have to look in the function arguments,
the local declarations, and the member variables of the class I'm in. The
function arguments and local declarations are right next to the code using
the variable.
I'd also argue that's a problem with your design, unless you're actually
doing something sufficiently complicated that you're going to have to look
up the types of the variables too. If I'm manipulating dozens of member
variables in a function, it's likely either a list of relatively independent
statements (like initializing dozens of parameters to their defaults) or a
function I should be refactoring.
So when you see mCounter in your code, how do you know what type it is?
I don't rely on the IDE to look things up. But since it's there, I use it.
No, but you're assuming that your form of redundancy makes the code more
readable simply by asking the question. (I can't see any reason why you
would ask such a question except to imply that the redundancy you advocate
makes code more readable, which is exactly what we're discussing. However, I
may be misreading why you asked such a question. But I think not, given that
no reasonable programmer would be against readability, making it either a
rhetorical question or an insult.)
>> better too.
>   Haha.
Well, we're talking about somewhat different things here, then.
I don't *need* the IDE to look up variables, and I don't *rely* on the IDE
for readability. Of course, ASCII code without an IDE is less readable than
with an IDE. That doesn't mean *your* solution to not using an IDE is the
best one, or even necessary.
But if all member variables are private, I don't need a naming convention to
tell me where to look. If it's not a function argument or a local variable,
it's a member variable.
Date: 7 Jun 2010 15:30:02
Message: <4c0d48ba@news.povray.org>
  On the contrary. The more complex the class is, the more helpful naming
conventions are. It's the exact opposite of what you are saying.
  Naming conventions of variables are not so much necessary with very small
and simple classes, as there is less code to read and understand, and
functions tend to be much shorter. OTOH, if you have used a certain naming
convention in your more complex classes, it's a good idea to use the
convention everywhere for consistency and to avoid confusion ("why is
this naming convention used here but not there?")
  Citing a few very specific examples where it's easier to *guess* where
something is defined doesn't mean that it's *always* so easy to make that
guess, no matter how well you try to name your variables.
  The best situation is when you don't have to guess at all.
> >> Why?
  Because it's an extensive subject. I have told you how to get more
information on that subject: Get a good book.
  It's related to modularity and abstraction.
  Many object-oriented developers frown upon abusing getters and setters
(even if the language helps you creating them automatically) because they
are only slightly better than direct public member variables.
  It's a problem of design: If you have too many getters/setters in the
public interface, you are exposing too much of the internal implementations
of the class, and hence your class' public interface is not abstract enough.
  Just because the programming language might make it easier to create such
getter/setter pairs doesn't mean it's a good idea to abuse the feature.
  It being part of the language doesn't make it any less confusing. It's
confusing if it's hard to tell from a name where it might be defined. If
it looks like a variable but isn't, then it can be even *more* confusing.
  The property syntax may be a handy convenience shortcut, but just because
it exists doesn't mean it cannot be abused and obfuscated code cannot be
created with it.
  But does it help readability? Less typing doesn't always equate with
better readability.
> >> I.e.,
> >>     x.a = 27;
  You didn't understand what I was saying.
  You *don't* have public member variables, period. Hence if you are doing
"x.a" from the outside, that 'a' is *not* a public member variable, period.
Hence the only thing it can be is a public member function.
  You have some kind of obsession that I'm always talking about C++. Forget
about C++. I'm talking about object-oriented programming.
  Are you telling me it's *impossible* to make getter/setter functions in C#
which actually look like functions? They have gone the extra mile to actually
forbid that?
  As I said, if you really want to make your code more confusing, it's your
prerogative.
  It could be a local variable. Or a function parameter. Or variable in the
file scope. Or a global variable.
  But makes it unclear where it might have been declared if you call it
without qualifications.
  I have never talked about any C# property syntax being confusing, even
tough you seem to think I have. I have been talking about variable naming
being confusing, and how deliberately abusing properties can make them
even *more* confusing than they already were.
> site invokes.
  "Having to find out which function is being really called in this
inheritance hierarchy can sometimes be confusing, hence it doesn't matter
if finding out variable declarations is equally confusing" is not really a
good argument.
  You still can't get your head around the fact that I'm not talking about
the syntax, but about variable naming conventions.
  Exactly which part of OOD forbids free functions, and most importantly, why?
> > nothing.
  And the naming can help you finding out where to look, making that task
easier. So?
> I don't encode that
  Is it "all or nothing" to you? Either you have to put *everything* related
to the variable in its name, or you shouldn't put anything at all?
  That would be a false dichotomy.
  You can't always avoid it. If a single character in the variable name makes
the task easier when you want to do it, so much the better.
  Besides, it's not always about just finding the declaration. It's more
often about simply understanding the code. When you see that a member
variable is being used you don't necessarily have to look at its declaration;
it may still be easier to understand than if the name didn't make it clear
if what is being used is a member variable or something else. When many
variables from different sources are being heavily used in a short piece
of code, it helps understanding what is being done to what when you
directly see what is a member variable and what is something else.
Date: 7 Jun 2010 16:27:39
Message: <4c0d563b$1@news.povray.org>
I'm saying that if your class is too complicated, you should simplify it,
not add comments everywhere you refer to a variable to remind you its purpose.
Agreed.
Agreed.
Also agreed. But I think using a prefix on a variable that's essentially a
comment telling you where to look for the definition everywhere you read or
write the name of a variable is not the best solution.
I've read a number of books on the subject. The best advice is to use a
language where the distinction is not a problem. The problem of having
publicly available variables is caused by the language, not by the model. If
the API has a value that acts like a variable, there's really not a
conceptual problem with modeling it by a variable.
No, it really isn't. The only reason to do this is if the syntax for getters
and setters differs from the syntax for variables. In that case, you want to
use the same syntax everywhere, to avoid changing the callers if you decide
it has to change from being a variable to a setter function.
abc = Menu.GetTitle()
isn't really any more abstract than
abc = Menu.Title
Nor is
Menu.Title = "Hello World"
any less abstract than
Menu.SetTitle("Hello World")
Some things really are that simple.
I disagree. If you have a menu-drawing class, and you want to know the font
for the title, the color of the title, the string for the title, the font
and color for the entries when unselected, when selected, whether the
entries are aligned or not, etc etc etc, then there's no good reason not to
use something that looks like a public variable.
It's not abuse. It's what they're for.
But because setters and getters are part of the language, it *doesn't* look
like a variable, any more than
   my_vector[3]
looks like an array reference in C++
> created with it.
Well, sure. And if you're writing code that clearly does something more than
set or get, then you shouldn't use a property. We know that already.
E.g., when adding an entry to the menu, it would be bad style to use a
setter where "assigning" to the setter adds the text to the end of the list
or whatever. The point of a property is that to outside classes it behaves
like a variable.
> better readability.
Yes. It helps readability, modularity, and abstraction.
>>>> I.e.,
>>>>     x.a = 27;
Who doesn't have public member variables?
I understand what you're saying.  I said "in C#."  You seem to be ignoring
that, somehow implying that your personal style (don't have public member
variables) is somehow enforced by C#. I'm saying "the language supports this
with this syntax."  You're somehow implying "No, it doesn't, because it's
bad style to take advantage of it" or something?
You're talking about what *you* think is good style for OO programming,
which varies with different languages implementing OO programming. I'm
disagreeing that your style guidelines apply to OO languages with different
syntax and semantics.
> forbid that?
No. I'm saying that you're trying to impose your style on the definition of
C# for some reason. I'm saying that if you know C#, there's no confusion
about properties or variables.
If you want to follow a style guideline that says "all member variables are
private", then
   xyz.abc = 27;
immediately tells you abc is a property setter, so there's no confusion.
If you don't want to follow the convention that all member variables are
private, then you can take advantage of that ambiguity to make your code
more clear just like an OO program takes advantage of dynamic dispatch to
make the code more clear.
Actually, C# is pretty much the most readable and maintainable language in
that whole category that I've found. The details of the syntax and the rules
and restrictions make it 99.5% of the time trivial to see what's going on.
No such thing as "file scope" in C#, because it's OO. No such thing as
"global variable" in C#, because it's OO.
(Note that .NET does support those things, including stuff like FORTRAN
/DATA/ blocks as well, but C# doesn't do that per se.)
Only to the extent that it's OO and thus inherited. I.e.,
    xyz.abc = "Hello";
isn't any more unclear than
    xyz->setAbc("Hello");
is in C++.
I'm not sure what "abuse" of properties you're talking about. Nobody is
talking about "abusing" properties. The title of a menu, or the color the
selected entry is drawn in, is a property of the menu. That's why
"properties" have that name.
You indeed seemed to be calling the ambiguity between assigning to a
property setter and assigning to a public variable to be confusing. Maybe I
misunderstood. If it's not confusing, then I'm not sure what the problem is.
See two paragraphs down, where you say "I'd call it confusing" while talking
about C# property syntax.
>> site invokes.
> good argument.
The solution to one is the solution to the other. Why only half-solve the
problem?
^^^^  What's this? ^^^^  :-)
I understand. I have my head around it. I'm talking about, however,
functions that look syntactically like variables, and I'm asking you whether
you think they should be named like variables or not. You seem to say "no",
at which point my opinion is reinforced that I don't need a naming
convention for local private variables.
What class are they a member of? What instance is the distinguished
instance.  They're functions unassociated with objects.  In a *very* OO
class-based language, such functions aren't even possible.
(Yes, you can have OO languages like CLOS and such where member methods
aren't associated with classes per se. Neither of us are talking about that.)
> easier. So?
It's not worth the effort of maintaining it, for me.
>> I don't encode that
No. I'm trying to figure out what your goal is. Telling you where to look up
the type information makes more sense than encoding it in the variable. But
to me, knowing it's either essentially on the same screen I'm looking at or
it's an instance variable of the class I'm referencing seems sufficient to
me. I don't really get confused when I'm reading code between what's a local
variable and what's a function argument, so I'm not sure why I'd be confused
between either of those and a member variable.
I'll disagree. Sure, *if* it does, then it's helpful. In my experience,
however, it doesn't.
But under your rules (no public member variables in superclasses), I'd still
know it was an instance variable, because it's unqualified but not declared
in the function I'm looking at.
Now, granted, the code at work has 14,000-line-long functions implementing
an entire application in main(). But I'd argue that adding flags to variable
names isn't the right cure to the problem of a function not fitting on a
screen or two.
Basically, you're asserting it's helpful in your experience. I'm asserting
that in my experience it isn't. Absent anything scientific or even reasoned
beyond "it tells you to look for the declaration outside the function", it
doesn't look like you'll convince me. :-)
Date: 7 Jun 2010 16:37:05
Message: <4c0d5871@news.povray.org>
> of C# for some reason. I'm saying that if you know C#, there's no
> confusion about properties or variables.
BTW, C# already has naming conventions that covers much of what you're
talking about, established by MS and used throughout the libraries. They're
also much more extensive than simply how you capitalize variables you can
trivially look up with the IDE. It makes it possible for me to know exactly
the arguments to xyz.OnChange, xyz.OnChanging, and xyz.OnChanged, knowing
nothing more than the conjucation of the verb there, for example. I also
know how to start in the background any process I want to run that way, how
to get the result back, what the functions will be called, etc.
I find it much more helpful to be able to look at a function call and say
"Oh, that launches a thread that runs X, and when it finishes it'll invoke
my Y function with two arguments that are .....".
The style guides are dozens of pages long, letting you read code written to
that guideline and actually know useful information about it rather than
just where to look up useful information.
I'm not against naming conventions, and I do think they improve readability.
I just don't agree that "mCounter" vs "gCounter" is an example of that.
Date: 8 Jun 2010 03:25:43
Message: <4c0df077$1@news.povray.org>
Sure, I know that already, but not everyone else shares your view.
There are several differences with ";".  It's only one character long,
usually only appears 0 or 1 times on a line, and *often* gives you useful
information.  On the contrary, "std::" is 5 characters long, often appears
many times on one line, and very *rarely* helps to actually disambiguate any
code.
> brevity.
As I said before, it makes the code easier and faster *for me* to read, and
saves *me* time.  I understand how you feel and how you prefer the extra
verbosity, but it's pretty shortsighted to say you don't understand other
views when it's been explained to you 100 times.
